The EEPROM of the AD9545 fails to be loaded
ISSUE: The EEPROM of the AD9545 fails to be loaded when it is powered on. The IIC waveform is captured and the value of the 00 register (chipType value, fixed as 0x05) is incorrectly read, causing the AD9545 to stop loading.
the bin and *.cso generated by ACE are attached.
<?xml version="1.0" encoding="utf-8"?>
<Session Name="Session" AppVersion="" FileVersion="" xmlns="AnalogDevices/Csa/Configuration/Schemas/Session.xsd">
  <Elements>
    <Element Id="EvalSystem">
      <System xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Name="System" xmlns="AnalogDevices/Csa/Evaluation/Sessions/EvalSystemSessionElement.Schema.xsd">
        <Subsystems>
          <Subsystem Name="Subsystem_1">
            <Components>
              <Component ComponentId="AD9545Board" Name="AD9545 Board">
                <Info Name="AD9545 Board" Description="A USB to SPI interface board for the AD9545." />
                <SavedState>
                  <Board Id="AD9545Board" xmlns="">
                    <Parameter Id="virtual-parameter-vpserialtype" Value="0" />
                    <Parameter Id="virtual-parameter-vpspiioconfig" Value="true" />
                    <Parameter Id="virtual-parameter-vpspibitorder" Value="false" />
                    <Parameter Id="virtual-parameter-vpspistreamingtype" Value="0" />
                    <Parameter Id="virtual-parameter-vpSPISelected" Value="true" />
                    <Parameter Id="virtual-parameter-vpI2CSelected" Value="false" />
                    <Parameter Id="fx2-port-a-pins" Value="7" />
                    <Parameter Id="pa_usb_status-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_usb_status-data-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_csb-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_csb-data-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_resetb-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_resetb-data-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_enable_i2c-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_enable_i2c-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_4-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_4-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_5-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_5-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_6-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_6-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_7-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_7-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="fx2-port-b-pins" Value="0" />
                    <Parameter Id="pb_sdio-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_sdio-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_sdo-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_sdo-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_2-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_2-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_3-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_3-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_4-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_4-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_5-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_5-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_6-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_6-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_7-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_7-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="fx2-port-c-pins" Value="0" />
                    <Parameter Id="pc_gpio_0-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_0-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_1-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_1-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_2-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_2-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_3-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_3-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_4-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_4-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_5-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_5-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_6-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_6-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_7-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_7-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="fx2-port-d-pins" Value="0" />
                    <Parameter Id="pd_mp0-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp0-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp1-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp1-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp2-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp2-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp3-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp3-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp4-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp4-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp5-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp5-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp6-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp6-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_gpio_7-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_gpio_7-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="fx2-port-e-pins" Value="0" />
                    <Parameter Id="pe_gpio_0-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_0-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_1-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_1-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_2-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_2-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_3-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_3-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_4-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_4-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_5-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_5-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_6-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_6-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_7-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_7-data-fx2-port-e-pins" Value="false" />
                    <Chips>
                      <Chip Id="Chip.AD9545.AD9545" InstanceName="AD9545">
                        <Parameter Id="virtual-parameter-feature_1" Value="true" />
                        <Parameter Id="virtual-parameter-feature_2" Value="true" />
                        <Parameter Id="virtual-parameter-feature_3" Value="true" />
                        <Parameter Id="ad9545-pins" Value="1" />
                        <Parameter Id="resetb-direction-ad9545-pins" Value="false" />
                        <Parameter Id="resetb-data-ad9545-pins" Value="true" />
                        <Parameter Id="ad9545-m-pins" Value="0" />
                        <Parameter Id="mp0-direction-ad9545-m-pins" Value="true" />
                        <Parameter Id="mp0-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp1-direction-ad9545-m-pins" Value="true" />
                        <Parameter Id="mp1-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp2-direction-ad9545-m-pins" Value="true" />
                        <Parameter Id="mp2-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp3-direction-ad9545-m-pins" Value="true" />
                        <Parameter Id="mp3-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp4-direction-ad9545-m-pins" Value="true" />
                        <Parameter Id="mp4-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp5-direction-ad9545-m-pins" Value="true" />
                        <Parameter Id="mp5-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="virtual-parameter-hwAttached" Value="true" />
                        <Parameter Id="virtual-parameter-feature1_0_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-feature1_1_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-_TestVP" Value="0" />
                        <Parameter Id="virtual-parameter-ListSelect" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_err_src" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_err_src" Value="false" />
                        <Parameter Id="virtual-parameter-sysclk_expression" Value="52 MHz" />
                        <Parameter Id="virtual-parameter-SysClkFreq" Value="52 MHz" />
                        <Parameter Id="virtual-parameter-SysClkFreq_wiz" Value="52 MHz" />
                        <Parameter Id="virtual-parameter-sysclk_decimal" Value="52000000" />
                        <Parameter Id="virtual-parameter-sysclk_fin_num" Value="52000000" />
                        <Parameter Id="virtual-parameter-sysclk_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_sysclk_Fpfd" Value="104000000" />
                        <Parameter Id="virtual-parameter-wiz_sysclk_Fvco" Value="2392000000" />
                        <Parameter Id="virtual-parameter-REFA_Expression" Value="1" />
                        <Parameter Id="virtual-parameter-REFA" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-REFA_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refa_decimal" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fin_num" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refA_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refA_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refA_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refa_en" Value="true" />
                        <Parameter Id="virtual-parameter-refa_se" Value="true" />
                        <Parameter Id="virtual-parameter-refa_se_pd" Value="false" />
                        <Parameter Id="virtual-parameter-refa_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-REFAA_Expression" Value="1" />
                        <Parameter Id="virtual-parameter-REFAA" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-REFAA_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refaa_decimal" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fin_num" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refAA_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refAA_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refAA_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refaa_en" Value="true" />
                        <Parameter Id="virtual-parameter-refaa_se" Value="1" />
                        <Parameter Id="virtual-parameter-refaa_se_pd" Value="false" />
                        <Parameter Id="virtual-parameter-refaa_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-refa_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refa_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refa_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refaa_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refaa_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refaa_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refa_diff" Value="false" />
                        <Parameter Id="virtual-parameter-refa_diff_pd" Value="true" />
                        <Parameter Id="virtual-parameter-REFB_Expression" Value="156.25M" />
                        <Parameter Id="virtual-parameter-REFB" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-REFB_wiz" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-refb_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-refB_fin_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-refB_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refB_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refB_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refB_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refB_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refB_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refB_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refb_en" Value="true" />
                        <Parameter Id="virtual-parameter-refb_se" Value="false" />
                        <Parameter Id="virtual-parameter-refb_se_pd" Value="true" />
                        <Parameter Id="virtual-parameter-refb_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-REFBB_Expression" Value="25 MHz" />
                        <Parameter Id="virtual-parameter-REFBB" Value="25 MHz" />
                        <Parameter Id="virtual-parameter-REFBB_wiz" Value="25 MHz" />
                        <Parameter Id="virtual-parameter-refbb_decimal" Value="25000000" />
                        <Parameter Id="virtual-parameter-refBB_fin_num" Value="25000000" />
                        <Parameter Id="virtual-parameter-refBB_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refBB_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refBB_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refBB_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refBB_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refBB_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refBB_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refbb_en" Value="false" />
                        <Parameter Id="virtual-parameter-refbb_se" Value="1" />
                        <Parameter Id="virtual-parameter-refbb_se_pd" Value="true" />
                        <Parameter Id="virtual-parameter-refbb_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-refb_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refb_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refb_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refbb_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refbb_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refbb_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refb_diff" Value="true" />
                        <Parameter Id="virtual-parameter-refb_diff_pd" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_sel" Value="true" />
