Hello everyone,
We want to use the AD1937 as an ADC/DAC solution for a vibration control system.
For this we want to have excelent ADC/DAC linearity and phase stability of the sampling and the possibility to control the sampling times excaltly.
All this is fulfilled by the AD1937.
The only thing we are not sure about is the ADC/DAC gain.
The data sheet specifies +-10% ADC/DAC gain error (red), which is far outside our requirements of 0.05% (500 pmm).
But we are okay with calibrating the gain against an AC voltage reference (e.g. Fluke 5700A) or a reference voltmeter (e.g. HP3458A).
An initial calibration after PCB assembly is done anyway to calibrate the frontend gain and phase delay.
The gain error drift (green) is specified at 30 pmm/°C, which would be fine since we are mostly in an air conditioning lab.
So the question is
How stable is the ADC/DAC gain error over time, assuming stable AVDD and stable room temperature?
And for scientify interest, where does this large gain deviation come from, some kind of factory trimming for linearity?
Thanks for your help in advance
