how to fix address of DC input entry ?
Software Version: ADAU1467
Hi
   I use dc input entry for parameters' setup from MCU,
 in the image attacjed. 41 dc entrys were defined, Is it possible to have all d entrys allocated together  ?  The first entry is far from others in the image.
  • Hello Jerrywang,
    Usually, it won't happen like this. It will be in a contiguous address. I tried this and all the time it comes in a continuous address. which version you are using?
    Please look at the capture window to see how these parameters (address) are arranged and verify this once again in the capture window whether these addresses are split in different places. After all capture window's addresses are just replicated in the exported files.
    Harish
  • I use verion 4.7.
    & I attached the whole parameter header file here,
    pls searh "Module MasterCtrl - DC Input Entry", total 40  DC inputs in  MasterCtrl Module,
    the first input  "MOD_MASTERCTRL_MASTERCTRL_ALG0_DCINPALG145X1VALUE_ADDR"
    is not in the continuous address space, Same as difference  found in capture window.
     * File:           D:\Projects\Mipro\MA-SigmaDSP\20230612-MADSP\Output\20230612-MA-SIGMADSP_IC_1_PARAM.h
     * Created:        Monday, June 12, 2023 2:54:02 PM
     * Description:    20230612-MA-SIGMADSP:IC 1 parameter RAM definitions.
     * This software is distributed in the hope that it will be useful,
     * but is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
     * CONDITIONS OF ANY KIND, without even the implied warranty of
     * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
     * This software may only be used to program products purchased from
     * Analog Devices for incorporation by you into audio products that
     * are intended for resale to audio product end users. This software
     * may not be distributed whole or in any part to third parties.
     * Copyright ©2023 Analog Devices, Inc. All rights reserved.
    #ifndef __20230612_MA_SIGMADSP_IC_1_PARAM_H__
    #define __20230612_MA_SIGMADSP_IC_1_PARAM_H__
    /* Module Music_Level - Single Level Detector*/
    #define MOD_AUDIOIN_MUSIC_LEVEL_COUNT                  2
    #define MOD_AUDIOIN_MUSIC_LEVEL_DEVICE                 "IC1"
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002_ADDR 0
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002_MEMORYPAGE 0
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002LEVEL_ADDR 2171
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002LEVEL_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002LEVEL_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_MUSIC_LEVEL_ALG0_SINGLEBANDLEVELREADS3002LEVEL_MEMORYPAGE 0
    /* Module OutputLevel - Single Level Detector*/
    #define MOD_AUDIOOUT_OUTPUTLEVEL_COUNT                 2
    #define MOD_AUDIOOUT_OUTPUTLEVEL_DEVICE                "IC1"
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001_ADDR 0
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001LEVEL_ADDR 2294
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001LEVEL_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001LEVEL_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTLEVEL_ALG0_SINGLEBANDLEVELREADS3001LEVEL_MEMORYPAGE 0
    /* Module Voice_Level - Single Level Detector*/
    #define MOD_ECHO_REVERB_VOICE_LEVEL_COUNT              2
    #define MOD_ECHO_REVERB_VOICE_LEVEL_DEVICE             "IC1"
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003_ADDR 0
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003LEVEL_ADDR 2291
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003LEVEL_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003LEVEL_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_VOICE_LEVEL_ALG0_SINGLEBANDLEVELREADS3003LEVEL_MEMORYPAGE 0
    /* Module GainTable - Index Lookup Table*/
    #define MOD_MASTERCTRL_GAINTABLE_COUNT                 128
    #define MOD_MASTERCTRL_GAINTABLE_DEVICE                "IC1"
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE0_ADDR 28
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE0_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE0_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE0_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE1_ADDR 29
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.891250938133746)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE1_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE2_ADDR 30
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.794328234724281)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE2_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE3_ADDR 31
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE3_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.707945784384138)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE3_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE3_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE4_ADDR 32
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE4_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.630957344480193)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE4_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE4_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE5_ADDR 33
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE5_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.562341325190349)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE5_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE5_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE6_ADDR 34
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE6_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.501187233627272)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE6_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE6_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE7_ADDR 35
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE7_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.446683592150963)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE7_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE7_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE8_ADDR 36
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE8_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.398107170553497)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE8_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE8_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE9_ADDR 37
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE9_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.354813389233575)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE9_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE9_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE10_ADDR 38
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE10_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.316227766016838)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE10_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE10_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE11_ADDR 39
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE11_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.281838293126445)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE11_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE11_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE12_ADDR 40
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE12_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.251188643150958)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE12_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE12_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE13_ADDR 41
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE13_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.223872113856834)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE13_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE13_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE14_ADDR 42
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE14_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.199526231496888)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE14_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE14_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE15_ADDR 43
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE15_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.177827941003892)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE15_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE15_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE16_ADDR 44
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE16_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.158489319246111)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE16_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE16_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE17_ADDR 45
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE17_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.141253754462275)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE17_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE17_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE18_ADDR 46
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE18_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.125892541179417)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE18_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE18_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE19_ADDR 47
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE19_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.112201845430196)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE19_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE19_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE20_ADDR 48
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE20_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.1)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE20_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE20_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE21_ADDR 49
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE21_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0891250938133746)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE21_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE21_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE22_ADDR 50
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE22_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0794328234724281)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE22_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE22_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE23_ADDR 51
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE23_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0707945784384138)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE23_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE23_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE24_ADDR 52
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE24_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0630957344480193)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE24_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE24_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE25_ADDR 53
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE25_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0562341325190349)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE25_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE25_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE26_ADDR 54
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE26_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0501187233627272)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE26_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE26_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE27_ADDR 55
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE27_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0446683592150963)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE27_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE27_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE28_ADDR 56
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE28_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0398107170553497)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE28_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE28_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE29_ADDR 57
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE29_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0354813389233576)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE29_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE29_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE30_ADDR 58
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE30_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0316227766016838)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE30_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLdcPCONFIGFORMAT1TABLE30_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE31_ADDR 59
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE31_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0281838293126445)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE31_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE31_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE32_ADDR 60
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE32_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0251188643150958)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE32_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE32_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE33_ADDR 61
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE33_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0223872113856834)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE33_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE33_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE34_ADDR 62
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE34_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0199526231496888)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE34_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE34_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE35_ADDR 63
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE35_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0177827941003892)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE35_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE35_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE36_ADDR 64
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE36_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0158489319246111)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE36_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE36_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE37_ADDR 65
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE37_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0141253754462275)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE37_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE37_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE38_ADDR 66
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE38_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0125892541179417)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE38_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE38_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE39_ADDR 67
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE39_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0112201845430196)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE39_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE39_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE40_ADDR 68
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE40_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.01)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE40_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE40_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE41_ADDR 69
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE41_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00891250938133746)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE41_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE41_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE42_ADDR 70
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE42_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00794328234724281)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE42_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE42_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE43_ADDR 71
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE43_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00707945784384138)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE43_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE43_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE44_ADDR 72
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE44_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00630957344480193)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE44_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE44_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE45_ADDR 73
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE45_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00562341325190349)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE45_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE45_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE46_ADDR 74
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE46_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00501187233627272)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE46_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE46_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE47_ADDR 75
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE47_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00446683592150963)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE47_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE47_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE48_ADDR 76
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE48_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00398107170553497)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE48_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE48_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE49_ADDR 77
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE49_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00354813389233575)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE49_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE49_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE50_ADDR 78
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE50_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00316227766016838)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE50_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE50_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE51_ADDR 79
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE51_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00281838293126445)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE51_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE51_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE52_ADDR 80
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE52_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00251188643150958)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE52_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE52_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE53_ADDR 81
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE53_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00223872113856834)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE53_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE53_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE54_ADDR 82
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE54_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00199526231496888)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE54_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE54_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE55_ADDR 83
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE55_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00177827941003892)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE55_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE55_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE56_ADDR 84
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE56_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00158489319246111)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE56_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE56_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE57_ADDR 85
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE57_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00141253754462275)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE57_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE57_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE58_ADDR 86
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE58_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00125892541179417)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE58_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE58_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE59_ADDR 87
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE59_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00112201845430196)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE59_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE59_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE60_ADDR 88
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE60_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.001)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE60_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE60_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE61_ADDR 89
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE61_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000891250938133746)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE61_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE61_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE62_ADDR 90
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE62_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000794328234724281)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE62_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE62_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE63_ADDR 91
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE63_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000707945784384138)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE63_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE63_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE64_ADDR 92
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE64_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000630957344480193)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE64_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE64_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE65_ADDR 93
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE65_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000562341325190349)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE65_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE65_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE66_ADDR 94
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE66_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000501187233627273)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE66_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE66_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE67_ADDR 95
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE67_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000446683592150963)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE67_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE67_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE68_ADDR 96
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE68_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000398107170553497)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE68_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE68_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE69_ADDR 97
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE69_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000354813389233575)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE69_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE69_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE70_ADDR 98
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE70_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000316227766016838)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE70_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE70_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE71_ADDR 99
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE71_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000281838293126446)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE71_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE71_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE72_ADDR 100
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE72_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000251188643150958)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE72_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE72_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE73_ADDR 101
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE73_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000223872113856834)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE73_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE73_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE74_ADDR 102
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE74_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000199526231496888)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE74_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE74_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE75_ADDR 103
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE75_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000177827941003892)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE75_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE75_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE76_ADDR 104
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE76_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000158489319246111)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE76_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE76_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE77_ADDR 105
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE77_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000141253754462275)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE77_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE77_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE78_ADDR 106
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE78_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000125892541179417)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE78_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE78_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE79_ADDR 107
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE79_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000112201845430196)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE79_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE79_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE80_ADDR 108
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE80_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0001)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE80_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE80_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE81_ADDR 109
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE81_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(8.91250938133746E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE81_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE81_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE82_ADDR 110
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE82_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(7.94328234724282E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE82_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE82_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE83_ADDR 111
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE83_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(7.07945784384137E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE83_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE83_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE84_ADDR 112
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE84_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(6.30957344480193E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE84_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE84_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE85_ADDR 113
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE85_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.62341325190349E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE85_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE85_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE86_ADDR 114
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE86_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.01187233627273E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE86_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE86_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE87_ADDR 115
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE87_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(4.46683592150963E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE87_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE87_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE88_ADDR 116
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE88_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(3.98107170553497E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE88_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE88_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE89_ADDR 117
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE89_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(3.54813389233575E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE89_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE89_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE90_ADDR 118
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE90_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(3.16227766016838E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE90_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE90_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE91_ADDR 119
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE91_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(2.81838293126445E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE91_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE91_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE92_ADDR 120
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE92_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(2.51188643150958E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE92_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE92_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE93_ADDR 121
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE93_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(2.23872113856834E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE93_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE93_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE94_ADDR 122
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE94_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.99526231496888E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE94_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE94_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE95_ADDR 123
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE95_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.77827941003892E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE95_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE95_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE96_ADDR 124
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE96_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.58489319246111E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE96_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE96_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE97_ADDR 125
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE97_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.41253754462276E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE97_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE97_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE98_ADDR 126
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE98_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.25892541179417E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE98_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE98_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE99_ADDR 127
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE99_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.12201845430196E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE99_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE99_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE100_ADDR 128
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1E-05)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE100_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE101_ADDR 129
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(8.91250938133746E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE101_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE102_ADDR 130
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(7.94328234724282E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE102_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE103_ADDR 131
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(7.07945784384137E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE103_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE104_ADDR 132
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(6.30957344480193E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE104_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE105_ADDR 133
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE105_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.62341325190349E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE105_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE105_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE106_ADDR 134
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE106_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.01187233627273E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE106_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE106_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE107_ADDR 135
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE107_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(4.46683592150963E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE107_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE107_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE108_ADDR 136
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE108_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(3.98107170553497E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE108_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE108_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE109_ADDR 137
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE109_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(3.54813389233575E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE109_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE109_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE110_ADDR 138
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(3.16227766016838E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE110_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE111_ADDR 139
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(2.81838293126446E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE111_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE112_ADDR 140
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(2.51188643150958E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE112_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE113_ADDR 141
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(2.23872113856834E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE113_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE114_ADDR 142
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.99526231496888E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE114_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE115_ADDR 143
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE115_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.77827941003892E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE115_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE115_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE116_ADDR 144
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE116_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.58489319246111E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE116_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE116_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE117_ADDR 145
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE117_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.41253754462276E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE117_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE117_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE118_ADDR 146
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE118_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.25892541179417E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE118_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE118_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE119_ADDR 147
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE119_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.12201845430196E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE119_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE119_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE120_ADDR 148
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1E-06)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE120_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE121_ADDR 149
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(8.91250938133746E-07)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE121_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE122_ADDR 150
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(7.94328234724282E-07)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE122_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE123_ADDR 151
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(7.07945784384137E-07)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE123_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE124_ADDR 152
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(6.30957344480193E-07)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE124_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE125_ADDR 153
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE125_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.62341325190349E-07)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE125_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE125_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE126_ADDR 154
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE126_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.01187233627273E-07)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE126_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE126_MEMORYPAGE 0
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE127_ADDR 155
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE127_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE127_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_GAINTABLE_ALG0_LUTGROWALG300NOLPCONFIGFORMAT1TABLE127_MEMORYPAGE 0
    /* Module LowCut - General Eq (2nd order)*/
    #define MOD_WMIC2_LOWCUT_COUNT                         30
    #define MOD_WMIC2_LOWCUT_DEVICE                        "IC1"
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B2_ADDR           156
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B2_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B2_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B2_MEMORYPAGE     0
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B1_ADDR           157
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B1_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(-1.99067421396581)
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B1_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B1_MEMORYPAGE     0
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B0_ADDR           158
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B0_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B0_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_B0_MEMORYPAGE     0
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A2_ADDR           159
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A2_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(-0.990759490563372)
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A2_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A2_MEMORYPAGE     0
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A1_ADDR           160
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A1_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(1.99058893736825)
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A1_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_LOWCUT_ALG0_STAGE0_A1_MEMORYPAGE     0
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B2_ADDR           161
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B2_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B2_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B2_MEMORYPAGE     0
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B1_ADDR           162
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B1_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(-1.99067421396581)
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B1_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B1_MEMORYPAGE     0
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B0_ADDR           163
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B0_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B0_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_B0_MEMORYPAGE     0
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A2_ADDR           164
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A2_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(-0.990759490563372)
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A2_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A2_MEMORYPAGE     0
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A1_ADDR           165
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A1_VALUE          SIGMASTUDIOTYPE_8_24_CONVERT(1.99058893736825)
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A1_TYPE           SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_LOWCUT_ALG0_STAGE0_A1_MEMORYPAGE     0
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B2_ADDR             166
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B2_MEMORYPAGE       0
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B1_ADDR             167
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-1.99067421396581)
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B1_MEMORYPAGE       0
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B0_ADDR             168
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B0_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B0_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_B0_MEMORYPAGE       0
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A2_ADDR             169
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-0.990759490563372)
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A2_MEMORYPAGE       0
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A1_ADDR             170
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(1.99058893736825)
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_LOWCUT_ALG0_STAGE0_A1_MEMORYPAGE       0
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B2_ADDR             171
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B2_MEMORYPAGE       0
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B1_ADDR             172
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-1.99067421396581)
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B1_MEMORYPAGE       0
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B0_ADDR             173
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B0_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B0_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_B0_MEMORYPAGE       0
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A2_ADDR             174
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-0.990759490563372)
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A2_MEMORYPAGE       0
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A1_ADDR             175
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(1.99058893736825)
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_LOWCUT_ALG0_STAGE0_A1_MEMORYPAGE       0
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B2_ADDR             176
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B2_MEMORYPAGE       0
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B1_ADDR             177
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-1.99067421396581)
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B1_MEMORYPAGE       0
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B0_ADDR             178
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B0_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B0_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_B0_MEMORYPAGE       0
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A2_ADDR             179
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-0.990759490563372)
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A2_MEMORYPAGE       0
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A1_ADDR             180
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(1.99058893736825)
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_LOWCUT_ALG0_STAGE0_A1_MEMORYPAGE       0
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B2_ADDR             181
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B2_MEMORYPAGE       0
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B1_ADDR             182
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-1.99067421396581)
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B1_MEMORYPAGE       0
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B0_ADDR             183
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B0_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(0.995337106982905)
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B0_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_B0_MEMORYPAGE       0
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A2_ADDR             184
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A2_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(-0.990759490563372)
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A2_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A2_MEMORYPAGE       0
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A1_ADDR             185
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A1_VALUE            SIGMASTUDIOTYPE_8_24_CONVERT(1.99058893736825)
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A1_TYPE             SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_LOWCUT_ALG0_STAGE0_A1_MEMORYPAGE       0
    /* Module ZeroComp1 - Zero Comparator*/
    #define MOD_AUDIOIN_ZEROCOMP1_COUNT                    1
    #define MOD_AUDIOIN_ZEROCOMP1_DEVICE                   "IC1"
    #define MOD_AUDIOIN_ZEROCOMP1_OUTPUT_ADDR              186
    #define MOD_AUDIOIN_ZEROCOMP1_OUTPUT_FIXPT             0x00000001
    #define MOD_AUDIOIN_ZEROCOMP1_OUTPUT_VALUE             SIGMASTUDIOTYPE_INTEGER_CONVERT(1)
    #define MOD_AUDIOIN_ZEROCOMP1_OUTPUT_TYPE              SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOIN_ZEROCOMP1_OUTPUT_MEMORYPAGE        0
    /* Module EQLbt - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_BT_EQLBT_COUNT                             96
    #define MOD_BT_EQLBT_DEVICE                            "IC1"
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2100_ADDR 187
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2100_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2101_ADDR 188
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2101_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2102_ADDR 189
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2102_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2103_ADDR 190
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2103_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2104_ADDR 191
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2104_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2110_ADDR 192
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2110_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2111_ADDR 193
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2111_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2112_ADDR 194
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2112_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2113_ADDR 195
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2113_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2114_ADDR 196
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2114_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2120_ADDR 197
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2120_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2121_ADDR 198
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2121_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2122_ADDR 199
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2122_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2123_ADDR 200
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2123_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2124_ADDR 201
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2124_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2130_ADDR 202
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2130_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2131_ADDR 203
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2131_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2132_ADDR 204
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2132_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2133_ADDR 205
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2133_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2134_ADDR 206
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2134_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2140_ADDR 207
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2140_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2141_ADDR 208
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2141_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2142_ADDR 209
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2142_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2143_ADDR 210
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2143_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2144_ADDR 211
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2144_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2150_ADDR 212
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2150_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2151_ADDR 213
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2151_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2152_ADDR 214
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2152_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2153_ADDR 215
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2153_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2154_ADDR 216
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2154_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2160_ADDR 217
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2160_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2161_ADDR 218
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2161_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2162_ADDR 219
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2162_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2163_ADDR 220
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2163_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2164_ADDR 221
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2164_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2170_ADDR 222
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2170_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2171_ADDR 223
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2171_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2172_ADDR 224
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2172_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2173_ADDR 225
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2173_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2174_ADDR 226
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2174_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2180_ADDR 227
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2180_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2181_ADDR 228
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2181_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2182_ADDR 229
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2182_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2183_ADDR 230
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2183_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2184_ADDR 231
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2184_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2190_ADDR 232
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2190_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2191_ADDR 233
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2191_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2192_ADDR 234
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2192_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2193_ADDR 235
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2193_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2194_ADDR 236
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B2194_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21100_ADDR 237
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21100_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21101_ADDR 238
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21101_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21102_ADDR 239
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21102_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21103_ADDR 240
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21103_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21104_ADDR 241
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21104_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21110_ADDR 242
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21110_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21111_ADDR 243
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21111_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21112_ADDR 244
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21112_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21113_ADDR 245
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21113_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21114_ADDR 246
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21114_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21120_ADDR 247
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21120_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21121_ADDR 248
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21121_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21122_ADDR 249
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21122_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21123_ADDR 250
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21123_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21124_ADDR 251
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21124_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21130_ADDR 252
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21130_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21131_ADDR 253
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21131_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21132_ADDR 254
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21132_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21133_ADDR 255
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21133_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21134_ADDR 256
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21134_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21140_ADDR 257
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21140_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21141_ADDR 258
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21141_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21142_ADDR 259
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21142_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21143_ADDR 260
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21143_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21144_ADDR 261
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21144_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21150_ADDR 262
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21150_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21151_ADDR 263
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21151_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21152_ADDR 264
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21152_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21153_ADDR 265
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21153_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21154_ADDR 266
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19B21154_MEMORYPAGE 0
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19ALPHA_ADDR 5207
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQLBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG19ALPHA_MEMORYPAGE 0
    /* Module EQLw2 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_WMIC2_EQLW2_COUNT                          96
    #define MOD_WMIC2_EQLW2_DEVICE                         "IC1"
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2100_ADDR 269
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2100_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2101_ADDR 270
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2101_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2102_ADDR 271
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2102_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2103_ADDR 272
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2103_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2104_ADDR 273
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2104_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2110_ADDR 274
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2110_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2111_ADDR 275
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2111_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2112_ADDR 276
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2112_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2113_ADDR 277
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2113_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2114_ADDR 278
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2114_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2120_ADDR 279
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2120_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2121_ADDR 280
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2121_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2122_ADDR 281
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2122_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2123_ADDR 282
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2123_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2124_ADDR 283
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2124_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2130_ADDR 284
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2130_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2131_ADDR 285
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2131_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2132_ADDR 286
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2132_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2133_ADDR 287
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2133_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2134_ADDR 288
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2134_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2140_ADDR 289
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2140_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2141_ADDR 290
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2141_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2142_ADDR 291
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2142_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2143_ADDR 292
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2143_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2144_ADDR 293
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2144_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2150_ADDR 294
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2150_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2151_ADDR 295
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2151_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2152_ADDR 296
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2152_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2153_ADDR 297
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2153_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2154_ADDR 298
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2154_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2160_ADDR 299
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2160_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2161_ADDR 300
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2161_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2162_ADDR 301
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2162_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2163_ADDR 302
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2163_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2164_ADDR 303
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2164_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2170_ADDR 304
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2170_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2171_ADDR 305
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2171_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2172_ADDR 306
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2172_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2173_ADDR 307
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2173_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2174_ADDR 308
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2174_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2180_ADDR 309
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2180_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2181_ADDR 310
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2181_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2182_ADDR 311
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2182_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2183_ADDR 312
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2183_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2184_ADDR 313
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2184_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2190_ADDR 314
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2190_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2191_ADDR 315
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2191_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2192_ADDR 316
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2192_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2193_ADDR 317
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2193_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2194_ADDR 318
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B2194_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21100_ADDR 319
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21100_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21101_ADDR 320
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21101_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21102_ADDR 321
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21102_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21103_ADDR 322
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21103_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21104_ADDR 323
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21104_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21110_ADDR 324
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21110_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21111_ADDR 325
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21111_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21112_ADDR 326
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21112_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21113_ADDR 327
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21113_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21114_ADDR 328
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21114_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21120_ADDR 329
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21120_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21121_ADDR 330
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21121_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21122_ADDR 331
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21122_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21123_ADDR 332
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21123_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21124_ADDR 333
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21124_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21130_ADDR 334
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21130_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21131_ADDR 335
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21131_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21132_ADDR 336
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21132_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21133_ADDR 337
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21133_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21134_ADDR 338
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21134_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21140_ADDR 339
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21140_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21141_ADDR 340
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21141_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21142_ADDR 341
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21142_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21143_ADDR 342
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21143_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21144_ADDR 343
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21144_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21150_ADDR 344
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21150_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21151_ADDR 345
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21151_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21152_ADDR 346
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21152_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21153_ADDR 347
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21153_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21154_ADDR 348
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16B21154_MEMORYPAGE 0
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16ALPHA_ADDR 5210
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQLW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG16ALPHA_MEMORYPAGE 0
    /* Module EQLw1 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_WMIC1_EQLW1_COUNT                          96
    #define MOD_WMIC1_EQLW1_DEVICE                         "IC1"
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2100_ADDR 351
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2100_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2101_ADDR 352
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2101_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2102_ADDR 353
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2102_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2103_ADDR 354
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2103_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2104_ADDR 355
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2104_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2110_ADDR 356
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2110_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2111_ADDR 357
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2111_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2112_ADDR 358
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2112_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2113_ADDR 359
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2113_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2114_ADDR 360
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2114_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2120_ADDR 361
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2120_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2121_ADDR 362
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2121_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2122_ADDR 363
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2122_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2123_ADDR 364
