HMC7044 vs AD9528
I am designing a module with AD9375 RF Transceiver. i need to provide reference clock of 122.88MHz<219fs jitter.
I came across AD9528 & HMC7044 which might meet my requirements.I calculated the Timing jitter using ADI Sim CLK as shown below,
It is observed that HMC7044 performance gets reduced a lot in lower frequencies while AD9528 phase noise remains same.
Can you suggest with which part should i proceed to meet the expected performance mentioned in AD9375 Data sheet.
Also it would be great if you can share the measured phase noise of AD9528 & HMC7044 at/near 122.88MHz.
Thanks in Advance,
Deva
