LTC6952 multi-stage
I want to implement multiLTC6952 stages.
The system will be composed by one master stage LTC6952 locked on an external 10MHz.
The master stage provides 5 outputs pair (REF clock - 100MHz & SSRQ PASS THRU) to synchronize 5 systems.
Design :
I want to know if I can do it because Analog devices examples implement only one VCO stage and multi clock distribution stages.
In my design, I must use a VCO in each stage :
1/ Stage 1 : VCO 1GHz locked on an external 10MHz
This stage provide a reference clock at 100MHz (low frequency reference because the 2° stage is at 1m)
2/ Stage 2 : VCO 4GHz locked on a 100MHz reference clock provided by the master LTC6952.
This stage provide JESD204B clocks
Jitter impact ?
Regards.
Lionel
    on May 11, 2021 12:16 PM
    Sorry for the delay.  I'm still catching up on vacation emails.
    Yes, a 2 stage synchronization scheme with a LTC6952 in stage 1 and 2 is possible.
    The challenge with this is the architecture will be the close in noise (i.e. phase offsets <40kHz).  The reason for this is the quality of the 2nd stage reference will probably limit the phase noise, due to the stage 1 GHz VCO performance.  If you can share the 1GHz VCO performance at 100Hz, 1kHz, 10kHz, 100kHz, 1MHz, 10MHz phase offsets, then I can create some phase noise curves and give you a better answer on the jitter impact.
    With that being said if you are not concerned about the phase offsets <40kHz, then there won't be much jitter impact at phase offsets >40kHz.
  • Sorry for the delay and thank you for your answer.
    You can find in the attached document VCO performances and OCXO (for the reference input).
    Regards.
    Lionel
    PDFPDF
    on May 28, 2021 7:43 PM in reply to LRZ31
    Here is the stage 2 comparison.
    If the stage 2 reference input is driven directly by an ideal 100M reference then stage 2 outputs would generate the plot on the left.
    If the stage 2 reference input is driven from the the 1G SAW locked to the stage 1 reference which is then divided down to 100M then stage 2 outputs would generate the plot on the right.  There is some small degradation <10k.
    Both plots shown used a 4GHz output signal.  I used the 4G VCO on the eval board for the VCO.