                        <Parameter Id="virtual-parameter-DPLL0p0 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p0 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p0OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p0 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p0_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p0_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p0_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p0_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p0_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p0_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p0_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p1_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p1 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p1 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p1OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p1 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p1_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p1_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p1_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p1_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p1_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p1_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p1_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p2_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p2 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p2 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p2OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p2 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p2_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p2_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p2_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p2_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p2_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p2_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p2_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p3_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p3 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p3 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p3OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p3 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p3_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p3_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p3_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p3_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p3_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p3_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p3_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p4_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p4 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p4 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p4OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p4 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p4_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p4_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p4_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p4_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p4_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p4_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p4_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p5_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p5 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p5 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p5OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p5 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p5_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p5_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p5_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p5_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p5_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p5_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p5_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0_mod_count" Value="156250000" />
                        <Parameter Id="virtual-parameter-DPLL0 Profile Selection" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0 Manual Profile" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_auto_profile_bar" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_profile_en" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_profile_active" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_total_ndiv" Value="4001" />
                        <Parameter Id="virtual-parameter-DPLL0 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0 Reference Source" Value="2" />
                        <Parameter Id="virtual-parameter-dpll0_src0_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src1_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src2_selected" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_src3_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src4_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src5_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src6_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src7_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src8_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src9_selected" Value="false" />
                        <Parameter Id="virtual-parameter-nco0_div" Value="7.6544" />
                        <Parameter Id="virtual-parameter-dpll0_ext_zd" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_ext_zd_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_buildout_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_hitless" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_hitless_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_operating_mode" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_profile_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_tag_mode" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_fb_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_ref_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_fb_untagged" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_is_hitless" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_is_buildout" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_is_internal" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_is_external" Value="false" />
                        <Parameter Id="virtual-parameter-out0A_mod_fout" Value="1" />
                        <Parameter Id="virtual-parameter-out0A_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out0A_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out0a_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0a_expression" Value="156.25*(1/1) MHz" />
                        <Parameter Id="virtual-parameter-out0A_gui" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-OUT0A" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-out0A_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0A_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0A_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0A_en" Value="true" />
                        <Parameter Id="virtual-parameter-out0A_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 0A Total Divide" Value="8" />
                        <Parameter Id="virtual-parameter-out0a_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0A_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0A_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0A_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0A_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out0A_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 0A_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0B_mod_fout" Value="1" />
                        <Parameter Id="virtual-parameter-out0B_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out0B_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out0b_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0b_expression" Value="156.25*(8/10) MHz" />
                        <Parameter Id="virtual-parameter-out0B_gui" Value="125 MHz" />
                        <Parameter Id="virtual-parameter-OUT0B" Value="125 MHz" />
                        <Parameter Id="virtual-parameter-out0B_decimal" Value="125000000" />
                        <Parameter Id="virtual-parameter-out0B_num" Value="125000000" />
                        <Parameter Id="virtual-parameter-out0B_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0B_en" Value="true" />
                        <Parameter Id="virtual-parameter-out0B_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 0B Total Divide" Value="10" />
                        <Parameter Id="virtual-parameter-out0b_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0B_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0B_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0B_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0B_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out0B_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 0B_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0C_mod_fout" Value="0" />
                        <Parameter Id="virtual-parameter-out0C_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out0C_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out0c_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0c_expression" Value="156.25*(1/1) MHz" />
                        <Parameter Id="virtual-parameter-out0C_gui" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-OUT0C" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-out0C_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0C_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0C_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0C_en" Value="true" />
                        <Parameter Id="virtual-parameter-out0C_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 0C Total Divide" Value="8" />
                        <Parameter Id="virtual-parameter-out0c_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0C_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0C_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0C_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0C_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out0C_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 0C_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-dpll1p0_sel" Value="true" />
                        <Parameter Id="virtual-parameter-DPLL1p0 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p0 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p0OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p0 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p0_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p0_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p0_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p0_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p0_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p0_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p0_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p1_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p1 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p1 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p1OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p1 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p1_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p1_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p1_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p1_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p1_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p1_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p1_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p2_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p2 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p2 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p2OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p2 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p2_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p2_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p2_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p2_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p2_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p2_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p2_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p3_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p3 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p3 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p3OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p3 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p3_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p3_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p3_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p3_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p3_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p3_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p3_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p4_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p4 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p4 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p4OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p4 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p4_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p4_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p4_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p4_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p4_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p4_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p4_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p5_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p5 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p5 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p5OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p5 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p5_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p5_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p5_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p5_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p5_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p5_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p5_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1_mod_count" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1 Profile Selection" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1 Manual Profile" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_auto_profile_bar" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_profile_en" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_profile_active" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_total_ndiv" Value="4001" />
                        <Parameter Id="virtual-parameter-DPLL1 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_src0_selected" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_src1_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src2_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src3_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src4_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src5_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src6_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src7_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src8_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src9_selected" Value="false" />
                        <Parameter Id="virtual-parameter-nco1_div" Value="7.4009901" />
                        <Parameter Id="virtual-parameter-dpll1_ext_zd" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_ext_zd_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_buildout_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_hitless" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_hitless_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_operating_mode" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_profile_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_tag_mode" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_fb_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_ref_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_fb_untagged" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_is_hitless" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_is_buildout" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_is_internal" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_is_external" Value="false" />
                        <Parameter Id="virtual-parameter-out1A_mod_fout" Value="0" />
