hmc7044 phase noise degradation
Product Number: HMC7044
Dear Sir,
We have fabricated the board as per our requirement and datasheet. Accurate frequency not generated as per configuration. Attached is the register file and schematic which we have implemented for your reference.    i think you maybe able to guide properly since we already had discussion on phase noise improvement of ADL4356, this we are using exclusively for phase noise improvement of ADL4356.PDF
# glbl_cfg1_swrst[0:0] = 0x0
dut.write(0x0, 0x0)
# glbl_cfg1_sleep[0:0] = 0x0
# glbl_cfg1_restart[1:1] = 0x0
# sysr_cfg1_pulsor_req[2:2] = 0x0
# pll1_cfg1_forceholdover[4:4] = 0x0
# glbl_cfg1_perf_pllvco[5:5] = 0x0
# dist_cfg1_perf_floor[6:6] = 0x1
# sysr_cfg1_reseed_req[7:7] = 0x0
dut.write(0x1, 0x40)
# sysr_cfg1_rev[0:0] = 0x0
# sysr_cfg1_slipN_req[1:1] = 0x0
# pll2_cfg1_autotune_trig[2:2] = 0x0
dut.write(0x2, 0x0)
# glbl_cfg1_ena_pll1[0:0] = 0x1
# glbl_cfg1_ena_pll2[1:1] = 0x1
# glbl_cfg1_ena_sysr[2:2] = 0x1
# glbl_cfg2_ena_vcos[4:3] = 0x2
# glbl_cfg1_ena_sysri[5:5] = 0x1
dut.write(0x3, 0x37)
# glbl_cfg7_ena_clkgr[6:0] = 0x7F
dut.write(0x4, 0x7F)
# glbl_cfg4_ena_rpath[3:0] = 0x3
# dist_cfg1_refbuf0_as_rfsync[4:4] = 0x0
# dist_cfg1_refbuf1_as_extvco[5:5] = 0x0
# pll2_cfg2_syncpin_modesel[7:6] = 0x1
dut.write(0x5, 0x43)
# glbl_cfg1_clear_alarms[0:0] = 0x0
dut.write(0x6, 0x0)
# glbl_reserved[0:0] = 0x0
dut.write(0x7, 0x0)
# glbl_cfg1_dis_pll2_syncatlock[0:0] = 0x1
dut.write(0x9, 0x1)
# glbl_cfg5_ibuf0_en[0:0] = 0x1
# glbl_cfg5_ibuf0_mode[4:1] = 0xE
dut.write(0xA, 0x1D)
# glbl_cfg5_ibuf1_en[0:0] = 0x1
# glbl_cfg5_ibuf1_mode[4:1] = 0xA
dut.write(0xB, 0x15)
# glbl_cfg5_ibuf2_en[0:0] = 0x1
# glbl_cfg5_ibuf2_mode[4:1] = 0xA
dut.write(0xC, 0x15)
# glbl_cfg5_ibuf3_en[0:0] = 0x1
# glbl_cfg5_ibuf3_mode[4:1] = 0xA
dut.write(0xD, 0x15)
# glbl_cfg5_ibufv_en[0:0] = 0x1
# glbl_cfg5_ibufv_mode[4:1] = 0xA
dut.write(0xE, 0x15)
# pll1_cfg2_rprior1[1:0] = 0x1
# pll1_cfg2_rprior2[3:2] = 0x1
# pll1_cfg2_rprior3[5:4] = 0x2
# pll1_cfg2_rprior4[7:6] = 0x3
dut.write(0x14, 0xE5)
# pll1_cfg3_los_valtime_sel[2:0] = 0x3
dut.write(0x15, 0x3)
# pll1_cfg2_holdover_exitcrit[1:0] = 0x0
# pll1_cfg2_holdover_exitactn[3:2] = 0x3
dut.write(0x16, 0xC)
# pll1_cfg7_hodac_offsetval[6:0] = 0x0
dut.write(0x17, 0x0)
# pll1_cfg2_hoadc_bw_reduction[1:0] = 0x0
# pll1_cfg1_hodac_force_quickmode[2:2] = 0x0
# pll1_cfg1_hodac_dis_avg_track[3:3] = 0x0
dut.write(0x18, 0x0)
# pll1_cfg1_los_uses_vcxodiv[0:0] = 0x0
# pll1_cfg1_los_bypass_lcmdiv[1:1] = 0x0
dut.write(0x19, 0x0)
# pll1_cfg4_cpi[3:0] = 0x0
dut.write(0x1A, 0x0)
# pll1_cfg1_pfd_invert[0:0] = 0x0
# pll1_cfg1_cppulldn[1:1] = 0x0
# pll1_cfg1_cppullup[2:2] = 0x0
# pll1_cfg1_cpendn[3:3] = 0x1
# pll1_cfg1_cpenup[4:4] = 0x1
dut.write(0x1B, 0x18)
# pll1_cfg8_los_div_setpt_r0[7:0] = 0x1
dut.write(0x1C, 0x1)
# pll1_cfg8_los_div_setpt_r1[7:0] = 0x1
dut.write(0x1D, 0x1)
# pll1_cfg8_los_div_setpt_r2[7:0] = 0x1
dut.write(0x1E, 0x1)
# pll1_cfg8_los_div_setpt_r3[7:0] = 0x1
dut.write(0x1F, 0x1)
# pll1_cfg8_los_div_setpt_vcxo[7:0] = 0xA
dut.write(0x20, 0xA)
# pll1_cfg16_refdivrat_lsb[7:0] = 0x2
dut.write(0x21, 0x2)
# pll1_cfg16_refdivrat_msb[7:0] = 0x0
dut.write(0x22, 0x0)
# pll1_cfg16_fbdivrat_lsb[7:0] = 0x14
dut.write(0x26, 0x14)
# pll1_cfg16_fbdivrat_msb[7:0] = 0x0
dut.write(0x27, 0x0)
# pll1_cfg5_lkdtimersetpt[4:0] = 0x15
# pll1_cfg1_use_slip_for_lkdrst[5:5] = 0x0
dut.write(0x28, 0x15)
# pll1_cfg1_automode[0:0] = 0x1
# pll1_cfg1_autorevertive[1:1] = 0x0
# pll1_cfg1_holdover_uses_dac[2:2] = 0x1
# pll1_cfg2_manclksel[4:3] = 0x0
# pll1_cfg1_byp_debouncer[5:5] = 0x0
dut.write(0x29, 0x5)
# pll1_hoff_timer_setpoint[7:0] = 0x0
dut.write(0x2A, 0x0)
# pll2_reserved[7:0] = 0x1
dut.write(0x31, 0x1)
# pll2_cfg1_rpath_x2_bypass[0:0] = 0x1
dut.write(0x32, 0x1)
# pll2_rdiv_cfg12_divratio_lsb[7:0] = 0x1
dut.write(0x33, 0x1)
# pll2_rdiv_cfg12_divratio_msb[3:0] = 0x0
dut.write(0x34, 0x0)
# pll2_vdiv_cfg16_divratio_lsb[7:0] = 0x1B
dut.write(0x35, 0x1B)
# pll2_vdiv_cfg16_divratio_msb[7:0] = 0x0
dut.write(0x36, 0x0)
# pll2_cfg4_cp_gain[3:0] = 0x0
dut.write(0x37, 0x0)
# pll2_pfd_cfg1_invert[0:0] = 0x0
# pll2_pfd_cfg1_force_dn[1:1] = 0x0
# pll2_pfd_cfg1_force_up[2:2] = 0x0
# pll2_pfd_cfg1_dn_en[3:3] = 0x1
# pll2_pfd_cfg1_up_en[4:4] = 0x1
dut.write(0x38, 0x18)