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2123_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2124_ADDR 365
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2124_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2130_ADDR 366
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2130_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2131_ADDR 367
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2131_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2132_ADDR 368
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2132_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2133_ADDR 369
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2133_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2134_ADDR 370
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2134_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2140_ADDR 371
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2140_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2141_ADDR 372
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2141_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2142_ADDR 373
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2142_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2143_ADDR 374
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2143_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2144_ADDR 375
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2144_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2150_ADDR 376
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2150_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2151_ADDR 377
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2151_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2152_ADDR 378
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2152_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2153_ADDR 379
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2153_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2154_ADDR 380
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2154_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2160_ADDR 381
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2160_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2161_ADDR 382
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2161_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2162_ADDR 383
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2162_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2163_ADDR 384
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2163_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2164_ADDR 385
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2164_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2170_ADDR 386
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2170_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2171_ADDR 387
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2171_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2172_ADDR 388
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2172_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2173_ADDR 389
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2173_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2174_ADDR 390
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2174_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2180_ADDR 391
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2180_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2181_ADDR 392
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2181_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2182_ADDR 393
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2182_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2183_ADDR 394
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2183_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2184_ADDR 395
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2184_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2190_ADDR 396
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2190_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2191_ADDR 397
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2191_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2192_ADDR 398
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2192_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2193_ADDR 399
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2193_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2194_ADDR 400
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B2194_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21100_ADDR 401
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21100_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21101_ADDR 402
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21101_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21102_ADDR 403
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21102_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21103_ADDR 404
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21103_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21104_ADDR 405
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21104_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21110_ADDR 406
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21110_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21111_ADDR 407
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21111_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21112_ADDR 408
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21112_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21113_ADDR 409
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21113_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21114_ADDR 410
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21114_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21120_ADDR 411
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21120_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21121_ADDR 412
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21121_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21122_ADDR 413
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21122_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21123_ADDR 414
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21123_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21124_ADDR 415
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21124_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21130_ADDR 416
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21130_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21131_ADDR 417
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21131_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21132_ADDR 418
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21132_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21133_ADDR 419
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21133_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21134_ADDR 420
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21134_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21140_ADDR 421
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21140_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21141_ADDR 422
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21141_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21142_ADDR 423
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21142_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21143_ADDR 424
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21143_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21144_ADDR 425
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21144_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21150_ADDR 426
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21150_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21151_ADDR 427
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21151_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21152_ADDR 428
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21152_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21153_ADDR 429
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21153_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21154_ADDR 430
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13B21154_MEMORYPAGE 0
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13ALPHA_ADDR 5213
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQLW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG13ALPHA_MEMORYPAGE 0
    /* Module EQLrx4 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX4_EQLRX4_COUNT                           96
    #define MOD_RX4_EQLRX4_DEVICE                          "IC1"
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2100_ADDR 433
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2100_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2101_ADDR 434
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2101_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2102_ADDR 435
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2102_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2103_ADDR 436
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2103_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2104_ADDR 437
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2104_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2110_ADDR 438
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2110_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2111_ADDR 439
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2111_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2112_ADDR 440
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2112_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2113_ADDR 441
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2113_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2114_ADDR 442
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2114_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2120_ADDR 443
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2120_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2121_ADDR 444
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2121_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2122_ADDR 445
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2122_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2123_ADDR 446
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2123_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2124_ADDR 447
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2124_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2130_ADDR 448
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2130_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2131_ADDR 449
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2131_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2132_ADDR 450
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2132_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2133_ADDR 451
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2133_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2134_ADDR 452
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2134_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2140_ADDR 453
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2140_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2141_ADDR 454
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2141_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2142_ADDR 455
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2142_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2143_ADDR 456
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2143_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2144_ADDR 457
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2144_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2150_ADDR 458
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2150_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2151_ADDR 459
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2151_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2152_ADDR 460
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2152_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2153_ADDR 461
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2153_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2154_ADDR 462
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2154_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2160_ADDR 463
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2160_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2161_ADDR 464
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2161_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2162_ADDR 465
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2162_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2163_ADDR 466
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2163_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2164_ADDR 467
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2164_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2170_ADDR 468
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2170_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2171_ADDR 469
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2171_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2172_ADDR 470
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2172_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2173_ADDR 471
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2173_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2174_ADDR 472
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2174_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2180_ADDR 473
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2180_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2181_ADDR 474
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2181_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2182_ADDR 475
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2182_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2183_ADDR 476
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2183_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2184_ADDR 477
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2184_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2190_ADDR 478
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2190_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2191_ADDR 479
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2191_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2192_ADDR 480
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2192_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2193_ADDR 481
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2193_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2194_ADDR 482
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B2194_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21100_ADDR 483
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21100_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21101_ADDR 484
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21101_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21102_ADDR 485
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21102_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21103_ADDR 486
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21103_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21104_ADDR 487
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21104_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21110_ADDR 488
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21110_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21111_ADDR 489
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21111_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21112_ADDR 490
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21112_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21113_ADDR 491
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21113_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21114_ADDR 492
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21114_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21120_ADDR 493
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21120_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21121_ADDR 494
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21121_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21122_ADDR 495
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21122_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21123_ADDR 496
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21123_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21124_ADDR 497
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21124_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21130_ADDR 498
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21130_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21131_ADDR 499
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21131_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21132_ADDR 500
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21132_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21133_ADDR 501
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21133_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21134_ADDR 502
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21134_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21140_ADDR 503
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21140_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21141_ADDR 504
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21141_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21142_ADDR 505
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21142_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21143_ADDR 506
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21143_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21144_ADDR 507
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21144_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21150_ADDR 508
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21150_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21151_ADDR 509
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21151_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21152_ADDR 510
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21152_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21153_ADDR 511
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21153_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21154_ADDR 512
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10B21154_MEMORYPAGE 0
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10ALPHA_ADDR 5216
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQLRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG10ALPHA_MEMORYPAGE 0
    /* Module EQLrx3 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX3_EQLRX3_COUNT                           96
    #define MOD_RX3_EQLRX3_DEVICE                          "IC1"
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2100_ADDR 515
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2100_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2101_ADDR 516
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2101_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2102_ADDR 517
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2102_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2103_ADDR 518
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2103_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2104_ADDR 519
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2104_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2110_ADDR 520
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2110_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2111_ADDR 521
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2111_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2112_ADDR 522
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2112_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2113_ADDR 523
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2113_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2114_ADDR 524
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2114_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2120_ADDR 525
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2120_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2121_ADDR 526
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2121_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2122_ADDR 527
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2122_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2123_ADDR 528
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2123_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2124_ADDR 529
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2124_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2130_ADDR 530
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2130_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2131_ADDR 531
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2131_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2132_ADDR 532
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2132_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2133_ADDR 533
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2133_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2134_ADDR 534
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2134_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2140_ADDR 535
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2140_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2141_ADDR 536
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2141_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2142_ADDR 537
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2142_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2143_ADDR 538
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2143_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2144_ADDR 539
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2144_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2150_ADDR 540
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2150_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2151_ADDR 541
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2151_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2152_ADDR 542
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2152_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2153_ADDR 543
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2153_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2154_ADDR 544
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2154_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2160_ADDR 545
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2160_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2161_ADDR 546
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2161_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2162_ADDR 547
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2162_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2163_ADDR 548
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2163_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2164_ADDR 549
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2164_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2170_ADDR 550
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2170_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2171_ADDR 551
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2171_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2172_ADDR 552
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2172_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2173_ADDR 553
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2173_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2174_ADDR 554
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2174_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2180_ADDR 555
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2180_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2181_ADDR 556
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2181_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2182_ADDR 557
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2182_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2183_ADDR 558
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2183_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2184_ADDR 559
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2184_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2190_ADDR 560
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2190_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2191_ADDR 561
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2191_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2192_ADDR 562
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2192_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2193_ADDR 563
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2193_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2194_ADDR 564
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B2194_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21100_ADDR 565
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21100_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21101_ADDR 566
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21101_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21102_ADDR 567
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21102_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21103_ADDR 568
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21103_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21104_ADDR 569
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21104_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21110_ADDR 570
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21110_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21111_ADDR 571
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21111_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21112_ADDR 572
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21112_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21113_ADDR 573
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21113_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21114_ADDR 574
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21114_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21120_ADDR 575
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21120_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21121_ADDR 576
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21121_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21122_ADDR 577
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21122_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21123_ADDR 578
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21123_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21124_ADDR 579
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21124_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21130_ADDR 580
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21130_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21131_ADDR 581
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21131_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21132_ADDR 582
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21132_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21133_ADDR 583
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21133_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21134_ADDR 584
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21134_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21140_ADDR 585
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21140_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21141_ADDR 586
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21141_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21142_ADDR 587
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21142_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21143_ADDR 588
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21143_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21144_ADDR 589
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21144_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21150_ADDR 590
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21150_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21151_ADDR 591
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21151_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21152_ADDR 592
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21152_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21153_ADDR 593
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21153_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21154_ADDR 594
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7B21154_MEMORYPAGE 0
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7ALPHA_ADDR 5219
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQLRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG7ALPHA_MEMORYPAGE 0
    /* Module EQLrx2 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX2_EQLRX2_COUNT                           96
    #define MOD_RX2_EQLRX2_DEVICE                          "IC1"
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2100_ADDR 597
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2100_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2101_ADDR 598
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2101_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2102_ADDR 599
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2102_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2103_ADDR 600
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2103_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2104_ADDR 601
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2104_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2110_ADDR 602
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2110_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2111_ADDR 603
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2111_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2112_ADDR 604
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2112_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2113_ADDR 605
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2113_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2114_ADDR 606
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2114_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2120_ADDR 607
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2120_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2121_ADDR 608
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2121_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2122_ADDR 609
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2122_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2123_ADDR 610
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2123_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2124_ADDR 611
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2124_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2130_ADDR 612
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2130_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2131_ADDR 613
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2131_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2132_ADDR 614
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2132_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2133_ADDR 615
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2133_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2134_ADDR 616
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2134_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2140_ADDR 617
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2140_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2141_ADDR 618
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2141_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2142_ADDR 619
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2142_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2143_ADDR 620
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2143_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2144_ADDR 621
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2144_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2150_ADDR 622
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2150_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2151_ADDR 623
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2151_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2152_ADDR 624
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2152_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2153_ADDR 625
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2153_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2154_ADDR 626
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2154_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2160_ADDR 627
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2160_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2161_ADDR 628
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2161_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2162_ADDR 629
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2162_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2163_ADDR 630
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2163_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2164_ADDR 631
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2164_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2170_ADDR 632
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2170_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2171_ADDR 633
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2171_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2172_ADDR 634
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2172_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2173_ADDR 635
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2173_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2174_ADDR 636
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2174_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2180_ADDR 637
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2180_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2181_ADDR 638
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2181_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2182_ADDR 639
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2182_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2183_ADDR 640
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2183_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2184_ADDR 641
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2184_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2190_ADDR 642
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2190_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2191_ADDR 643
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2191_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2192_ADDR 644
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2192_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2193_ADDR 645
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2193_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2194_ADDR 646
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B2194_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21100_ADDR 647
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21100_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21101_ADDR 648
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21101_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21102_ADDR 649
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21102_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21103_ADDR 650
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21103_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21104_ADDR 651
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21104_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21110_ADDR 652
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21110_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21111_ADDR 653
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21111_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21112_ADDR 654
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21112_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21113_ADDR 655
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21113_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21114_ADDR 656
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21114_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21120_ADDR 657
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21120_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21121_ADDR 658
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21121_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21122_ADDR 659
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21122_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21123_ADDR 660
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21123_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21124_ADDR 661
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21124_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21130_ADDR 662
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21130_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21131_ADDR 663
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21131_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21132_ADDR 664
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21132_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21133_ADDR 665
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21133_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21134_ADDR 666
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21134_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21140_ADDR 667
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21140_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21141_ADDR 668
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21141_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21142_ADDR 669
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21142_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21143_ADDR 670
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21143_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21144_ADDR 671
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21144_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21150_ADDR 672
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21150_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21151_ADDR 673
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21151_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21152_ADDR 674
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21152_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21153_ADDR 675
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21153_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21154_ADDR 676
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4B21154_MEMORYPAGE 0
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4ALPHA_ADDR 5222
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQLRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG4ALPHA_MEMORYPAGE 0
    /* Module EQLrx1 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX1_EQLRX1_COUNT                           96
    #define MOD_RX1_EQLRX1_DEVICE                          "IC1"
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2100_ADDR 679
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2100_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2101_ADDR 680
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2101_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2102_ADDR 681
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2102_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2103_ADDR 682
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2103_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2104_ADDR 683
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2104_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2110_ADDR 684
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2110_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2111_ADDR 685
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2111_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2112_ADDR 686
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2112_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2113_ADDR 687
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2113_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2114_ADDR 688
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2114_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2120_ADDR 689
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2120_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2121_ADDR 690
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2121_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2122_ADDR 691
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2122_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2123_ADDR 692
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2123_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2124_ADDR 693
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2124_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2130_ADDR 694
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2130_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2131_ADDR 695
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2131_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2132_ADDR 696
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2132_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2133_ADDR 697
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2133_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2134_ADDR 698
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2134_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2140_ADDR 699
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2140_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2141_ADDR 700
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2141_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2142_ADDR 701
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2142_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2143_ADDR 702
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2143_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2144_ADDR 703
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2144_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2150_ADDR 704
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2150_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2151_ADDR 705
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2151_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2152_ADDR 706
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2152_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2153_ADDR 707
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2153_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2154_ADDR 708
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2154_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2160_ADDR 709
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2160_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2161_ADDR 710
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2161_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2162_ADDR 711
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2162_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2163_ADDR 712
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2163_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2164_ADDR 713
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2164_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2170_ADDR 714
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2170_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2171_ADDR 715
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2171_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2172_ADDR 716
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2172_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2173_ADDR 717
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2173_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2174_ADDR 718
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2174_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2180_ADDR 719
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2180_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2181_ADDR 720
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2181_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2182_ADDR 721
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2182_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2183_ADDR 722
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2183_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2184_ADDR 723
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2184_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2190_ADDR 724
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2190_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2191_ADDR 725
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2191_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2192_ADDR 726
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2192_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2193_ADDR 727
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2193_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2194_ADDR 728
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B2194_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21100_ADDR 729
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21100_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21101_ADDR 730
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21101_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21102_ADDR 731
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21102_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21103_ADDR 732
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21103_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21104_ADDR 733
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21104_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21110_ADDR 734
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21110_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21111_ADDR 735
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21111_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21112_ADDR 736
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21112_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21113_ADDR 737
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21113_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21114_ADDR 738
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21114_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21120_ADDR 739
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21120_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21121_ADDR 740
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21121_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21122_ADDR 741
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21122_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21123_ADDR 742
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21123_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21124_ADDR 743
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21124_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21130_ADDR 744
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21130_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21131_ADDR 745
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21131_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21132_ADDR 746
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21132_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21133_ADDR 747
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21133_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21134_ADDR 748
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21134_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21140_ADDR 749
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21140_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21141_ADDR 750
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21141_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21142_ADDR 751
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21142_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21143_ADDR 752
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21143_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21144_ADDR 753
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21144_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21150_ADDR 754
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21150_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21151_ADDR 755
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21151_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21152_ADDR 756
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21152_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21153_ADDR 757
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21153_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21154_ADDR 758
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1B21154_MEMORYPAGE 0
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1ALPHA_ADDR 5225
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQLRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG1ALPHA_MEMORYPAGE 0
    /* Module EQLmp3 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_MP3_EQLMP3_COUNT                           96
    #define MOD_MP3_EQLMP3_DEVICE                          "IC1"
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2100_ADDR 761
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2100_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2101_ADDR 762
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2101_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2102_ADDR 763
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2102_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2103_ADDR 764
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2103_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2104_ADDR 765
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2104_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2110_ADDR 766
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2110_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2111_ADDR 767
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2111_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2112_ADDR 768
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2112_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2113_ADDR 769
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2113_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2114_ADDR 770
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2114_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2120_ADDR 771
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2120_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2121_ADDR 772
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2121_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2122_ADDR 773
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2122_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2123_ADDR 774
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2123_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2124_ADDR 775
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2124_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2130_ADDR 776
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2130_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2131_ADDR 777
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2131_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2132_ADDR 778
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2132_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2133_ADDR 779
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2133_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2134_ADDR 780
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2134_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2140_ADDR 781
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2140_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2141_ADDR 782
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2141_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2142_ADDR 783
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2142_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2143_ADDR 784
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2143_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2144_ADDR 785
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2144_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2150_ADDR 786
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2150_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2151_ADDR 787
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2151_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2152_ADDR 788
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2152_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2153_ADDR 789
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2153_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2154_ADDR 790
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2154_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2160_ADDR 791
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2160_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2161_ADDR 792
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2161_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2162_ADDR 793
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2162_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2163_ADDR 794
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2163_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2164_ADDR 795
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2164_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2170_ADDR 796
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2170_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2171_ADDR 797
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2171_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2172_ADDR 798
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2172_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2173_ADDR 799
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2173_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2174_ADDR 800
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2174_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2180_ADDR 801
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2180_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2181_ADDR 802
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2181_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2182_ADDR 803
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2182_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2183_ADDR 804
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2183_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2184_ADDR 805
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2184_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2190_ADDR 806
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2190_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2191_ADDR 807
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2191_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2192_ADDR 808
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2192_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2193_ADDR 809
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2193_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2194_ADDR 810
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B2194_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21100_ADDR 811
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21100_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21101_ADDR 812
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21101_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21102_ADDR 813
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21102_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21103_ADDR 814
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21103_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21104_ADDR 815
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21104_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21110_ADDR 816
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21110_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21111_ADDR 817
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21111_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21112_ADDR 818
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21112_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21113_ADDR 819
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21113_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21114_ADDR 820
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21114_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21120_ADDR 821
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21120_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21121_ADDR 822
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21121_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21122_ADDR 823
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21122_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21123_ADDR 824
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21123_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21124_ADDR 825
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21124_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21130_ADDR 826
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21130_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21131_ADDR 827
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21131_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21132_ADDR 828
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21132_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21133_ADDR 829
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21133_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21134_ADDR 830
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21134_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21140_ADDR 831
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21140_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21141_ADDR 832
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21141_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21142_ADDR 833
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21142_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21143_ADDR 834
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21143_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21144_ADDR 835
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21144_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21150_ADDR 836
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21150_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21151_ADDR 837
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21151_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21152_ADDR 838
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21152_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21153_ADDR 839
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21153_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21154_ADDR 840
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22B21154_MEMORYPAGE 0
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22ALPHA_ADDR 5228
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQLMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG22ALPHA_MEMORYPAGE 0
    /* Module EQMbt - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_BT_EQMBT_COUNT                             96
    #define MOD_BT_EQMBT_DEVICE                            "IC1"
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2100_ADDR 843
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2100_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2101_ADDR 844
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2101_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2102_ADDR 845
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2102_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2103_ADDR 846
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2103_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2104_ADDR 847
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2104_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2110_ADDR 848
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2110_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2111_ADDR 849
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2111_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2112_ADDR 850
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2112_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2113_ADDR 851
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2113_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2114_ADDR 852
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2114_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2120_ADDR 853
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2120_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2121_ADDR 854
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2121_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2122_ADDR 855
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2122_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2123_ADDR 856
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2123_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2124_ADDR 857
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2124_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2130_ADDR 858
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2130_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2131_ADDR 859
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2131_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2132_ADDR 860
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2132_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2133_ADDR 861
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2133_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2134_ADDR 862
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2134_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2140_ADDR 863
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2140_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2141_ADDR 864
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2141_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2142_ADDR 865
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2142_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2143_ADDR 866
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2143_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2144_ADDR 867
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2144_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2150_ADDR 868
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2150_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2151_ADDR 869
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2151_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2152_ADDR 870
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2152_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2153_ADDR 871
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2153_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2154_ADDR 872
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2154_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2160_ADDR 873
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2160_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2161_ADDR 874
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2161_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2162_ADDR 875
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2162_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2163_ADDR 876
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2163_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2164_ADDR 877
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2164_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2170_ADDR 878
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2170_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2171_ADDR 879
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2171_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2172_ADDR 880
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2172_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2173_ADDR 881
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2173_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2174_ADDR 882
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2174_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2180_ADDR 883
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2180_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2181_ADDR 884
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2181_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2182_ADDR 885
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2182_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2183_ADDR 886
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2183_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2184_ADDR 887
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2184_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2190_ADDR 888
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2190_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2191_ADDR 889
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2191_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2192_ADDR 890
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2192_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2193_ADDR 891
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2193_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2194_ADDR 892
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B2194_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21100_ADDR 893
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21100_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21101_ADDR 894
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21101_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21102_ADDR 895
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21102_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21103_ADDR 896
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21103_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21104_ADDR 897
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21104_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21110_ADDR 898
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21110_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21111_ADDR 899
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21111_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21112_ADDR 900
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21112_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21113_ADDR 901
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21113_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21114_ADDR 902
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21114_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21120_ADDR 903
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21120_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21121_ADDR 904
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21121_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21122_ADDR 905
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21122_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21123_ADDR 906
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21123_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21124_ADDR 907
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21124_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21130_ADDR 908
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21130_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21131_ADDR 909
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21131_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21132_ADDR 910
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21132_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21133_ADDR 911
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21133_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21134_ADDR 912
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21134_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21140_ADDR 913
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21140_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21141_ADDR 914
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21141_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21142_ADDR 915
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21142_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21143_ADDR 916
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21143_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21144_ADDR 917
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21144_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21150_ADDR 918
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21150_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21151_ADDR 919
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21151_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21152_ADDR 920
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21152_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21153_ADDR 921
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21153_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21154_ADDR 922
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20B21154_MEMORYPAGE 0
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20ALPHA_ADDR 5231
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQMBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG20ALPHA_MEMORYPAGE 0
    /* Module EQMw2 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_WMIC2_EQMW2_COUNT                          96
    #define MOD_WMIC2_EQMW2_DEVICE                         "IC1"
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2100_ADDR 925
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2100_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2101_ADDR 926
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2101_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2102_ADDR 927
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2102_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2103_ADDR 928
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2103_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2104_ADDR 929
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2104_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2110_ADDR 930
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2110_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2111_ADDR 931
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2111_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2112_ADDR 932
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2112_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2113_ADDR 933