                        <Parameter Id="virtual-parameter-out1A_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out1A_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out1a_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1a_expression" Value="1" />
                        <Parameter Id="virtual-parameter-out1A_gui" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-OUT1A" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1A_decimal" Value="1" />
                        <Parameter Id="virtual-parameter-out1A_num" Value="1" />
                        <Parameter Id="virtual-parameter-out1A_den" Value="1" />
                        <Parameter Id="virtual-parameter-out1A_en" Value="true" />
                        <Parameter Id="virtual-parameter-out1A_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 1A Total Divide" Value="1616000000" />
                        <Parameter Id="virtual-parameter-out1a_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1A_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1A_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1A_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1A_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out1A_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 1A_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_mod_fout" Value="0.125" />
                        <Parameter Id="virtual-parameter-out1B_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out1B_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out1b_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1b_expression" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_gui" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-OUT1B" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1B_decimal" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_num" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_den" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_en" Value="true" />
                        <Parameter Id="virtual-parameter-out1B_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 1B Total Divide" Value="1616000000" />
                        <Parameter Id="virtual-parameter-out1b_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1B_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1B_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1B_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1B_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 1B_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-M0_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M0_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M0_auxtdc0_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M0_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M0_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M1_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M2_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M3_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M4_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M5_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M6_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-internal_temperature" Value="0" />
                        <Parameter Id="virtual-parameter-external_temperature" Value="0" />
                        <Parameter Id="virtual-parameter-aux_dpll_enable" Value="false" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_input" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_wiz" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_num" Value="0" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_nco0_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-wiz_nco0_Fin" Value="2392000000" />
                        <Parameter Id="virtual-parameter-wiz_nco0_Fout" Value="312500000" />
                        <Parameter Id="virtual-parameter-wiz_nco1_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-wiz_nco1_Fin" Value="2392000000" />
                        <Parameter Id="virtual-parameter-wiz_nco1_Fout" Value="323200000" />
                        <Parameter Id="virtual-parameter-wiz_dpll0_enable" Value="false" />
                        <Parameter Id="virtual-parameter-wiz_dpll0_fout" Value="312.5" />
                        <Parameter Id="virtual-parameter-wiz_dpll1_enable" Value="false" />
                        <Parameter Id="virtual-parameter-wiz_dpll1_fout" Value="323.2" />
                        <Parameter Id="virtual-parameter-ExtWizParamsVisible" Value="false" />
                        <Parameter Id="virtual-parameter-dist0_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dist1_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-mpins_button" Value="true" />
                        <Parameter Id="virtual-parameter-temp_sensor_button" Value="true" />
                        <Parameter Id="virtual-parameter-aux_tdcs_button" Value="true" />
                        <Parameter Id="virtual-parameter-user_ts_button" Value="true" />
                        <Parameter Id="virtual-parameter-idTest" Value="1" />
                        <Parameter Id="virtual-parameter-Hidden" Value="false" />
                        <Parameter Id="virtual-parameter-sessionVersion" Value="1.1.8.0" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Fundamental" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_carrier_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Fundamental Wizard" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-AuxNCO0_Fundamental_Express" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-auxnco0_center" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_offset" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_pulse_width_input" Value="40 ns" />
                        <Parameter Id="virtual-parameter-auxnco0_pulse_width_display" Value="0 s" />
                        <Parameter Id="virtual-parameter-auxnco0_tag_rate_expression_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_tag_rate_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_tags_enable_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Tag Rate" Value="0" />
                        <Parameter Id="virtual-parameter-auxnco0_tags_wiz_visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Tag Rate Visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 phase type" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 inverted phase type" Value="true" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Enable" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Fundamental" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_carrier_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Fundamental Wizard" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-AuxNCO1_Fundamental_Express" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-auxnco1_center" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_offset" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_pulse_width_input" Value="40 ns" />
                        <Parameter Id="virtual-parameter-auxnco1_pulse_width_display" Value="0 s" />
                        <Parameter Id="virtual-parameter-auxnco1_tag_rate_expression_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_tag_rate_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_tags_enable_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Tag Rate" Value="0" />
                        <Parameter Id="virtual-parameter-auxnco1_tags_wiz_visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Tag Rate Visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 phase type" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 inverted phase type" Value="true" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Enable" Value="false" />
                        <Parameter Id="virtual-parameter-auxtdc0_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_exp" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_evaled" Value="10000000 / 1" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_wiz" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_value" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_num" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_exp" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_evaled" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_wiz" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_value" Value="0.0000001" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_num" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_den" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc0_display_string" Value=" M0" />
                        <Parameter Id="virtual-parameter-auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_exp" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_evaled" Value="10000000 / 1" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_wiz" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_value" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_num" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_exp" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_evaled" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_wiz" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_value" Value="0.0000001" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_num" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_den" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc1_display_string" Value="None" />
                        <Parameter Id="virtual-parameter-auxtdc_ping_pong_display_string" Value="None" />
                        <RegisterMap UniqueId="0.serial_port" Address="0" Count="10">
                          <Register Address="0" Value="24" />
                          <Register Address="1" Value="0" />
                          <Register Address="3" Value="5" />
                          <Register Address="4" Value="21" />
                          <Register Address="5" Value="1" />
                          <Register Address="6" Value="2" />
                          <Register Address="B" Value="0" />
                          <Register Address="C" Value="56" />
                          <Register Address="D" Value="4" />
                          <Register Address="F" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="10.serial_port_extensions" Address="10" Count="1">
                          <Register Address="10" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="20.scratchpad" Address="20" Count="4">
                          <Register Address="20" Value="0" />
                          <Register Address="21" Value="0" />
                          <Register Address="22" Value="0" />
                          <Register Address="23" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="100.mpin_status_control" Address="100" Count="12">
                          <Register Address="100" Value="0" />
                          <Register Address="101" Value="0" />
                          <Register Address="102" Value="30" />
                          <Register Address="103" Value="0" />
                          <Register Address="104" Value="0" />
                          <Register Address="105" Value="0" />
                          <Register Address="106" Value="0" />
                          <Register Address="107" Value="0" />
                          <Register Address="108" Value="0" />
                          <Register Address="109" Value="0" />
                          <Register Address="10A" Value="0" />
                          <Register Address="10B" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="10C.irq_common_mask" Address="10C" Count="5">
                          <Register Address="10C" Value="0" />
                          <Register Address="10D" Value="0" />
                          <Register Address="10E" Value="0" />
                          <Register Address="10F" Value="0" />
                          <Register Address="110" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="111.irq_pll_0_mask" Address="111" Count="5">
                          <Register Address="111" Value="0" />
                          <Register Address="112" Value="0" />
                          <Register Address="113" Value="0" />
                          <Register Address="114" Value="0" />
                          <Register Address="115" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="116.irq_pll_1_mask" Address="116" Count="5">
                          <Register Address="116" Value="0" />
                          <Register Address="117" Value="0" />
                          <Register Address="118" Value="0" />
                          <Register Address="119" Value="0" />
                          <Register Address="11A" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="200.system_clock" Address="200" Count="10">
                          <Register Address="200" Value="17" />
                          <Register Address="201" Value="09" />
                          <Register Address="202" Value="0" />
                          <Register Address="203" Value="08" />
                          <Register Address="204" Value="71" />
                          <Register Address="205" Value="1B" />
                          <Register Address="206" Value="0C" />
                          <Register Address="207" Value="32" />
                          <Register Address="208" Value="0" />
                          <Register Address="209" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="280.system_clock_comp" Address="280" Count="29">
                          <Register Address="280" Value="0" />
                          <Register Address="281" Value="0" />
                          <Register Address="282" Value="0" />
                          <Register Address="283" Value="0" />
                          <Register Address="284" Value="0" />
                          <Register Address="285" Value="0" />
                          <Register Address="286" Value="0" />
                          <Register Address="287" Value="0" />
                          <Register Address="288" Value="0" />
                          <Register Address="289" Value="0" />
                          <Register Address="28A" Value="0" />
                          <Register Address="28B" Value="0" />
                          <Register Address="28C" Value="0" />
                          <Register Address="28D" Value="0" />
                          <Register Address="28E" Value="0" />
                          <Register Address="28F" Value="0" />
                          <Register Address="290" Value="0" />
                          <Register Address="291" Value="0" />
                          <Register Address="292" Value="0" />
                          <Register Address="293" Value="0" />
                          <Register Address="294" Value="0" />
                          <Register Address="295" Value="0" />
                          <Register Address="296" Value="0" />
                          <Register Address="297" Value="0" />
                          <Register Address="298" Value="0" />
                          <Register Address="299" Value="0" />
                          <Register Address="29A" Value="0" />
                          <Register Address="29B" Value="0" />
                          <Register Address="29C" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="300.reference_general_a" Address="300" Count="4">