# pll2_cfg1_oscout_path_en[0:0] = 0x0
# pll2_cfg2_oscout_divratio[2:1] = 0x0
dut.write(0x39, 0x0)
# pll2_cfg1_obuf0_drvr_en[0:0] = 0x0
# pll2_cfg5_obuf0_drvr_res[2:1] = 0x0
# pll2_cfg5_obuf0_drvr_mode[5:4] = 0x0
dut.write(0x3A, 0x0)
# pll2_cfg1_obuf1_drvr_en[0:0] = 0x0
# pll2_cfg5_obuf1_drvr_res[2:1] = 0x0
# pll2_cfg5_obuf1_drvr_mode[5:4] = 0x0
dut.write(0x3B, 0x0)
# glbl_cfg5_gpi1_en[0:0] = 0x0
# glbl_cfg5_gpi1_sel[4:1] = 0x0
dut.write(0x46, 0x0)
# glbl_cfg5_gpi2_en[0:0] = 0x0
# glbl_cfg5_gpi2_sel[4:1] = 0x0
dut.write(0x47, 0x0)
# glbl_cfg5_gpi3_en[0:0] = 0x0
# glbl_cfg5_gpi3_sel[4:1] = 0x0
dut.write(0x48, 0x0)
# glbl_cfg5_gpi4_en[0:0] = 0x1
# glbl_cfg5_gpi4_sel[4:1] = 0x8
dut.write(0x49, 0x11)
# glbl_cfg8_gpo1_en[0:0] = 0x0
# glbl_cfg8_gpo1_mode[1:1] = 0x0
# glbl_cfg8_gpo1_sel[7:2] = 0x0
dut.write(0x50, 0x0)
# glbl_cfg8_gpo2_en[0:0] = 0x0
# glbl_cfg8_gpo2_mode[1:1] = 0x0
# glbl_cfg8_gpo2_sel[7:2] = 0x0
dut.write(0x51, 0x0)
# glbl_cfg8_gpo3_en[0:0] = 0x0
# glbl_cfg8_gpo3_mode[1:1] = 0x0
# glbl_cfg8_gpo3_sel[7:2] = 0x0
dut.write(0x52, 0x0)
# glbl_cfg8_gpo4_en[0:0] = 0x0
# glbl_cfg8_gpo4_mode[1:1] = 0x0
# glbl_cfg8_gpo4_sel[7:2] = 0x0
dut.write(0x53, 0x0)
# glbl_cfg2_sdio_en[0:0] = 0x1
# glbl_cfg2_sdio_mode[1:1] = 0x1
dut.write(0x54, 0x3)
# sysr_cfg3_pulsor_mode[2:0] = 0x0
dut.write(0x5A, 0x0)
# sysr_cfg1_synci_invpol[0:0] = 0x0
# sysr_cfg1_pll2_carryup_sel[1:1] = 0x1
# sysr_cfg1_ext_sync_retimemode[2:2] = 0x1
dut.write(0x5B, 0x6)
# sysr_cfg16_divrat_lsb[7:0] = 0x0
dut.write(0x5C, 0x0)
# sysr_cfg16_divrat_msb[3:0] = 0x0
dut.write(0x5D, 0x0)
# dist_cfg1_extvco_islowfreq_sel[0:0] = 0x0
# dist_cfg1_extvco_div2_sel[1:1] = 0x0
dut.write(0x64, 0x0)
# clkgrpx_cfg1_alg_dly_lowpwr_sel[0:0] = 0x0
dut.write(0x65, 0x0)
# alrm_cfg4_pll1_los4_allow[3:0] = 0x0
# alrm_cfg1_pll1_hold_allow[4:4] = 0x0
# alrm_cfg1_pll1_lock_allow[5:5] = 0x0
# alrm_cfg1_pll1_acq_allow[6:6] = 0x0
# alrm_cfg1_pll1_nearlock_allow[7:7] = 0x0
dut.write(0x70, 0x0)
# alrm_cfg1_pll2_lock_allow[0:0] = 0x0
# alrm_cfg1_sysr_unsyncd_allow[1:1] = 0x0
# alrm_cfg1_clkgrpx_validph_allow[2:2] = 0x0
# alrm_cfg1_plls_both_locked_allow[3:3] = 0x0
# alrm_cfg1_sync_req_allow[4:4] = 0x1
dut.write(0x71, 0x10)
# glbl_ro8_chipid_lob[7:0] = 0x1
dut.write(0x78, 0x1)
# glbl_ro8_chipid_mid[7:0] = 0x52
dut.write(0x79, 0x52)
# glbl_ro8_chipid_hib[7:0] = 0x4
dut.write(0x7A, 0x4)
# alrm_ro1_alarm_masked_viaspi[0:0] = 0x0
dut.write(0x7B, 0x0)
# alrm_ro4_pll1_los4_now[3:0] = 0x0
# alrm_ro1_pll1_hold_now[4:4] = 0x0
# alrm_ro1_pll1_lock_now[5:5] = 0x1
# alrm_ro1_pll1_acq_now[6:6] = 0x0
# alrm_ro1_pll1_nearlock_now[7:7] = 0x1
dut.write(0x7C, 0xA0)
# alrm_ro1_pll2_lock_now[0:0] = 0x0
# alrm_ro1_sysr_unsyncd_now[1:1] = 0x1
# alrm_ro1_clkgrpx_validph_now[2:2] = 0x0
# alrm_ro1_plls_both_locked_now[3:3] = 0x0
# alrm_ro1_sync_req_now[4:4] = 0x0
dut.write(0x7D, 0x2)
# alrm_ro4_pll1_los4_latch[3:0] = 0x0
# alrm_ro1_pll1_hold_latch[4:4] = 0x0
# alrm_ro1_pll1_acq_latch[5:5] = 0x1
# alrm_ro1_pll2_acq_latch[6:6] = 0x1
dut.write(0x7E, 0x60)
# pll1_ro3_fsm_state[2:0] = 0x2
# pll1_ro2_selected_clkidx[4:3] = 0x1
# pll1_ro2_bestclk[6:5] = 0x1
dut.write(0x82, 0x2A)
# pll1_ro7_dac_avg[6:0] = 0x42
dut.write(0x83, 0x42)
# pll1_ro7_dac_current[6:0] = 0x41
# pll1_ro1_dac_compare[7:7] = 0x0
dut.write(0x84, 0x41)
# pll1_ro1_adc_outofrange[0:0] = 0x0
# pll1_ro1_adc_moving_quick[1:1] = 0x0
# pll1_ro1_lookslikelos_vcxo[2:2] = 0x0
# pll1_ro1_los_active_ref[3:3] = 0x0
dut.write(0x85, 0x0)
# pll1_ro5_eng_fullstate[4:3] = 0x0
dut.write(0x86, 0x0)
# pll2_ro8_tunestatus[7:0] = 0xFF
dut.write(0x8C, 0xFF)
# pll2_ro8_vtune_error_lsb[7:0] = 0x7
dut.write(0x8D, 0x7)
# pll2_ro8_vtune_error_msb[5:0] = 0x0
# pll2_ro8_vtune_error_sign[6:6] = 0x0
# pll2_ro8_vtune_status[7:7] = 0x0
dut.write(0x8E, 0x0)
# pll2_ro4_syncfsm_state[3:0] = 0x0
# pll2_ro4_atunefsm_state[7:4] = 0x0
dut.write(0x8F, 0x0)
# sysr_ro4_fsmstate[3:0] = 0xA
# grpx_ro1_outdivfsm_busy[4:4] = 0x0
dut.write(0x91, 0xA)
# reg_96[7:0] = 0x0
dut.write(0x96, 0x0)
# reg_97[7:0] = 0x0
dut.write(0x97, 0x0)
# reg_98[7:0] = 0x0
dut.write(0x98, 0x0)
# reg_99[7:0] = 0x0
dut.write(0x99, 0x0)
# reg_9A[7:0] = 0xFF
dut.write(0x9A, 0xFF)