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2113_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2114_ADDR 934
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2114_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2120_ADDR 935
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2120_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2121_ADDR 936
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2121_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2122_ADDR 937
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2122_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2123_ADDR 938
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2123_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2124_ADDR 939
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2124_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2130_ADDR 940
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2130_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2131_ADDR 941
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2131_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2132_ADDR 942
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2132_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2133_ADDR 943
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2133_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2134_ADDR 944
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2134_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2140_ADDR 945
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2140_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2141_ADDR 946
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2141_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2142_ADDR 947
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2142_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2143_ADDR 948
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2143_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2144_ADDR 949
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2144_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2150_ADDR 950
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2150_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2151_ADDR 951
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2151_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2152_ADDR 952
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2152_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2153_ADDR 953
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2153_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2154_ADDR 954
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2154_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2160_ADDR 955
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2160_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2161_ADDR 956
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2161_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2162_ADDR 957
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2162_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2163_ADDR 958
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2163_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2164_ADDR 959
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2164_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2170_ADDR 960
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2170_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2171_ADDR 961
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2171_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2172_ADDR 962
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2172_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2173_ADDR 963
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2173_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2174_ADDR 964
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2174_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2180_ADDR 965
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2180_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2181_ADDR 966
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2181_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2182_ADDR 967
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2182_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2183_ADDR 968
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2183_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2184_ADDR 969
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2184_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2190_ADDR 970
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2190_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2191_ADDR 971
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2191_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2192_ADDR 972
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2192_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2193_ADDR 973
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2193_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2194_ADDR 974
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B2194_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21100_ADDR 975
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21100_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21101_ADDR 976
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21101_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21102_ADDR 977
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21102_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21103_ADDR 978
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21103_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21104_ADDR 979
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21104_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21110_ADDR 980
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21110_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21111_ADDR 981
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21111_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21112_ADDR 982
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21112_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21113_ADDR 983
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21113_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21114_ADDR 984
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21114_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21120_ADDR 985
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21120_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21121_ADDR 986
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21121_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21122_ADDR 987
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21122_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21123_ADDR 988
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21123_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21124_ADDR 989
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21124_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21130_ADDR 990
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21130_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21131_ADDR 991
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21131_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21132_ADDR 992
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21132_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21133_ADDR 993
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21133_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21134_ADDR 994
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21134_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21140_ADDR 995
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21140_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21141_ADDR 996
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21141_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21142_ADDR 997
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21142_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21143_ADDR 998
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21143_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21144_ADDR 999
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21144_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21150_ADDR 1000
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21150_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21151_ADDR 1001
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21151_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21152_ADDR 1002
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21152_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21153_ADDR 1003
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21153_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21154_ADDR 1004
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17B21154_MEMORYPAGE 0
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17ALPHA_ADDR 5234
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQMW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG17ALPHA_MEMORYPAGE 0
    /* Module EQMw1 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_WMIC1_EQMW1_COUNT                          96
    #define MOD_WMIC1_EQMW1_DEVICE                         "IC1"
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2100_ADDR 1007
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2100_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2101_ADDR 1008
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2101_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2102_ADDR 1009
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2102_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2103_ADDR 1010
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2103_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2104_ADDR 1011
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2104_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2110_ADDR 1012
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2110_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2111_ADDR 1013
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2111_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2112_ADDR 1014
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2112_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2113_ADDR 1015
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2113_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2114_ADDR 1016
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2114_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2120_ADDR 1017
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2120_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2121_ADDR 1018
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2121_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2122_ADDR 1019
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2122_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2123_ADDR 1020
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2123_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2124_ADDR 1021
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2124_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2130_ADDR 1022
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2130_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2131_ADDR 1023
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2131_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2132_ADDR 1024
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2132_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2133_ADDR 1025
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2133_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2134_ADDR 1026
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2134_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2140_ADDR 1027
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2140_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2141_ADDR 1028
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2141_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2142_ADDR 1029
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2142_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2143_ADDR 1030
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2143_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2144_ADDR 1031
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2144_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2150_ADDR 1032
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2150_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2151_ADDR 1033
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2151_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2152_ADDR 1034
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2152_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2153_ADDR 1035
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2153_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2154_ADDR 1036
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2154_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2160_ADDR 1037
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2160_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2161_ADDR 1038
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2161_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2162_ADDR 1039
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2162_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2163_ADDR 1040
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2163_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2164_ADDR 1041
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2164_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2170_ADDR 1042
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2170_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2171_ADDR 1043
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2171_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2172_ADDR 1044
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2172_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2173_ADDR 1045
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2173_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2174_ADDR 1046
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2174_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2180_ADDR 1047
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2180_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2181_ADDR 1048
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2181_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2182_ADDR 1049
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2182_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2183_ADDR 1050
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2183_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2184_ADDR 1051
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2184_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2190_ADDR 1052
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2190_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2191_ADDR 1053
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2191_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2192_ADDR 1054
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2192_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2193_ADDR 1055
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2193_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2194_ADDR 1056
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B2194_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21100_ADDR 1057
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21100_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21101_ADDR 1058
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21101_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21102_ADDR 1059
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21102_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21103_ADDR 1060
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21103_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21104_ADDR 1061
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21104_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21110_ADDR 1062
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21110_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21111_ADDR 1063
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21111_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21112_ADDR 1064
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21112_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21113_ADDR 1065
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21113_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21114_ADDR 1066
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21114_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21120_ADDR 1067
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21120_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21121_ADDR 1068
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21121_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21122_ADDR 1069
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21122_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21123_ADDR 1070
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21123_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21124_ADDR 1071
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21124_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21130_ADDR 1072
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21130_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21131_ADDR 1073
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21131_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21132_ADDR 1074
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21132_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21133_ADDR 1075
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21133_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21134_ADDR 1076
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21134_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21140_ADDR 1077
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21140_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21141_ADDR 1078
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21141_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21142_ADDR 1079
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21142_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21143_ADDR 1080
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21143_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21144_ADDR 1081
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21144_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21150_ADDR 1082
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21150_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21151_ADDR 1083
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21151_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21152_ADDR 1084
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21152_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21153_ADDR 1085
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21153_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21154_ADDR 1086
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14B21154_MEMORYPAGE 0
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14ALPHA_ADDR 5237
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQMW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG14ALPHA_MEMORYPAGE 0
    /* Module EQMrx4 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX4_EQMRX4_COUNT                           96
    #define MOD_RX4_EQMRX4_DEVICE                          "IC1"
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2100_ADDR 1089
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2100_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2101_ADDR 1090
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2101_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2102_ADDR 1091
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2102_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2103_ADDR 1092
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2103_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2104_ADDR 1093
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2104_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2110_ADDR 1094
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2110_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2111_ADDR 1095
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2111_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2112_ADDR 1096
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2112_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2113_ADDR 1097
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2113_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2114_ADDR 1098
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2114_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2120_ADDR 1099
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2120_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2121_ADDR 1100
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2121_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2122_ADDR 1101
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2122_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2123_ADDR 1102
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2123_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2124_ADDR 1103
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2124_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2130_ADDR 1104
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2130_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2131_ADDR 1105
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2131_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2132_ADDR 1106
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2132_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2133_ADDR 1107
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2133_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2134_ADDR 1108
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2134_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2140_ADDR 1109
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2140_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2141_ADDR 1110
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2141_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2142_ADDR 1111
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2142_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2143_ADDR 1112
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2143_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2144_ADDR 1113
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2144_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2150_ADDR 1114
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2150_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2151_ADDR 1115
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2151_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2152_ADDR 1116
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2152_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2153_ADDR 1117
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2153_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2154_ADDR 1118
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2154_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2160_ADDR 1119
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2160_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2161_ADDR 1120
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2161_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2162_ADDR 1121
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2162_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2163_ADDR 1122
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2163_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2164_ADDR 1123
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2164_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2170_ADDR 1124
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2170_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2171_ADDR 1125
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2171_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2172_ADDR 1126
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2172_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2173_ADDR 1127
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2173_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2174_ADDR 1128
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2174_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2180_ADDR 1129
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2180_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2181_ADDR 1130
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2181_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2182_ADDR 1131
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2182_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2183_ADDR 1132
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2183_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2184_ADDR 1133
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2184_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2190_ADDR 1134
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2190_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2191_ADDR 1135
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2191_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2192_ADDR 1136
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2192_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2193_ADDR 1137
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2193_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2194_ADDR 1138
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B2194_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21100_ADDR 1139
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21100_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21101_ADDR 1140
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21101_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21102_ADDR 1141
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21102_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21103_ADDR 1142
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21103_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21104_ADDR 1143
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21104_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21110_ADDR 1144
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21110_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21111_ADDR 1145
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21111_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21112_ADDR 1146
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21112_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21113_ADDR 1147
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21113_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21114_ADDR 1148
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21114_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21120_ADDR 1149
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21120_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21121_ADDR 1150
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21121_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21122_ADDR 1151
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21122_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21123_ADDR 1152
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21123_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21124_ADDR 1153
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21124_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21130_ADDR 1154
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21130_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21131_ADDR 1155
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21131_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21132_ADDR 1156
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21132_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21133_ADDR 1157
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21133_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21134_ADDR 1158
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21134_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21140_ADDR 1159
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21140_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21141_ADDR 1160
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21141_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21142_ADDR 1161
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21142_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21143_ADDR 1162
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21143_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21144_ADDR 1163
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21144_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21150_ADDR 1164
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21150_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21151_ADDR 1165
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21151_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21152_ADDR 1166
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21152_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21153_ADDR 1167
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21153_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21154_ADDR 1168
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11B21154_MEMORYPAGE 0
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11ALPHA_ADDR 5240
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQMRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG11ALPHA_MEMORYPAGE 0
    /* Module EQMrx3 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX3_EQMRX3_COUNT                           96
    #define MOD_RX3_EQMRX3_DEVICE                          "IC1"
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2100_ADDR 1171
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2100_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2101_ADDR 1172
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2101_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2102_ADDR 1173
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2102_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2103_ADDR 1174
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2103_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2104_ADDR 1175
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2104_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2110_ADDR 1176
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2110_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2111_ADDR 1177
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2111_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2112_ADDR 1178
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2112_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2113_ADDR 1179
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2113_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2114_ADDR 1180
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2114_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2120_ADDR 1181
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2120_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2121_ADDR 1182
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2121_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2122_ADDR 1183
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2122_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2123_ADDR 1184
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2123_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2124_ADDR 1185
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2124_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2130_ADDR 1186
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2130_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2131_ADDR 1187
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2131_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2132_ADDR 1188
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2132_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2133_ADDR 1189
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2133_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2134_ADDR 1190
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2134_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2140_ADDR 1191
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2140_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2141_ADDR 1192
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2141_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2142_ADDR 1193
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2142_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2143_ADDR 1194
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2143_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2144_ADDR 1195
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2144_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2150_ADDR 1196
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2150_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2151_ADDR 1197
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2151_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2152_ADDR 1198
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2152_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2153_ADDR 1199
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2153_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2154_ADDR 1200
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2154_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2160_ADDR 1201
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2160_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2161_ADDR 1202
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2161_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2162_ADDR 1203
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2162_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2163_ADDR 1204
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2163_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2164_ADDR 1205
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2164_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2170_ADDR 1206
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2170_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2171_ADDR 1207
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2171_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2172_ADDR 1208
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2172_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2173_ADDR 1209
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2173_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2174_ADDR 1210
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2174_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2180_ADDR 1211
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2180_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2181_ADDR 1212
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2181_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2182_ADDR 1213
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2182_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2183_ADDR 1214
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2183_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2184_ADDR 1215
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2184_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2190_ADDR 1216
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2190_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2191_ADDR 1217
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2191_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2192_ADDR 1218
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2192_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2193_ADDR 1219
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2193_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2194_ADDR 1220
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B2194_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21100_ADDR 1221
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21100_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21101_ADDR 1222
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21101_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21102_ADDR 1223
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21102_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21103_ADDR 1224
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21103_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21104_ADDR 1225
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21104_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21110_ADDR 1226
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21110_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21111_ADDR 1227
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21111_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21112_ADDR 1228
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21112_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21113_ADDR 1229
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21113_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21114_ADDR 1230
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21114_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21120_ADDR 1231
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21120_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21121_ADDR 1232
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21121_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21122_ADDR 1233
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21122_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21123_ADDR 1234
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21123_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21124_ADDR 1235
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21124_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21130_ADDR 1236
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21130_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21131_ADDR 1237
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21131_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21132_ADDR 1238
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21132_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21133_ADDR 1239
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21133_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21134_ADDR 1240
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21134_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21140_ADDR 1241
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21140_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21141_ADDR 1242
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21141_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21142_ADDR 1243
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21142_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21143_ADDR 1244
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21143_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21144_ADDR 1245
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21144_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21150_ADDR 1246
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21150_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21151_ADDR 1247
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21151_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21152_ADDR 1248
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21152_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21153_ADDR 1249
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21153_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21154_ADDR 1250
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8B21154_MEMORYPAGE 0
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8ALPHA_ADDR 5243
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQMRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG8ALPHA_MEMORYPAGE 0
    /* Module EQMrx2 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX2_EQMRX2_COUNT                           96
    #define MOD_RX2_EQMRX2_DEVICE                          "IC1"
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2100_ADDR 1253
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2100_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2101_ADDR 1254
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2101_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2102_ADDR 1255
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2102_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2103_ADDR 1256
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2103_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2104_ADDR 1257
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2104_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2110_ADDR 1258
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2110_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2111_ADDR 1259
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2111_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2112_ADDR 1260
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2112_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2113_ADDR 1261
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2113_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2114_ADDR 1262
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2114_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2120_ADDR 1263
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2120_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2121_ADDR 1264
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2121_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2122_ADDR 1265
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2122_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2123_ADDR 1266
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2123_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2124_ADDR 1267
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2124_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2130_ADDR 1268
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2130_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2131_ADDR 1269
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2131_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2132_ADDR 1270
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2132_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2133_ADDR 1271
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2133_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2134_ADDR 1272
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2134_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2140_ADDR 1273
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2140_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2141_ADDR 1274
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2141_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2142_ADDR 1275
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2142_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2143_ADDR 1276
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2143_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2144_ADDR 1277
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2144_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2150_ADDR 1278
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2150_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2151_ADDR 1279
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2151_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2152_ADDR 1280
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2152_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2153_ADDR 1281
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2153_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2154_ADDR 1282
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2154_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2160_ADDR 1283
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2160_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2161_ADDR 1284
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2161_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2162_ADDR 1285
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2162_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2163_ADDR 1286
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2163_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2164_ADDR 1287
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2164_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2170_ADDR 1288
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2170_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2171_ADDR 1289
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2171_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2172_ADDR 1290
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2172_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2173_ADDR 1291
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2173_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2174_ADDR 1292
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2174_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2180_ADDR 1293
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2180_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2181_ADDR 1294
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2181_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2182_ADDR 1295
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2182_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2183_ADDR 1296
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2183_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2184_ADDR 1297
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2184_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2190_ADDR 1298
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2190_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2191_ADDR 1299
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2191_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2192_ADDR 1300
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2192_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2193_ADDR 1301
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2193_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2194_ADDR 1302
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B2194_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21100_ADDR 1303
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21100_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21101_ADDR 1304
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21101_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21102_ADDR 1305
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21102_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21103_ADDR 1306
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21103_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21104_ADDR 1307
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21104_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21110_ADDR 1308
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21110_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21111_ADDR 1309
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21111_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21112_ADDR 1310
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21112_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21113_ADDR 1311
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21113_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21114_ADDR 1312
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21114_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21120_ADDR 1313
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21120_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21121_ADDR 1314
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21121_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21122_ADDR 1315
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21122_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21123_ADDR 1316
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21123_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21124_ADDR 1317
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21124_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21130_ADDR 1318
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21130_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21131_ADDR 1319
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21131_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21132_ADDR 1320
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21132_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21133_ADDR 1321
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21133_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21134_ADDR 1322
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21134_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21140_ADDR 1323
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21140_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21141_ADDR 1324
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21141_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21142_ADDR 1325
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21142_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21143_ADDR 1326
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21143_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21144_ADDR 1327
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21144_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21150_ADDR 1328
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21150_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21151_ADDR 1329
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21151_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21152_ADDR 1330
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21152_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21153_ADDR 1331
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21153_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21154_ADDR 1332
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5B21154_MEMORYPAGE 0
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5ALPHA_ADDR 5246
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQMRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG5ALPHA_MEMORYPAGE 0
    /* Module EQMrx1 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX1_EQMRX1_COUNT                           96
    #define MOD_RX1_EQMRX1_DEVICE                          "IC1"
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2100_ADDR 1335
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2100_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2101_ADDR 1336
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2101_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2102_ADDR 1337
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2102_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2103_ADDR 1338
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2103_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2104_ADDR 1339
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2104_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2110_ADDR 1340
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2110_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2111_ADDR 1341
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2111_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2112_ADDR 1342
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2112_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2113_ADDR 1343
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2113_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2114_ADDR 1344
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2114_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2120_ADDR 1345
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2120_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2121_ADDR 1346
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2121_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2122_ADDR 1347
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2122_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2123_ADDR 1348
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2123_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2124_ADDR 1349
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2124_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2130_ADDR 1350
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2130_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2131_ADDR 1351
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2131_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2132_ADDR 1352
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2132_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2133_ADDR 1353
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2133_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2134_ADDR 1354
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2134_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2140_ADDR 1355
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2140_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2141_ADDR 1356
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2141_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2142_ADDR 1357
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2142_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2143_ADDR 1358
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2143_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2144_ADDR 1359
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2144_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2150_ADDR 1360
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2150_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2151_ADDR 1361
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2151_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2152_ADDR 1362
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2152_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2153_ADDR 1363
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2153_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2154_ADDR 1364
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2154_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2160_ADDR 1365
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2160_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2161_ADDR 1366
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2161_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2162_ADDR 1367
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2162_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2163_ADDR 1368
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2163_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2164_ADDR 1369
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2164_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2170_ADDR 1370
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2170_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2171_ADDR 1371
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2171_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2172_ADDR 1372
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2172_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2173_ADDR 1373
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2173_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2174_ADDR 1374
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2174_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2180_ADDR 1375
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2180_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2181_ADDR 1376
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2181_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2182_ADDR 1377
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2182_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2183_ADDR 1378
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2183_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2184_ADDR 1379
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2184_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2190_ADDR 1380
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2190_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2191_ADDR 1381
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2191_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2192_ADDR 1382
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2192_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2193_ADDR 1383
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2193_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2194_ADDR 1384
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B2194_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21100_ADDR 1385
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21100_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21101_ADDR 1386
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21101_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21102_ADDR 1387
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21102_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21103_ADDR 1388
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21103_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21104_ADDR 1389
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21104_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21110_ADDR 1390
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21110_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21111_ADDR 1391
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21111_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21112_ADDR 1392
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21112_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21113_ADDR 1393
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21113_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21114_ADDR 1394
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21114_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21120_ADDR 1395
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21120_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21121_ADDR 1396
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21121_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21122_ADDR 1397
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21122_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21123_ADDR 1398
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21123_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21124_ADDR 1399
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21124_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21130_ADDR 1400
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21130_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21131_ADDR 1401
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21131_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21132_ADDR 1402
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21132_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21133_ADDR 1403
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21133_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21134_ADDR 1404
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21134_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21140_ADDR 1405
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21140_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21141_ADDR 1406
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21141_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21142_ADDR 1407
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21142_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21143_ADDR 1408
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21143_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21144_ADDR 1409
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21144_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21150_ADDR 1410
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21150_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21151_ADDR 1411
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21151_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21152_ADDR 1412
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21152_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21153_ADDR 1413
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21153_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21154_ADDR 1414
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2B21154_MEMORYPAGE 0
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2ALPHA_ADDR 5249
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQMRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG2ALPHA_MEMORYPAGE 0
    /* Module EQMmp3 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_MP3_EQMMP3_COUNT                           96
    #define MOD_MP3_EQMMP3_DEVICE                          "IC1"
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2100_ADDR 1417
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2100_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2101_ADDR 1418
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2101_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2102_ADDR 1419
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2102_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2103_ADDR 1420
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2103_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2104_ADDR 1421
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2104_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2110_ADDR 1422
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2110_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2111_ADDR 1423
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2111_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2112_ADDR 1424
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2112_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2113_ADDR 1425
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2113_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2114_ADDR 1426
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2114_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2120_ADDR 1427
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2120_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2121_ADDR 1428
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2121_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2122_ADDR 1429
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2122_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2123_ADDR 1430
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2123_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2124_ADDR 1431
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2124_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2130_ADDR 1432
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2130_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2131_ADDR 1433
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2131_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2132_ADDR 1434
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2132_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2133_ADDR 1435
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2133_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2134_ADDR 1436
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2134_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2140_ADDR 1437
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2140_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2141_ADDR 1438
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2141_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2142_ADDR 1439
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2142_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2143_ADDR 1440
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2143_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2144_ADDR 1441
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2144_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2150_ADDR 1442
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2150_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2151_ADDR 1443
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2151_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2152_ADDR 1444
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2152_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2153_ADDR 1445
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2153_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2154_ADDR 1446
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2154_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2160_ADDR 1447
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2160_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2161_ADDR 1448
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2161_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2162_ADDR 1449
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2162_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2163_ADDR 1450
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2163_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2164_ADDR 1451
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2164_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2170_ADDR 1452
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2170_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2171_ADDR 1453
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2171_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2172_ADDR 1454
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2172_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2173_ADDR 1455
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2173_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2174_ADDR 1456
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2174_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2180_ADDR 1457
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2180_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2181_ADDR 1458
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2181_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2182_ADDR 1459
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2182_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2183_ADDR 1460
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2183_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2184_ADDR 1461
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2184_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2190_ADDR 1462
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2190_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2191_ADDR 1463
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2191_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2192_ADDR 1464
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2192_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2193_ADDR 1465
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2193_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2194_ADDR 1466
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B2194_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21100_ADDR 1467
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21100_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21101_ADDR 1468
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21101_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21102_ADDR 1469
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21102_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21103_ADDR 1470
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21103_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21104_ADDR 1471
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21104_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21110_ADDR 1472
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21110_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21111_ADDR 1473
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21111_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21112_ADDR 1474
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21112_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21113_ADDR 1475
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21113_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21114_ADDR 1476
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21114_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21120_ADDR 1477
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21120_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21121_ADDR 1478
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21121_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21122_ADDR 1479
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21122_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21123_ADDR 1480
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21123_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21124_ADDR 1481
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21124_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21130_ADDR 1482
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21130_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21131_ADDR 1483
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21131_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21132_ADDR 1484
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21132_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21133_ADDR 1485
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21133_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21134_ADDR 1486
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21134_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21140_ADDR 1487
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21140_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21141_ADDR 1488
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21141_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21142_ADDR 1489
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21142_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21143_ADDR 1490
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21143_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21144_ADDR 1491
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21144_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21150_ADDR 1492
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21150_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21151_ADDR 1493
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21151_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21152_ADDR 1494
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21152_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21153_ADDR 1495
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21153_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21154_ADDR 1496
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23B21154_MEMORYPAGE 0
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23ALPHA_ADDR 5252
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQMMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG23ALPHA_MEMORYPAGE 0
    /* Module EQHbt - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_BT_EQHBT_COUNT                             96
    #define MOD_BT_EQHBT_DEVICE                            "IC1"
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2100_ADDR 1499