                          <Register Address="300" Value="0A0" />
                          <Register Address="301" Value="1" />
                          <Register Address="302" Value="40" />
                          <Register Address="303" Value="40" />
                        </RegisterMap>
                        <RegisterMap UniqueId="304.reference_general_b" Address="304" Count="4">
                          <Register Address="304" Value="1" />
                          <Register Address="305" Value="1" />
                          <Register Address="306" Value="40" />
                          <Register Address="307" Value="40" />
                        </RegisterMap>
                        <RegisterMap UniqueId="400.reference_input_a" Address="400" Count="21">
                          <Register Address="400" Value="0" />
                          <Register Address="401" Value="0" />
                          <Register Address="402" Value="0" />
                          <Register Address="403" Value="0" />
                          <Register Address="404" Value="0" />
                          <Register Address="405" Value="0" />
                          <Register Address="406" Value="64" />
                          <Register Address="407" Value="0A7" />
                          <Register Address="408" Value="0B3" />
                          <Register Address="409" Value="0B6" />
                          <Register Address="40A" Value="0E0" />
                          <Register Address="40B" Value="0D" />
                          <Register Address="40C" Value="0A0" />
                          <Register Address="40D" Value="086" />
                          <Register Address="40E" Value="1" />
                          <Register Address="40F" Value="3" />
                          <Register Address="410" Value="0A" />
                          <Register Address="411" Value="0" />
                          <Register Address="412" Value="0" />
                          <Register Address="413" Value="0" />
                          <Register Address="414" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="420.reference_input_aa" Address="420" Count="21">
                          <Register Address="420" Value="0" />
                          <Register Address="421" Value="0" />
                          <Register Address="422" Value="0" />
                          <Register Address="423" Value="0" />
                          <Register Address="424" Value="0" />
                          <Register Address="425" Value="0" />
                          <Register Address="426" Value="64" />
                          <Register Address="427" Value="0A7" />
                          <Register Address="428" Value="0B3" />
                          <Register Address="429" Value="0B6" />
                          <Register Address="42A" Value="0E0" />
                          <Register Address="42B" Value="0D" />
                          <Register Address="42C" Value="0A0" />
                          <Register Address="42D" Value="086" />
                          <Register Address="42E" Value="1" />
                          <Register Address="42F" Value="3" />
                          <Register Address="430" Value="0A" />
                          <Register Address="431" Value="0" />
                          <Register Address="432" Value="0" />
                          <Register Address="433" Value="0" />
                          <Register Address="434" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="440.reference_input_b" Address="440" Count="21">
                          <Register Address="440" Value="0D" />
                          <Register Address="441" Value="3" />
                          <Register Address="442" Value="0" />
                          <Register Address="443" Value="0" />
                          <Register Address="444" Value="0" />
                          <Register Address="445" Value="40" />
                          <Register Address="446" Value="78" />
                          <Register Address="447" Value="7D" />
                          <Register Address="448" Value="1" />
                          <Register Address="449" Value="0" />
                          <Register Address="44A" Value="0" />
                          <Register Address="44B" Value="0" />
                          <Register Address="44C" Value="0A0" />
                          <Register Address="44D" Value="086" />
                          <Register Address="44E" Value="1" />
                          <Register Address="44F" Value="3" />
                          <Register Address="450" Value="0A" />
                          <Register Address="451" Value="0" />
                          <Register Address="452" Value="0" />
                          <Register Address="453" Value="0" />
                          <Register Address="454" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="460.reference_input_bb" Address="460" Count="21">
                          <Register Address="460" Value="7C" />
                          <Register Address="461" Value="0" />
                          <Register Address="462" Value="0" />
                          <Register Address="463" Value="0" />
                          <Register Address="464" Value="0" />
                          <Register Address="465" Value="090" />
                          <Register Address="466" Value="2F" />
                          <Register Address="467" Value="50" />
                          <Register Address="468" Value="09" />
                          <Register Address="469" Value="0" />
                          <Register Address="46A" Value="0" />
                          <Register Address="46B" Value="0" />
                          <Register Address="46C" Value="0A0" />
                          <Register Address="46D" Value="086" />
                          <Register Address="46E" Value="1" />
                          <Register Address="46F" Value="3" />
                          <Register Address="470" Value="0A" />
                          <Register Address="471" Value="0" />
                          <Register Address="472" Value="0" />
                          <Register Address="473" Value="0" />
                          <Register Address="474" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="800.source_profile_0_a" Address="800" Count="18">
                          <Register Address="800" Value="0BC" />
                          <Register Address="801" Value="2" />
                          <Register Address="802" Value="0" />
                          <Register Address="803" Value="0A" />
                          <Register Address="804" Value="0A" />
                          <Register Address="805" Value="0BC" />
                          <Register Address="806" Value="2" />
                          <Register Address="807" Value="0" />
                          <Register Address="808" Value="0A" />
                          <Register Address="809" Value="0A" />
                          <Register Address="80A" Value="0" />
                          <Register Address="80B" Value="0" />
                          <Register Address="80C" Value="0" />
                          <Register Address="80D" Value="0" />
                          <Register Address="80E" Value="0" />
                          <Register Address="80F" Value="0" />
                          <Register Address="810" Value="0" />
                          <Register Address="811" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="820.source_profile_1_aa" Address="820" Count="18">
                          <Register Address="820" Value="0BC" />
                          <Register Address="821" Value="2" />
                          <Register Address="822" Value="0" />
                          <Register Address="823" Value="0A" />
                          <Register Address="824" Value="0A" />
                          <Register Address="825" Value="0BC" />
                          <Register Address="826" Value="2" />
                          <Register Address="827" Value="0" />
                          <Register Address="828" Value="0A" />
                          <Register Address="829" Value="0A" />
                          <Register Address="82A" Value="0" />
                          <Register Address="82B" Value="0" />
                          <Register Address="82C" Value="0" />
                          <Register Address="82D" Value="0" />
                          <Register Address="82E" Value="0" />
                          <Register Address="82F" Value="0" />
                          <Register Address="830" Value="0" />
                          <Register Address="831" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="840.source_profile_2_b" Address="840" Count="18">
                          <Register Address="840" Value="0BC" />
                          <Register Address="841" Value="2" />
                          <Register Address="842" Value="0" />
                          <Register Address="843" Value="0A" />
                          <Register Address="844" Value="0A" />
                          <Register Address="845" Value="0BC" />
                          <Register Address="846" Value="2" />
                          <Register Address="847" Value="0" />
                          <Register Address="848" Value="0A" />
                          <Register Address="849" Value="0A" />
                          <Register Address="84A" Value="0" />
                          <Register Address="84B" Value="0" />
                          <Register Address="84C" Value="0" />
                          <Register Address="84D" Value="0" />
                          <Register Address="84E" Value="0" />
                          <Register Address="84F" Value="0" />
                          <Register Address="850" Value="0" />
                          <Register Address="851" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="860.source_profile_3_bb" Address="860" Count="18">
                          <Register Address="860" Value="0BC" />
                          <Register Address="861" Value="2" />
                          <Register Address="862" Value="0" />
                          <Register Address="863" Value="0A" />
                          <Register Address="864" Value="0A" />
                          <Register Address="865" Value="0BC" />
                          <Register Address="866" Value="2" />
                          <Register Address="867" Value="0" />
                          <Register Address="868" Value="0A" />
                          <Register Address="869" Value="0A" />
                          <Register Address="86A" Value="0" />
                          <Register Address="86B" Value="0" />
                          <Register Address="86C" Value="0" />
                          <Register Address="86D" Value="0" />
                          <Register Address="86E" Value="0" />
                          <Register Address="86F" Value="0" />
                          <Register Address="870" Value="0" />
                          <Register Address="871" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="880.source_profile_4_auxnco_0" Address="880" Count="18">
                          <Register Address="880" Value="0BC" />
                          <Register Address="881" Value="2" />
                          <Register Address="882" Value="0" />
                          <Register Address="883" Value="0A" />
                          <Register Address="884" Value="0A" />
                          <Register Address="885" Value="0BC" />
                          <Register Address="886" Value="2" />
                          <Register Address="887" Value="0" />
                          <Register Address="888" Value="0A" />
                          <Register Address="889" Value="0A" />
                          <Register Address="88A" Value="0" />
                          <Register Address="88B" Value="0" />
                          <Register Address="88C" Value="0" />
                          <Register Address="88D" Value="0" />
                          <Register Address="88E" Value="0" />
                          <Register Address="88F" Value="0" />
                          <Register Address="890" Value="0" />
                          <Register Address="891" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="8A0.source_profile_5_auxnco_1" Address="8A0" Count="18">
                          <Register Address="8A0" Value="0BC" />
                          <Register Address="8A1" Value="2" />
                          <Register Address="8A2" Value="0" />
                          <Register Address="8A3" Value="0A" />
                          <Register Address="8A4" Value="0A" />
                          <Register Address="8A5" Value="0BC" />
                          <Register Address="8A6" Value="2" />
                          <Register Address="8A7" Value="0" />
                          <Register Address="8A8" Value="0A" />
                          <Register Address="8A9" Value="0A" />
                          <Register Address="8AA" Value="0" />
                          <Register Address="8AB" Value="0" />
                          <Register Address="8AC" Value="0" />
                          <Register Address="8AD" Value="0" />
                          <Register Address="8AE" Value="0" />
                          <Register Address="8AF" Value="0" />
                          <Register Address="8B0" Value="0" />
                          <Register Address="8B1" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="8C0.source_profile_6_dpll_0" Address="8C0" Count="18">
                          <Register Address="8C0" Value="0BC" />
                          <Register Address="8C1" Value="2" />
                          <Register Address="8C2" Value="0" />
                          <Register Address="8C3" Value="0A" />
                          <Register Address="8C4" Value="0A" />
                          <Register Address="8C5" Value="0BC" />
                          <Register Address="8C6" Value="2" />
                          <Register Address="8C7" Value="0" />
                          <Register Address="8C8" Value="0A" />
                          <Register Address="8C9" Value="0A" />
                          <Register Address="8CA" Value="0" />
                          <Register Address="8CB" Value="0" />
                          <Register Address="8CC" Value="0" />
                          <Register Address="8CD" Value="0" />
                          <Register Address="8CE" Value="0" />
                          <Register Address="8CF" Value="0" />
                          <Register Address="8D0" Value="0" />
                          <Register Address="8D1" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="8E0.source_profile_7_dpll_1" Address="8E0" Count="18">
                          <Register Address="8E0" Value="0BC" />
                          <Register Address="8E1" Value="2" />
                          <Register Address="8E2" Value="0" />
                          <Register Address="8E3" Value="0A" />
                          <Register Address="8E4" Value="0A" />