# reg_9B[7:0] = 0x0
dut.write(0x9B, 0x0)
# reg_9C[7:0] = 0xAA
dut.write(0x9C, 0xAA)
# reg_9D[7:0] = 0xAA
dut.write(0x9D, 0xAA)
# reg_9E[7:0] = 0xAA
dut.write(0x9E, 0xAA)
# reg_9F[7:0] = 0x4D
dut.write(0x9F, 0x4D)
# reg_A0[7:0] = 0xDF
dut.write(0xA0, 0xDF)
# reg_A1[7:0] = 0x97
dut.write(0xA1, 0x97)
# reg_A2[7:0] = 0x3
dut.write(0xA2, 0x3)
# reg_A3[7:0] = 0x0
dut.write(0xA3, 0x0)
# reg_A4[7:0] = 0xFF
dut.write(0xA4, 0xFF)
# reg_A5[7:0] = 0x6
dut.write(0xA5, 0x6)
# reg_A6[7:0] = 0x1C
dut.write(0xA6, 0x1C)
# reg_A7[7:0] = 0x0
dut.write(0xA7, 0x0)
# reg_A8[7:0] = 0x6
dut.write(0xA8, 0x6)
# reg_A9[7:0] = 0x0
dut.write(0xA9, 0x0)
# reg_AB[7:0] = 0x0
dut.write(0xAB, 0x0)
# reg_AC[7:0] = 0x20
dut.write(0xAC, 0x20)
# reg_AD[7:0] = 0x0
dut.write(0xAD, 0x0)
# reg_AE[7:0] = 0xFF
dut.write(0xAE, 0xFF)
# reg_AF[7:0] = 0x50
dut.write(0xAF, 0x50)
# reg_B0[7:0] = 0x4
dut.write(0xB0, 0x4)
# reg_B1[7:0] = 0xD
dut.write(0xB1, 0xD)
# reg_B2[7:0] = 0x0
dut.write(0xB2, 0x0)
# reg_B3[7:0] = 0x0
dut.write(0xB3, 0x0)
# reg_B5[7:0] = 0x0
dut.write(0xB5, 0x0)
# reg_B6[7:0] = 0x0
dut.write(0xB6, 0x0)
# reg_B7[7:0] = 0x0
dut.write(0xB7, 0x0)
# reg_B8[7:0] = 0x0
dut.write(0xB8, 0x0)
# clkgrp1_div1_cfg1_en[0:0] = 0x1
# clkgrp1_div1_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp1_div1_cfg2_startmode[3:2] = 0x3
# clkgrp1_div1_cfg1_rev[4:4] = 0x0
# clkgrp1_div1_cfg1_slipmask[5:5] = 0x0
# clkgrp1_div1_cfg1_reseedmask[6:6] = 0x1
# clkgrp1_div1_cfg1_hi_perf[7:7] = 0x1
dut.write(0xC8, 0xCD)
# clkgrp1_div1_cfg12_divrat_lsb[7:0] = 0x20
dut.write(0xC9, 0x20)
# clkgrp1_div1_cfg12_divrat_msb[3:0] = 0x0
dut.write(0xCA, 0x0)
# clkgrp1_div1_cfg5_fine_delay[4:0] = 0x0
dut.write(0xCB, 0x0)
# clkgrp1_div1_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0xCC, 0x0)
# clkgrp1_div1_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0xCD, 0x0)
# clkgrp1_div1_cfg12_mslip_msb[3:0] = 0x0
dut.write(0xCE, 0x0)
# clkgrp1_div1_cfg2_sel_outmux[1:0] = 0x0
# clkgrp1_div1_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0xCF, 0x0)
# clkgrp1_div1_cfg5_drvr_res[1:0] = 0x0
# clkgrp1_div1_cfg5_drvr_spare[2:2] = 0x0
# clkgrp1_div1_cfg5_drvr_mode[4:3] = 0x0
# clkgrp1_div1_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp1_div1_cfg2_mutesel[7:6] = 0x0
dut.write(0xD0, 0x0)
# clkgrp1_div2_cfg1_en[0:0] = 0x0
# clkgrp1_div2_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp1_div2_cfg2_startmode[3:2] = 0x0
# clkgrp1_div2_cfg1_rev[4:4] = 0x0
# clkgrp1_div2_cfg1_slipmask[5:5] = 0x0
# clkgrp1_div2_cfg1_reseedmask[6:6] = 0x0
# clkgrp1_div2_cfg1_hi_perf[7:7] = 0x0
dut.write(0xD2, 0x0)
# clkgrp1_div2_cfg12_divrat_lsb[7:0] = 0x0
dut.write(0xD3, 0x0)
# clkgrp1_div2_cfg12_divrat_msb[3:0] = 0x1
dut.write(0xD4, 0x1)
# clkgrp1_div2_cfg5_fine_delay[4:0] = 0x0
dut.write(0xD5, 0x0)
# clkgrp1_div2_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0xD6, 0x0)
# clkgrp1_div2_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0xD7, 0x0)
# clkgrp1_div2_cfg12_mslip_msb[3:0] = 0x0
dut.write(0xD8, 0x0)
# clkgrp1_div2_cfg2_sel_outmux[1:0] = 0x0
# clkgrp1_div2_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0xD9, 0x0)
# clkgrp1_div2_cfg5_drvr_res[1:0] = 0x0
# clkgrp1_div2_cfg5_drvr_spare[2:2] = 0x0
# clkgrp1_div2_cfg5_drvr_mode[4:3] = 0x2
# clkgrp1_div2_cfg_outbuf_dyn[5:5] = 0x1
# clkgrp1_div2_cfg2_mutesel[7:6] = 0x0
dut.write(0xDA, 0x30)
# clkgrp2_div1_cfg1_en[0:0] = 0x1
# clkgrp2_div1_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp2_div1_cfg2_startmode[3:2] = 0x3
# clkgrp2_div1_cfg1_rev[4:4] = 0x0
# clkgrp2_div1_cfg1_slipmask[5:5] = 0x0
# clkgrp2_div1_cfg1_reseedmask[6:6] = 0x0
# clkgrp2_div1_cfg1_hi_perf[7:7] = 0x1
dut.write(0xDC, 0x8D)
# clkgrp2_div1_cfg12_divrat_lsb[7:0] = 0x20
dut.write(0xDD, 0x20)
# clkgrp2_div1_cfg12_divrat_msb[3:0] = 0x0
dut.write(0xDE, 0x0)
# clkgrp2_div1_cfg5_fine_delay[4:0] = 0x0
dut.write(0xDF, 0x0)
# clkgrp2_div1_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0xE0, 0x0)
# clkgrp2_div1_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0xE1, 0x0)
# clkgrp2_div1_cfg12_mslip_msb[3:0] = 0x0
dut.write(0xE2, 0x0)
