Could you please confirm the input and output specifications for the serial data port of the AD1895?
data sheet page 20 Serial Data Ports - Data Format
www.analog.com/.../AD1895.pdf
When the serial data input interface format is set to Left-Justified or I2S,
is it correct that the AD1895 always captures the serial data as 24-bit data,
regardless of whether the external device outputs 16, 18, 20, or 24-bit words,
and processes the data internally at 24-bit resolution?
When the AD1895 is configured in Bypass Mode,
does the serial data output provide an exact pass-through of the serial data received at the serial data input?
For example, if an external device outputs 16-bit data and the bits below the LSB contain random data,
is it correct that these bits are passed through unchanged and appear at the serial data output as received?
When Bypass Mode is disabled and the serial data output word width is set to 20, 18, or 16 bits,
the AD1895 performs dithering and word-length reduction.
After this processing, are all bits below the selected output word length forced to zero,
or can they contain non-zero values generated by the dithering process?