                          <Register Address="8E5" Value="0BC" />
                          <Register Address="8E6" Value="2" />
                          <Register Address="8E7" Value="0" />
                          <Register Address="8E8" Value="0A" />
                          <Register Address="8E9" Value="0A" />
                          <Register Address="8EA" Value="0" />
                          <Register Address="8EB" Value="0" />
                          <Register Address="8EC" Value="0" />
                          <Register Address="8ED" Value="0" />
                          <Register Address="8EE" Value="0" />
                          <Register Address="8EF" Value="0" />
                          <Register Address="8F0" Value="0" />
                          <Register Address="8F1" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="C00.lf_coefficients_0" Address="C00" Count="12">
                          <Register Address="C00" Value="0C2" />
                          <Register Address="C01" Value="0F0" />
                          <Register Address="C02" Value="0B3" />
                          <Register Address="C03" Value="55" />
                          <Register Address="C04" Value="0C9" />
                          <Register Address="C05" Value="0FB" />
                          <Register Address="C06" Value="5C" />
                          <Register Address="C07" Value="0F6" />
                          <Register Address="C08" Value="0CA" />
                          <Register Address="C09" Value="11" />
                          <Register Address="C0A" Value="0DF" />
                          <Register Address="C0B" Value="0CC" />
                        </RegisterMap>
                        <RegisterMap UniqueId="C0C.lf_coefficients_1" Address="C0C" Count="12">
                          <Register Address="C0C" Value="0A9" />
                          <Register Address="C0D" Value="0A0" />
                          <Register Address="C0E" Value="0B7" />
                          <Register Address="C0F" Value="0CD" />
                          <Register Address="C10" Value="0DB" />
                          <Register Address="C11" Value="0F3" />
                          <Register Address="C12" Value="79" />
                          <Register Address="C13" Value="0D4" />
                          <Register Address="C14" Value="0CE" />
                          <Register Address="C15" Value="4D" />
                          <Register Address="C16" Value="0A7" />
                          <Register Address="C17" Value="0CF" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1000.dpll_0" Address="1000" Count="43">
                          <Register Address="1000" Value="092" />
                          <Register Address="1001" Value="2" />
                          <Register Address="1002" Value="77" />
                          <Register Address="1003" Value="0DF" />
                          <Register Address="1004" Value="71" />
                          <Register Address="1005" Value="21" />
                          <Register Address="1006" Value="0FF" />
                          <Register Address="1007" Value="0FF" />
                          <Register Address="1008" Value="0FF" />
                          <Register Address="1009" Value="0" />
                          <Register Address="100A" Value="0A" />
                          <Register Address="100B" Value="0" />
                          <Register Address="100C" Value="0" />
                          <Register Address="100D" Value="0" />
                          <Register Address="100E" Value="38" />
                          <Register Address="100F" Value="0" />
                          <Register Address="1010" Value="0" />
                          <Register Address="1011" Value="0" />
                          <Register Address="1012" Value="0" />
                          <Register Address="1013" Value="0" />
                          <Register Address="1014" Value="6" />
                          <Register Address="1015" Value="0" />
                          <Register Address="1016" Value="0" />
                          <Register Address="1017" Value="0" />
                          <Register Address="1018" Value="0" />
                          <Register Address="1019" Value="0" />
                          <Register Address="101A" Value="0" />
                          <Register Address="101B" Value="0" />
                          <Register Address="101C" Value="0" />
                          <Register Address="101D" Value="0" />
                          <Register Address="101E" Value="0" />
                          <Register Address="101F" Value="0" />
                          <Register Address="1020" Value="0" />
                          <Register Address="1021" Value="0" />
                          <Register Address="1022" Value="0" />
                          <Register Address="1023" Value="0" />
                          <Register Address="1024" Value="0" />
                          <Register Address="1025" Value="0" />
                          <Register Address="1026" Value="0" />
                          <Register Address="1027" Value="0" />
                          <Register Address="1028" Value="0" />
                          <Register Address="102A" Value="0" />
                          <Register Address="102B" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1080.apll_0" Address="1080" Count="4">
                          <Register Address="1080" Value="094" />
                          <Register Address="1081" Value="08" />
                          <Register Address="1082" Value="0E0" />
                          <Register Address="1083" Value="3" />
                        </RegisterMap>
                        <RegisterMap UniqueId="10C0.dist_0_general_0" Address="10C0" Count="29">
                          <Register Address="10C0" Value="0" />
                          <Register Address="10C1" Value="0" />
                          <Register Address="10C2" Value="090" />
                          <Register Address="10C3" Value="2F" />
                          <Register Address="10C4" Value="50" />
                          <Register Address="10C5" Value="09" />
                          <Register Address="10C6" Value="40" />
                          <Register Address="10C7" Value="59" />
                          <Register Address="10C8" Value="73" />
                          <Register Address="10C9" Value="7" />
                          <Register Address="10CA" Value="0" />
                          <Register Address="10CB" Value="0" />
                          <Register Address="10CC" Value="0" />
                          <Register Address="10CD" Value="0" />
                          <Register Address="10CE" Value="0" />
                          <Register Address="10CF" Value="0" />
                          <Register Address="10D0" Value="0" />
                          <Register Address="10D1" Value="0" />
                          <Register Address="10D2" Value="0" />
                          <Register Address="10D3" Value="0" />
                          <Register Address="10D4" Value="0" />
                          <Register Address="10D5" Value="0" />
                          <Register Address="10D6" Value="0" />
                          <Register Address="10D7" Value="5" />
                          <Register Address="10D8" Value="0D" />
                          <Register Address="10D9" Value="5" />
                          <Register Address="10DA" Value="0" />
                          <Register Address="10DB" Value="0" />
                          <Register Address="10DC" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1100.distribution_divider_0_a" Address="1100" Count="9">
                          <Register Address="1100" Value="08" />
                          <Register Address="1101" Value="0" />
                          <Register Address="1102" Value="0" />
                          <Register Address="1103" Value="0" />
                          <Register Address="1104" Value="0" />
                          <Register Address="1105" Value="0" />
                          <Register Address="1106" Value="0" />
                          <Register Address="1107" Value="0" />
                          <Register Address="1108" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1109.distribution_divider_0_aa" Address="1109" Count="9">
                          <Register Address="1109" Value="0" />
                          <Register Address="110A" Value="0" />
                          <Register Address="110B" Value="0" />
                          <Register Address="110C" Value="0" />
                          <Register Address="110D" Value="0" />
                          <Register Address="110E" Value="0" />
                          <Register Address="110F" Value="0" />
                          <Register Address="1110" Value="0" />
                          <Register Address="1111" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1112.distribution_divider_0_b" Address="1112" Count="9">
                          <Register Address="1112" Value="0A" />
                          <Register Address="1113" Value="0" />
                          <Register Address="1114" Value="0" />
                          <Register Address="1115" Value="0" />
                          <Register Address="1116" Value="0" />
                          <Register Address="1117" Value="0" />
                          <Register Address="1118" Value="0" />
                          <Register Address="1119" Value="0" />
                          <Register Address="111A" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="111B.distribution_divider_0_bb" Address="111B" Count="9">
                          <Register Address="111B" Value="0" />
                          <Register Address="111C" Value="0" />
                          <Register Address="111D" Value="0" />
                          <Register Address="111E" Value="0" />
                          <Register Address="111F" Value="0" />
                          <Register Address="1120" Value="0" />
                          <Register Address="1121" Value="0" />
                          <Register Address="1122" Value="0" />
                          <Register Address="1123" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1124.distribution_divider_0_c" Address="1124" Count="9">
                          <Register Address="1124" Value="08" />
                          <Register Address="1125" Value="0" />
                          <Register Address="1126" Value="0" />
                          <Register Address="1127" Value="0" />
                          <Register Address="1128" Value="0" />
                          <Register Address="1129" Value="0" />
                          <Register Address="112A" Value="0" />
                          <Register Address="112B" Value="0" />
                          <Register Address="112C" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="112D.distribution_divider_0_cc" Address="112D" Count="9">
                          <Register Address="112D" Value="0" />
                          <Register Address="112E" Value="0" />
                          <Register Address="112F" Value="0" />
                          <Register Address="1130" Value="0" />
                          <Register Address="1131" Value="0" />
                          <Register Address="1132" Value="0" />
                          <Register Address="1133" Value="0" />
                          <Register Address="1134" Value="0" />
                          <Register Address="1135" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1200.translation_profile_0_0" Address="1200" Count="24">
                          <Register Address="1200" Value="0" />
                          <Register Address="1201" Value="2" />
                          <Register Address="1202" Value="0" />
                          <Register Address="1203" Value="0" />
                          <Register Address="1204" Value="0" />
                          <Register Address="1205" Value="0" />
                          <Register Address="1206" Value="0" />
                          <Register Address="1207" Value="0" />
                          <Register Address="1208" Value="0A0" />
                          <Register Address="1209" Value="0F" />
                          <Register Address="120A" Value="0" />
                          <Register Address="120B" Value="0" />
                          <Register Address="120C" Value="0A0" />
                          <Register Address="120D" Value="0F" />
                          <Register Address="120E" Value="0" />
                          <Register Address="120F" Value="0" />
                          <Register Address="1210" Value="0" />
                          <Register Address="1211" Value="0" />
                          <Register Address="1212" Value="0" />
                          <Register Address="1213" Value="0" />
                          <Register Address="1214" Value="0" />
                          <Register Address="1215" Value="0" />
                          <Register Address="1216" Value="0" />
                          <Register Address="1217" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1220.translation_profile_0_1" Address="1220" Count="24">
                          <Register Address="1220" Value="0" />
                          <Register Address="1221" Value="0" />
                          <Register Address="1222" Value="0" />
                          <Register Address="1223" Value="0" />
                          <Register Address="1224" Value="0" />
                          <Register Address="1225" Value="0" />
                          <Register Address="1226" Value="0" />
                          <Register Address="1227" Value="0" />
                          <Register Address="1228" Value="0A0" />
                          <Register Address="1229" Value="0F" />
                          <Register Address="122A" Value="0" />
                          <Register Address="122B" Value="0" />
                          <Register Address="122C" Value="0A0" />
                          <Register Address="122D" Value="0F" />
                          <Register Address="122E" Value="0" />
                          <Register Address="122F" Value="0" />
                          <Register Address="1230" Value="0" />
                          <Register Address="1231" Value="0" />
                          <Register Address="1232" Value="0" />
                          <Register Address="1233" Value="0" />
                          <Register Address="1234" Value="0" />
                          <Register Address="1235" Value="0" />
                          <Register Address="1236" Value="0" />
                          <Register Address="1237" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1240.translation_profile_0_2" Address="1240" Count="24">
                          <Register Address="1240" Value="0" />
                          <Register Address="1241" Value="0" />
                          <Register Address="1242" Value="0" />
                          <Register Address="1243" Value="0" />
