Reading Register value from HMC7044
How to read Register values from HMC7044?
Which register to set as General purpose Output pin to read register value?
I am setting register 0x53  = 0x5 (to SDATA from SPI communication).
what is the spi sequence to request register value.
I am doing the following in my code using STM32
1. Sending Read Command with register value and count of registers to be read:1. (SPI Write)
2. SLEN High
3. 10 ms delay
4. SLEN LOW
5. Clearing buffer
6. SPI read
but i am not receiving anything.
I do not know which register to set to request data.
Urgently solution required. Immediate answer would be appreciated.
    GPIO4 is configured as input by default. If you want to use it as output you need to disable GPIO input buffer first, by writing Reg0x049[0]=0. Reg0x53=0x05 shows that you are using open drain mode. Do you have pull-up resistor on the pin? If so, what is the value?
    Can you send a scope shot to see timing of SLEN,SCLK and SDATA pins.
    Kudret
  • Mr. Kudret, Thank You so much for your reply.
    issue solved!
    As You said i wrote  b0 of Reg 0x049 = 0.
    I dint have a pull up resister but a pull down resistor of 27kohm so i changed the mode to CMOS mode
    Solution of read was: The SDATA Pin is bidirectional. SPI has to be configured in half duplex master mode. and simply SPI_Recieve function could read the register values.
    Also it came to notice that when Reg 0x00 = 0x1, ie global soft reset control is high, registers cant be written to. when i made this register zero--> i could write and read the registers.
    Oscilloscope: The data transfer from mcu to HMC (SDATA) was in sync with falling edge of clock (SCLK).
    Again Thanks for your swift answer.
