Hi folk,
I'm trying to use this PLL with a PIC24 Microchip microcontroller.
The interface is an SPI because I leave the SP0,SP1 pins starting through the integrated pull-down resistors.
What is not clear, is the programming sequence. I try to be more clear about.
There is a command that's need to be sent for register update.
Have this command sent for each configuration register write?
Thank you.
Best Regards,
MM