                          <Register Address="1244" Value="0" />
                          <Register Address="1245" Value="0" />
                          <Register Address="1246" Value="0" />
                          <Register Address="1247" Value="0" />
                          <Register Address="1248" Value="0A0" />
                          <Register Address="1249" Value="0F" />
                          <Register Address="124A" Value="0" />
                          <Register Address="124B" Value="0" />
                          <Register Address="124C" Value="0A0" />
                          <Register Address="124D" Value="0F" />
                          <Register Address="124E" Value="0" />
                          <Register Address="124F" Value="0" />
                          <Register Address="1250" Value="0" />
                          <Register Address="1251" Value="0" />
                          <Register Address="1252" Value="0" />
                          <Register Address="1253" Value="0" />
                          <Register Address="1254" Value="0" />
                          <Register Address="1255" Value="0" />
                          <Register Address="1256" Value="0" />
                          <Register Address="1257" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1260.translation_profile_0_3" Address="1260" Count="24">
                          <Register Address="1260" Value="0" />
                          <Register Address="1261" Value="0" />
                          <Register Address="1262" Value="0" />
                          <Register Address="1263" Value="0" />
                          <Register Address="1264" Value="0" />
                          <Register Address="1265" Value="0" />
                          <Register Address="1266" Value="0" />
                          <Register Address="1267" Value="0" />
                          <Register Address="1268" Value="0A0" />
                          <Register Address="1269" Value="0F" />
                          <Register Address="126A" Value="0" />
                          <Register Address="126B" Value="0" />
                          <Register Address="126C" Value="0A0" />
                          <Register Address="126D" Value="0F" />
                          <Register Address="126E" Value="0" />
                          <Register Address="126F" Value="0" />
                          <Register Address="1270" Value="0" />
                          <Register Address="1271" Value="0" />
                          <Register Address="1272" Value="0" />
                          <Register Address="1273" Value="0" />
                          <Register Address="1274" Value="0" />
                          <Register Address="1275" Value="0" />
                          <Register Address="1276" Value="0" />
                          <Register Address="1277" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1280.translation_profile_0_4" Address="1280" Count="24">
                          <Register Address="1280" Value="0" />
                          <Register Address="1281" Value="0" />
                          <Register Address="1282" Value="0" />
                          <Register Address="1283" Value="0" />
                          <Register Address="1284" Value="0" />
                          <Register Address="1285" Value="0" />
                          <Register Address="1286" Value="0" />
                          <Register Address="1287" Value="0" />
                          <Register Address="1288" Value="0A0" />
                          <Register Address="1289" Value="0F" />
                          <Register Address="128A" Value="0" />
                          <Register Address="128B" Value="0" />
                          <Register Address="128C" Value="0A0" />
                          <Register Address="128D" Value="0F" />
                          <Register Address="128E" Value="0" />
                          <Register Address="128F" Value="0" />
                          <Register Address="1290" Value="0" />
                          <Register Address="1291" Value="0" />
                          <Register Address="1292" Value="0" />
                          <Register Address="1293" Value="0" />
                          <Register Address="1294" Value="0" />
                          <Register Address="1295" Value="0" />
                          <Register Address="1296" Value="0" />
                          <Register Address="1297" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="12A0.translation_profile_0_5" Address="12A0" Count="24">
                          <Register Address="12A0" Value="0" />
                          <Register Address="12A1" Value="0" />
                          <Register Address="12A2" Value="0" />
                          <Register Address="12A3" Value="0" />
                          <Register Address="12A4" Value="0" />
                          <Register Address="12A5" Value="0" />
                          <Register Address="12A6" Value="0" />
                          <Register Address="12A7" Value="0" />
                          <Register Address="12A8" Value="0A0" />
                          <Register Address="12A9" Value="0F" />
                          <Register Address="12AA" Value="0" />
                          <Register Address="12AB" Value="0" />
                          <Register Address="12AC" Value="0A0" />
                          <Register Address="12AD" Value="0F" />
                          <Register Address="12AE" Value="0" />
                          <Register Address="12AF" Value="0" />
                          <Register Address="12B0" Value="0" />
                          <Register Address="12B1" Value="0" />
                          <Register Address="12B2" Value="0" />
                          <Register Address="12B3" Value="0" />
                          <Register Address="12B4" Value="0" />
                          <Register Address="12B5" Value="0" />
                          <Register Address="12B6" Value="0" />
                          <Register Address="12B7" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1400.dpll_1" Address="1400" Count="43">
                          <Register Address="1400" Value="40" />
                          <Register Address="1401" Value="54" />
                          <Register Address="1402" Value="0C" />
                          <Register Address="1403" Value="08" />
                          <Register Address="1404" Value="097" />
                          <Register Address="1405" Value="22" />
                          <Register Address="1406" Value="0FF" />
                          <Register Address="1407" Value="0FF" />
                          <Register Address="1408" Value="0FF" />
                          <Register Address="1409" Value="0" />
                          <Register Address="140A" Value="0A" />
                          <Register Address="140B" Value="0" />
                          <Register Address="140C" Value="0" />
                          <Register Address="140D" Value="0" />
                          <Register Address="140E" Value="38" />
                          <Register Address="140F" Value="0" />
                          <Register Address="1410" Value="0" />
                          <Register Address="1411" Value="0" />
                          <Register Address="1412" Value="0" />
                          <Register Address="1413" Value="0" />
                          <Register Address="1414" Value="6" />
                          <Register Address="1415" Value="0" />
                          <Register Address="1416" Value="0" />
                          <Register Address="1417" Value="0" />
                          <Register Address="1418" Value="0" />
                          <Register Address="1419" Value="0" />
                          <Register Address="141A" Value="0" />
                          <Register Address="141B" Value="0" />
                          <Register Address="141C" Value="0" />
                          <Register Address="141D" Value="0" />
                          <Register Address="141E" Value="0" />
                          <Register Address="141F" Value="0" />
                          <Register Address="1420" Value="0" />
                          <Register Address="1421" Value="0" />
                          <Register Address="1422" Value="0" />
                          <Register Address="1423" Value="0" />
                          <Register Address="1424" Value="0" />
                          <Register Address="1425" Value="0" />
                          <Register Address="1426" Value="0" />
                          <Register Address="1427" Value="0" />
                          <Register Address="1428" Value="0" />
                          <Register Address="142A" Value="0" />
                          <Register Address="142B" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1480.apll_1" Address="1480" Count="4">
                          <Register Address="1480" Value="090" />
                          <Register Address="1481" Value="0A" />
                          <Register Address="1482" Value="0E0" />
                          <Register Address="1483" Value="3" />
                        </RegisterMap>
                        <RegisterMap UniqueId="14C0.dist_1_general_1" Address="14C0" Count="22">
                          <Register Address="14C0" Value="0" />
                          <Register Address="14C1" Value="0" />
                          <Register Address="14C2" Value="0" />
                          <Register Address="14C3" Value="0" />
                          <Register Address="14C4" Value="0" />
                          <Register Address="14C5" Value="0" />
                          <Register Address="14C6" Value="08" />
                          <Register Address="14C7" Value="0" />
                          <Register Address="14C8" Value="0" />
                          <Register Address="14C9" Value="0" />
                          <Register Address="14CE" Value="0" />
                          <Register Address="14CF" Value="0" />
                          <Register Address="14D0" Value="0" />
                          <Register Address="14D2" Value="0" />
                          <Register Address="14D3" Value="0" />
                          <Register Address="14D4" Value="0" />
                          <Register Address="14D6" Value="0" />
                          <Register Address="14D7" Value="15" />
                          <Register Address="14D8" Value="0D" />
                          <Register Address="14DA" Value="0" />
                          <Register Address="14DB" Value="0" />
                          <Register Address="14DC" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1500.distribution_divider_1_a" Address="1500" Count="9">
                          <Register Address="1500" Value="0" />
                          <Register Address="1501" Value="34" />
                          <Register Address="1502" Value="52" />
                          <Register Address="1503" Value="60" />
                          <Register Address="1504" Value="0" />
                          <Register Address="1505" Value="0" />
                          <Register Address="1506" Value="0" />
                          <Register Address="1507" Value="0" />
                          <Register Address="1508" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1509.distribution_divider_1_aa" Address="1509" Count="9">
                          <Register Address="1509" Value="0" />
                          <Register Address="150A" Value="0" />
                          <Register Address="150B" Value="0" />
                          <Register Address="150C" Value="0" />
                          <Register Address="150D" Value="0" />
                          <Register Address="150E" Value="0" />
                          <Register Address="150F" Value="0" />
                          <Register Address="1510" Value="0" />
                          <Register Address="1511" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1512.distribution_divider_1_b" Address="1512" Count="9">
                          <Register Address="1512" Value="0" />
                          <Register Address="1513" Value="34" />
                          <Register Address="1514" Value="52" />
                          <Register Address="1515" Value="60" />
                          <Register Address="1516" Value="0" />
                          <Register Address="1517" Value="0" />
                          <Register Address="1518" Value="0" />
                          <Register Address="1519" Value="0" />
                          <Register Address="151A" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="151B.distribution_divider_1_bb" Address="151B" Count="9">
                          <Register Address="151B" Value="0" />
                          <Register Address="151C" Value="0" />
                          <Register Address="151D" Value="0" />
                          <Register Address="151E" Value="0" />
                          <Register Address="151F" Value="0" />
                          <Register Address="1520" Value="0" />
                          <Register Address="1521" Value="0" />
                          <Register Address="1522" Value="0" />
                          <Register Address="1523" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1600.translation_profile_1_0" Address="1600" Count="24">
                          <Register Address="1600" Value="0" />
                          <Register Address="1601" Value="0" />
                          <Register Address="1602" Value="0" />
                          <Register Address="1603" Value="0" />
                          <Register Address="1604" Value="0" />
                          <Register Address="1605" Value="0" />
                          <Register Address="1606" Value="0" />
                          <Register Address="1607" Value="0" />
                          <Register Address="1608" Value="0A0" />
                          <Register Address="1609" Value="0F" />
                          <Register Address="160A" Value="0" />
                          <Register Address="160B" Value="0" />
                          <Register Address="160C" Value="0A0" />
                          <Register Address="160D" Value="0F" />
                          <Register Address="160E" Value="0" />
                          <Register Address="160F" Value="0" />
                          <Register Address="1610" Value="0" />
                          <Register Address="1611" Value="0" />
                          <Register Address="1612" Value="0" />
                          <Register Address="1613" Value="0" />
                          <Register Address="1614" Value="0" />
                          <Register Address="1615" Value="0" />
                          <Register Address="1616" Value="0" />
                          <Register Address="1617" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1620.translation_profile_1_1" Address="1620" Count="24">
                          <Register Address="1620" Value="0" />