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2100_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2101_ADDR 1500
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2101_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2102_ADDR 1501
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2102_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2103_ADDR 1502
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2103_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2104_ADDR 1503
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2104_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2110_ADDR 1504
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2110_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2111_ADDR 1505
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2111_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2112_ADDR 1506
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2112_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2113_ADDR 1507
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2113_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2114_ADDR 1508
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2114_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2120_ADDR 1509
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2120_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2121_ADDR 1510
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2121_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2122_ADDR 1511
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2122_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2123_ADDR 1512
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2123_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2124_ADDR 1513
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2124_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2130_ADDR 1514
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2130_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2131_ADDR 1515
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2131_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2132_ADDR 1516
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2132_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2133_ADDR 1517
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2133_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2134_ADDR 1518
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2134_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2140_ADDR 1519
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2140_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2141_ADDR 1520
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2141_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2142_ADDR 1521
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2142_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2143_ADDR 1522
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2143_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2144_ADDR 1523
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2144_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2150_ADDR 1524
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2150_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2151_ADDR 1525
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2151_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2152_ADDR 1526
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2152_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2153_ADDR 1527
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2153_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2154_ADDR 1528
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2154_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2160_ADDR 1529
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2160_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2161_ADDR 1530
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2161_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2162_ADDR 1531
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2162_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2163_ADDR 1532
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2163_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2164_ADDR 1533
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2164_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2170_ADDR 1534
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2170_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2171_ADDR 1535
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2171_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2172_ADDR 1536
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2172_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2173_ADDR 1537
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2173_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2174_ADDR 1538
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2174_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2180_ADDR 1539
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2180_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2181_ADDR 1540
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2181_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2182_ADDR 1541
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2182_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2183_ADDR 1542
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2183_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2184_ADDR 1543
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2184_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2190_ADDR 1544
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2190_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2191_ADDR 1545
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2191_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2192_ADDR 1546
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2192_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2193_ADDR 1547
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2193_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2194_ADDR 1548
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B2194_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21100_ADDR 1549
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21100_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21101_ADDR 1550
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21101_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21102_ADDR 1551
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21102_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21103_ADDR 1552
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21103_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21104_ADDR 1553
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21104_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21110_ADDR 1554
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21110_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21111_ADDR 1555
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21111_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21112_ADDR 1556
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21112_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21113_ADDR 1557
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21113_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21114_ADDR 1558
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21114_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21120_ADDR 1559
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21120_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21121_ADDR 1560
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21121_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21122_ADDR 1561
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21122_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21123_ADDR 1562
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21123_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21124_ADDR 1563
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21124_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21130_ADDR 1564
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21130_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21131_ADDR 1565
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21131_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21132_ADDR 1566
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21132_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21133_ADDR 1567
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21133_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21134_ADDR 1568
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21134_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21140_ADDR 1569
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21140_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21141_ADDR 1570
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21141_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21142_ADDR 1571
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21142_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21143_ADDR 1572
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21143_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21144_ADDR 1573
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21144_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21150_ADDR 1574
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21150_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21151_ADDR 1575
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21151_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21152_ADDR 1576
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21152_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21153_ADDR 1577
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21153_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21154_ADDR 1578
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21B21154_MEMORYPAGE 0
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21ALPHA_ADDR 5255
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_BT_EQHBT_ALG0_IDXSELINDPBANDSALGMDPSLEWALG21ALPHA_MEMORYPAGE 0
    /* Module EQHw2 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_WMIC2_EQHW2_COUNT                          96
    #define MOD_WMIC2_EQHW2_DEVICE                         "IC1"
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2100_ADDR 1581
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2100_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2101_ADDR 1582
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2101_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2102_ADDR 1583
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2102_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2103_ADDR 1584
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2103_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2104_ADDR 1585
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2104_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2110_ADDR 1586
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2110_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2111_ADDR 1587
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2111_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2112_ADDR 1588
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2112_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2113_ADDR 1589
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2113_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2114_ADDR 1590
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2114_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2120_ADDR 1591
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2120_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2121_ADDR 1592
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2121_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2122_ADDR 1593
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2122_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2123_ADDR 1594
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2123_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2124_ADDR 1595
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2124_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2130_ADDR 1596
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2130_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2131_ADDR 1597
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2131_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2132_ADDR 1598
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2132_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2133_ADDR 1599
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2133_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2134_ADDR 1600
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2134_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2140_ADDR 1601
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2140_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2141_ADDR 1602
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2141_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2142_ADDR 1603
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2142_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2143_ADDR 1604
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2143_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2144_ADDR 1605
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2144_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2150_ADDR 1606
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2150_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2151_ADDR 1607
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2151_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2152_ADDR 1608
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2152_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2153_ADDR 1609
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2153_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2154_ADDR 1610
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2154_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2160_ADDR 1611
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2160_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2161_ADDR 1612
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2161_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2162_ADDR 1613
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2162_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2163_ADDR 1614
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2163_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2164_ADDR 1615
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2164_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2170_ADDR 1616
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2170_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2171_ADDR 1617
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2171_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2172_ADDR 1618
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2172_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2173_ADDR 1619
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2173_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2174_ADDR 1620
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2174_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2180_ADDR 1621
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2180_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2181_ADDR 1622
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2181_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2182_ADDR 1623
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2182_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2183_ADDR 1624
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2183_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2184_ADDR 1625
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2184_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2190_ADDR 1626
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2190_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2191_ADDR 1627
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2191_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2192_ADDR 1628
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2192_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2193_ADDR 1629
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2193_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2194_ADDR 1630
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B2194_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21100_ADDR 1631
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21100_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21101_ADDR 1632
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21101_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21102_ADDR 1633
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21102_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21103_ADDR 1634
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21103_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21104_ADDR 1635
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21104_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21110_ADDR 1636
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21110_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21111_ADDR 1637
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21111_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21112_ADDR 1638
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21112_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21113_ADDR 1639
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21113_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21114_ADDR 1640
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21114_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21120_ADDR 1641
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21120_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21121_ADDR 1642
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21121_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21122_ADDR 1643
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21122_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21123_ADDR 1644
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21123_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21124_ADDR 1645
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21124_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21130_ADDR 1646
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21130_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21131_ADDR 1647
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21131_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21132_ADDR 1648
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21132_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21133_ADDR 1649
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21133_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21134_ADDR 1650
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21134_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21140_ADDR 1651
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21140_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21141_ADDR 1652
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21141_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21142_ADDR 1653
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21142_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21143_ADDR 1654
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21143_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21144_ADDR 1655
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21144_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21150_ADDR 1656
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21150_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21151_ADDR 1657
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21151_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21152_ADDR 1658
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21152_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21153_ADDR 1659
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21153_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21154_ADDR 1660
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18B21154_MEMORYPAGE 0
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18ALPHA_ADDR 5258
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC2_EQHW2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG18ALPHA_MEMORYPAGE 0
    /* Module EQHw1 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_WMIC1_EQHW1_COUNT                          96
    #define MOD_WMIC1_EQHW1_DEVICE                         "IC1"
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2100_ADDR 1663
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2100_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2101_ADDR 1664
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2101_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2102_ADDR 1665
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2102_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2103_ADDR 1666
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2103_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2104_ADDR 1667
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2104_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2110_ADDR 1668
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2110_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2111_ADDR 1669
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2111_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2112_ADDR 1670
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2112_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2113_ADDR 1671
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2113_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2114_ADDR 1672
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2114_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2120_ADDR 1673
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2120_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2121_ADDR 1674
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2121_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2122_ADDR 1675
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2122_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2123_ADDR 1676
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2123_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2124_ADDR 1677
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2124_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2130_ADDR 1678
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2130_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2131_ADDR 1679
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2131_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2132_ADDR 1680
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2132_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2133_ADDR 1681
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2133_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2134_ADDR 1682
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2134_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2140_ADDR 1683
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2140_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2141_ADDR 1684
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2141_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2142_ADDR 1685
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2142_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2143_ADDR 1686
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2143_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2144_ADDR 1687
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2144_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2150_ADDR 1688
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2150_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2151_ADDR 1689
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2151_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2152_ADDR 1690
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2152_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2153_ADDR 1691
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2153_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2154_ADDR 1692
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2154_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2160_ADDR 1693
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2160_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2161_ADDR 1694
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2161_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2162_ADDR 1695
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2162_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2163_ADDR 1696
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2163_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2164_ADDR 1697
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2164_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2170_ADDR 1698
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2170_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2171_ADDR 1699
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2171_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2172_ADDR 1700
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2172_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2173_ADDR 1701
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2173_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2174_ADDR 1702
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2174_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2180_ADDR 1703
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2180_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2181_ADDR 1704
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2181_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2182_ADDR 1705
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2182_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2183_ADDR 1706
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2183_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2184_ADDR 1707
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2184_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2190_ADDR 1708
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2190_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2191_ADDR 1709
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2191_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2192_ADDR 1710
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2192_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2193_ADDR 1711
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2193_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2194_ADDR 1712
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B2194_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21100_ADDR 1713
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21100_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21101_ADDR 1714
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21101_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21102_ADDR 1715
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21102_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21103_ADDR 1716
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21103_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21104_ADDR 1717
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21104_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21110_ADDR 1718
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21110_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21111_ADDR 1719
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21111_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21112_ADDR 1720
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21112_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21113_ADDR 1721
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21113_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21114_ADDR 1722
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21114_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21120_ADDR 1723
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21120_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21121_ADDR 1724
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21121_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21122_ADDR 1725
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21122_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21123_ADDR 1726
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21123_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21124_ADDR 1727
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21124_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21130_ADDR 1728
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21130_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21131_ADDR 1729
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21131_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21132_ADDR 1730
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21132_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21133_ADDR 1731
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21133_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21134_ADDR 1732
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21134_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21140_ADDR 1733
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21140_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21141_ADDR 1734
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21141_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21142_ADDR 1735
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21142_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21143_ADDR 1736
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21143_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21144_ADDR 1737
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21144_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21150_ADDR 1738
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21150_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21151_ADDR 1739
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21151_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21152_ADDR 1740
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21152_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21153_ADDR 1741
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21153_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21154_ADDR 1742
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15B21154_MEMORYPAGE 0
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15ALPHA_ADDR 5261
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_WMIC1_EQHW1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG15ALPHA_MEMORYPAGE 0
    /* Module EQHrx4 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX4_EQHRX4_COUNT                           96
    #define MOD_RX4_EQHRX4_DEVICE                          "IC1"
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2100_ADDR 1745
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2100_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2101_ADDR 1746
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2101_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2102_ADDR 1747
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2102_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2103_ADDR 1748
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2103_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2104_ADDR 1749
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2104_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2110_ADDR 1750
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2110_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2111_ADDR 1751
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2111_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2112_ADDR 1752
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2112_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2113_ADDR 1753
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2113_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2114_ADDR 1754
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2114_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2120_ADDR 1755
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2120_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2121_ADDR 1756
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2121_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2122_ADDR 1757
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2122_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2123_ADDR 1758
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2123_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2124_ADDR 1759
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2124_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2130_ADDR 1760
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2130_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2131_ADDR 1761
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2131_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2132_ADDR 1762
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2132_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2133_ADDR 1763
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2133_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2134_ADDR 1764
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2134_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2140_ADDR 1765
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2140_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2141_ADDR 1766
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2141_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2142_ADDR 1767
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2142_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2143_ADDR 1768
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2143_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2144_ADDR 1769
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2144_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2150_ADDR 1770
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2150_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2151_ADDR 1771
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2151_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2152_ADDR 1772
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2152_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2153_ADDR 1773
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2153_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2154_ADDR 1774
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2154_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2160_ADDR 1775
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2160_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2161_ADDR 1776
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2161_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2162_ADDR 1777
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2162_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2163_ADDR 1778
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2163_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2164_ADDR 1779
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2164_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2170_ADDR 1780
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2170_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2171_ADDR 1781
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2171_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2172_ADDR 1782
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2172_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2173_ADDR 1783
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2173_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2174_ADDR 1784
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2174_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2180_ADDR 1785
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2180_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2181_ADDR 1786
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2181_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2182_ADDR 1787
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2182_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2183_ADDR 1788
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2183_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2184_ADDR 1789
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2184_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2190_ADDR 1790
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2190_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2191_ADDR 1791
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2191_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2192_ADDR 1792
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2192_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2193_ADDR 1793
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2193_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2194_ADDR 1794
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B2194_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21100_ADDR 1795
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21100_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21101_ADDR 1796
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21101_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21102_ADDR 1797
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21102_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21103_ADDR 1798
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21103_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21104_ADDR 1799
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21104_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21110_ADDR 1800
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21110_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21111_ADDR 1801
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21111_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21112_ADDR 1802
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21112_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21113_ADDR 1803
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21113_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21114_ADDR 1804
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21114_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21120_ADDR 1805
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21120_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21121_ADDR 1806
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21121_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21122_ADDR 1807
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21122_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21123_ADDR 1808
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21123_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21124_ADDR 1809
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21124_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21130_ADDR 1810
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21130_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21131_ADDR 1811
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21131_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21132_ADDR 1812
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21132_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21133_ADDR 1813
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21133_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21134_ADDR 1814
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21134_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21140_ADDR 1815
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21140_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21141_ADDR 1816
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21141_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21142_ADDR 1817
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21142_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21143_ADDR 1818
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21143_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21144_ADDR 1819
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21144_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21150_ADDR 1820
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21150_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21151_ADDR 1821
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21151_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21152_ADDR 1822
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21152_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21153_ADDR 1823
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21153_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21154_ADDR 1824
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12B21154_MEMORYPAGE 0
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12ALPHA_ADDR 5264
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX4_EQHRX4_ALG0_IDXSELINDPBANDSALGMDPSLEWALG12ALPHA_MEMORYPAGE 0
    /* Module EQHrx3 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX3_EQHRX3_COUNT                           96
    #define MOD_RX3_EQHRX3_DEVICE                          "IC1"
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2100_ADDR 1827
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2100_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2101_ADDR 1828
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2101_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2102_ADDR 1829
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2102_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2103_ADDR 1830
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2103_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2104_ADDR 1831
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2104_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2110_ADDR 1832
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2110_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2111_ADDR 1833
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2111_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2112_ADDR 1834
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2112_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2113_ADDR 1835
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2113_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2114_ADDR 1836
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2114_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2120_ADDR 1837
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2120_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2121_ADDR 1838
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2121_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2122_ADDR 1839
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2122_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2123_ADDR 1840
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2123_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2124_ADDR 1841
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2124_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2130_ADDR 1842
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2130_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2131_ADDR 1843
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2131_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2132_ADDR 1844
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2132_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2133_ADDR 1845
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2133_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2134_ADDR 1846
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2134_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2140_ADDR 1847
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2140_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2141_ADDR 1848
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2141_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2142_ADDR 1849
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2142_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2143_ADDR 1850
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2143_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2144_ADDR 1851
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2144_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2150_ADDR 1852
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2150_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2151_ADDR 1853
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2151_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2152_ADDR 1854
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2152_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2153_ADDR 1855
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2153_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2154_ADDR 1856
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2154_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2160_ADDR 1857
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2160_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2161_ADDR 1858
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2161_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2162_ADDR 1859
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2162_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2163_ADDR 1860
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2163_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2164_ADDR 1861
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2164_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2170_ADDR 1862
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2170_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2171_ADDR 1863
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2171_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2172_ADDR 1864
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2172_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2173_ADDR 1865
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2173_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2174_ADDR 1866
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2174_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2180_ADDR 1867
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2180_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2181_ADDR 1868
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2181_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2182_ADDR 1869
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2182_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2183_ADDR 1870
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2183_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2184_ADDR 1871
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2184_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2190_ADDR 1872
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2190_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2191_ADDR 1873
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2191_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2192_ADDR 1874
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2192_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2193_ADDR 1875
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2193_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2194_ADDR 1876
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B2194_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21100_ADDR 1877
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21100_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21101_ADDR 1878
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21101_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21102_ADDR 1879
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21102_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21103_ADDR 1880
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21103_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21104_ADDR 1881
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21104_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21110_ADDR 1882
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21110_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21111_ADDR 1883
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21111_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21112_ADDR 1884
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21112_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21113_ADDR 1885
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21113_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21114_ADDR 1886
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21114_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21120_ADDR 1887
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21120_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21121_ADDR 1888
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21121_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21122_ADDR 1889
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21122_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21123_ADDR 1890
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21123_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21124_ADDR 1891
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21124_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21130_ADDR 1892
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21130_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21131_ADDR 1893
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21131_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21132_ADDR 1894
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21132_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21133_ADDR 1895
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21133_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21134_ADDR 1896
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21134_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21140_ADDR 1897
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21140_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21141_ADDR 1898
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21141_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21142_ADDR 1899
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21142_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21143_ADDR 1900
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21143_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21144_ADDR 1901
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21144_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21150_ADDR 1902
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21150_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21151_ADDR 1903
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21151_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21152_ADDR 1904
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21152_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21153_ADDR 1905
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21153_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21154_ADDR 1906
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9B21154_MEMORYPAGE 0
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9ALPHA_ADDR 5267
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX3_EQHRX3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG9ALPHA_MEMORYPAGE 0
    /* Module EQHrx2 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX2_EQHRX2_COUNT                           96
    #define MOD_RX2_EQHRX2_DEVICE                          "IC1"
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2100_ADDR 1909
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2100_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2101_ADDR 1910
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2101_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2102_ADDR 1911
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2102_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2103_ADDR 1912
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2103_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2104_ADDR 1913
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2104_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2110_ADDR 1914
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2110_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2111_ADDR 1915
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2111_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2112_ADDR 1916
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2112_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2113_ADDR 1917
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2113_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2114_ADDR 1918
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2114_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2120_ADDR 1919
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2120_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2121_ADDR 1920
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2121_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2122_ADDR 1921
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2122_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2123_ADDR 1922
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2123_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2124_ADDR 1923
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2124_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2130_ADDR 1924
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2130_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2131_ADDR 1925
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2131_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2132_ADDR 1926
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2132_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2133_ADDR 1927
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2133_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2134_ADDR 1928
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2134_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2140_ADDR 1929
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2140_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2141_ADDR 1930
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2141_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2142_ADDR 1931
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2142_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2143_ADDR 1932
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2143_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2144_ADDR 1933
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2144_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2150_ADDR 1934
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2150_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2151_ADDR 1935
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2151_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2152_ADDR 1936
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2152_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2153_ADDR 1937
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2153_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2154_ADDR 1938
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2154_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2160_ADDR 1939
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2160_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2161_ADDR 1940
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2161_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2162_ADDR 1941
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2162_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2163_ADDR 1942
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2163_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2164_ADDR 1943
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2164_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2170_ADDR 1944
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2170_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2171_ADDR 1945
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2171_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2172_ADDR 1946
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2172_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2173_ADDR 1947
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2173_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2174_ADDR 1948
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2174_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2180_ADDR 1949
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2180_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2181_ADDR 1950
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2181_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2182_ADDR 1951
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2182_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2183_ADDR 1952
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2183_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2184_ADDR 1953
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2184_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2190_ADDR 1954
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2190_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2191_ADDR 1955
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2191_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2192_ADDR 1956
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2192_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2193_ADDR 1957
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2193_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2194_ADDR 1958
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B2194_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21100_ADDR 1959
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21100_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21101_ADDR 1960
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21101_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21102_ADDR 1961
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21102_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21103_ADDR 1962
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21103_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21104_ADDR 1963
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21104_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21110_ADDR 1964
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21110_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21111_ADDR 1965
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21111_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21112_ADDR 1966
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21112_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21113_ADDR 1967
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21113_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21114_ADDR 1968
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21114_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21120_ADDR 1969
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21120_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21121_ADDR 1970
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21121_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21122_ADDR 1971
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21122_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21123_ADDR 1972
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21123_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21124_ADDR 1973
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21124_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21130_ADDR 1974
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21130_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21131_ADDR 1975
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21131_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21132_ADDR 1976
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21132_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21133_ADDR 1977
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21133_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21134_ADDR 1978
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21134_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21140_ADDR 1979
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21140_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21141_ADDR 1980
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21141_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21142_ADDR 1981
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21142_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21143_ADDR 1982
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21143_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21144_ADDR 1983
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21144_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21150_ADDR 1984
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21150_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21151_ADDR 1985
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21151_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21152_ADDR 1986
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21152_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21153_ADDR 1987
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21153_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21154_ADDR 1988
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6B21154_MEMORYPAGE 0
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6ALPHA_ADDR 5270
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX2_EQHRX2_ALG0_IDXSELINDPBANDSALGMDPSLEWALG6ALPHA_MEMORYPAGE 0
    /* Module EQHrx1 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_RX1_EQHRX1_COUNT                           96
    #define MOD_RX1_EQHRX1_DEVICE                          "IC1"
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2100_ADDR 1991
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2100_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2101_ADDR 1992
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2101_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2102_ADDR 1993
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2102_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2103_ADDR 1994
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2103_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2104_ADDR 1995
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2104_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2110_ADDR 1996
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2110_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2111_ADDR 1997
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2111_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2112_ADDR 1998
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2112_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2113_ADDR 1999
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2113_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2114_ADDR 2000
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2114_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2120_ADDR 2001
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2120_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2121_ADDR 2002
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2121_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2122_ADDR 2003
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2122_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2123_ADDR 2004
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2123_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2124_ADDR 2005
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2124_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2130_ADDR 2006
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2130_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2131_ADDR 2007
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2131_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2132_ADDR 2008
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2132_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2133_ADDR 2009
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2133_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2134_ADDR 2010
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2134_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2140_ADDR 2011
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2140_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2141_ADDR 2012
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2141_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2142_ADDR 2013
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2142_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2143_ADDR 2014
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2143_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2144_ADDR 2015
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2144_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2150_ADDR 2016
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2150_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2151_ADDR 2017
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2151_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2152_ADDR 2018
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2152_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2153_ADDR 2019
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2153_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2154_ADDR 2020
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2154_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2160_ADDR 2021
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2160_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2161_ADDR 2022
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2161_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2162_ADDR 2023
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2162_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2163_ADDR 2024
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2163_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2164_ADDR 2025
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2164_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2170_ADDR 2026
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2170_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2171_ADDR 2027
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2171_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2172_ADDR 2028
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2172_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2173_ADDR 2029
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2173_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2174_ADDR 2030
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2174_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2180_ADDR 2031
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2180_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2181_ADDR 2032
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2181_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2182_ADDR 2033
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2182_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2183_ADDR 2034
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2183_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2184_ADDR 2035
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2184_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2190_ADDR 2036
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2190_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2191_ADDR 2037
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2191_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2192_ADDR 2038
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2192_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2193_ADDR 2039
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2193_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2194_ADDR 2040
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B2194_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21100_ADDR 2041
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21100_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21101_ADDR 2042
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21101_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21102_ADDR 2043
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21102_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21103_ADDR 2044
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21103_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21104_ADDR 2045
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21104_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21110_ADDR 2046
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21110_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21111_ADDR 2047
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21111_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21112_ADDR 2048
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21112_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21113_ADDR 2049
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21113_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21114_ADDR 2050
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21114_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21120_ADDR 2051
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21120_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21121_ADDR 2052
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21121_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21122_ADDR 2053
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21122_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21123_ADDR 2054
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21123_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21124_ADDR 2055
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21124_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21130_ADDR 2056
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21130_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21131_ADDR 2057
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21131_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21132_ADDR 2058
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21132_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21133_ADDR 2059
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21133_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21134_ADDR 2060
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21134_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21140_ADDR 2061
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21140_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21141_ADDR 2062
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21141_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21142_ADDR 2063
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21142_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21143_ADDR 2064
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21143_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21144_ADDR 2065
