Dear Analog, and fellow engineers,
Can the SSM2166 be used for differential microphone inputs?
The + and - inputs are available for both the vca and the buffer (where the rms detector is fed from). The data sheet shortly mentions differential signals along with the uses for the VCAr input.
Since the vca inputs are both 1k to virtual gnd (probably they mean a virtual short to the internal reference, being a single supply IC), the input signal of the vca could be attenuated by adding extra series resistance to the input pins, lowering the input current.
The buffer could be configured for differential opamp stage, taking the 180k input resistance into account.
I sketched a schematic, excuse the prehistoric print. Are my assumptions right?
It would be great to know what the CMRR of the vca is, and how tightly those 1ks are matched internally.
Cheers, GaborNL