                          <Register Address="1621" Value="0" />
                          <Register Address="1622" Value="0" />
                          <Register Address="1623" Value="0" />
                          <Register Address="1624" Value="0" />
                          <Register Address="1625" Value="0" />
                          <Register Address="1626" Value="0" />
                          <Register Address="1627" Value="0" />
                          <Register Address="1628" Value="0A0" />
                          <Register Address="1629" Value="0F" />
                          <Register Address="162A" Value="0" />
                          <Register Address="162B" Value="0" />
                          <Register Address="162C" Value="0A0" />
                          <Register Address="162D" Value="0F" />
                          <Register Address="162E" Value="0" />
                          <Register Address="162F" Value="0" />
                          <Register Address="1630" Value="0" />
                          <Register Address="1631" Value="0" />
                          <Register Address="1632" Value="0" />
                          <Register Address="1633" Value="0" />
                          <Register Address="1634" Value="0" />
                          <Register Address="1635" Value="0" />
                          <Register Address="1636" Value="0" />
                          <Register Address="1637" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1640.translation_profile_1_2" Address="1640" Count="24">
                          <Register Address="1640" Value="0" />
                          <Register Address="1641" Value="0" />
                          <Register Address="1642" Value="0" />
                          <Register Address="1643" Value="0" />
                          <Register Address="1644" Value="0" />
                          <Register Address="1645" Value="0" />
                          <Register Address="1646" Value="0" />
                          <Register Address="1647" Value="0" />
                          <Register Address="1648" Value="0A0" />
                          <Register Address="1649" Value="0F" />
                          <Register Address="164A" Value="0" />
                          <Register Address="164B" Value="0" />
                          <Register Address="164C" Value="0A0" />
                          <Register Address="164D" Value="0F" />
                          <Register Address="164E" Value="0" />
                          <Register Address="164F" Value="0" />
                          <Register Address="1650" Value="0" />
                          <Register Address="1651" Value="0" />
                          <Register Address="1652" Value="0" />
                          <Register Address="1653" Value="0" />
                          <Register Address="1654" Value="0" />
                          <Register Address="1655" Value="0" />
                          <Register Address="1656" Value="0" />
                          <Register Address="1657" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1660.translation_profile_1_3" Address="1660" Count="24">
                          <Register Address="1660" Value="0" />
                          <Register Address="1661" Value="0" />
                          <Register Address="1662" Value="0" />
                          <Register Address="1663" Value="0" />
                          <Register Address="1664" Value="0" />
                          <Register Address="1665" Value="0" />
                          <Register Address="1666" Value="0" />
                          <Register Address="1667" Value="0" />
                          <Register Address="1668" Value="0A0" />
                          <Register Address="1669" Value="0F" />
                          <Register Address="166A" Value="0" />
                          <Register Address="166B" Value="0" />
                          <Register Address="166C" Value="0A0" />
                          <Register Address="166D" Value="0F" />
                          <Register Address="166E" Value="0" />
                          <Register Address="166F" Value="0" />
                          <Register Address="1670" Value="0" />
                          <Register Address="1671" Value="0" />
                          <Register Address="1672" Value="0" />
                          <Register Address="1673" Value="0" />
                          <Register Address="1674" Value="0" />
                          <Register Address="1675" Value="0" />
                          <Register Address="1676" Value="0" />
                          <Register Address="1677" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1680.translation_profile_1_4" Address="1680" Count="24">
                          <Register Address="1680" Value="0" />
                          <Register Address="1681" Value="0" />
                          <Register Address="1682" Value="0" />
                          <Register Address="1683" Value="0" />
                          <Register Address="1684" Value="0" />
                          <Register Address="1685" Value="0" />
                          <Register Address="1686" Value="0" />
                          <Register Address="1687" Value="0" />
                          <Register Address="1688" Value="0A0" />
                          <Register Address="1689" Value="0F" />
                          <Register Address="168A" Value="0" />
                          <Register Address="168B" Value="0" />
                          <Register Address="168C" Value="0A0" />
                          <Register Address="168D" Value="0F" />
                          <Register Address="168E" Value="0" />
                          <Register Address="168F" Value="0" />
                          <Register Address="1690" Value="0" />
                          <Register Address="1691" Value="0" />
                          <Register Address="1692" Value="0" />
                          <Register Address="1693" Value="0" />
                          <Register Address="1694" Value="0" />
                          <Register Address="1695" Value="0" />
                          <Register Address="1696" Value="0" />
                          <Register Address="1697" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="16A0.translation_profile_1_5" Address="16A0" Count="24">
                          <Register Address="16A0" Value="0" />
                          <Register Address="16A1" Value="0" />
                          <Register Address="16A2" Value="0" />
                          <Register Address="16A3" Value="0" />
                          <Register Address="16A4" Value="0" />
                          <Register Address="16A5" Value="0" />
                          <Register Address="16A6" Value="0" />
                          <Register Address="16A7" Value="0" />
                          <Register Address="16A8" Value="0A0" />
                          <Register Address="16A9" Value="0F" />
                          <Register Address="16AA" Value="0" />
                          <Register Address="16AB" Value="0" />
                          <Register Address="16AC" Value="0A0" />
                          <Register Address="16AD" Value="0F" />
                          <Register Address="16AE" Value="0" />
                          <Register Address="16AF" Value="0" />
                          <Register Address="16B0" Value="0" />
                          <Register Address="16B1" Value="0" />
                          <Register Address="16B2" Value="0" />
                          <Register Address="16B3" Value="0" />
                          <Register Address="16B4" Value="0" />
                          <Register Address="16B5" Value="0" />
                          <Register Address="16B6" Value="0" />
                          <Register Address="16B7" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2000.op_ctrl" Address="2000" Count="6">
                          <Register Address="2000" Value="0" />
                          <Register Address="2001" Value="08" />
                          <Register Address="2002" Value="0" />
                          <Register Address="2003" Value="0" />
                          <Register Address="2004" Value="0" />
                          <Register Address="2005" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2006.irq_common_clear" Address="2006" Count="5">
                          <Register Address="2006" Value="0" />
                          <Register Address="2007" Value="0" />
                          <Register Address="2008" Value="0" />
                          <Register Address="2009" Value="0" />
                          <Register Address="200A" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="200B.irq_pll_0_clear" Address="200B" Count="5">
                          <Register Address="200B" Value="0" />
                          <Register Address="200C" Value="0" />
                          <Register Address="200D" Value="0" />
                          <Register Address="200E" Value="0" />
                          <Register Address="200F" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2010.irq_pll_1_clear" Address="2010" Count="5">
                          <Register Address="2010" Value="0" />
                          <Register Address="2011" Value="0" />
                          <Register Address="2012" Value="0" />
                          <Register Address="2013" Value="0" />
                          <Register Address="2014" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2100.operational_control_pll_0" Address="2100" Count="8">
                          <Register Address="2100" Value="0" />
                          <Register Address="2101" Value="0" />
                          <Register Address="2102" Value="0" />
                          <Register Address="2103" Value="0" />
                          <Register Address="2104" Value="0" />
                          <Register Address="2105" Value="0" />
                          <Register Address="2106" Value="0" />
                          <Register Address="2107" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2200.operational_control_pll_1" Address="2200" Count="7">
                          <Register Address="2200" Value="0" />
                          <Register Address="2201" Value="0" />
                          <Register Address="2202" Value="0" />
                          <Register Address="2203" Value="08" />
                          <Register Address="2205" Value="0" />
                          <Register Address="2206" Value="0" />
                          <Register Address="2207" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2800.auxnco_0" Address="2800" Count="31">
                          <Register Address="2800" Value="0" />
                          <Register Address="2801" Value="0" />
                          <Register Address="2802" Value="0" />
                          <Register Address="2803" Value="0" />
                          <Register Address="2804" Value="0" />
                          <Register Address="2805" Value="0" />
                          <Register Address="2806" Value="0" />
                          <Register Address="2807" Value="0" />
                          <Register Address="2808" Value="0" />
                          <Register Address="2809" Value="0" />
                          <Register Address="280A" Value="0" />
                          <Register Address="280B" Value="0" />
                          <Register Address="280C" Value="0" />
                          <Register Address="280D" Value="0" />
                          <Register Address="280E" Value="0" />
                          <Register Address="280F" Value="0" />
                          <Register Address="2810" Value="0" />
                          <Register Address="2811" Value="0" />
                          <Register Address="2812" Value="0" />
                          <Register Address="2813" Value="0" />
                          <Register Address="2814" Value="0" />
                          <Register Address="2815" Value="0" />
                          <Register Address="2816" Value="0" />
                          <Register Address="2817" Value="0" />
                          <Register Address="2818" Value="0" />
                          <Register Address="2819" Value="0" />
                          <Register Address="281A" Value="0" />
                          <Register Address="281B" Value="0" />
                          <Register Address="281C" Value="0" />
                          <Register Address="281D" Value="0" />
                          <Register Address="281E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2840.auxnco_1" Address="2840" Count="31">
                          <Register Address="2840" Value="0" />
                          <Register Address="2841" Value="0" />
                          <Register Address="2842" Value="0" />
                          <Register Address="2843" Value="0" />
                          <Register Address="2844" Value="0" />
                          <Register Address="2845" Value="0" />
                          <Register Address="2846" Value="0" />
                          <Register Address="2847" Value="0" />
                          <Register Address="2848" Value="0" />
                          <Register Address="2849" Value="0" />
                          <Register Address="284A" Value="0" />
                          <Register Address="284B" Value="0" />
                          <Register Address="284C" Value="0" />
                          <Register Address="284D" Value="0" />
                          <Register Address="284E" Value="0" />
                          <Register Address="284F" Value="0" />
                          <Register Address="2850" Value="0" />
                          <Register Address="2851" Value="0" />
                          <Register Address="2852" Value="0" />
                          <Register Address="2853" Value="0" />
                          <Register Address="2854" Value="0" />
                          <Register Address="2855" Value="0" />
                          <Register Address="2856" Value="0" />
                          <Register Address="2857" Value="0" />
                          <Register Address="2858" Value="0" />
                          <Register Address="2859" Value="0" />
                          <Register Address="285A" Value="0" />
                          <Register Address="285B" Value="0" />
                          <Register Address="285C" Value="0" />
                          <Register Address="285D" Value="0" />
                          <Register Address="285E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2900.temp_sensor" Address="2900" Count="7">
                          <Register Address="2900" Value="0" />
                          <Register Address="2901" Value="0" />
                          <Register Address="2902" Value="0" />
                          <Register Address="2903" Value="0" />
                          <Register Address="2904" Value="0" />