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21144_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21150_ADDR 2066
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21150_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21151_ADDR 2067
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21151_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21152_ADDR 2068
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21152_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21153_ADDR 2069
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21153_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21154_ADDR 2070
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3B21154_MEMORYPAGE 0
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3ALPHA_ADDR 5273
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_RX1_EQHRX1_ALG0_IDXSELINDPBANDSALGMDPSLEWALG3ALPHA_MEMORYPAGE 0
    /* Module EQHmp3 - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_MP3_EQHMP3_COUNT                           96
    #define MOD_MP3_EQHMP3_DEVICE                          "IC1"
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2100_ADDR 2073
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2100_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2101_ADDR 2074
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2101_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2102_ADDR 2075
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2102_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2103_ADDR 2076
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2103_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2104_ADDR 2077
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2104_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2110_ADDR 2078
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2110_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2111_ADDR 2079
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2111_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2112_ADDR 2080
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2112_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2113_ADDR 2081
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2113_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2114_ADDR 2082
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2114_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2120_ADDR 2083
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2120_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2121_ADDR 2084
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2121_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2122_ADDR 2085
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2122_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2123_ADDR 2086
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2123_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2124_ADDR 2087
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2124_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2130_ADDR 2088
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2130_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2131_ADDR 2089
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2131_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2132_ADDR 2090
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2132_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2133_ADDR 2091
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2133_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2134_ADDR 2092
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2134_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2140_ADDR 2093
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2140_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2141_ADDR 2094
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2141_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2142_ADDR 2095
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2142_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2143_ADDR 2096
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2143_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2144_ADDR 2097
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2144_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2150_ADDR 2098
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2150_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2151_ADDR 2099
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2151_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2152_ADDR 2100
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2152_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2153_ADDR 2101
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2153_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2154_ADDR 2102
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2154_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2160_ADDR 2103
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2160_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2161_ADDR 2104
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2161_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2162_ADDR 2105
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2162_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2163_ADDR 2106
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2163_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2164_ADDR 2107
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2164_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2170_ADDR 2108
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2170_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2171_ADDR 2109
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2171_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2172_ADDR 2110
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2172_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2173_ADDR 2111
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2173_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2174_ADDR 2112
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2174_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2180_ADDR 2113
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2180_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2181_ADDR 2114
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2181_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2182_ADDR 2115
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2182_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2183_ADDR 2116
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2183_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2184_ADDR 2117
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2184_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2190_ADDR 2118
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2190_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2191_ADDR 2119
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2191_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2192_ADDR 2120
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2192_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2193_ADDR 2121
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2193_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2194_ADDR 2122
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B2194_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21100_ADDR 2123
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21100_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21101_ADDR 2124
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21101_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21102_ADDR 2125
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21102_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21103_ADDR 2126
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21103_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21104_ADDR 2127
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21104_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21110_ADDR 2128
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21110_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21111_ADDR 2129
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21111_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21112_ADDR 2130
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21112_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21113_ADDR 2131
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21113_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21114_ADDR 2132
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21114_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21120_ADDR 2133
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21120_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21121_ADDR 2134
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21121_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21122_ADDR 2135
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21122_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21123_ADDR 2136
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21123_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21124_ADDR 2137
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21124_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21130_ADDR 2138
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21130_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21131_ADDR 2139
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21131_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21132_ADDR 2140
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21132_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21133_ADDR 2141
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21133_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21134_ADDR 2142
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21134_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21140_ADDR 2143
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21140_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21141_ADDR 2144
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21141_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21142_ADDR 2145
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21142_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21143_ADDR 2146
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21143_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21144_ADDR 2147
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21144_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21150_ADDR 2148
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21150_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21151_ADDR 2149
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21151_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21152_ADDR 2150
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21152_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21153_ADDR 2151
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21153_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21154_ADDR 2152
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24B21154_MEMORYPAGE 0
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24ALPHA_ADDR 5276
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MP3_EQHMP3_ALG0_IDXSELINDPBANDSALGMDPSLEWALG24ALPHA_MEMORYPAGE 0
    /* Module NxM Mixer1 - NxM Mixer*/
    #define MOD_AUDIOIN_NXMMIXER1_COUNT                    6
    #define MOD_AUDIOIN_NXMMIXER1_DEVICE                   "IC1"
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0000_ADDR 2155
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0000_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0000_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0000_MEMORYPAGE 0
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0001_ADDR 2156
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0001_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0001_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0001_MEMORYPAGE 0
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0002_ADDR 2157
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0002_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0002_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0002_MEMORYPAGE 0
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0003_ADDR 2158
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0003_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0003_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0003_MEMORYPAGE 0
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0004_ADDR 2159
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0004_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0004_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0004_MEMORYPAGE 0
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0005_ADDR 2160
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0005_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0005_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NXMMIXER1_ALG0_NXNMIXS3004P6ALG1VOL0005_MEMORYPAGE 0
    /* Module Nx1 Linear1 - Nx1 Mixer (Linear)*/
    #define MOD_AUDIOIN_NX1LINEAR1_COUNT                   4
    #define MOD_AUDIOIN_NX1LINEAR1_DEVICE                  "IC1"
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_SLEW_MODE_ADDR     2161
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_SLEW_MODE_FIXPT    0x0000186A
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_SLEW_MODE_VALUE    SIGMASTUDIOTYPE_INTEGER_CONVERT(6250)
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_SLEW_MODE_TYPE     SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_SLEW_MODE_MEMORYPAGE 0
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0000_ADDR 2165
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0000_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0000_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0000_MEMORYPAGE 0
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0001_ADDR 2166
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0001_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0001_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0001_MEMORYPAGE 0
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0002_ADDR 2167
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0002_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0002_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_NX1LINEAR1_ALG0_MIXER3X1SLEWS300ALG2TARGET0002_MEMORYPAGE 0
    /* Module MusicLimiter _3 - Limiter*/
    #define MOD_AUDIOIN_MUSICLIMITER_3_COUNT               3
    #define MOD_AUDIOIN_MUSICLIMITER_3_DEVICE              "IC1"
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_THRESHOLD_ADDR 2168
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_THRESHOLD_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_THRESHOLD_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_THRESHOLD_MEMORYPAGE 0
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_RMS_ADDR       5277
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_RMS_VALUE      SIGMASTUDIOTYPE_8_24_CONVERT(0.000239881380791562)
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_RMS_TYPE       SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_RMS_MEMORYPAGE 0
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_DECAY_ADDR     5278
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_DECAY_VALUE    SIGMASTUDIOTYPE_8_24_CONVERT(0.000244140625)
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_DECAY_TYPE     SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOIN_MUSICLIMITER_3_ALG0_DECAY_MEMORYPAGE 0
    /* Module VADStAccel1_2 - Voice Activity Detector w/ Accelerator*/
    #define MOD_VAD_VADSTACCEL1_2_COUNT                    13
    #define MOD_VAD_VADSTACCEL1_2_DEVICE                   "IC1"
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001LPF_ADDR 2172
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001LPF_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00391929027183668)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001LPF_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001LPF_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERHI_ADDR 2173
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERHI_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.25)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERHI_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERHI_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERLO_ADDR 2174
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERLO_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.25)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERLO_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPTRACKERLO_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERHI_ADDR 2175
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERHI_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.5)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERHI_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERHI_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERLO_ADDR 2176
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERLO_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.5)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERLO_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMTRACKERLO_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPWAIT_ADDR 2179
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPWAIT_FIXPT 0x00005DC0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPWAIT_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(24000)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPWAIT_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001TOPWAIT_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMWAIT_ADDR 2180
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMWAIT_FIXPT 0x0000BB80
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMWAIT_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(48000)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMWAIT_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001BOTTOMWAIT_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKTOP_ADDR 2181
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKTOP_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.00240140490349)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKTOP_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKTOP_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOM_ADDR 2182
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOM_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.00000479706378)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOM_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOM_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOP_ADDR 2183
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOP_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.999952030627796)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOP_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOP_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASEBOTTOM_ADDR 2184
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASEBOTTOM_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.998801455759303)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASEBOTTOM_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASEBOTTOM_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOPACCEL_ADDR 2185
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOPACCEL_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.999041049631648)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOPACCEL_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001RELEASETOPACCEL_MEMORYPAGE 0
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOMACCEL_ADDR 2186
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOMACCEL_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.0000383771546)
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOMACCEL_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_VADSTACCEL1_2_ALG0_ALGVADACCELS3001ATTACKBOTTOMACCEL_MEMORYPAGE 0
    /* Module MasterCtrl - DC Input Entry*/
    #define MOD_MASTERCTRL_MASTERCTRL_COUNT                40
    #define MOD_MASTERCTRL_MASTERCTRL_DEVICE               "IC1"
    #define MOD_MASTERCTRL_MASTERCTRL_ALG0_DCINPALG145X1VALUE_ADDR 2187
    #define MOD_MASTERCTRL_MASTERCTRL_ALG0_DCINPALG145X1VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG0_DCINPALG145X1VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG0_DCINPALG145X1VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG1_DCINPALG145X10VALUE_ADDR 5165
    #define MOD_MASTERCTRL_MASTERCTRL_ALG1_DCINPALG145X10VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG1_DCINPALG145X10VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG1_DCINPALG145X10VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG2_DCINPALG145X35VALUE_ADDR 5166
    #define MOD_MASTERCTRL_MASTERCTRL_ALG2_DCINPALG145X35VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG2_DCINPALG145X35VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG2_DCINPALG145X35VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG3_DCINPALG145X2VALUE_ADDR 5167
    #define MOD_MASTERCTRL_MASTERCTRL_ALG3_DCINPALG145X2VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG3_DCINPALG145X2VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG3_DCINPALG145X2VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG4_DCINPALG145X3VALUE_ADDR 5168
    #define MOD_MASTERCTRL_MASTERCTRL_ALG4_DCINPALG145X3VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG4_DCINPALG145X3VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG4_DCINPALG145X3VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG5_DCINPALG145X4VALUE_ADDR 5169
    #define MOD_MASTERCTRL_MASTERCTRL_ALG5_DCINPALG145X4VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG5_DCINPALG145X4VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG5_DCINPALG145X4VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG6_DCINPALG145X5VALUE_ADDR 5170
    #define MOD_MASTERCTRL_MASTERCTRL_ALG6_DCINPALG145X5VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG6_DCINPALG145X5VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG6_DCINPALG145X5VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG7_DCINPALG145X6VALUE_ADDR 5171
    #define MOD_MASTERCTRL_MASTERCTRL_ALG7_DCINPALG145X6VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG7_DCINPALG145X6VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG7_DCINPALG145X6VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG8_DCINPALG145X7VALUE_ADDR 5172
    #define MOD_MASTERCTRL_MASTERCTRL_ALG8_DCINPALG145X7VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG8_DCINPALG145X7VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG8_DCINPALG145X7VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG9_DCINPALG145X8VALUE_ADDR 5173
    #define MOD_MASTERCTRL_MASTERCTRL_ALG9_DCINPALG145X8VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG9_DCINPALG145X8VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG9_DCINPALG145X8VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG10_DCINPALG145X9VALUE_ADDR 5174
    #define MOD_MASTERCTRL_MASTERCTRL_ALG10_DCINPALG145X9VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG10_DCINPALG145X9VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG10_DCINPALG145X9VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG11_DCINPALG145X11VALUE_ADDR 5175
    #define MOD_MASTERCTRL_MASTERCTRL_ALG11_DCINPALG145X11VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG11_DCINPALG145X11VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG11_DCINPALG145X11VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG12_DCINPALG145X12VALUE_ADDR 5176
    #define MOD_MASTERCTRL_MASTERCTRL_ALG12_DCINPALG145X12VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG12_DCINPALG145X12VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG12_DCINPALG145X12VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG13_DCINPALG145X13VALUE_ADDR 5177
    #define MOD_MASTERCTRL_MASTERCTRL_ALG13_DCINPALG145X13VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG13_DCINPALG145X13VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG13_DCINPALG145X13VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG14_DCINPALG145X14VALUE_ADDR 5178
    #define MOD_MASTERCTRL_MASTERCTRL_ALG14_DCINPALG145X14VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG14_DCINPALG145X14VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG14_DCINPALG145X14VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG15_DCINPALG145X15VALUE_ADDR 5179
    #define MOD_MASTERCTRL_MASTERCTRL_ALG15_DCINPALG145X15VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG15_DCINPALG145X15VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG15_DCINPALG145X15VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG16_DCINPALG145X16VALUE_ADDR 5180
    #define MOD_MASTERCTRL_MASTERCTRL_ALG16_DCINPALG145X16VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG16_DCINPALG145X16VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG16_DCINPALG145X16VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG17_DCINPALG145X17VALUE_ADDR 5181
    #define MOD_MASTERCTRL_MASTERCTRL_ALG17_DCINPALG145X17VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG17_DCINPALG145X17VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG17_DCINPALG145X17VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG18_DCINPALG145X18VALUE_ADDR 5182
    #define MOD_MASTERCTRL_MASTERCTRL_ALG18_DCINPALG145X18VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG18_DCINPALG145X18VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG18_DCINPALG145X18VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG19_DCINPALG145X19VALUE_ADDR 5183
    #define MOD_MASTERCTRL_MASTERCTRL_ALG19_DCINPALG145X19VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG19_DCINPALG145X19VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG19_DCINPALG145X19VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG20_DCINPALG145X20VALUE_ADDR 5184
    #define MOD_MASTERCTRL_MASTERCTRL_ALG20_DCINPALG145X20VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG20_DCINPALG145X20VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG20_DCINPALG145X20VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG21_DCINPALG145X21VALUE_ADDR 5185
    #define MOD_MASTERCTRL_MASTERCTRL_ALG21_DCINPALG145X21VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG21_DCINPALG145X21VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG21_DCINPALG145X21VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG22_DCINPALG145X22VALUE_ADDR 5186
    #define MOD_MASTERCTRL_MASTERCTRL_ALG22_DCINPALG145X22VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG22_DCINPALG145X22VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG22_DCINPALG145X22VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG23_DCINPALG145X23VALUE_ADDR 5187
    #define MOD_MASTERCTRL_MASTERCTRL_ALG23_DCINPALG145X23VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG23_DCINPALG145X23VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG23_DCINPALG145X23VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG24_DCINPALG145X24VALUE_ADDR 5188
    #define MOD_MASTERCTRL_MASTERCTRL_ALG24_DCINPALG145X24VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG24_DCINPALG145X24VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG24_DCINPALG145X24VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG25_DCINPALG145X25VALUE_ADDR 5189
    #define MOD_MASTERCTRL_MASTERCTRL_ALG25_DCINPALG145X25VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG25_DCINPALG145X25VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG25_DCINPALG145X25VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG26_DCINPALG145X26VALUE_ADDR 5190
    #define MOD_MASTERCTRL_MASTERCTRL_ALG26_DCINPALG145X26VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG26_DCINPALG145X26VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG26_DCINPALG145X26VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG27_DCINPALG145X27VALUE_ADDR 5191
    #define MOD_MASTERCTRL_MASTERCTRL_ALG27_DCINPALG145X27VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG27_DCINPALG145X27VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG27_DCINPALG145X27VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG28_DCINPALG145X28VALUE_ADDR 5192
    #define MOD_MASTERCTRL_MASTERCTRL_ALG28_DCINPALG145X28VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG28_DCINPALG145X28VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG28_DCINPALG145X28VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG29_DCINPALG145X29VALUE_ADDR 5193
    #define MOD_MASTERCTRL_MASTERCTRL_ALG29_DCINPALG145X29VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG29_DCINPALG145X29VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG29_DCINPALG145X29VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG30_DCINPALG145X30VALUE_ADDR 5194
    #define MOD_MASTERCTRL_MASTERCTRL_ALG30_DCINPALG145X30VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG30_DCINPALG145X30VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG30_DCINPALG145X30VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG31_DCINPALG145X31VALUE_ADDR 5195
    #define MOD_MASTERCTRL_MASTERCTRL_ALG31_DCINPALG145X31VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG31_DCINPALG145X31VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG31_DCINPALG145X31VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG32_DCINPALG145X32VALUE_ADDR 5196
    #define MOD_MASTERCTRL_MASTERCTRL_ALG32_DCINPALG145X32VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG32_DCINPALG145X32VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG32_DCINPALG145X32VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG33_DCINPALG145X33VALUE_ADDR 5197
    #define MOD_MASTERCTRL_MASTERCTRL_ALG33_DCINPALG145X33VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG33_DCINPALG145X33VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG33_DCINPALG145X33VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG34_DCINPALG145X34VALUE_ADDR 5198
    #define MOD_MASTERCTRL_MASTERCTRL_ALG34_DCINPALG145X34VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG34_DCINPALG145X34VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG34_DCINPALG145X34VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG35_DCINPALG145X37VALUE_ADDR 5199
    #define MOD_MASTERCTRL_MASTERCTRL_ALG35_DCINPALG145X37VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG35_DCINPALG145X37VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG35_DCINPALG145X37VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG36_DCINPALG145X38VALUE_ADDR 5200
    #define MOD_MASTERCTRL_MASTERCTRL_ALG36_DCINPALG145X38VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG36_DCINPALG145X38VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG36_DCINPALG145X38VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG37_DCINPALG145X39VALUE_ADDR 5201
    #define MOD_MASTERCTRL_MASTERCTRL_ALG37_DCINPALG145X39VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG37_DCINPALG145X39VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG37_DCINPALG145X39VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG38_DCINPALG145X40VALUE_ADDR 5202
    #define MOD_MASTERCTRL_MASTERCTRL_ALG38_DCINPALG145X40VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG38_DCINPALG145X40VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG38_DCINPALG145X40VALUE_MEMORYPAGE 0
    #define MOD_MASTERCTRL_MASTERCTRL_ALG39_DCINPALG145X41VALUE_ADDR 5203
    #define MOD_MASTERCTRL_MASTERCTRL_ALG39_DCINPALG145X41VALUE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(5.96E-08)
    #define MOD_MASTERCTRL_MASTERCTRL_ALG39_DCINPALG145X41VALUE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_MASTERCTRL_MASTERCTRL_ALG39_DCINPALG145X41VALUE_MEMORYPAGE 0
    /* Module Reverb1 - Reverb*/
    #define MOD_ECHO_REVERB_REVERB1_COUNT                  80
    #define MOD_ECHO_REVERB_REVERB1_DEVICE                 "IC1"
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS0_ADDR 2188
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS0_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.000358320212753991)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS0_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS0_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS1_ADDR 2189
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00266179913227321)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS1_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS2_ADDR 2190
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0023707568386553)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS2_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS3_ADDR 2191
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS3_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000657625251955311)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS3_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS3_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS4_ADDR 2192
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS4_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00273782283595552)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS4_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS4_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS5_ADDR 2193
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS5_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-4.67821145422691E-05)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS5_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS5_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS6_ADDR 2194
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS6_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0036653279949608)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS6_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS6_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS7_ADDR 2195
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS7_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00122279349853922)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS7_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS7_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS8_ADDR 2196
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS8_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00444594375102344)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS8_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS8_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS9_ADDR 2197
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS9_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00318633844141416)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS9_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS9_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS10_ADDR 2198
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS10_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00470957628602974)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS10_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS10_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS11_ADDR 2199
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS11_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00578460467050378)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS11_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS11_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS12_ADDR 2200
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS12_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00409466373683179)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS12_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS12_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS13_ADDR 2201
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS13_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00884004913238062)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS13_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS13_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS14_ADDR 2202
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS14_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00223893448028406)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS14_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS14_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS15_ADDR 2203
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS15_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0120348894506642)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS15_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS15_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS16_ADDR 2204
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS16_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00118939249475349)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS16_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS16_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS17_ADDR 2205
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS17_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0149150451754351)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS17_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS17_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS18_ADDR 2206
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS18_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00649181891217908)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS18_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS18_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS19_ADDR 2207
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS19_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0168589233165653)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS19_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS19_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS20_ADDR 2208
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS20_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0139238617487715)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS20_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS20_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS21_ADDR 2209
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS21_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0170844859984342)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS21_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS21_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS22_ADDR 2210
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS22_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0238218310924939)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS22_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS22_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS23_ADDR 2211
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS23_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0144997178963001)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS23_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS23_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS24_ADDR 2212
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS24_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0368718030422081)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS24_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS24_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS25_ADDR 2213
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS25_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00726892389110675)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS25_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS25_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS26_ADDR 2214
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS26_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0550517984108165)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS26_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS26_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS27_ADDR 2215
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS27_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00896493587521034)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS27_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS27_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS28_ADDR 2216
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS28_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0857371240203618)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS28_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS28_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS29_ADDR 2217
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS29_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0516415630996757)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS29_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS29_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS30_ADDR 2218
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS30_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.178280791662733)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS30_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS30_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS31_ADDR 2219
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS31_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.416135310886697)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS31_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS31_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS32_ADDR 2220
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS32_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.416135310886697)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS32_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS32_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS33_ADDR 2221
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS33_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.178280791662733)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS33_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS33_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS34_ADDR 2222
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS34_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0516415630996757)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS34_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS34_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS35_ADDR 2223
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS35_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0857371240203618)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS35_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS35_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS36_ADDR 2224
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS36_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00896493587521034)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS36_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS36_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS37_ADDR 2225
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS37_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0550517984108165)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS37_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS37_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS38_ADDR 2226
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS38_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00726892389110675)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS38_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS38_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS39_ADDR 2227
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS39_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0368718030422081)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS39_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS39_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS40_ADDR 2228
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS40_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0144997178963001)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS40_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS40_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS41_ADDR 2229
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS41_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0238218310924939)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS41_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS41_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS42_ADDR 2230
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS42_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0170844859984342)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS42_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS42_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS43_ADDR 2231
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS43_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0139238617487715)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS43_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS43_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS44_ADDR 2232
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS44_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0168589233165653)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS44_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS44_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS45_ADDR 2233
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS45_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00649181891217908)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS45_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS45_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS46_ADDR 2234
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS46_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0149150451754351)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS46_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS46_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS47_ADDR 2235
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS47_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00118939249475349)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS47_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS47_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS48_ADDR 2236
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS48_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0120348894506642)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS48_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS48_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS49_ADDR 2237
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS49_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00223893448028406)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS49_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS49_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS50_ADDR 2238
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS50_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00884004913238062)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS50_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS50_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS51_ADDR 2239
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS51_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00409466373683179)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS51_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS51_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS52_ADDR 2240
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS52_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00578460467050378)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS52_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS52_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS53_ADDR 2241
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS53_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00470957628602974)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS53_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS53_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS54_ADDR 2242
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS54_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00318633844141416)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS54_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS54_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS55_ADDR 2243
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS55_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00444594375102344)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS55_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS55_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS56_ADDR 2244
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS56_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.00122279349853922)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS56_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS56_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS57_ADDR 2245
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS57_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0036653279949608)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS57_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS57_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS58_ADDR 2246
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS58_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-4.67821145422691E-05)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS58_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS58_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS59_ADDR 2247
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS59_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00273782283595552)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS59_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS59_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS60_ADDR 2248
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS60_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000657625251955311)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS60_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS60_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS61_ADDR 2249
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS61_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0023707568386553)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS61_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS61_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS62_ADDR 2250
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS62_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.00266179913227321)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS62_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS62_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS63_ADDR 2251
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS63_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.000358320212753991)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS63_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS63_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS64_ADDR 2252
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS64_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS64_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001COEFFS64_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFSIN_ADDR 2253
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFSIN_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.707107)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFSIN_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFSIN_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFCOS_ADDR 2254
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFCOS_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.707107)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFCOS_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001DIFCOS_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001AP_ADDR 2255
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001AP_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.5)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001AP_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001AP_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001C707_ADDR 2256
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001C707_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.707107)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001C707_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001C707_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LP_ADDR 2257
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LP_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.188)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LP_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LP_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSLP_ADDR 2258
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSLP_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.977)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSLP_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSLP_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSGAIN_ADDR 2259
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSGAIN_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.0625)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSGAIN_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001BASSGAIN_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS0_ADDR 2260
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS0_FIXPT 0x00000000
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS0_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(0)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS0_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS0_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS1_ADDR 2261
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS1_FIXPT 0x00400000
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS1_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(4194304)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS1_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001OFFSETS1_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001MASK_ADDR 2262
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001MASK_FIXPT 0x00FFFFFE
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001MASK_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(16777214)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001MASK_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001MASK_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001TSCALE_ADDR 2263
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001TSCALE_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0001220703125)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001TSCALE_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001TSCALE_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LFOINC_ADDR 2264
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LFOINC_FIXPT 0x000001F6
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LFOINC_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(502)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LFOINC_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LFOINC_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001HALFEXCURS_ADDR 2265
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001HALFEXCURS_FIXPT 0x0000C000
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001HALFEXCURS_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(49152)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001HALFEXCURS_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001HALFEXCURS_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAIN_ADDR 24631
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAIN_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.829)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAIN_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAIN_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAINHALF_ADDR 24632
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAINHALF_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.4145)
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAINHALF_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_REVERB1_ALG0_REVERBS3001LOOPGAINHALF_MEMORYPAGE 0
    /* Module MultiTapG1 - Multitap Gain*/
    #define MOD_ECHO_REVERB_MULTITAPG1_COUNT               12
    #define MOD_ECHO_REVERB_MULTITAPG1_DEVICE              "IC1"
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN1_ADDR 2266
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.7)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN1_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY1_ADDR 2267
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY1_FIXPT 0xFFFFFF88
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY1_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-120)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY1_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY1_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN2_ADDR 2268
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.56)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN2_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY2_ADDR 2269
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY2_FIXPT 0xFFFFFF10
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY2_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-240)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY2_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY2_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN3_ADDR 2270
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN3_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.48)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN3_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN3_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY3_ADDR 2271
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY3_FIXPT 0xFFFFFE84
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY3_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-380)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY3_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY3_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN4_ADDR 2272
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN4_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.44)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN4_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN4_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY4_ADDR 2273
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY4_FIXPT 0xFFFFFE0C
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY4_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-500)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY4_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY4_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN5_ADDR 2274
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN5_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.3)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN5_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN5_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY5_ADDR 2275
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY5_FIXPT 0xFFFFFD44
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY5_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-700)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY5_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY5_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN6_ADDR 2276
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN6_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.4)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN6_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_LINEARGAIN6_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY6_ADDR 2277
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY6_FIXPT 0xFFFFFCE0
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY6_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-800)
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY6_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_MULTITAPG1_ALG0_CURRENTDELAY6_MEMORYPAGE 0
    /* Module Dec1_2 - VAD Flag*/
    #define MOD_VAD_DEC1_2_COUNT                           2
    #define MOD_VAD_DEC1_2_DEVICE                          "IC1"
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001THRESH_ADDR 2278
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001THRESH_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.0316227766016838)
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001THRESH_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001THRESH_MEMORYPAGE 0
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001COUNT_ADDR  2279
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001COUNT_FIXPT 0x00002EE0
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001COUNT_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(12000)
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001COUNT_TYPE  SIGMASTUDIOTYPE_INTEGER
    #define MOD_VAD_DEC1_2_ALG0_VADFLAGALGS3001COUNT_MEMORYPAGE 0
    /* Module Single 1 - Single Volume*/
    #define MOD_ECHO_REVERB_SINGLE1_COUNT                  2
    #define MOD_ECHO_REVERB_SINGLE1_DEVICE                 "IC1"
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_TARGET_ADDR       2282
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_TARGET_VALUE      SIGMASTUDIOTYPE_8_24_CONVERT(0.125892541179417)
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_TARGET_TYPE       SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_TARGET_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_SLEW_MODE_ADDR    2283
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_SLEW_MODE_FIXPT   0x0000208A
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_SLEW_MODE_VALUE   SIGMASTUDIOTYPE_INTEGER_CONVERT(8330)
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_SLEW_MODE_TYPE    SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_SINGLE1_ALG0_SLEW_MODE_MEMORYPAGE 0
    /* Module ZeroComp1_2 - Zero Comparator*/
    #define MOD_VAD_ZEROCOMP1_2_COUNT                      1
    #define MOD_VAD_ZEROCOMP1_2_DEVICE                     "IC1"
    #define MOD_VAD_ZEROCOMP1_2_OUTPUT_ADDR                2284
    #define MOD_VAD_ZEROCOMP1_2_OUTPUT_FIXPT               0x01000000
    #define MOD_VAD_ZEROCOMP1_2_OUTPUT_VALUE               SIGMASTUDIOTYPE_INTEGER_CONVERT(16777216)
    #define MOD_VAD_ZEROCOMP1_2_OUTPUT_TYPE                SIGMASTUDIOTYPE_INTEGER
    #define MOD_VAD_ZEROCOMP1_2_OUTPUT_MEMORYPAGE          0
    /* Module MultiTapG2 - Multitap Gain*/
    #define MOD_ECHO_REVERB_MULTITAPG2_COUNT               2
    #define MOD_ECHO_REVERB_MULTITAPG2_DEVICE              "IC1"
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_LINEARGAIN1_ADDR 2287
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_LINEARGAIN1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.6)
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_LINEARGAIN1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_LINEARGAIN1_MEMORYPAGE 0
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_CURRENTDELAY1_ADDR 2288
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_CURRENTDELAY1_FIXPT 0xFFFFE700
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_CURRENTDELAY1_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-6400)
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_CURRENTDELAY1_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_ECHO_REVERB_MULTITAPG2_ALG0_CURRENTDELAY1_MEMORYPAGE 0
    /* Module Nx1 Linear2 - Nx1 Mixer (Linear)*/
    #define MOD_AUDIOOUT_NX1LINEAR2_COUNT                  2
    #define MOD_AUDIOOUT_NX1LINEAR2_DEVICE                 "IC1"
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0000_ADDR 2292
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0000_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0000_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0000_MEMORYPAGE 0
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0001_ADDR 2293
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0001_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0001_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_NX1LINEAR2_ALG0_MIXER2X1NOSLEWS300ALG1VOL0001_MEMORYPAGE 0
    /* Module OutputEQL - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_AUDIOOUT_OUTPUTEQL_COUNT                   96
    #define MOD_AUDIOOUT_OUTPUTEQL_DEVICE                  "IC1"
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2100_ADDR 2295
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2100_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2101_ADDR 2296
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2101_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2102_ADDR 2297
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2102_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2103_ADDR 2298
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2103_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2104_ADDR 2299
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2104_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2110_ADDR 2300
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2110_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2111_ADDR 2301
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2111_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2112_ADDR 2302
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2112_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2113_ADDR 2303
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2113_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2114_ADDR 2304
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2114_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2120_ADDR 2305
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2120_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2121_ADDR 2306
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2121_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2122_ADDR 2307
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2122_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2123_ADDR 2308
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2123_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2124_ADDR 2309
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2124_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2130_ADDR 2310
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2130_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2131_ADDR 2311
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2131_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2132_ADDR 2312
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2132_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2133_ADDR 2313
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2133_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2134_ADDR 2314
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2134_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2140_ADDR 2315
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2140_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2141_ADDR 2316
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2141_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2142_ADDR 2317
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2142_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2143_ADDR 2318
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2143_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2144_ADDR 2319
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2144_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2150_ADDR 2320
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2150_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2151_ADDR 2321
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2151_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2152_ADDR 2322
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2152_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2153_ADDR 2323
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2153_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2154_ADDR 2324
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2154_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2160_ADDR 2325
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2160_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2161_ADDR 2326
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2161_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2162_ADDR 2327
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2162_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2163_ADDR 2328
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2163_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2164_ADDR 2329
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2164_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2170_ADDR 2330
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2170_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2171_ADDR 2331
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2171_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2172_ADDR 2332
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2172_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2173_ADDR 2333
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2173_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2174_ADDR 2334
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2174_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2180_ADDR 2335
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2180_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2181_ADDR 2336
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2181_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2182_ADDR 2337
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2182_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2183_ADDR 2338
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2183_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2184_ADDR 2339
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2184_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2190_ADDR 2340
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2190_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2191_ADDR 2341
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2191_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2192_ADDR 2342
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2192_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2193_ADDR 2343
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2193_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2194_ADDR 2344
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B2194_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21100_ADDR 2345
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21100_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21101_ADDR 2346
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21101_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21102_ADDR 2347
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21102_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21103_ADDR 2348
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21103_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21104_ADDR 2349
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21104_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21110_ADDR 2350
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21110_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21111_ADDR 2351
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21111_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21112_ADDR 2352
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21112_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21113_ADDR 2353
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21113_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21114_ADDR 2354