# clkgrp2_div1_cfg2_sel_outmux[1:0] = 0x0
# clkgrp2_div1_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0xE3, 0x0)
# clkgrp2_div1_cfg5_drvr_res[1:0] = 0x0
# clkgrp2_div1_cfg5_drvr_spare[2:2] = 0x0
# clkgrp2_div1_cfg5_drvr_mode[4:3] = 0x0
# clkgrp2_div1_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp2_div1_cfg2_mutesel[7:6] = 0x0
dut.write(0xE4, 0x0)
# clkgrp2_div2_cfg1_en[0:0] = 0x0
# clkgrp2_div2_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp2_div2_cfg2_startmode[3:2] = 0x0
# clkgrp2_div2_cfg1_rev[4:4] = 0x0
# clkgrp2_div2_cfg1_slipmask[5:5] = 0x0
# clkgrp2_div2_cfg1_reseedmask[6:6] = 0x0
# clkgrp2_div2_cfg1_hi_perf[7:7] = 0x0
dut.write(0xE6, 0x0)
# clkgrp2_div2_cfg12_divrat_lsb[7:0] = 0x0
dut.write(0xE7, 0x0)
# clkgrp2_div2_cfg12_divrat_msb[3:0] = 0x1
dut.write(0xE8, 0x1)
# clkgrp2_div2_cfg5_fine_delay[4:0] = 0x0
dut.write(0xE9, 0x0)
# clkgrp2_div2_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0xEA, 0x0)
# clkgrp2_div2_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0xEB, 0x0)
# clkgrp2_div2_cfg12_mslip_msb[3:0] = 0x0
dut.write(0xEC, 0x0)
# clkgrp2_div2_cfg2_sel_outmux[1:0] = 0x0
# clkgrp2_div2_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0xED, 0x0)
# clkgrp2_div2_cfg5_drvr_res[1:0] = 0x3
# clkgrp2_div2_cfg5_drvr_spare[2:2] = 0x1
# clkgrp2_div2_cfg5_drvr_mode[4:3] = 0x3
# clkgrp2_div2_cfg_outbuf_dyn[5:5] = 0x1
# clkgrp2_div2_cfg2_mutesel[7:6] = 0x3
dut.write(0xEE, 0xFF)
# clkgrp3_div1_cfg1_en[0:0] = 0x1
# clkgrp3_div1_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp3_div1_cfg2_startmode[3:2] = 0x3
# clkgrp3_div1_cfg1_rev[4:4] = 0x0
# clkgrp3_div1_cfg1_slipmask[5:5] = 0x0
# clkgrp3_div1_cfg1_reseedmask[6:6] = 0x0
# clkgrp3_div1_cfg1_hi_perf[7:7] = 0x1
dut.write(0xF0, 0x8D)
# clkgrp3_div1_cfg12_divrat_lsb[7:0] = 0x20
dut.write(0xF1, 0x20)
# clkgrp3_div1_cfg12_divrat_msb[3:0] = 0x0
dut.write(0xF2, 0x0)
# clkgrp3_div1_cfg5_fine_delay[4:0] = 0x0
dut.write(0xF3, 0x0)
# clkgrp3_div1_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0xF4, 0x0)
# clkgrp3_div1_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0xF5, 0x0)
# clkgrp3_div1_cfg12_mslip_msb[3:0] = 0x0
dut.write(0xF6, 0x0)
# clkgrp3_div1_cfg2_sel_outmux[1:0] = 0x0
# clkgrp3_div1_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0xF7, 0x0)
# clkgrp3_div1_cfg5_drvr_res[1:0] = 0x3
# clkgrp3_div1_cfg5_drvr_spare[2:2] = 0x0
# clkgrp3_div1_cfg5_drvr_mode[4:3] = 0x3
# clkgrp3_div1_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp3_div1_cfg2_mutesel[7:6] = 0x0
dut.write(0xF8, 0x1B)
# clkgrp3_div2_cfg1_en[0:0] = 0x1
# clkgrp3_div2_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp3_div2_cfg2_startmode[3:2] = 0x3
# clkgrp3_div2_cfg1_rev[4:4] = 0x1
# clkgrp3_div2_cfg1_slipmask[5:5] = 0x0
# clkgrp3_div2_cfg1_reseedmask[6:6] = 0x1
# clkgrp3_div2_cfg1_hi_perf[7:7] = 0x0
dut.write(0xFA, 0x5D)
# clkgrp3_div2_cfg12_divrat_lsb[7:0] = 0x1E
dut.write(0xFB, 0x1E)
# clkgrp3_div2_cfg12_divrat_msb[3:0] = 0x0
dut.write(0xFC, 0x0)
# clkgrp3_div2_cfg5_fine_delay[4:0] = 0x0
dut.write(0xFD, 0x0)
# clkgrp3_div2_cfg5_sel_coarse_delay[4:0] = 0xF
dut.write(0xFE, 0xF)
# clkgrp3_div2_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0xFF, 0x0)
# clkgrp3_div2_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x100, 0x0)
# clkgrp3_div2_cfg2_sel_outmux[1:0] = 0x0
# clkgrp3_div2_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x101, 0x0)
# clkgrp3_div2_cfg5_drvr_res[1:0] = 0x1
# clkgrp3_div2_cfg5_drvr_spare[2:2] = 0x0
# clkgrp3_div2_cfg5_drvr_mode[4:3] = 0x2
# clkgrp3_div2_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp3_div2_cfg2_mutesel[7:6] = 0x2
dut.write(0x102, 0x91)
# clkgrp4_div1_cfg1_en[0:0] = 0x0
# clkgrp4_div1_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp4_div1_cfg2_startmode[3:2] = 0x0
# clkgrp4_div1_cfg1_rev[4:4] = 0x0
# clkgrp4_div1_cfg1_slipmask[5:5] = 0x0
# clkgrp4_div1_cfg1_reseedmask[6:6] = 0x0
# clkgrp4_div1_cfg1_hi_perf[7:7] = 0x0
dut.write(0x104, 0x0)
# clkgrp4_div1_cfg12_divrat_lsb[7:0] = 0x2
dut.write(0x105, 0x2)
# clkgrp4_div1_cfg12_divrat_msb[3:0] = 0x0
dut.write(0x106, 0x0)
# clkgrp4_div1_cfg5_fine_delay[4:0] = 0x0
dut.write(0x107, 0x0)
# clkgrp4_div1_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0x108, 0x0)
# clkgrp4_div1_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0x109, 0x0)
# clkgrp4_div1_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x10A, 0x0)
# clkgrp4_div1_cfg2_sel_outmux[1:0] = 0x0
# clkgrp4_div1_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x10B, 0x0)
# clkgrp4_div1_cfg5_drvr_res[1:0] = 0x1
# clkgrp4_div1_cfg5_drvr_spare[2:2] = 0x0
# clkgrp4_div1_cfg5_drvr_mode[4:3] = 0x0
# clkgrp4_div1_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp4_div1_cfg2_mutesel[7:6] = 0x0
dut.write(0x10C, 0x1)
# clkgrp4_div2_cfg1_en[0:0] = 0x1
# clkgrp4_div2_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp4_div2_cfg2_startmode[3:2] = 0x3
# clkgrp4_div2_cfg1_rev[4:4] = 0x1
# clkgrp4_div2_cfg1_slipmask[5:5] = 0x0
# clkgrp4_div2_cfg1_reseedmask[6:6] = 0x1
# clkgrp4_div2_cfg1_hi_perf[7:7] = 0x0
dut.write(0x10E, 0x5D)
# clkgrp4_div2_cfg12_divrat_lsb[7:0] = 0x20
dut.write(0x10F, 0x20)
# clkgrp4_div2_cfg12_divrat_msb[3:0] = 0x0
dut.write(0x110, 0x0)
# clkgrp4_div2_cfg5_fine_delay[4:0] = 0x0
dut.write(0x111, 0x0)
# clkgrp4_div2_cfg5_sel_coarse_delay[4:0] = 0xF
dut.write(0x112, 0xF)
# clkgrp4_div2_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0x113, 0x0)
# clkgrp4_div2_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x114, 0x0)
# clkgrp4_div2_cfg2_sel_outmux[1:0] = 0x0
# clkgrp4_div2_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x115, 0x0)
# clkgrp4_div2_cfg5_drvr_res[1:0] = 0x1
# clkgrp4_div2_cfg5_drvr_spare[2:2] = 0x0
# clkgrp4_div2_cfg5_drvr_mode[4:3] = 0x2
# clkgrp4_div2_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp4_div2_cfg2_mutesel[7:6] = 0x2
dut.write(0x116, 0x91)
# clkgrp5_div1_cfg1_en[0:0] = 0x1
# clkgrp5_div1_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp5_div1_cfg2_startmode[3:2] = 0x3
# clkgrp5_div1_cfg1_rev[4:4] = 0x1
# clkgrp5_div1_cfg1_slipmask[5:5] = 0x0
# clkgrp5_div1_cfg1_reseedmask[6:6] = 0x1
# clkgrp5_div1_cfg1_hi_perf[7:7] = 0x0
dut.write(0x118, 0x5D)
# clkgrp5_div1_cfg12_divrat_lsb[7:0] = 0x22
dut.write(0x119, 0x22)
# clkgrp5_div1_cfg12_divrat_msb[3:0] = 0x0
dut.write(0x11A, 0x0)
# clkgrp5_div1_cfg5_fine_delay[4:0] = 0x0
dut.write(0x11B, 0x0)
# clkgrp5_div1_cfg5_sel_coarse_delay[4:0] = 0xF
dut.write(0x11C, 0xF)
# clkgrp5_div1_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0x11D, 0x0)
# clkgrp5_div1_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x11E, 0x0)
# clkgrp5_div1_cfg2_sel_outmux[1:0] = 0x0
# clkgrp5_div1_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x11F, 0x0)
# clkgrp5_div1_cfg5_drvr_res[1:0] = 0x1
# clkgrp5_div1_cfg5_drvr_spare[2:2] = 0x0
# clkgrp5_div1_cfg5_drvr_mode[4:3] = 0x2
# clkgrp5_div1_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp5_div1_cfg2_mutesel[7:6] = 0x2
dut.write(0x120, 0x91)
# clkgrp5_div2_cfg1_en[0:0] = 0x0
# clkgrp5_div2_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp5_div2_cfg2_startmode[3:2] = 0x0
# clkgrp5_div2_cfg1_rev[4:4] = 0x0
# clkgrp5_div2_cfg1_slipmask[5:5] = 0x0
# clkgrp5_div2_cfg1_reseedmask[6:6] = 0x0
# clkgrp5_div2_cfg1_hi_perf[7:7] = 0x0
dut.write(0x122, 0x0)
# clkgrp5_div2_cfg12_divrat_lsb[7:0] = 0x0
dut.write(0x123, 0x0)
# clkgrp5_div2_cfg12_divrat_msb[3:0] = 0x1
dut.write(0x124, 0x1)
# clkgrp5_div2_cfg5_fine_delay[4:0] = 0x0
dut.write(0x125, 0x0)
# clkgrp5_div2_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0x126, 0x0)
# clkgrp5_div2_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0x127, 0x0)
# clkgrp5_div2_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x128, 0x0)
# clkgrp5_div2_cfg2_sel_outmux[1:0] = 0x0
# clkgrp5_div2_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x129, 0x0)
# clkgrp5_div2_cfg5_drvr_res[1:0] = 0x0
# clkgrp5_div2_cfg5_drvr_spare[2:2] = 0x0
# clkgrp5_div2_cfg5_drvr_mode[4:3] = 0x2
# clkgrp5_div2_cfg_outbuf_dyn[5:5] = 0x1
# clkgrp5_div2_cfg2_mutesel[7:6] = 0x0
dut.write(0x12A, 0x30)
# clkgrp6_div1_cfg1_en[0:0] = 0x0
# clkgrp6_div1_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp6_div1_cfg2_startmode[3:2] = 0x0
# clkgrp6_div1_cfg1_rev[4:4] = 0x0
# clkgrp6_div1_cfg1_slipmask[5:5] = 0x0
# clkgrp6_div1_cfg1_reseedmask[6:6] = 0x0
# clkgrp6_div1_cfg1_hi_perf[7:7] = 0x0
dut.write(0x12C, 0x0)
# clkgrp6_div1_cfg12_divrat_lsb[7:0] = 0x2
dut.write(0x12D, 0x2)
# clkgrp6_div1_cfg12_divrat_msb[3:0] = 0x0
dut.write(0x12E, 0x0)
# clkgrp6_div1_cfg5_fine_delay[4:0] = 0x0
dut.write(0x12F, 0x0)
