PCB Footprint Drawing
The user sought guidance on recommended and minimum pad sizes for the PCB footprint of the ADAU1860-1, particularly for using the minimum pad diameter. The support engineer provided a link to Analog Devices' BGA PCB design guidelines. The user found the ball size in the datasheet and confirmed the solution was sufficient.
Category: Datasheet/Specs
Product Number: ADAU1860-1, ADAU1860, ADAU1860
Could you please provide information about the recommended and minimum pad sizes for the PCB footprint, and whether you suggest soldermask-defined or not?
I'm in a battle with the PCB vendor over copper clearances and need to use the minimum possible pad diameter.
Thank you!
