I plan to configure a HMC7043 through SPI by FPGA.
The datasheet only SPI bus timing info is max SPI Bus Frequency.
Do you have any timing info about setup/hold time (tS, tH) and clock to output time (tCO)?
Min 15ns setup time and min 10 ns hold time is adequate for both HMC7043/HMC7044.
Kudret
Thank you. I suppose 15 ns will be ok also as clock to output time (tCO)?
Yes, 15ns clock to output is also okay.
