Dear Sir
Use the DSM tool for MAX98390 EVK to set the Vdrx, play the 1Khz sing wave, and use the 4Ohm cement load + Low pass filter to measure the output waveform with an oscilloscope.
Then adjust the Volume upwards,
It was found that the output can still exceed the set voltage of Vdrx and is not limited to clipping.
My understanding is that Vdrx should limit the output limit, and the part exceeding the setting should be protected by clipping.
Is this current phenomenon normal?
How should I set it to achieve the condition of Output power limit = 2W /4Ohm?