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21114_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21120_ADDR 2355
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21120_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21121_ADDR 2356
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21121_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21122_ADDR 2357
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21122_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21123_ADDR 2358
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21123_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21124_ADDR 2359
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21124_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21130_ADDR 2360
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21130_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21131_ADDR 2361
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21131_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21132_ADDR 2362
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21132_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21133_ADDR 2363
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21133_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21134_ADDR 2364
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21134_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21140_ADDR 2365
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21140_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21141_ADDR 2366
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21141_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21142_ADDR 2367
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21142_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21143_ADDR 2368
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21143_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21144_ADDR 2369
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21144_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21150_ADDR 2370
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21150_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21151_ADDR 2371
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21151_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21152_ADDR 2372
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21152_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21153_ADDR 2373
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21153_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21154_ADDR 2374
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25B21154_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25ALPHA_ADDR 5284
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQL_ALG0_IDXSELINDPBANDSALGMDPSLEWALG25ALPHA_MEMORYPAGE 0
    /* Module MusicLimiter _2 - Limiter*/
    #define MOD_AUDIOOUT_MUSICLIMITER_2_COUNT              3
    #define MOD_AUDIOOUT_MUSICLIMITER_2_DEVICE             "IC1"
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_THRESHOLD_ADDR 2377
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_THRESHOLD_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_THRESHOLD_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_THRESHOLD_MEMORYPAGE 0
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_RMS_ADDR      5285
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_RMS_VALUE     SIGMASTUDIOTYPE_8_24_CONVERT(0.000239881380791562)
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_RMS_TYPE      SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_RMS_MEMORYPAGE 0
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_DECAY_ADDR    5286
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_DECAY_VALUE   SIGMASTUDIOTYPE_8_24_CONVERT(0.000244140625)
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_DECAY_TYPE    SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_MUSICLIMITER_2_ALG0_DECAY_MEMORYPAGE 0
    /* Module OutputEQH - IdxSelectable Indp. Multiple Band Filter*/
    #define MOD_AUDIOOUT_OUTPUTEQH_COUNT                   96
    #define MOD_AUDIOOUT_OUTPUTEQH_DEVICE                  "IC1"
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2100_ADDR 2380
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.855757161606809)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2100_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2101_ADDR 2381
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.83988090183272)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2101_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2102_ADDR 2382
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2102_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2103_ADDR 2383
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.855757161606809)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2103_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2104_ADDR 2384
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.83988090183272)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2104_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2110_ADDR 2385
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2110_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2111_ADDR 2386
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2111_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2112_ADDR 2387
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2112_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2113_ADDR 2388
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2113_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2114_ADDR 2389
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2114_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2120_ADDR 2390
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2120_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2121_ADDR 2391
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2121_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2122_ADDR 2392
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2122_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2123_ADDR 2393
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2123_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2124_ADDR 2394
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2124_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2130_ADDR 2395
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2130_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2131_ADDR 2396
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2131_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2132_ADDR 2397
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2132_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2133_ADDR 2398
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2133_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2134_ADDR 2399
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2134_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2140_ADDR 2400
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2140_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2141_ADDR 2401
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2141_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2142_ADDR 2402
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2142_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2143_ADDR 2403
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2143_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2144_ADDR 2404
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2144_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2150_ADDR 2405
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2150_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2151_ADDR 2406
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2151_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2152_ADDR 2407
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2152_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2153_ADDR 2408
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2153_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2154_ADDR 2409
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2154_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2160_ADDR 2410
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2160_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2160_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2160_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2161_ADDR 2411
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2161_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2161_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2161_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2162_ADDR 2412
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2162_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2162_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2162_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2163_ADDR 2413
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2163_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2163_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2163_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2164_ADDR 2414
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2164_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2164_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2164_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2170_ADDR 2415
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2170_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2170_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2170_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2171_ADDR 2416
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2171_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2171_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2171_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2172_ADDR 2417
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2172_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2172_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2172_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2173_ADDR 2418
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2173_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2173_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2173_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2174_ADDR 2419
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2174_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2174_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2174_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2180_ADDR 2420
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2180_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2180_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2180_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2181_ADDR 2421
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2181_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2181_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2181_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2182_ADDR 2422
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2182_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2182_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2182_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2183_ADDR 2423
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2183_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2183_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2183_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2184_ADDR 2424
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2184_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2184_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2184_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2190_ADDR 2425
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2190_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2190_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2190_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2191_ADDR 2426
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2191_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2191_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2191_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2192_ADDR 2427
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2192_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2192_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2192_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2193_ADDR 2428
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2193_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2193_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2193_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2194_ADDR 2429
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2194_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2194_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B2194_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21100_ADDR 2430
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21100_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21100_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21100_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21101_ADDR 2431
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21101_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21101_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21101_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21102_ADDR 2432
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21102_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21102_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21102_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21103_ADDR 2433
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21103_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21103_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21103_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21104_ADDR 2434
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21104_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21104_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21104_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21110_ADDR 2435
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21110_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21110_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21110_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21111_ADDR 2436
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21111_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21111_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21111_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21112_ADDR 2437
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21112_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21112_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21112_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21113_ADDR 2438
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21113_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21113_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21113_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21114_ADDR 2439
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21114_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21114_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21114_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21120_ADDR 2440
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21120_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21120_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21120_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21121_ADDR 2441
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21121_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21121_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21121_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21122_ADDR 2442
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21122_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21122_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21122_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21123_ADDR 2443
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21123_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21123_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21123_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21124_ADDR 2444
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21124_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21124_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21124_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21130_ADDR 2445
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21130_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21130_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21130_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21131_ADDR 2446
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21131_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21131_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21131_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21132_ADDR 2447
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21132_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21132_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21132_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21133_ADDR 2448
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21133_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21133_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21133_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21134_ADDR 2449
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21134_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21134_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21134_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21140_ADDR 2450
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21140_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21140_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21140_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21141_ADDR 2451
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21141_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21141_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21141_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21142_ADDR 2452
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21142_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21142_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21142_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21143_ADDR 2453
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21143_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21143_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21143_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21144_ADDR 2454
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21144_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21144_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21144_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21150_ADDR 2455
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21150_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21150_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21150_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21151_ADDR 2456
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21151_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21151_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21151_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21152_ADDR 2457
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21152_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21152_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21152_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21153_ADDR 2458
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21153_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21153_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21153_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21154_ADDR 2459
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21154_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21154_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26B21154_MEMORYPAGE 0
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26ALPHA_ADDR 5289
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26ALPHA_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.997918835299299)
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26ALPHA_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_OUTPUTEQH_ALG0_IDXSELINDPBANDSALGMDPSLEWALG26ALPHA_MEMORYPAGE 0
    /* Module Nx1 Linear2_2 - Nx1 Mixer (Linear)*/
    #define MOD_AUDIOOUT_NX1LINEAR2_2_COUNT                2
    #define MOD_AUDIOOUT_NX1LINEAR2_2_DEVICE               "IC1"
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0000_ADDR 2462
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0000_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0000_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0000_MEMORYPAGE 0
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0001_ADDR 2463
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0001_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0001_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_NX1LINEAR2_2_ALG0_MIXER2X1NOSLEWS300ALG2VOL0001_MEMORYPAGE 0
    /* Module CorssOver - Automatic Speaker EQ*/
    #define MOD_AUDIOOUT_CORSSOVER_COUNT                   24
    #define MOD_AUDIOOUT_CORSSOVER_DEVICE                  "IC1"
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002LOWINVERT_ADDR 2464
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002LOWINVERT_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002LOWINVERT_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002LOWINVERT_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002HIGHINVERT_ADDR 2465
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002HIGHINVERT_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002HIGHINVERT_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002HIGHINVERT_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB2_ADDR 2466
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.689306168767582)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB1_ADDR 2467
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.37861233753516)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB0_ADDR 2468
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB0_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.689306168767582)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB0_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMB0_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA2_ADDR 2469
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.477592250072517)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA1_ADDR 2470
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.27963242499781)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT1_PARAMA1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB2_ADDR 2471
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.689306168767582)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB1_ADDR 2472
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.37861233753516)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB0_ADDR 2473
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB0_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.689306168767582)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB0_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMB0_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA2_ADDR 2474
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.477592250072517)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA1_ADDR 2475
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.27963242499781)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND0_FILT2_PARAMA1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB2_ADDR 2476
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.998150511190452)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB1_ADDR 2477
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.9963010223809)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB0_ADDR 2478
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB0_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.998150511190452)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB0_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMB0_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA2_ADDR 2479
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.996304442992686)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA1_ADDR 2480
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.99629760176912)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT1_PARAMA1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB2_ADDR 2481
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.998150511190452)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB1_ADDR 2482
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-1.9963010223809)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB0_ADDR 2483
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB0_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.998150511190452)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB0_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMB0_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA2_ADDR 2484
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA2_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(-0.996304442992686)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA2_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA2_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA1_ADDR 2485
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA1_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1.99629760176912)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA1_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_BAND1_FILT2_PARAMA1_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY0_ADDR 5290
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY0_FIXPT 0x00000001
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY0_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY0_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY0_MEMORYPAGE 0
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY1_ADDR 5291
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY1_FIXPT 0x00000001
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY1_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1)
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY1_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_CORSSOVER_ALG0_DOUBLEBANDSPKREQALGDPS3002DELAY1_MEMORYPAGE 0
    /* Module SpeakerLow_Limiter - Limiter*/
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_COUNT          3
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_DEVICE         "IC1"
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_THRESHOLD_ADDR 2486
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_THRESHOLD_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_THRESHOLD_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_THRESHOLD_MEMORYPAGE 0
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_RMS_ADDR  5292
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_RMS_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000239881380791562)
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_RMS_TYPE  SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_RMS_MEMORYPAGE 0
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_DECAY_ADDR 5293
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_DECAY_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000244140625)
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_DECAY_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_SPEAKERLOW_LIMITER_ALG0_DECAY_MEMORYPAGE 0
    /* Module SpeakerHi_Limiter - Limiter*/
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_COUNT           3
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_DEVICE          "IC1"
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_THRESHOLD_ADDR 2489
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_THRESHOLD_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(1)
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_THRESHOLD_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_THRESHOLD_MEMORYPAGE 0
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_RMS_ADDR   5294
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_RMS_VALUE  SIGMASTUDIOTYPE_8_24_CONVERT(0.000239881380791562)
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_RMS_TYPE   SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_RMS_MEMORYPAGE 0
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_DECAY_ADDR 5295
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_DECAY_VALUE SIGMASTUDIOTYPE_8_24_CONVERT(0.000244140625)
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_DECAY_TYPE SIGMASTUDIOTYPE_8_24
    #define MOD_AUDIOOUT_SPEAKERHI_LIMITER_ALG0_DECAY_MEMORYPAGE 0
    /* Module Wav Player1 - Wav Player*/
    #define MOD_AUDIOOUT_WAVPLAYER1_COUNT                  2650
    #define MOD_AUDIOOUT_WAVPLAYER1_DEVICE                 "IC1"
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT00_ADDR 2494
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT00_FIXPT 0xF1FF40FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT00_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-234929925)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT00_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT00_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01_ADDR 2495
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01_FIXPT 0x3FFA6BF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1073376245)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02_ADDR 2496
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02_FIXPT 0xCA003A09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-905954807)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT03_ADDR 2497
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT03_FIXPT 0x6605D304
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT03_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1711657732)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT03_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT03_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT04_ADDR 2498
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT04_FIXPT 0x8DFE92FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT04_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1912696066)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT04_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT04_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT05_ADDR 2499
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT05_FIXPT 0xA3FDFA04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT05_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1543636476)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT05_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT05_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT06_ADDR 2500
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT06_FIXPT 0x2B0631FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT06_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(721826302)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT06_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT06_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT07_ADDR 2501
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT07_FIXPT 0x63FBBCF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT07_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1677442293)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT07_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT07_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT08_ADDR 2502
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT08_FIXPT 0x4CF5D0F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT08_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1291178233)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT08_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT08_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT09_ADDR 2503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT09_FIXPT 0xBF04D405
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT09_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1090202619)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT09_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT09_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT010_ADDR 2504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT010_FIXPT 0xCFFECCFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT010_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-805384963)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT010_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT010_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT011_ADDR 2505
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT011_FIXPT 0x30016DFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT011_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(805400063)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT011_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT011_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT012_ADDR 2506
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT012_FIXPT 0x2C05690E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT012_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(738552078)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT012_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT012_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT013_ADDR 2507
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT013_FIXPT 0x1F08BAFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT013_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(520665853)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT013_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT013_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT014_ADDR 2508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT014_FIXPT 0x8CF6BCF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT014_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1929986826)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT014_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT014_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT015_ADDR 2509
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT015_FIXPT 0x39FAEE04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT015_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(972746244)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT015_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT015_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT016_ADDR 2510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT016_FIXPT 0xB40B7500
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT016_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1274317568)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT016_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT016_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT017_ADDR 2511
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT017_FIXPT 0xEFFF1400
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT017_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-268495872)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT017_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT017_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT018_ADDR 2512
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT018_FIXPT 0x21020005
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT018_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(553779205)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT018_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT018_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT019_ADDR 2513
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT019_FIXPT 0xD30CE90B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT019_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-754128629)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT019_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT019_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT020_ADDR 2514
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT020_FIXPT 0x7EF7F5EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT020_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2130179566)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT020_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT020_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT021_ADDR 2515
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT021_FIXPT 0x61EA9BF0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT021_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1642765296)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT021_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT021_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT022_ADDR 2516
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT022_FIXPT 0x15FAC902
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT022_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(368756994)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT022_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT022_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT023_ADDR 2517
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT023_FIXPT 0x9EF921F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT023_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1627840012)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT023_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT023_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT024_ADDR 2518
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT024_FIXPT 0xBCFD9C06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT024_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1124230138)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT024_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT024_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT025_ADDR 2519
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT025_FIXPT 0x81101B1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT025_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2129650917)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT025_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT025_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT026_ADDR 2520
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT026_FIXPT 0x031EDB04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT026_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(52353796)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT026_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT026_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT027_ADDR 2521
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT027_FIXPT 0x33F75EF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT027_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(871849713)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT027_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT027_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT028_ADDR 2522
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT028_FIXPT 0x20F88503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT028_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(553157891)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT028_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT028_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT029_ADDR 2523
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT029_FIXPT 0xD40A9FFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT029_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-737501185)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT029_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT029_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT030_ADDR 2524
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT030_FIXPT 0x5CEF19FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT030_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1559173626)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT030_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT030_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT031_ADDR 2525
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT031_FIXPT 0x8CFFE709
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT031_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1929386231)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT031_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT031_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT032_ADDR 2526
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT032_FIXPT 0xC613D817
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT032_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-971778025)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT032_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT032_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT033_ADDR 2527
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT033_FIXPT 0x1BFB00E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT033_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(469434599)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT033_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT033_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT034_ADDR 2528
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT034_FIXPT 0xEFE093E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT034_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-270494747)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT034_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT034_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT035_ADDR 2529
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT035_FIXPT 0xCAF4BCFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT035_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-889930500)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT035_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT035_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT036_ADDR 2530
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT036_FIXPT 0xD0F817EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT036_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-789047313)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT036_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT036_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT037_ADDR 2531
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT037_FIXPT 0x1002560D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT037_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(268588557)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT037_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT037_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT038_ADDR 2532
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT038_FIXPT 0x7320B92A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT038_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1931524394)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT038_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT038_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT039_ADDR 2533
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT039_FIXPT 0x962DFE0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT039_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1775370740)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT039_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT039_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT040_ADDR 2534
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT040_FIXPT 0x9AF52AEF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT040_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1695208721)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT040_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT040_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT041_ADDR 2535
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT041_FIXPT 0xF7EFDEFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT041_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-135274755)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT041_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT041_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT042_ADDR 2536
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT042_FIXPT 0x7D0039F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT042_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2097166837)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT042_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT042_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT043_ADDR 2537
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT043_FIXPT 0xBBE3E7F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT043_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1142691853)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT043_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT043_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT044_ADDR 2538
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT044_FIXPT 0xDAFC4914
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT044_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-621000428)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT044_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT044_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT045_ADDR 2539
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT045_FIXPT 0x871E801B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT045_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2028044261)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT045_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT045_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT046_ADDR 2540
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT046_FIXPT 0x51F6F0DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT046_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1375138013)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT046_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT046_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT047_ADDR 2541
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT047_FIXPT 0x20D759DE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT047_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(550984158)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT047_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT047_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT048_ADDR 2542
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT048_FIXPT 0x2AF72702
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT048_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(720840450)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT048_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT048_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT049_ADDR 2543
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT049_FIXPT 0x47FB6FF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT049_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1207660532)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT049_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT049_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT050_ADDR 2544
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT050_FIXPT 0x5C0AD918
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT050_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1544214808)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT050_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT050_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT051_ADDR 2545
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT051_FIXPT 0x16347C3D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT051_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(372538429)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT051_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT051_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT052_ADDR 2546
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT052_FIXPT 0xB52FC305
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT052_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1255161083)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT052_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT052_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT053_ADDR 2547
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT053_FIXPT 0x90E96FDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT053_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1863749666)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT053_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT053_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT054_ADDR 2548
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT054_FIXPT 0x2EE789F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT054_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(786926070)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT054_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT054_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT055_ADDR 2549
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT055_FIXPT 0x1FF5A3E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT055_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(536191971)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT055_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT055_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT056_ADDR 2550
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT056_FIXPT 0xE9E089F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT056_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-371160588)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT056_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT056_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT057_ADDR 2551
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT057_FIXPT 0x8F072B24
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT057_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1895355612)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT057_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT057_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT058_ADDR 2552
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT058_FIXPT 0xDC27CA0B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT058_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-601372149)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT058_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT058_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT059_ADDR 2553
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT059_FIXPT 0x56E668D5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT059_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1457940693)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT059_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT059_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT060_ADDR 2554
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT060_FIXPT 0x78D6B5F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT060_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2027337201)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT060_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT060_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT061_ADDR 2555
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT061_FIXPT 0xA4051E04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT061_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1543168508)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT061_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT061_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT062_ADDR 2556
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT062_FIXPT 0xF9FA9C03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT062_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-101016573)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT062_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT062_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT063_ADDR 2557
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT063_FIXPT 0x1018B332
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT063_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(270054194)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT063_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT063_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT064_ADDR 2558
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT064_FIXPT 0x1249273A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT064_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(306784058)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT064_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT064_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT065_ADDR 2559
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT065_FIXPT 0xBE0F07E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT065_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1106311192)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT065_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT065_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT066_ADDR 2560
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT066_FIXPT 0x1DD3FBD1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT066_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(500431825)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT066_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT066_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT067_ADDR 2561
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT067_FIXPT 0x7AE96EED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT067_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2062118637)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT067_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT067_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT068_ADDR 2562
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT068_FIXPT 0xF7E039DF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT068_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-136300065)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT068_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT068_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT069_ADDR 2563
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT069_FIXPT 0x02EB8D01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT069_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(48991489)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT069_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT069_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT070_ADDR 2564
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT070_FIXPT 0xE1233230
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT070_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-517787088)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT070_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT070_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT071_ADDR 2565
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT071_FIXPT 0xA6186CF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT071_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1508348681)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT071_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT071_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT072_ADDR 2566
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT072_FIXPT 0xB0DC4BD9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT072_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1327739943)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT072_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT072_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT073_ADDR 2567
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT073_FIXPT 0xABEEFA07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT073_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1410401785)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT073_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT073_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT074_ADDR 2568
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT074_FIXPT 0xBB076504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT074_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157143292)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT074_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT074_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT075_ADDR 2569
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT075_FIXPT 0x1F086A15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT075_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(520645141)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT075_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT075_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT076_ADDR 2570
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT076_FIXPT 0x372E9149
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT076_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(925798729)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT076_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT076_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT077_ADDR 2571
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT077_FIXPT 0x9F37580C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT077_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1623762932)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT077_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT077_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT078_ADDR 2572
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT078_FIXPT 0x5EE203C5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT078_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1591870405)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT078_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT078_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT079_ADDR 2573
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT079_FIXPT 0x79C5AEDC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT079_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2042998492)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT079_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT079_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT080_ADDR 2574
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT080_FIXPT 0xF0E4A7DF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT080_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-253450273)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT080_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT080_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT081_ADDR 2575
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT081_FIXPT 0xA8E2E4E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT081_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1461525272)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT081_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT081_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT082_ADDR 2576
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT082_FIXPT 0x55055D30
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT082_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1426414896)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT082_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT082_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT083_ADDR 2577
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT083_FIXPT 0x983D4921
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT083_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1740814047)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT083_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT083_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT084_ADDR 2578
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT084_FIXPT 0xF7FF3CE2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT084_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-134267678)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT084_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT084_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT085_ADDR 2579
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT085_FIXPT 0x2CDD15F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT085_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(752686579)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT085_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT085_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT086_ADDR 2580
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT086_FIXPT 0x620CCE0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT086_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1645006346)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT086_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT086_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT087_ADDR 2581
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT087_FIXPT 0x3907D304
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT087_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(956814084)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT087_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT087_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT088_ADDR 2582
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT088_FIXPT 0xDB11BE32
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT088_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-619594190)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT088_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT088_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT089_ADDR 2583
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT089_FIXPT 0xEE44BC28
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT089_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-297485272)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT089_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT089_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT090_ADDR 2584
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT090_FIXPT 0x68FBD3D0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT090_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1761334224)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT090_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT090_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT091_ADDR 2585
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT091_FIXPT 0x77B439BF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT091_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2008299967)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT091_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT091_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT092_ADDR 2586
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT092_FIXPT 0x0FD838E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT092_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(265828579)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT092_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT092_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT093_ADDR 2587
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT093_FIXPT 0x20E46DEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT093_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(551841259)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT093_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT093_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT094_ADDR 2588
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT094_FIXPT 0x87F9E023
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT094_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2013667293)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT094_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT094_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT095_ADDR 2589
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT095_FIXPT 0x68463E42
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT095_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1749433922)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT095_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT095_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT096_ADDR 2590
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT096_FIXPT 0x331FF3FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT096_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(857732093)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT096_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT096_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT097_ADDR 2591
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT097_FIXPT 0x80DD7EE3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT097_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2132967709)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT097_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT097_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT098_ADDR 2592
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT098_FIXPT 0x78F9DE09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT098_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2029641225)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT098_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT098_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT099_ADDR 2593
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT099_FIXPT 0x51058602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT099_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1359316482)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT099_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT099_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0100_ADDR 2594
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0100_FIXPT 0xBB01801E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0100_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157529570)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0100_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0100_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0101_ADDR 2595
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0101_FIXPT 0x0039A034
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0101_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(3776564)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0101_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0101_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0102_ADDR 2596
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0102_FIXPT 0x280959DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0102_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(671701469)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0102_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0102_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0103_ADDR 2597
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0103_FIXPT 0x2FB310AC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0103_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(800264364)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0103_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0103_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0104_ADDR 2598
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0104_FIXPT 0xECC6E6E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0104_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-322509080)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0104_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0104_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0105_ADDR 2599
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0105_FIXPT 0x23F1CCF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0105_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(603049207)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0105_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0105_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0106_ADDR 2600
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0106_FIXPT 0xF9FF9F22
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0106_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-100688094)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0106_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0106_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0107_ADDR 2601
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0107_FIXPT 0x30484153
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0107_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(810041683)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0107_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0107_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0108_ADDR 2602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0108_FIXPT 0x1935CE0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0108_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(422956557)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0108_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0108_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0109_ADDR 2603
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0109_FIXPT 0x51E278D2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0109_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1373796562)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0109_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0109_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0110_ADDR 2604
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0110_FIXPT 0x28E74403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0110_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(686244867)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0110_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0110_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0111_ADDR 2605
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0111_FIXPT 0xE70340FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0111_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-419217153)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0111_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0111_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0112_ADDR 2606
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0112_FIXPT 0x01FDBF12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0112_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(33406738)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0112_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0112_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0113_ADDR 2607
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0113_FIXPT 0xAE2C3D2F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0113_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1372832465)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0113_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0113_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0114_ADDR 2608