                          <Register Address="2905" Value="0" />
                          <Register Address="2906" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2A00.tdc_auxiliary" Address="2A00" Count="24">
                          <Register Address="2A00" Value="0" />
                          <Register Address="2A01" Value="0" />
                          <Register Address="2A02" Value="0E8" />
                          <Register Address="2A03" Value="76" />
                          <Register Address="2A04" Value="48" />
                          <Register Address="2A05" Value="17" />
                          <Register Address="2A06" Value="0" />
                          <Register Address="2A07" Value="0" />
                          <Register Address="2A08" Value="0" />
                          <Register Address="2A09" Value="0" />
                          <Register Address="2A0A" Value="0" />
                          <Register Address="2A0B" Value="0" />
                          <Register Address="2A0C" Value="0" />
                          <Register Address="2A0D" Value="0" />
                          <Register Address="2A0E" Value="0" />
                          <Register Address="2A0F" Value="0" />
                          <Register Address="2A10" Value="0" />
                          <Register Address="2A11" Value="0" />
                          <Register Address="2A12" Value="6" />
                          <Register Address="2A13" Value="7" />
                          <Register Address="2A14" Value="0" />
                          <Register Address="2A15" Value="0" />
                          <Register Address="2A16" Value="0" />
                          <Register Address="2A17" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2E00.eeprom" Address="2E00" Count="4">
                          <Register Address="2E00" Value="0" />
                          <Register Address="2E01" Value="0" />
                          <Register Address="2E02" Value="0" />
                          <Register Address="2E03" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2E10.eeprom_sequence" Address="2E10" Count="15">
                          <Register Address="2E10" Value="0FF" />
                          <Register Address="2E11" Value="0FF" />
                          <Register Address="2E12" Value="0FF" />
                          <Register Address="2E13" Value="0FF" />
                          <Register Address="2E14" Value="0FF" />
                          <Register Address="2E15" Value="0FF" />
                          <Register Address="2E16" Value="0FF" />
                          <Register Address="2E17" Value="0FF" />
                          <Register Address="2E18" Value="0FF" />
                          <Register Address="2E19" Value="0FF" />
                          <Register Address="2E1A" Value="0FF" />
                          <Register Address="2E1B" Value="0FF" />
                          <Register Address="2E1C" Value="0FF" />
                          <Register Address="2E1D" Value="0FF" />
                          <Register Address="2E1E" Value="0FF" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3000.status_readback" Address="3000" Count="11">
                          <Register Address="3000" Value="0" />
                          <Register Address="3001" Value="0" />
                          <Register Address="3002" Value="0" />
                          <Register Address="3003" Value="0" />
                          <Register Address="3004" Value="0" />
                          <Register Address="3005" Value="0" />
                          <Register Address="3006" Value="0" />
                          <Register Address="3007" Value="0" />
                          <Register Address="3008" Value="0" />
                          <Register Address="3009" Value="0" />
                          <Register Address="300A" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="300B.irq_common_read" Address="300B" Count="5">
                          <Register Address="300B" Value="0" />
                          <Register Address="300C" Value="0" />
                          <Register Address="300D" Value="0" />
                          <Register Address="300E" Value="0" />
                          <Register Address="300F" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3010.irq_pll_0_read" Address="3010" Count="5">
                          <Register Address="3010" Value="0" />
                          <Register Address="3011" Value="0" />
                          <Register Address="3012" Value="0" />
                          <Register Address="3013" Value="0" />
                          <Register Address="3014" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3015.irq_pll_1_read" Address="3015" Count="5">
                          <Register Address="3015" Value="0" />
                          <Register Address="3016" Value="0" />
                          <Register Address="3017" Value="0" />
                          <Register Address="3018" Value="0" />
                          <Register Address="3019" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3100.status_readback_pll_0" Address="3100" Count="15">
                          <Register Address="3100" Value="0" />
                          <Register Address="3101" Value="0" />
                          <Register Address="3102" Value="0" />
                          <Register Address="3103" Value="0" />
                          <Register Address="3104" Value="0" />
                          <Register Address="3105" Value="0" />
                          <Register Address="3106" Value="0" />
                          <Register Address="3107" Value="0" />
                          <Register Address="3108" Value="0" />
                          <Register Address="3109" Value="0" />
                          <Register Address="310A" Value="0" />
                          <Register Address="310B" Value="0" />
                          <Register Address="310C" Value="0" />
                          <Register Address="310D" Value="0" />
                          <Register Address="310E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3200.status_readback_pll_1" Address="3200" Count="15">
                          <Register Address="3200" Value="0" />
                          <Register Address="3201" Value="0" />
                          <Register Address="3202" Value="0" />
                          <Register Address="3203" Value="0" />
                          <Register Address="3204" Value="0" />
                          <Register Address="3205" Value="0" />
                          <Register Address="3206" Value="0" />
                          <Register Address="3207" Value="0" />
                          <Register Address="3208" Value="0" />
                          <Register Address="3209" Value="0" />
                          <Register Address="320A" Value="0" />
                          <Register Address="320B" Value="0" />
                          <Register Address="320C" Value="0" />
                          <Register Address="320D" Value="0" />
                          <Register Address="320E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3A00.tdc_auxiliary_read" Address="3A00" Count="60">
                          <Register Address="3A00" Value="0" />
                          <Register Address="3A01" Value="0" />
                          <Register Address="3A02" Value="0" />
                          <Register Address="3A03" Value="0" />
                          <Register Address="3A04" Value="0" />
                          <Register Address="3A05" Value="0" />
                          <Register Address="3A06" Value="0" />
                          <Register Address="3A07" Value="0" />
                          <Register Address="3A08" Value="0" />
                          <Register Address="3A09" Value="0" />
                          <Register Address="3A0A" Value="0" />
                          <Register Address="3A0B" Value="0" />
                          <Register Address="3A0C" Value="0" />
                          <Register Address="3A0D" Value="0" />
                          <Register Address="3A0E" Value="0" />
                          <Register Address="3A0F" Value="0" />
                          <Register Address="3A10" Value="0" />
                          <Register Address="3A11" Value="0" />
                          <Register Address="3A12" Value="0" />
                          <Register Address="3A13" Value="0" />
                          <Register Address="3A14" Value="0" />
                          <Register Address="3A15" Value="0" />
                          <Register Address="3A16" Value="0" />
                          <Register Address="3A17" Value="0" />
                          <Register Address="3A18" Value="0" />
                          <Register Address="3A19" Value="0" />
                          <Register Address="3A1A" Value="0" />
                          <Register Address="3A1B" Value="0" />
                          <Register Address="3A1C" Value="0" />
                          <Register Address="3A1D" Value="0" />
                          <Register Address="3A1E" Value="0" />
                          <Register Address="3A1F" Value="0" />
                          <Register Address="3A20" Value="0" />
                          <Register Address="3A21" Value="0" />
                          <Register Address="3A22" Value="0" />
                          <Register Address="3A23" Value="0" />
                          <Register Address="3A24" Value="0" />
                          <Register Address="3A25" Value="0" />
                          <Register Address="3A26" Value="0" />
                          <Register Address="3A27" Value="0" />
                          <Register Address="3A28" Value="0" />
                          <Register Address="3A29" Value="0" />
                          <Register Address="3A2A" Value="0" />
                          <Register Address="3A2B" Value="0" />
                          <Register Address="3A2C" Value="0" />
                          <Register Address="3A2D" Value="0" />
                          <Register Address="3A2E" Value="0" />
                          <Register Address="3A2F" Value="0" />
                          <Register Address="3A30" Value="0" />
                          <Register Address="3A31" Value="0" />
                          <Register Address="3A32" Value="0" />
                          <Register Address="3A33" Value="0" />
                          <Register Address="3A34" Value="0" />
                          <Register Address="3A35" Value="0" />
                          <Register Address="3A36" Value="0" />
                          <Register Address="3A37" Value="0" />
                          <Register Address="3A38" Value="0" />
                          <Register Address="3A39" Value="0" />
                          <Register Address="3A3A" Value="0" />
                          <Register Address="3A3B" Value="0" />
                        </RegisterMap>
                      </Chip>
                    </Chips>
                    <StateControls AllowStatePolling="true" />
                  </Board>
                </SavedState>
              </Component>
            </Components>
            <Connections />
          </Subsystem>
        </Subsystems>
      </System>
    </Element>
    <Element Id="Controllers">
      <Controller Name="AD9545 Board" HardwareID="Virtual&E40575A988F6" Path="Root::System.Subsystem_1.AD9545 Board" xmlns="" />
    </Element>
    <Element Id="Macros">
      <MacroManager xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="AnalogDevices/Csa/Evaluation/UI/Models/Sessions/MacroManagerSessionElement.Schema.xsd">
        <Macros />
      </MacroManager>
    </Element>
    <Element Id="Views" ActiveWorkspaceElement="Root::System.Subsystem_1.AD9545 Board.AD9545" WorkspaceElements="Root::,Root::System,Root::System.Subsystem_1.AD9545 Board,Root::System.Subsystem_1.AD9545 Board.AD9545,Root::System.Subsystem_1" />
  </Elements>
</Session>
We have done:
 Fetching the power-on loading waveform of AD9545, it is found that the register address of IIC is only 8bit, as shown in the figure below (decoded by oscilloscope).
The data format is also inconsistent with what the specification declares, as shown below:
Using AD9545 Eval board to test, the test result is consistent with the board we develop, and the address is only 8bit.
Use the computer to read the data inside EEPROM online, the address is 16bit, and the read data is correct, as shown below:
    I copied the file you send and I assigned it a cso extension. I called the file into ACE and I saw that no profile has been set for both DPLLs. I went today in the lab and I saw that clocks are generated when ACE is used. This is only because the Wizard writes some values into the freerun tuning words of both DPLLs, even if no translation profiles have been enabled. This anyway is not how the AD9545 should be configured. Please tell me what you want to accomplish with the AD9545 and I'll create a configuration for you.
    Regarding the I2C protocol you show from Table 80 from the data sheet: That is the protocol a controller must follow to read a register from the AD9545. When the AD9545 reads the EEPROM, the AD9545 follows the protocol of the EEPROM. See the data sheet of the 24AA16 EEPROM.
    I configured anyway the AD9545 according to your cso file and then I uploaded the configuration into the EEPROM on the evaluation board using some python scripts. I monitored the I2C communication in that moment on the scope and I saw it follows the EEPROM's page write protocol:
    START edge, 0xA0=control byte, control byte bit 0=0(write operation), 0x00 (word address), 0x05, 0x21, 0x01, 0x02, 0x56, 0x04, etc.
    This is the correct procedure.
    Then I powered down the evaluation board, I set pin M3 high to enable EEPROM download after power up and I powered up the board. I monitored the I2C communication between the EEPROM and the AD9545 and I saw:
    • START edge, 0xA0, 0x00. This is the AD9545 setting the EEPROM read pointer at address 0x00
    • 0xA1: This is the control byte with bit 0 set to 1, indicating a read operation
    • this is followed by 0x5, the content of address 0x00 of the EEPROM
    • this is followed by 0x21, 0x01, 0x02, 0x56, etc, exactly what was expected to be stored in the EEPROM
    Then I saw that the AD9545 did not generate any clock after it used the EEPROM. I believe the reason was that no sync operation was generated. I entered in ACE and I enabled the autosync feature to Immediate. I then again uploaded the EEPROM and this time, the outputs were generated right away.
    Petre
  • Dear Petre,
    Thanks a lot for your effort and clarification.
    1. As you point out, indeed I don't know how to configurate DPLL0&1 profile .Therefore I left it unconfigurated shown as picture below.
    2. By "auto sync" feature, do you mean the "auto sync mode" shown as picture below?This should be set as "Immediate"?
    3. Would you please spare some time to generate a configurationg file(*.cso) according to the picture above and send it to email:aaron.tang@richardsonrfpd.com?
    Thanks a lot.