# clkgrp6_div1_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0x130, 0x0)
# clkgrp6_div1_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0x131, 0x0)
# clkgrp6_div1_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x132, 0x0)
# clkgrp6_div1_cfg2_sel_outmux[1:0] = 0x0
# clkgrp6_div1_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x133, 0x0)
# clkgrp6_div1_cfg5_drvr_res[1:0] = 0x1
# clkgrp6_div1_cfg5_drvr_spare[2:2] = 0x0
# clkgrp6_div1_cfg5_drvr_mode[4:3] = 0x0
# clkgrp6_div1_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp6_div1_cfg2_mutesel[7:6] = 0x0
dut.write(0x134, 0x1)
# clkgrp6_div2_cfg1_en[0:0] = 0x0
# clkgrp6_div2_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp6_div2_cfg2_startmode[3:2] = 0x0
# clkgrp6_div2_cfg1_rev[4:4] = 0x0
# clkgrp6_div2_cfg1_slipmask[5:5] = 0x0
# clkgrp6_div2_cfg1_reseedmask[6:6] = 0x0
# clkgrp6_div2_cfg1_hi_perf[7:7] = 0x0
dut.write(0x136, 0x0)
# clkgrp6_div2_cfg12_divrat_lsb[7:0] = 0x0
dut.write(0x137, 0x0)
# clkgrp6_div2_cfg12_divrat_msb[3:0] = 0x1
dut.write(0x138, 0x1)
# clkgrp6_div2_cfg5_fine_delay[4:0] = 0x0
dut.write(0x139, 0x0)
# clkgrp6_div2_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0x13A, 0x0)
# clkgrp6_div2_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0x13B, 0x0)
# clkgrp6_div2_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x13C, 0x0)
# clkgrp6_div2_cfg2_sel_outmux[1:0] = 0x0
# clkgrp6_div2_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x13D, 0x0)
# clkgrp6_div2_cfg5_drvr_res[1:0] = 0x0
# clkgrp6_div2_cfg5_drvr_spare[2:2] = 0x0
# clkgrp6_div2_cfg5_drvr_mode[4:3] = 0x0
# clkgrp6_div2_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp6_div2_cfg2_mutesel[7:6] = 0x0
dut.write(0x13E, 0x0)
# clkgrp7_div1_cfg1_en[0:0] = 0x1
# clkgrp7_div1_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp7_div1_cfg2_startmode[3:2] = 0x3
# clkgrp7_div1_cfg1_rev[4:4] = 0x1
# clkgrp7_div1_cfg1_slipmask[5:5] = 0x0
# clkgrp7_div1_cfg1_reseedmask[6:6] = 0x1
# clkgrp7_div1_cfg1_hi_perf[7:7] = 0x0
dut.write(0x140, 0x5D)
# clkgrp7_div1_cfg12_divrat_lsb[7:0] = 0x24
dut.write(0x141, 0x24)
# clkgrp7_div1_cfg12_divrat_msb[3:0] = 0x0
dut.write(0x142, 0x0)
# clkgrp7_div1_cfg5_fine_delay[4:0] = 0x0
dut.write(0x143, 0x0)
# clkgrp7_div1_cfg5_sel_coarse_delay[4:0] = 0xF
dut.write(0x144, 0xF)
# clkgrp7_div1_cfg12_mslip_lsb[7:0] = 0xF
dut.write(0x145, 0xF)
# clkgrp7_div1_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x146, 0x0)
# clkgrp7_div1_cfg2_sel_outmux[1:0] = 0x0
# clkgrp7_div1_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x147, 0x0)
# clkgrp7_div1_cfg5_drvr_res[1:0] = 0x1
# clkgrp7_div1_cfg5_drvr_spare[2:2] = 0x0
# clkgrp7_div1_cfg5_drvr_mode[4:3] = 0x2
# clkgrp7_div1_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp7_div1_cfg2_mutesel[7:6] = 0x2
dut.write(0x148, 0x91)
# clkgrp7_div2_cfg1_en[0:0] = 0x0
# clkgrp7_div2_cfg1_phdelta_mslip[1:1] = 0x0
# clkgrp7_div2_cfg2_startmode[3:2] = 0x0
# clkgrp7_div2_cfg1_rev[4:4] = 0x0
# clkgrp7_div2_cfg1_slipmask[5:5] = 0x0
# clkgrp7_div2_cfg1_reseedmask[6:6] = 0x0
# clkgrp7_div2_cfg1_hi_perf[7:7] = 0x0
dut.write(0x14A, 0x0)
# clkgrp7_div2_cfg12_divrat_lsb[7:0] = 0x0
dut.write(0x14B, 0x0)
# clkgrp7_div2_cfg12_divrat_msb[3:0] = 0x0
dut.write(0x14C, 0x0)
# clkgrp7_div2_cfg5_fine_delay[4:0] = 0x0
dut.write(0x14D, 0x0)
# clkgrp7_div2_cfg5_sel_coarse_delay[4:0] = 0x0
dut.write(0x14E, 0x0)
# clkgrp7_div2_cfg12_mslip_lsb[7:0] = 0x0
dut.write(0x14F, 0x0)
# clkgrp7_div2_cfg12_mslip_msb[3:0] = 0x0
dut.write(0x150, 0x0)
# clkgrp7_div2_cfg2_sel_outmux[1:0] = 0x0
# clkgrp7_div2_cfg1_drvr_sel_testclk[2:2] = 0x0
dut.write(0x151, 0x0)
# clkgrp7_div2_cfg5_drvr_res[1:0] = 0x0
# clkgrp7_div2_cfg5_drvr_spare[2:2] = 0x0
# clkgrp7_div2_cfg5_drvr_mode[4:3] = 0x0
# clkgrp7_div2_cfg_outbuf_dyn[5:5] = 0x0
# clkgrp7_div2_cfg2_mutesel[7:6] = 0x0
dut.write(0x152, 0x0)
Updated register file attached
[edited by: akshay92 at 10:54 AM (GMT -4) on 13 May 2022]
    Did you send Restart Request after programming all registers? Restarts Request (setting Reg0x01[1]=1 and Reg0x01[1]=0, respectively) is required to initialize autocalibration.
    Kudret
  • Yes we have followed the typical programming sequence given in the datasheet.
  • Can you check if PLL1 and PLL2 are locked?