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0114_FIXPT 0x9008EEDB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0114_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1878462757)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0114_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0114_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0115_ADDR 2609
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0115_FIXPT 0xD8B2C1A9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0115_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-659373655)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0115_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0115_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0116_ADDR 2610
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0116_FIXPT 0x5CC927F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0116_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1556686835)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0116_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0116_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0117_ADDR 2611
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0117_FIXPT 0x7500F105
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0117_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1962995973)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0117_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0117_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0118_ADDR 2612
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0118_FIXPT 0x760E7E2D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0118_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1980661293)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0118_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0118_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0119_ADDR 2613
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0119_FIXPT 0xB64FFA58
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0119_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1236272552)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0119_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0119_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0120_ADDR 2614
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0120_FIXPT 0xFF30E004
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0120_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-13574140)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0120_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0120_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0121_ADDR 2615
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0121_FIXPT 0x2CDAFFC7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0121_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(752549831)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0121_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0121_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0122_ADDR 2616
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0122_FIXPT 0xC3DD14FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0122_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1008921345)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0122_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0122_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0123_ADDR 2617
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0123_FIXPT 0x82007DFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0123_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2113896965)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0123_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0123_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0124_ADDR 2618
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0124_FIXPT 0x9EF96E0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0124_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1627820531)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0124_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0124_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0125_ADDR 2619
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0125_FIXPT 0x2223E021
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0125_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(572776481)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0125_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0125_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0126_ADDR 2620
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0126_FIXPT 0xBDFA21D7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0126_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1107680809)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0126_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0126_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0127_ADDR 2621
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0127_FIXPT 0xE7B72DB6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0127_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-407425610)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0127_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0127_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0128_ADDR 2622
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0128_FIXPT 0xBFDAFB05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0128_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1076167931)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0128_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0128_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0129_ADDR 2623
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0129_FIXPT 0xC30F7C16
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0129_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1022395370)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0129_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0129_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0130_ADDR 2624
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0130_FIXPT 0x261F5C38
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0130_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(639589432)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0130_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0130_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0131_ADDR 2625
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0131_FIXPT 0x2C4F4E46
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0131_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(743394886)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0131_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0131_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0132_ADDR 2626
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0132_FIXPT 0x3019DBED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0132_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(807001069)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0132_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0132_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0133_ADDR 2627
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0133_FIXPT 0x42C625C4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0133_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1120282052)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0133_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0133_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0134_ADDR 2628
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0134_FIXPT 0x53E457FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0134_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1407473662)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0134_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0134_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0135_ADDR 2629
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0135_FIXPT 0xBFFA2AF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0135_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1074124041)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0135_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0135_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0136_ADDR 2630
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0136_FIXPT 0x0FF6EE0B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0136_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(267841035)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0136_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0136_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0137_ADDR 2631
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0137_FIXPT 0x05235D16
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0137_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(86203670)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0137_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0137_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0138_ADDR 2632
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0138_FIXPT 0x32F279D1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0138_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(854751697)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0138_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0138_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0139_ADDR 2633
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0139_FIXPT 0x57BB66D2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0139_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1471899346)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0139_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0139_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0140_ADDR 2634
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0140_FIXPT 0x9800F61A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0140_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1744767462)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0140_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0140_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0141_ADDR 2635
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0141_FIXPT 0x6D1DF21E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0141_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1830679070)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0141_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0141_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0142_ADDR 2636
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0142_FIXPT 0xD122CB3A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0142_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-786248902)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0142_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0142_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0143_ADDR 2637
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0143_FIXPT 0x1A445C26
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0143_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(440687654)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0143_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0143_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0144_ADDR 2638
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0144_FIXPT 0xDFF6B7CB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0144_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-537479221)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0144_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0144_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0145_ADDR 2639
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0145_FIXPT 0x8AB8B0D5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0145_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1967607595)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0145_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0145_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0146_ADDR 2640
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0146_FIXPT 0x40F27BF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0146_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1089633273)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0146_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0146_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0147_ADDR 2641
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0147_FIXPT 0x61F51AF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0147_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1643453173)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0147_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0147_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0148_ADDR 2642
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0148_FIXPT 0x0EFFA91E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0148_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(251635998)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0148_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0148_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0149_ADDR 2643
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0149_FIXPT 0xDE235A09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0149_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-568108535)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0149_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0149_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0150_ADDR 2644
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0150_FIXPT 0x0BE55ACA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0150_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(199580362)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0150_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0150_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0151_ADDR 2645
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0151_FIXPT 0x20D8D403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0151_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(551080963)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0151_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0151_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0152_ADDR 2646
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0152_FIXPT 0xC6198F20
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0152_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-971403488)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0152_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0152_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0153_ADDR 2647
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0153_FIXPT 0x081F8717
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0153_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(136283927)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0153_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0153_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0154_ADDR 2648
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0154_FIXPT 0xCC273239
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0154_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-869846471)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0154_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0154_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0155_ADDR 2649
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0155_FIXPT 0x08254CF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0155_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(136662265)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0155_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0155_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0156_ADDR 2650
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0156_FIXPT 0x38CBB6B5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0156_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(952874677)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0156_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0156_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0157_ADDR 2651
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0157_FIXPT 0x27CFB0EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0157_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(667922667)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0157_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0157_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0158_ADDR 2652
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0158_FIXPT 0xE7FBD2FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0158_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-402926851)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0158_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0158_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0159_ADDR 2653
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0159_FIXPT 0x9AF72300
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0159_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1695079680)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0159_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0159_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0160_ADDR 2654
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0160_FIXPT 0xF721082A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0160_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-148830166)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0160_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0160_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0161_ADDR 2655
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0161_FIXPT 0x2A16CDF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0161_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(706137585)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0161_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0161_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0162_ADDR 2656
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0162_FIXPT 0x0FD4EDDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0162_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(265612766)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0162_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0162_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0163_ADDR 2657
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0163_FIXPT 0xB104DE18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0163_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1325081064)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0163_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0163_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0164_ADDR 2658
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0164_FIXPT 0x35228B15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0164_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(891456277)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0164_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0164_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0165_ADDR 2659
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0165_FIXPT 0x370EDB1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0165_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(923720478)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0165_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0165_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0166_ADDR 2660
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0166_FIXPT 0x652B3316
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0166_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1697329942)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0166_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0166_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0167_ADDR 2661
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0167_FIXPT 0x7DED05C1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0167_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2112685505)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0167_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0167_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0168_ADDR 2662
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0168_FIXPT 0x88BA3DD8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0168_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2001060392)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0168_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0168_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0169_ADDR 2663
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0169_FIXPT 0x23F31C04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0169_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(603134980)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0169_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0169_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0170_ADDR 2664
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0170_FIXPT 0x040301FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0170_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(67305978)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0170_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0170_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0171_ADDR 2665
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0171_FIXPT 0xD60E552D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0171_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-703703763)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0171_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0171_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0172_ADDR 2666
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0172_FIXPT 0x542A1610
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0172_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1412044304)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0172_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0172_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0173_ADDR 2667
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0173_FIXPT 0xD8E65BD9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0173_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-655991847)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0173_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0173_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0174_ADDR 2668
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0174_FIXPT 0x93EDE70A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0174_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1813125366)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0174_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0174_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0175_ADDR 2669
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0175_FIXPT 0x9B18241B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0175_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1692916709)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0175_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0175_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0176_ADDR 2670
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0176_FIXPT 0x73059308
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0176_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1929745160)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0176_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0176_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0177_ADDR 2671
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0177_FIXPT 0x5319A517
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0177_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1394189591)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0177_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0177_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0178_ADDR 2672
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0178_FIXPT 0xE6FEF1D6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0178_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-419499562)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0178_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0178_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0179_ADDR 2673
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0179_FIXPT 0x89C24AD3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0179_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1983755565)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0179_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0179_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0180_ADDR 2674
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0180_FIXPT 0x24ED1BFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0180_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(619518974)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0180_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0180_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0181_ADDR 2675
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0181_FIXPT 0xE40D6101
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0181_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-468885247)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0181_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0181_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0182_ADDR 2676
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0182_FIXPT 0xBE098B1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0182_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1106670819)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0182_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0182_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0183_ADDR 2677
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0183_FIXPT 0x222AC01A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0183_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(573227034)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0183_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0183_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0184_ADDR 2678
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0184_FIXPT 0xF0F85ADE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0184_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-252159266)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0184_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0184_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0185_ADDR 2679
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0185_FIXPT 0x6FED4800
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0185_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1877821440)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0185_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0185_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0186_ADDR 2680
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0186_FIXPT 0x1E0C2217
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0186_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(504111639)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0186_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0186_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0187_ADDR 2681
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0187_FIXPT 0xBB0301FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0187_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157430789)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0187_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0187_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0188_ADDR 2682
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0188_FIXPT 0x38056F12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0188_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(939880210)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0188_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0188_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0189_ADDR 2683
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0189_FIXPT 0x07084FED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0189_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(117985261)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0189_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0189_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0190_ADDR 2684
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0190_FIXPT 0x37CF6EDD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0190_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(936341213)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0190_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0190_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0191_ADDR 2685
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0191_FIXPT 0x54EE9FFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0191_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1424924671)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0191_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0191_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0192_ADDR 2686
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0192_FIXPT 0xBF11D809
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0192_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1089349623)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0192_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0192_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0193_ADDR 2687
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0193_FIXPT 0xED030313
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0193_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-318569709)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0193_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0193_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0194_ADDR 2688
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0194_FIXPT 0xEB20191A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0194_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-350217958)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0194_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0194_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0195_ADDR 2689
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0195_FIXPT 0xD404AFE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0195_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-737890330)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0195_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0195_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0196_ADDR 2690
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0196_FIXPT 0xE5F1DFFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0196_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-437133318)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0196_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0196_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0197_ADDR 2691
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0197_FIXPT 0x1A04A60B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0197_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(436512267)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0197_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0197_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0198_ADDR 2692
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0198_FIXPT 0x02FCCCF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0198_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(50121971)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0198_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0198_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0199_ADDR 2693
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0199_FIXPT 0x3403350E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0199_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(872625422)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0199_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0199_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0200_ADDR 2694
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0200_FIXPT 0xC30981F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0200_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1022787080)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0200_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0200_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0201_ADDR 2695
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0201_FIXPT 0x4FDEAEE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0201_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1339993833)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0201_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0201_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0202_ADDR 2696
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0202_FIXPT 0xBFF63403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0202_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1074383869)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0202_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0202_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0203_ADDR 2697
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0203_FIXPT 0x040E3105
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0203_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(68038917)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0203_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0203_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0204_ADDR 2698
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0204_FIXPT 0x28010010
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0204_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(671154192)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0204_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0204_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0205_ADDR 2699
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0205_FIXPT 0xD717EC12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0205_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-686298094)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0205_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0205_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0206_ADDR 2700
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0206_FIXPT 0x220378EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0206_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(570652910)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0206_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0206_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0207_ADDR 2701
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0207_FIXPT 0xF6F46DFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0207_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-151753222)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0207_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0207_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0208_ADDR 2702
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0208_FIXPT 0xF3FC0401
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0208_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-201587711)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0208_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0208_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0209_ADDR 2703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0209_FIXPT 0xB4F9FDF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0209_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1258684937)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0209_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0209_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0210_ADDR 2704
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0210_FIXPT 0xFD068D0B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0210_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-49902325)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0210_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0210_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0211_ADDR 2705
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0211_FIXPT 0xE70626F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0211_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-419027207)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0211_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0211_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0212_ADDR 2706
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0212_FIXPT 0x39EDC6F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0212_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(971884279)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0212_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0212_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0213_ADDR 2707
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0213_FIXPT 0xB3FD4903
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0213_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1275246333)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0213_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0213_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0214_ADDR 2708
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0214_FIXPT 0xA405C8FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0214_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1543124738)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0214_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0214_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0215_ADDR 2709
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0215_FIXPT 0x25000A0E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0215_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(620759566)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0215_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0215_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0216_ADDR 2710
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0216_FIXPT 0xAB0E8F09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0216_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1425109239)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0216_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0216_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0217_ADDR 2711
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0217_FIXPT 0x00FD6FF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0217_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(16609265)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0217_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0217_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0218_ADDR 2712
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0218_FIXPT 0x40FA60FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0218_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1090150653)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0218_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0218_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0219_ADDR 2713
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0219_FIXPT 0xCDFF8AFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0219_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-838890755)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0219_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0219_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0220_ADDR 2714
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0220_FIXPT 0xAEF8F6FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0220_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1359415554)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0220_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0220_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0221_ADDR 2715
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0221_FIXPT 0x040BE307
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0221_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(67887879)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0221_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0221_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0222_ADDR 2716
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0222_FIXPT 0x530393F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0222_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1392743417)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0222_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0222_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0223_ADDR 2717
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0223_FIXPT 0xCBF4B102
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0223_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-873156350)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0223_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0223_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0224_ADDR 2718
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0224_FIXPT 0x6602A2FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0224_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1711448831)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0224_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0224_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0225_ADDR 2719
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0225_FIXPT 0x2AFBF2F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0225_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(721154808)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0225_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0225_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0226_ADDR 2720
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0226_FIXPT 0xA503D50A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0226_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1526475510)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0226_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0226_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0227_ADDR 2721
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0227_FIXPT 0x21044AFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0227_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(553929469)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0227_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0227_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0228_ADDR 2722
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0228_FIXPT 0x39F8EDFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0228_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(972615165)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0228_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0228_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0229_ADDR 2723
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0229_FIXPT 0x2A0B3504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0229_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(705377540)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0229_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0229_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0230_ADDR 2724
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0230_FIXPT 0xC9FC21FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0230_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-906223110)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0230_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0230_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0231_ADDR 2725
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0231_FIXPT 0x35FD440A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0231_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(905790474)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0231_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0231_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0232_ADDR 2726
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0232_FIXPT 0xB807CEFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0232_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1207447813)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0232_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0232_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0233_ADDR 2727
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0233_FIXPT 0x64F89EF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0233_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1694015225)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0233_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0233_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0234_ADDR 2728
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0234_FIXPT 0x71048F0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0234_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1896124172)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0234_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0234_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0235_ADDR 2729
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0235_FIXPT 0x2CFD8BF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0235_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(754813939)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0235_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0235_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0236_ADDR 2730
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0236_FIXPT 0xBCF35CFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0236_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1124901636)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0236_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0236_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0237_ADDR 2731
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0237_FIXPT 0x5E078FFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0237_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1577553914)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0237_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0237_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0238_ADDR 2732
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0238_FIXPT 0x2BF8D301
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0238_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(737727233)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0238_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0238_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0239_ADDR 2733
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0239_FIXPT 0xED080E16
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0239_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-318239210)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0239_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0239_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0240_ADDR 2734
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0240_FIXPT 0xB113B8FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0240_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1324107523)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0240_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0240_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0241_ADDR 2735
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0241_FIXPT 0x79F79DFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0241_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2046270972)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0241_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0241_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0242_ADDR 2736
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0242_FIXPT 0xBB03A301
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0242_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157389567)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0242_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0242_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0243_ADDR 2737
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0243_FIXPT 0x21EE38F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0243_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(569260276)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0243_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0243_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0244_ADDR 2738
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0244_FIXPT 0xE0FFFA0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0244_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-520095222)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0244_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0244_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0245_ADDR 2739
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0245_FIXPT 0xC214CFFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0245_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1038823426)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0245_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0245_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0246_ADDR 2740
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0246_FIXPT 0xC5EC00EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0246_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-974389013)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0246_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0246_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0247_ADDR 2741
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0247_FIXPT 0x14F72103
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0247_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(351740163)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0247_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0247_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0248_ADDR 2742
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0248_FIXPT 0xD0FBE8F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0248_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-788797194)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0248_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0248_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0249_ADDR 2743
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0249_FIXPT 0x7D081616
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0249_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2097681942)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0249_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0249_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0250_ADDR 2744
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0250_FIXPT 0x7623BC1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0250_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1982053406)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0250_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0250_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0251_ADDR 2745
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0251_FIXPT 0x06FD44F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0251_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(117261553)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0251_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0251_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0252_ADDR 2746
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0252_FIXPT 0xCCF1D5FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0252_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-856566278)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0252_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0252_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0253_ADDR 2747
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0253_FIXPT 0x47F993E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0253_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1207538659)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0253_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0253_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0254_ADDR 2748
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0254_FIXPT 0x53F24502
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0254_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1408386306)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0254_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0254_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0255_ADDR 2749
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0255_FIXPT 0x5313981B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0255_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1393793051)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0255_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0255_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0256_ADDR 2750
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0256_FIXPT 0x0CFDADE4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0256_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(217951716)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0256_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0256_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0257_ADDR 2751
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0257_FIXPT 0x4DE554FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0257_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1306875132)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0257_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0257_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0258_ADDR 2752
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0258_FIXPT 0x49060FFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0258_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1225134075)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0258_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0258_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0259_ADDR 2753
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0259_FIXPT 0xFBF9CC0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0259_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-67515377)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0259_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0259_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0260_ADDR 2754
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0260_FIXPT 0x3C23D931
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0260_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1008982321)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0260_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0260_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0261_ADDR 2755
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0261_FIXPT 0x5822FFF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0261_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1478688753)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0261_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0261_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0262_ADDR 2756
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0262_FIXPT 0x81E25DE7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0262_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2115871257)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0262_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0262_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0263_ADDR 2757
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0263_FIXPT 0x7EF36DED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0263_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2129882605)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0263_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0263_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0264_ADDR 2758
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0264_FIXPT 0xDCDF84F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0264_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-589331210)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0264_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0264_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0265_ADDR 2759
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0265_FIXPT 0x7A09D41E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0265_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2047464478)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0265_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0265_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0266_ADDR 2760
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0266_FIXPT 0xBC1E70F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0266_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1138855690)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0266_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0266_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0267_ADDR 2761
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0267_FIXPT 0x61E5A2E9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0267_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1642439401)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0267_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0267_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0268_ADDR 2762
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0268_FIXPT 0xA101C308
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0268_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1593720056)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0268_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0268_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0269_ADDR 2763
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0269_FIXPT 0x71F99F05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0269_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1912184581)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0269_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0269_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0270_ADDR 2764
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0270_FIXPT 0xE01B0C33
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0270_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-535098317)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0270_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0270_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0271_ADDR 2765
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0271_FIXPT 0x8A33380A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0271_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1976354806)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0271_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0271_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0272_ADDR 2766
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0272_FIXPT 0x7BDFC2D2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0272_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2078261970)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0272_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0272_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0273_ADDR 2767
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0273_FIXPT 0xBFE1F3EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0273_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1075710994)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0273_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0273_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0274_ADDR 2768
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0274_FIXPT 0x30E51BE3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0274_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(820321251)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0274_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0274_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0275_ADDR 2769
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0275_FIXPT 0x8EFB3118
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0275_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1896140520)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0275_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0275_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0276_ADDR 2770
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0276_FIXPT 0x222D3219
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0276_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(573387289)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0276_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0276_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0277_ADDR 2771
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0277_FIXPT 0xECF116E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0277_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-319744283)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0277_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0277_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0278_ADDR 2772
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0278_FIXPT 0x61F31B0B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0278_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1643322123)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0278_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0278_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0279_ADDR 2773
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0279_FIXPT 0xF50516FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0279_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-184215810)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0279_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0279_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0280_ADDR 2774
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0280_FIXPT 0x480DAB21
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0280_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1208855329)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0280_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0280_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0281_ADDR 2775
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0281_FIXPT 0x6F384D21
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0281_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1865960737)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0281_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0281_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0282_ADDR 2776
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0282_FIXPT 0xD1EA01CA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0282_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-773193270)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0282_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0282_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0283_ADDR 2777
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0283_FIXPT 0x6FCB2EE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0283_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1875586793)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0283_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0283_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0284_ADDR 2778
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0284_FIXPT 0x87E835E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0284_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2014824992)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0284_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0284_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0285_ADDR 2779
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0285_FIXPT 0x6CEF210F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0285_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1827610895)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0285_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0285_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0286_ADDR 2780
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0286_FIXPT 0x00394F37
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0286_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(3755831)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0286_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0286_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0287_ADDR 2781
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0287_FIXPT 0x3A0DE9E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0287_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(973990376)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0287_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0287_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0288_ADDR 2782
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0288_FIXPT 0x71E61C06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0288_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1910905862)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0288_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0288_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0289_ADDR 2783
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0289_FIXPT 0xA20BCFFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0289_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1576284165)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0289_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0289_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0290_ADDR 2784
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0290_FIXPT 0x4AFF5514
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0290_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1258247444)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0290_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0290_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0291_ADDR 2785
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0291_FIXPT 0xBB34282A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0291_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1154209750)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0291_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0291_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0292_ADDR 2786
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0292_FIXPT 0xC7F6BAC8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0292_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-940131640)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0292_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0292_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0293_ADDR 2787
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0293_FIXPT 0x41BD1FDA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0293_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1102913498)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0293_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0293_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0294_ADDR 2788
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0294_FIXPT 0x16EA0BE4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0294_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(384437220)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0294_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0294_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0295_ADDR 2789
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0295_FIXPT 0x98F01A11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0295_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1729095151)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0295_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0295_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0296_ADDR 2790
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0296_FIXPT 0xE9418248
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0296_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-381582776)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0296_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0296_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0297_ADDR 2791
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0297_FIXPT 0x051BEBF0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0297_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(85715952)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0297_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0297_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0298_ADDR 2792
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0298_FIXPT 0x8AE230F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0298_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1964887816)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0298_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0298_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0299_ADDR 2793
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0299_FIXPT 0x1306C9F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0299_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(319212025)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0299_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0299_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0300_ADDR 2794
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0300_FIXPT 0xF4F6DC05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0300_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-185148411)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0300_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0300_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0301_ADDR 2795
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0301_FIXPT 0x262B272D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0301_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(640362285)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0301_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0301_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0302_ADDR 2796
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0302_FIXPT 0xDDF831C9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0302_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-570936887)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0302_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0302_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0303_ADDR 2797
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0303_FIXPT 0x47B6B5D1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0303_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1203156433)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0303_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0303_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0304_ADDR 2798
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0304_FIXPT 0xE2EEE3F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0304_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-487660559)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0304_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0304_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0305_ADDR 2799
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0305_FIXPT 0x96FBBF15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0305_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1761886443)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0305_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0305_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0306_ADDR 2800
