I have some questions about the component:
1. what should be the input configuration to get into osc-in in LVDS format?
2. In the D\S is mentioned:
For a 2.1 V commonmode, 50 Ω single-ended source, the input limit of 2.8 V allows ~700 mV of amplitude, or 6 dBm of maximum reference power.
My question is about the differential input. Does The limit of 1.4Vp-p is differential or refer to each leg (which bring us to 2.8Vp-p differential)?
3. What should I connect to the unused leg for single-ended input (A or B configuration)?
Asaf
Hi Asaf,
1) For AC coupled LVDS input, you need to enable AC coupled input, disable 100 ohm internal termination and enable Hi-Z input. Also, you need to put 100 ohm termination resistance between positive…
what is the signal to signal jitter of the same output (using an external VCO input)?
Channel to channel skew varies depending on whether they are in same clock group or they are sharing same supply. Depending on these, channel to channel skew may vary up to 30ps.
Do you mean the skew between positive and negative outputs of the channel?
This value is very critical in our project
