Hi Analog Devices Team,
I previously designed a PCB and successfully used one ADAU7118 chip to drive eight microphones for data collection. Now I want to expand to more microphones. I have designed a new PCB with two ADAU7118 chips that share the same I2C bus. I have soldered one chip along with its surrounding circuitry to test whether it can output a normal PDM_CLK signal (3.072 MHz), but I found that it cannot output a proper signal. Sometimes the I2C communication is correct but there is no PDM_CLK signal; other times the I2C communication works fine and the signal is correct for an instant before immediately going wrong. I don’t know if this is caused by a soldering issue or a problem with my circuit design. I will now upload screenshots of some of the signals. I really have no idea what is causing this problem.
Thank you.
Correct BCLK:
Correct FSYNC:
Correct PDM_CLK:
Incorrect PDM_CLK:
