Question about ADCLK905
I am thinking of using the ADCLK905 as a clock buffer for ADF4106 (using a 10 MHz reference), but I have a few questions:
- Is needed any specifical waveform at the ADCLK905 input (sine, square..)? In page 9 of the datasheet appear some figure of the output waveform but I do not know if this waveform is dependent or not of the input waveform.
- Is the output level constant or it depends of the input level? I mean, the output level will be the same if the input is a 0.3Vpp or a 1.5Vpp signal?
Thank you very much,
Alberto
    on Apr 25, 2017 9:57 AM
    Hello Alberto,
    Either is ok, but square is desirable.
    The output clock waveform won't look different, but the additive phase noise of the buffer will be greater if a sine wave is used. The poor input slew rate has more time uncertainty in the zero crossing of the input clock.
    Yes.
