Hi
I try to set up EVAL-CN0338-ARDZ with EVAL-ADICUP360 while referring to “CO2 Gas Measurement Demo”.
https://wiki.analog.com/resources/eval/user-guides/eval-adicup360/reference_designs/demo_cn0338
I got ADuCM360_demo_cn0338.hex:226KB by CCES.
But PC shows following Pop Up Window.
I attached PC screen shot files(screen shot.zip) of CCES.
screen shot.zip
Please give me some advice on what is wrong.
Best regards
N.Kokubo
To add onto what Andrei said:
For the ADICUP360, in order to use the drag and drop feature, the file must be in a .BIN file format (not.HEX)
Cheers,
Brandon
Hello Brandon san, Andrei san
Thank you for your reply.
I used .BIN file format ,and got the welcom message and application menu successfly.
I close this question.
best regards
It looks like there might be a lingering connection for the board to an unfinished openocd process.
Try restarting the computer to make sure the process is stopped and then also power cycle the board. Then try just to drag and drop the hex file without trying to debug from crosscore.
By the way, does just debugging the project work? Without creating any hex file to begin with.
Regards,Andrei