  • Both the PLL are getting locked, we can see that from the register read. But the LED dedicated to the PLL lock is not glowing. Another thing is that we have designed the loop filter as per R1 and N1 values of 2 and 20 but it is not generating accurate results. While at R1 and N1 1 and 10 it is showing accurate results. Attached updated register file.
    dut.write(0x0,0x0000)
    dut.write(0x1,0x0040)
    dut.write(0x2,0x0000)
    dut.write(0x3,0x0000)
    dut.write(0x4,0x007e)
    dut.write(0x5,0x0042)
    dut.write(0x6,0x0000)
    dut.write(0x7,0x0000)
    dut.write(0x8,0x0000)
    dut.write(0x9,0x0000)
    dut.write(0xA,0x008)
    dut.write(0xB,0x008)
    dut.write(0xC,0x0000)
    dut.write(0xD,0x0000)
    dut.write(0xE,0x0014)
    dut.write(0xF,0x0000)
    dut.write(0x10,0x0000)
    dut.write(0x11,0x0000)
    dut.write(0x12,0x0000)
    dut.write(0x13,0x0000)
    dut.write(0x14,0x00e4)
    dut.write(0x15,0x002)
    dut.write(0x16,0x00c)
    dut.write(0x17,0x0000)
    dut.write(0x18,0x004)
    dut.write(0x19,0x0000)
    dut.write(0x1A,0x008)
    dut.write(0x1B,0x0018)
    dut.write(0x1C,0x0000)
    dut.write(0x1D,0x0000)
    dut.write(0x1E,0x0000)
    dut.write(0x1F,0x0000)
    dut.write(0x20,0x00a)
    dut.write(0x21,0x002)
    dut.write(0x22,0x0000)
    dut.write(0x23,0x0000)
    dut.write(0x24,0x0000)
    dut.write(0x25,0x0000)
    dut.write(0x26,0x0014)
    dut.write(0x27,0x0000)
    dut.write(0x28,0x0014)
    dut.write(0x29,0x004)
    dut.write(0x2A,0x0000)
    dut.write(0x2B,0x0000)
    dut.write(0x2C,0x0000)
    dut.write(0x2D,0x0000)
    dut.write(0x2E,0x0000)
    dut.write(0x2F,0x0000)
    dut.write(0x30,0x0000)
    dut.write(0x31,0x0000)
    dut.write(0x32,0x0000)
    dut.write(0x33,0x0000)
    dut.write(0x34,0x0000)
    dut.write(0x35,0x001a)
    dut.write(0x36,0x0000)
    dut.write(0x37,0x00e)
    dut.write(0x38,0x0018)
    dut.write(0x39,0x0000)
    dut.write(0x3A,0x0000)
    dut.write(0x3B,0x0000)
    dut.write(0x3C,0x0000)
    dut.write(0x3D,0x0000)
    dut.write(0x3E,0x0000)
    dut.write(0x3F,0x0000)
    dut.write(0x40,0x0000)
    dut.write(0x41,0x0000)
    dut.write(0x42,0x0000)
    dut.write(0x43,0x0000)
    dut.write(0x44,0x0000)
    dut.write(0x45,0x0000)
    dut.write(0x46,0x0000)
    dut.write(0x47,0x0000)
    dut.write(0x48,0x0000)
    dut.write(0x49,0x0000)
    dut.write(0x4A,0x0000)
    dut.write(0x4B,0x0000)
    dut.write(0x4C,0x0000)
    dut.write(0x4D,0x0000)
    dut.write(0x4E,0x0000)
    dut.write(0x4F,0x0000)
    dut.write(0x50,0x0014)
    dut.write(0x51,0x00e)
    dut.write(0x52,0x0000)
    dut.write(0x53,0x0000)
    dut.write(0x54,0x002)
    dut.write(0x55,0x0000)
    dut.write(0x56,0x0000)
    dut.write(0x57,0x0000)
    dut.write(0x58,0x0000)
    dut.write(0x59,0x0000)
    dut.write(0x5A,0x006)
    dut.write(0x5B,0x006)
    dut.write(0x5C,0x0000)
    dut.write(0x5D,0x00e)
    dut.write(0x5E,0x0000)
    dut.write(0x5F,0x0000)
    dut.write(0x60,0x0000)
    dut.write(0x61,0x0000)
    dut.write(0x62,0x0000)
    dut.write(0x63,0x0000)
    dut.write(0x64,0x0000)
    dut.write(0x65,0x0000)
    dut.write(0x66,0x0000)
    dut.write(0x67,0x0000)
    dut.write(0x68,0x0000)
    dut.write(0x69,0x0000)
    dut.write(0x6A,0x0000)
    dut.write(0x6B,0x0000)
    dut.write(0x6C,0x0000)
    dut.write(0x6D,0x0000)
    dut.write(0x6E,0x0000)
    dut.write(0x6F,0x0000)
    dut.write(0x70,0x0000)
    dut.write(0x71,0x0010)
    dut.write(0x72,0x0000)
    dut.write(0x73,0x0000)
    dut.write(0x74,0x0000)
    dut.write(0x75,0x0000)
    dut.write(0x76,0x0000)
    dut.write(0x77,0x0000)
    dut.write(0x78,0x0000)
    dut.write(0x79,0x0052)
    dut.write(0x7A,0x004)
    dut.write(0x7B,0x0000)
    dut.write(0x7C,0x0012)
    dut.write(0x7D,0x002)
    dut.write(0x7E,0x0072)
    dut.write(0x7F,0x0000)
    dut.write(0x80,0x0000)
    dut.write(0x81,0x0000)
    dut.write(0x82,0x00c)
    dut.write(0x83,0x0040)
    dut.write(0x84,0x0040)
    dut.write(0x85,0x00a)
    dut.write(0x86,0x006)
    dut.write(0x87,0x004)
    dut.write(0x88,0x0000)
    dut.write(0x89,0x0000)
    dut.write(0x8A,0x0000)
    dut.write(0x8B,0x0000)
    dut.write(0x8C,0x0000)
    dut.write(0x8D,0x0038)
    dut.write(0x8E,0x0042)
    dut.write(0x8F,0x0000)
    dut.write(0x90,0x0000)
    dut.write(0x91,0x00a)
    dut.write(0x92,0x0000)
    dut.write(0x93,0x0000)
    dut.write(0x94,0x0000)
    dut.write(0x95,0x0000)
    dut.write(0x96,0x0000)
    dut.write(0x97,0x0000)
    dut.write(0x98,0x0000)
    dut.write(0x99,0x0000)
    dut.write(0x9A,0x0000)
    dut.write(0x9B,0x00aa)
    dut.write(0x9C,0x00aa)
    dut.write(0x9D,0x00aa)
    dut.write(0x9E,0x00aa)
    dut.write(0x9F,0x004c)
    dut.write(0xA0,0x00de)
    dut.write(0xA1,0x0096)
    dut.write(0xA2,0x002)
    dut.write(0xA3,0x0000)
    dut.write(0xA4,0x0000)
    dut.write(0xA5,0x006)
    dut.write(0xA6,0x001c)
    dut.write(0xA7,0x0000)
    dut.write(0xA8,0x006)
    dut.write(0xA9,0x0000)
    dut.write(0xAA,0x0000)
    dut.write(0xAB,0x0000)
    dut.write(0xAC,0x0020)
    dut.write(0xAD,0x0000)
    dut.write(0xAE,0x008)
    dut.write(0xAF,0x0050)
    dut.write(0xB0,0x004)
    dut.write(0xB1,0x00c)
    dut.write(0xB2,0x0000)
    dut.write(0xB3,0x0000)
    dut.write(0xB4,0x0000)
    dut.write(0xB5,0x0000)
