CN0399 - RF Detector improvements
Looked around for a small & low power RF detector and this hits all the marks. I'm looking to take the design and expand it a bit. As the sensor output and ADC input are quite close in range, the "glueless" (not sure what to call a lack of filtering, buffering, conditioning) interface seems to worth just fine. Would it be worth putting a LPF between the two of them for higher noise immunity? And on that note, are there any  other suggestions to improve this circuit?
Btw, I'll be using it to measure incident and reflected power to an antenna in S-band
    on Apr 29, 2019 10:49 PM
    Filtering generally depends on the input signal peak to average ratio. the Crms cap value on ADL5904 increases as peak to average ratio of carier increases for additional averaging. additional interstage low pass can be implemented to lower the output noise with longer rise and fall time
    -andy
