Hi Team,
Customer wants to verify with us about SSM2305 minimum gain, especially interest to know if this device could be set to +1 or < +1 (attenuation), we worry if gain being too small would make it unstable, thanks!
Andrew
KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
SSM2305
Production
The SSM2305 is a fully integrated, high efficiency, Class-D
audio amplifier designed to maximize performance for mobile
phone applications. The application...
Datasheet
SSM2305 on Analog.com
SSM2315
Production
The SSM2315 is a fully integrated, high efficiency, Class-D audio
amplifier. It is designed to maximize performance for mobile
phone applications. The...
Datasheet
SSM2315 on Analog.com
ssm2375
Production
The SSM2375 is a fully integrated, high efficiency, Class-D audio
Datasheet
ssm2375 on Analog.com
SSM2377
Production
The SSM2377 is a fully integrated, high efficiency, Class-D audio
Datasheet
SSM2377 on Analog.com
Hi Team,
Andrew
Hi Team,
Any feedback? Thx!
Andrew
Hi AWANG01,
From the SSM2305 datasheet, the default gain is set to 18dB but can be reduced by using a pair of external resistors R_ext from the equation and schematic you've posted.
As far as questions for stability, I plan to test this issue and will get back to you within the next day or so with my findings.
TM
Thank you for the support, looking forward to having your feedback!
Andrew
Hi AWANG01,
I was able to run some performance tests on the SSM2315, which is almost identical in structure and allows for an adjustable gain by replacing the 0Ohm resistors, R_ext, in a similar manner to the SSM2305.
I was able to swop out the 0Ohm resistors to test the gain of 1 and <1. Please see the table below for some performance metrics:
| Measurements | SSM2315 REXT Values | ||
| 0Ω | 82kΩ | 243kΩ | |
| Gain | 5.905dB | -0.512dB | -5.965dB |
| SNR | 103.842dB | 102.146dB | 99.377dB |
| THD+N @ 1W | 0.004% | 0.019% | 0.020% |
NOTE: These are resistance values for the SSM2315, different values will need to be used for SSM2305 to achieve gains of 1 and <1.
The second column achieves the gain of 1 or about 0dB and the third column had a gain of about 1/2 or about -6dB. You can notice some degradation in the SNR performance, which drops 4dB from the datasheet specified mark of 103dB when setting the gain to 1/2. These degradation come from the THD+N values being higher with these R_ext values being increased. These changes will also require a higher input level signal to get the same performance out of the board since we increased the impedance near the input.
Lastly, in terms of stability, I did not experience any issues. As seen from the table, there are some trade-offs in performance you are sacrificing to achieve a smaller gain, but no problems for stability.
I would recommend potentially using newer designs like the SSM2375 or SSM2377 . The SSM2375 includes a feature for a highly flexible gain select pin that allows for a choice of 0dB.
Hope all this information was helpful for the customer!
Best,
TM
Hi Tyler,
Thanks a lot, your feedback is really helpful!
Have a nice day.
Andrew
