Maximum output current on CM pin?
Product Number: ADAU1361
Hi everyone
I am actually using the CM pin of ADAU1361 as the negative input on a AOP differential amplifier.
The impedance seen from the CM pin is around 40 kohm. The CM pin is also connected to LIN_P input pin.
As a result, the CM voltage is not stable, around 1 to 1,4 V between different products, instead of 1,65V (AVdd/2).
Is the current consumption too much for that pin? Is the impedance of my AOP amplifier too low?
I did not find the answer on the forum...Sorry
Thanks a lot!
