I bought the Ev-ADF4360-1EB1Z. When I look at the board, L1, L2, R25 and R26 are all not mounted.
Is this correct?
Is this correct?
Yes, this is correct for ADF4360-1. ADF4360-7 also uses same evaluation board and L1&L2, R25&R26 are required for ADF4360-7 to set VCO center frequency.
Kudret
TNX.
But L1&L2, R25&R26 are not mounted, so pin #9 and #10 (AGND) are open.
In the datasheet, they should be connected directly to GND.
Narutoh
Those pins are internally connected to ground. You can connect them to ground in your own board design.
Kudret
Thank you.
Finally, my question has been resolved and solved.
Narutoh