    dut.write(0xB6,0x0000)
    dut.write(0xB7,0x0000)
    dut.write(0xB8,0x0000)
    dut.write(0xB9,0x0000)
    dut.write(0xBA,0x0000)
    dut.write(0xBB,0x0000)
    dut.write(0xBC,0x0000)
    dut.write(0xBD,0x0000)
    dut.write(0xBE,0x0000)
    dut.write(0xBF,0x0000)
    dut.write(0xC0,0x0000)
    dut.write(0xC1,0x0000)
    dut.write(0xC2,0x0000)
    dut.write(0xC3,0x0000)
    dut.write(0xC4,0x0000)
    dut.write(0xC5,0x0000)
    dut.write(0xC6,0x0000)
    dut.write(0xC7,0x0000)
    dut.write(0xC8,0x005c)
    dut.write(0xC9,0x001c)
    dut.write(0xCA,0x0000)
    dut.write(0xCB,0x0000)
    dut.write(0xCC,0x00e)
    dut.write(0xCD,0x0000)
    dut.write(0xCE,0x0000)
    dut.write(0xCF,0x0000)
    dut.write(0xD0,0x0090)
    dut.write(0xD1,0x0000)
    dut.write(0xD2,0x0000)
    dut.write(0xD3,0x0000)
    dut.write(0xD4,0x0000)
    dut.write(0xD5,0x0000)
    dut.write(0xD6,0x0000)
    dut.write(0xD7,0x0000)
    dut.write(0xD8,0x0000)
    dut.write(0xD9,0x0000)
    dut.write(0xDA,0x0030)
    dut.write(0xDB,0x0000)
    dut.write(0xDC,0x0000)
    dut.write(0xDD,0x008)
    dut.write(0xDE,0x0000)
    dut.write(0xDF,0x0000)
    dut.write(0xE0,0x0000)
    dut.write(0xE1,0x0000)
    dut.write(0xE2,0x0000)
    dut.write(0xE3,0x0000)
    dut.write(0xE4,0x0000)
    dut.write(0xE5,0x0000)
    dut.write(0xE6,0x0000)
    dut.write(0xE7,0x0000)
    dut.write(0xE8,0x0000)
    dut.write(0xE9,0x0000)
    dut.write(0xEA,0x0000)
    dut.write(0xEB,0x0000)
    dut.write(0xEC,0x0000)
    dut.write(0xED,0x0000)
    dut.write(0xEE,0x0030)
    dut.write(0xEF,0x0000)
    dut.write(0xF0,0x0000)
    dut.write(0xF1,0x002)
    dut.write(0xF2,0x0000)
    dut.write(0xF3,0x0000)
    dut.write(0xF4,0x0000)
    dut.write(0xF5,0x0000)
    dut.write(0xF6,0x0000)
    dut.write(0xF7,0x0000)
    dut.write(0xF8,0x0000)
    dut.write(0xF9,0x0000)
    dut.write(0xFA,0x005c)
    dut.write(0xFB,0x001e)
    dut.write(0xFC,0x0000)
    dut.write(0xFD,0x0000)
    dut.write(0xFE,0x00e)
    dut.write(0xFF,0x0000)
    dut.write(0x100,0x0000)
    dut.write(0x101,0x0000)
    dut.write(0x102,0x0090)
    dut.write(0x103,0x0000)
    dut.write(0x104,0x0000)
    dut.write(0x105,0x002)
    dut.write(0x106,0x0000)
    dut.write(0x107,0x0000)
    dut.write(0x108,0x0000)
    dut.write(0x109,0x0000)
    dut.write(0x10A,0x0000)
    dut.write(0x10B,0x0000)
    dut.write(0x10C,0x0000)
    dut.write(0x10D,0x0000)
    dut.write(0x10E,0x005c)
    dut.write(0x10F,0x0020)
    dut.write(0x110,0x0000)
    dut.write(0x111,0x0000)
    dut.write(0x112,0x00e)
    dut.write(0x113,0x0000)
    dut.write(0x114,0x0000)
    dut.write(0x115,0x0000)
    dut.write(0x116,0x0090)
    dut.write(0x117,0x0000)
    dut.write(0x118,0x005c)
    dut.write(0x119,0x0022)
    dut.write(0x11A,0x0000)
    dut.write(0x11B,0x0000)
    dut.write(0x11C,0x00e)
    dut.write(0x11D,0x0000)
    dut.write(0x11E,0x0000)
    dut.write(0x11F,0x0000)
    dut.write(0x120,0x0090)
    dut.write(0x121,0x0000)
    dut.write(0x122,0x0000)
    dut.write(0x123,0x0000)
    dut.write(0x124,0x0000)
    dut.write(0x125,0x0000)
    dut.write(0x126,0x0000)
    dut.write(0x127,0x0000)
    dut.write(0x128,0x0000)
    dut.write(0x129,0x0000)
    dut.write(0x12A,0x0030)
    dut.write(0x12B,0x0000)
    dut.write(0x12C,0x0000)
    dut.write(0x12D,0x002)
    dut.write(0x12E,0x0000)
    dut.write(0x12F,0x0000)
    dut.write(0x130,0x0000)
    dut.write(0x131,0x0000)
    dut.write(0x132,0x0000)
    dut.write(0x133,0x0000)
    dut.write(0x134,0x0000)
    dut.write(0x135,0x0000)
    dut.write(0x136,0x0000)
    dut.write(0x137,0x0000)
    dut.write(0x138,0x0000)
    dut.write(0x139,0x0000)
    dut.write(0x13A,0x0000)
    dut.write(0x13B,0x0000)
    dut.write(0x13C,0x0000)
    dut.write(0x13D,0x0000)
    dut.write(0x13E,0x0030)
    dut.write(0x13F,0x0000)
    dut.write(0x140,0x005c)
    dut.write(0x141,0x0024)
    dut.write(0x142,0x0000)
    dut.write(0x143,0x0000)
    dut.write(0x144,0x00e)
    dut.write(0x145,0x0000)
    dut.write(0x146,0x0000)
    dut.write(0x147,0x0000)
    dut.write(0x148,0x0090)
    dut.write(0x149,0x0000)
    dut.write(0x14A,0x0000)
    dut.write(0x14B,0x0000)
    dut.write(0x14C,0x0000)
    dut.write(0x14D,0x0000)
    dut.write(0x14E,0x0000)
    dut.write(0x14F,0x0000)
    dut.write(0x150,0x0000)
    dut.write(0x151,0x0000)
    dut.write(0x152,0x0000)
    dut.write(0x153,0x0000)
    I think your PLL1 loop is not stable. Did you simulate your loop filter with the charge pump current and PFD frequency you are using?
  • The loop 1 components are as per schematic shared in post. The charge pump as per simulation was 120uA but we observed it is not getting locked at 120uA. We increased the charge pump to 1.08 mA and changed the PFD from 5MHz to 10MHz by making R1 and N1 as 1 and 10 instead of 2 and 20. After this we are getting accurate output but theoretically and as per simulation the values for loop filter are different but with simulation config we are not getting accurate results. What could be the reason
  • Can you suggest a loop filter config and charge pump value for this schematic.
    You can use R0_presclaer=1 R1=1, OSCIN_Prescaler=10, N1=10 Reg0x01=0x08 register configuration with default eval board filter component values given as below.