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0306_FIXPT 0x77481754
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0306_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2001213268)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0306_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0306_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0307_ADDR 2801
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0307_FIXPT 0xF92718F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0307_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-114878217)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0307_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0307_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0308_ADDR 2802
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0308_FIXPT 0xCBD6D5E9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0308_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-875112983)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0308_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0308_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0309_ADDR 2803
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0309_FIXPT 0xFAFD19F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0309_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-84076042)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0309_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0309_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0310_ADDR 2804
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0310_FIXPT 0x00F2BBFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0310_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(15907839)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0310_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0310_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0311_ADDR 2805
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0311_FIXPT 0x2F278026
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0311_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(791117862)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0311_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0311_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0312_ADDR 2806
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0312_FIXPT 0xE6F6CECA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0312_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-420032822)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0312_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0312_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0313_ADDR 2807
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0313_FIXPT 0x5EB4D8D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0313_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1588910292)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0313_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0313_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0314_ADDR 2808
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0314_FIXPT 0xF8F8D200
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0314_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-117911040)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0314_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0314_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0315_ADDR 2809
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0315_FIXPT 0x90090224
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0315_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1878457820)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0315_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0315_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0316_ADDR 2810
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0316_FIXPT 0xD3531E52
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0316_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-749527470)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0316_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0316_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0317_ADDR 2811
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0317_FIXPT 0xF11BC8E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0317_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-249837336)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0317_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0317_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0318_ADDR 2812
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0318_FIXPT 0x2CCBD2E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0318_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(751555296)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0318_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0318_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0319_ADDR 2813
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0319_FIXPT 0x74F72AF2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0319_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1962355442)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0319_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0319_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0320_ADDR 2814
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0320_FIXPT 0x0CEDFBFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0320_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(216923130)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0320_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0320_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0321_ADDR 2815
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0321_FIXPT 0x7222EA1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0321_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1914890782)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0321_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0321_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0322_ADDR 2816
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0322_FIXPT 0xFAF1C2CB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0322_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-84819253)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0322_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0322_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0323_ADDR 2817
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0323_FIXPT 0xBDBFABE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0323_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1111512090)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0323_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0323_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0324_ADDR 2818
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0324_FIXPT 0x430ABC10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0324_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1124776976)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0324_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0324_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0325_ADDR 2819
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0325_FIXPT 0x4418DE2F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0325_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1142480431)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0325_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0325_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0326_ADDR 2820
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0326_FIXPT 0xA051F543
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0326_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1605241533)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0326_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0326_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0327_ADDR 2821
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0327_FIXPT 0x8F0B9DD7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0327_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1895064105)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0327_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0327_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0328_ADDR 2822
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0328_FIXPT 0xF8C14DDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0328_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-121549346)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0328_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0328_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0329_ADDR 2823
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0329_FIXPT 0x44F44FEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0329_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1156861931)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0329_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0329_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0330_ADDR 2824
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0330_FIXPT 0xECE74204
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0330_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-320388604)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0330_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0330_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0331_ADDR 2825
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0331_FIXPT 0xB027D31C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0331_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1339567332)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0331_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0331_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0332_ADDR 2826
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0332_FIXPT 0x55F11ECD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0332_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1441865421)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0332_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0332_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0333_ADDR 2827
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0333_FIXPT 0x1ECF1AFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0333_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(516889340)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0333_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0333_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0334_ADDR 2828
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0334_FIXPT 0x381DEB1A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0334_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(941484826)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0334_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0334_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0335_ADDR 2829
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0335_FIXPT 0x86184D38
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0335_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2045227720)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0335_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0335_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0336_ADDR 2830
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0336_FIXPT 0xAC49FD23
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0336_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1404437213)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0336_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0336_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0337_ADDR 2831
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0337_FIXPT 0x5EEB8DBC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0337_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1592495548)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0337_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0337_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0338_ADDR 2832
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0338_FIXPT 0x4EC1D6E4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0338_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1321326308)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0338_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0338_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0339_ADDR 2833
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0339_FIXPT 0xD0ED04E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0339_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-789773083)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0339_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0339_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0340_ADDR 2834
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0340_FIXPT 0xFAED5D1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0340_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-85107427)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0340_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0340_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0341_ADDR 2835
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0341_FIXPT 0x4B341813
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0341_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1261705235)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0341_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0341_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0342_ADDR 2836
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0342_FIXPT 0xEBE8E9CE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0342_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-337057330)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0342_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0342_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0343_ADDR 2837
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0343_FIXPT 0x99EFE61C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0343_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1712331236)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0343_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0343_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0344_ADDR 2838
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0344_FIXPT 0xE119A813
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0344_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-518412269)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0344_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0344_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0345_ADDR 2839
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0345_FIXPT 0xC11CBB3A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0345_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1055081670)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0345_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0345_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0346_ADDR 2840
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0346_FIXPT 0xAC36C7FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0346_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1405696001)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0346_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0346_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0347_ADDR 2841
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0347_FIXPT 0x72CAF1AD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0347_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1925902765)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0347_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0347_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0348_ADDR 2842
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0348_FIXPT 0x4ECD69EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0348_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1322084844)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0348_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0348_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0349_ADDR 2843
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0349_FIXPT 0x06EB92F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0349_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(116101876)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0349_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0349_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0350_ADDR 2844
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0350_FIXPT 0xBC14D539
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0350_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1139485383)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0350_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0350_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0351_ADDR 2845
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0351_FIXPT 0x252EA602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0351_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(623814146)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0351_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0351_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0352_ADDR 2846
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0352_FIXPT 0x80DE2EDF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0352_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2132922657)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0352_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0352_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0353_ADDR 2847
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0353_FIXPT 0x350BD819
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0353_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(889968665)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0353_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0353_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0354_ADDR 2848
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0354_FIXPT 0xAC104B0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0354_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1408218353)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0354_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0354_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0355_ADDR 2849
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0355_FIXPT 0x55274733
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0355_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1428637491)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0355_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0355_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0356_ADDR 2850
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0356_FIXPT 0x0F06DECD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0356_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(252108493)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0356_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0356_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0357_ADDR 2851
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0357_FIXPT 0x0BA7FABF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0357_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(195558079)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0357_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0357_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0358_ADDR 2852
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0358_FIXPT 0x8FED0EF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0358_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1880289545)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0358_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0358_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0359_ADDR 2853
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0359_FIXPT 0xF9FE3F0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0359_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-100778225)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0359_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0359_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0360_ADDR 2854
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0360_FIXPT 0x3E392E40
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0360_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1043934784)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0360_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0360_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0361_ADDR 2855
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0361_FIXPT 0x6A1442E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0361_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1779712741)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0361_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0361_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0362_ADDR 2856
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0362_FIXPT 0x53D76C00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0362_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1406626816)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0362_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0362_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0363_ADDR 2857
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0363_FIXPT 0xCD14580D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0363_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-854304755)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0363_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0363_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0364_ADDR 2858
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0364_FIXPT 0xDB07D615
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0364_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-620243435)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0364_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0364_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0365_ADDR 2859
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0365_FIXPT 0x092AB709
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0365_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(153794313)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0365_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0365_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0366_ADDR 2860
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0366_FIXPT 0xE0D1B0AB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0366_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-523128661)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0366_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0366_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0367_ADDR 2861
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0367_FIXPT 0xF0BE62F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0367_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-255958287)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0367_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0367_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0368_ADDR 2862
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0368_FIXPT 0x9205A30B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0368_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1845124341)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0368_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0368_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0369_ADDR 2863
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0369_FIXPT 0xD016803E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0369_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-803831746)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0369_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0369_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0370_ADDR 2864
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0370_FIXPT 0xB140CD14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0370_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1321153260)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0370_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0370_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0371_ADDR 2865
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0371_FIXPT 0xECE475D1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0371_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-320571951)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0371_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0371_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0372_ADDR 2866
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0372_FIXPT 0x0CF8960D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0372_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(217617933)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0372_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0372_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0373_ADDR 2867
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0373_FIXPT 0x360A96FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0373_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(906663679)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0373_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0373_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0374_ADDR 2868
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0374_FIXPT 0x6D08A11E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0374_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1829282078)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0374_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0374_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0375_ADDR 2869
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0375_FIXPT 0xAC03DBD2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0375_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1409033262)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0375_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0375_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0376_ADDR 2870
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0376_FIXPT 0x88B181CF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0376_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2001632817)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0376_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0376_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0377_ADDR 2871
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0377_FIXPT 0x0100BA13
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0377_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(16824851)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0377_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0377_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0378_ADDR 2872
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0378_FIXPT 0x9817B519
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0378_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1743276775)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0378_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0378_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0379_ADDR 2873
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0379_FIXPT 0xA339A33B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0379_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1556503749)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0379_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0379_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0380_ADDR 2874
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0380_FIXPT 0x81114DDB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0380_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2129572389)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0380_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0380_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0381_ADDR 2875
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0381_FIXPT 0x7FD126F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0381_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2144413431)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0381_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0381_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0382_ADDR 2876
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0382_FIXPT 0x8D078F03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0382_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1928884477)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0382_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0382_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0383_ADDR 2877
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0383_FIXPT 0x36F44B06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0383_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(921979654)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0383_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0383_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0384_ADDR 2878
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0384_FIXPT 0xC31B2501
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0384_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1021631231)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0384_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0384_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0385_ADDR 2879
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0385_FIXPT 0xEFD127BE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0385_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-271505474)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0385_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0385_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0386_ADDR 2880
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0386_FIXPT 0xE7E5290E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0386_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-404412146)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0386_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0386_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0387_ADDR 2881
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0387_FIXPT 0x0D1FEA14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0387_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(220195348)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0387_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0387_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0388_ADDR 2882
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0388_FIXPT 0x501BC039
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0388_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1343995961)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0388_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0388_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0389_ADDR 2883
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0389_FIXPT 0x782C6DF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0389_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2016177657)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0389_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0389_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0390_ADDR 2884
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0390_FIXPT 0xDFCD7DD9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0390_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-540181031)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0390_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0390_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0391_ADDR 2885
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0391_FIXPT 0x82F66902
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0391_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2097780478)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0391_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0391_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0392_ADDR 2886
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0392_FIXPT 0x8EFA85F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0392_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1896184332)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0392_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0392_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0393_ADDR 2887
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0393_FIXPT 0x0B0F2A18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0393_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(185543192)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0393_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0393_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0394_ADDR 2888
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0394_FIXPT 0x7EF917D0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0394_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2130253776)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0394_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0394_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0395_ADDR 2889
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0395_FIXPT 0xF6DA6A01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0395_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-153458175)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0395_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0395_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0396_ADDR 2890
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0396_FIXPT 0x7117441D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0396_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1897350173)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0396_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0396_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0397_ADDR 2891
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0397_FIXPT 0x170F3E22
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0397_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(386874914)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0397_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0397_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0398_ADDR 2892
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0398_FIXPT 0xE330FB14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0398_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-483329260)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0398_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0398_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0399_ADDR 2893
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0399_FIXPT 0xAEE1BDCC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0399_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1360937524)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0399_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0399_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0400_ADDR 2894
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0400_FIXPT 0x68E167F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0400_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1759602678)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0400_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0400_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0401_ADDR 2895
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0401_FIXPT 0x2B0673F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0401_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(721843189)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0401_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0401_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0402_ADDR 2896
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0402_FIXPT 0xDF00FB18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0402_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-553583848)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0402_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0402_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0403_ADDR 2897
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0403_FIXPT 0xF60E76EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0403_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-166824209)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0403_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0403_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0404_ADDR 2898
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0404_FIXPT 0x99DBC9F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0404_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1713649167)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0404_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0404_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0405_ADDR 2899
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0405_FIXPT 0x440B571D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0405_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1141593885)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0405_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0405_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0406_ADDR 2900
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0406_FIXPT 0x7C115511
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0406_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2081510673)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0406_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0406_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0407_ADDR 2901
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0407_FIXPT 0xBE21C819
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0407_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1105082343)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0407_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0407_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0408_ADDR 2902
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0408_FIXPT 0xF5F3FECB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0408_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-168558901)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0408_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0408_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0409_ADDR 2903
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0409_FIXPT 0xFBDA74F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0409_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-69569293)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0409_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0409_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0410_ADDR 2904
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0410_FIXPT 0xDD051FFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0410_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-586866689)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0410_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0410_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0411_ADDR 2905
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0411_FIXPT 0x8FFA9B0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0411_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1879401713)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0411_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0411_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0412_ADDR 2906
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0412_FIXPT 0xD1196D07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0412_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-786862841)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0412_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0412_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0413_ADDR 2907
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0413_FIXPT 0x60E285EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0413_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1625458158)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0413_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0413_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0414_ADDR 2908
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0414_FIXPT 0x7D03A215
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0414_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2097390101)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0414_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0414_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0415_ADDR 2909
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0415_FIXPT 0x56157606
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0415_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1444247046)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0415_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0415_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0416_ADDR 2910
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0416_FIXPT 0x09123013
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0416_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(152186899)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0416_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0416_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0417_ADDR 2911
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0417_FIXPT 0xC2FAA4D6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0417_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1023761194)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0417_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0417_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0418_ADDR 2912
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0418_FIXPT 0xF8DFD5F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0418_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-119548431)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0418_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0418_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0419_ADDR 2913
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0419_FIXPT 0x6E02B007
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0419_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1845669895)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0419_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0419_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0420_ADDR 2914
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0420_FIXPT 0xF3F9F00B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0420_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-201723893)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0420_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0420_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0421_ADDR 2915
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0421_FIXPT 0x3A174E0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0421_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(974605834)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0421_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0421_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0422_ADDR 2916
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0422_FIXPT 0x72EC85F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0422_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1928103409)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0422_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0422_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0423_ADDR 2917
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0423_FIXPT 0x7C029B0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0423_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2080545551)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0423_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0423_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0424_ADDR 2918
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0424_FIXPT 0xD6126EFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0424_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-703435011)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0424_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0424_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0425_ADDR 2919
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0425_FIXPT 0x9805C508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0425_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1744452344)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0425_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0425_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0426_ADDR 2920
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0426_FIXPT 0x95FF86E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0426_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1778415897)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0426_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0426_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0427_ADDR 2921
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0427_FIXPT 0x05E870F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0427_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(99119353)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0427_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0427_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0428_ADDR 2922
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0428_FIXPT 0x8C036B08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0428_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1945933048)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0428_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0428_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0429_ADDR 2923
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0429_FIXPT 0xBDFAD507
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0429_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1107634937)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0429_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0429_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0430_ADDR 2924
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0430_FIXPT 0x1D107308
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0430_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(487617288)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0430_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0430_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0431_ADDR 2925
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0431_FIXPT 0x3FF59BF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0431_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1073060853)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0431_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0431_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0432_ADDR 2926
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0432_FIXPT 0x8405B80A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0432_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2079999990)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0432_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0432_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0433_ADDR 2927
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0433_FIXPT 0xBB07DDF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0433_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157112331)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0433_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0433_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0434_ADDR 2928
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0434_FIXPT 0xC8FE7306
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0434_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-922848506)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0434_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0434_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0435_ADDR 2929
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0435_FIXPT 0x4B0006F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0435_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1258292978)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0435_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0435_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0436_ADDR 2930
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0436_FIXPT 0xB1F4A203
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0436_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1309367805)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0436_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0436_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0437_ADDR 2931
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0437_FIXPT 0xCA05C800
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0437_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-905590784)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0437_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0437_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0438_ADDR 2932
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0438_FIXPT 0xE8F67D04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0438_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-386499324)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0438_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0438_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0439_ADDR 2933
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0439_FIXPT 0x8E09DD03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0439_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1911956221)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0439_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0439_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0440_ADDR 2934
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0440_FIXPT 0x84FA39FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0440_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2063975939)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0440_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0440_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0441_ADDR 2935
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0441_FIXPT 0xFA0AC102
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0441_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-99958526)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0441_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0441_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0442_ADDR 2936
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0442_FIXPT 0x6CF939F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0442_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1828272629)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0442_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0442_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0443_ADDR 2937
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0443_FIXPT 0x42032705
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0443_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1107502853)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0443_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0443_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0444_ADDR 2938
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0444_FIXPT 0xFCFF57FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0444_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-50374660)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0444_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0444_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0445_ADDR 2939
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0445_FIXPT 0xAC01E20B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0445_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1409162741)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0445_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0445_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0446_ADDR 2940
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0446_FIXPT 0xC5FD5CF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0446_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-973251338)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0446_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0446_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0447_ADDR 2941
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0447_FIXPT 0x27F67A03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0447_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(670464515)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0447_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0447_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0448_ADDR 2942
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0448_FIXPT 0xBD02FDFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0448_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1123877379)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0448_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0448_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0449_ADDR 2943
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0449_FIXPT 0xF8FECF06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0449_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-117518586)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0449_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0449_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0450_ADDR 2944
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0450_FIXPT 0x230A23FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0450_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(587867131)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0450_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0450_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0451_ADDR 2945
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0451_FIXPT 0xAEF60BF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0451_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1359606791)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0451_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0451_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0452_ADDR 2946
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0452_FIXPT 0x8A078503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0452_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1979218685)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0452_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0452_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0453_ADDR 2947
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0453_FIXPT 0xF200F905
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0453_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-234817275)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0453_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0453_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0454_ADDR 2948
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0454_FIXPT 0xB208C107
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0454_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1308049145)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0454_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0454_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0455_ADDR 2949
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0455_FIXPT 0x10F4F3EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0455_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(284488687)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0455_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0455_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0456_ADDR 2950
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0456_FIXPT 0x79F67F03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0456_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2046197507)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0456_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0456_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0457_ADDR 2951
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0457_FIXPT 0x11FA7FFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0457_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(301629436)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0457_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0457_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0458_ADDR 2952
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0458_FIXPT 0xD904A90C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0458_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-654006004)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0458_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0458_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0459_ADDR 2953
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0459_FIXPT 0xE20EAFF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0459_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-502353928)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0459_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0459_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0460_ADDR 2954
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0460_FIXPT 0xC6F53900
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0460_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-957007616)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0460_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0460_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0461_ADDR 2955
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0461_FIXPT 0xB60BD6FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0461_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1240738050)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0461_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0461_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0462_ADDR 2956
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0462_FIXPT 0x8D01CE05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0462_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1929261563)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0462_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0462_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0463_ADDR 2957
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0463_FIXPT 0x530C6302
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0463_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1393320706)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0463_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0463_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0464_ADDR 2958
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0464_FIXPT 0x86EA11EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0464_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2031480341)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0464_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0464_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0465_ADDR 2959
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0465_FIXPT 0xF6F81B00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0465_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-151512320)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0465_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0465_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0466_ADDR 2960
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0466_FIXPT 0x61F23601
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0466_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1643263489)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0466_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0466_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0467_ADDR 2961
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0467_FIXPT 0xFD0FAD1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0467_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-49304291)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0467_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0467_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0468_ADDR 2962
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0468_FIXPT 0x4A0954F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0468_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1242125555)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0468_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0468_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0469_ADDR 2963
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0469_FIXPT 0xEFF92E0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0469_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-268882422)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0469_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0469_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0470_ADDR 2964
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0470_FIXPT 0x6A0328F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0470_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1778591986)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0470_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0470_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0471_ADDR 2965
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0471_FIXPT 0xE9FFAC09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0471_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-369120247)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0471_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0471_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0472_ADDR 2966
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0472_FIXPT 0xDB13C8F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0472_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-619460365)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0472_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0472_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0473_ADDR 2967
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0473_FIXPT 0xC1E103ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0473_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1042218003)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0473_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0473_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0474_ADDR 2968
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0474_FIXPT 0x9AFDE6F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0474_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1694636300)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0474_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0474_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0475_ADDR 2969
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0475_FIXPT 0x02FB4712
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0475_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(50022162)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0475_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0475_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0476_ADDR 2970
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0476_FIXPT 0x67240823
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0476_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1730414627)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0476_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0476_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0477_ADDR 2971
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0477_FIXPT 0x30FA5CF2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0477_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(821714162)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0477_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0477_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0478_ADDR 2972
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0478_FIXPT 0x42FF6903
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0478_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1124034819)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0478_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0478_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0479_ADDR 2973
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0479_FIXPT 0xC4EBCEF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0479_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-991179023)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0479_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0479_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0480_ADDR 2974
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0480_FIXPT 0x43062619
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0480_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1124476441)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0480_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0480_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0481_ADDR 2975
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0481_FIXPT 0x80067BDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0481_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2147058722)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0481_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0481_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0482_ADDR 2976
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0482_FIXPT 0x20E056F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0482_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(551573240)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0482_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0482_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0483_ADDR 2977
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0483_FIXPT 0x9E0149F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0483_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1644082699)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0483_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0483_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0484_ADDR 2978
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0484_FIXPT 0x3E0ECE27
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0484_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1041157671)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0484_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0484_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0485_ADDR 2979
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0485_FIXPT 0xC9346A0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0485_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-919311857)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0485_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0485_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0486_ADDR 2980
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0486_FIXPT 0xDEEB6CED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0486_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-554996499)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0486_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0486_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0487_ADDR 2981
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0487_FIXPT 0x24FC3EEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0487_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(620510955)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0487_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0487_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0488_ADDR 2982
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0488_FIXPT 0x9CE41701
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0488_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1662773503)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0488_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0488_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0489_ADDR 2983
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0489_FIXPT 0x051CFE15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0489_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(85786133)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0489_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0489_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0490_ADDR 2984
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0490_FIXPT 0x16E4C1D7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0490_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(384090583)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0490_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0490_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0491_ADDR 2985
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0491_FIXPT 0x9FF59909
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0491_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1611294455)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0491_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0491_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0492_ADDR 2986
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0492_FIXPT 0x29F94C09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0492_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(704203785)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0492_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0492_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0493_ADDR 2987
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0493_FIXPT 0x0A28A73F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0493_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(170436415)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0493_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0493_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0494_ADDR 2988
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0494_FIXPT 0x651BF6E4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0494_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1696331492)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0494_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0494_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0495_ADDR 2989
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0495_FIXPT 0xFEDC06F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0495_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-19134734)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0495_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0495_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0496_ADDR 2990
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0496_FIXPT 0x35E971DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0496_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(904491485)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0496_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0496_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0497_ADDR 2991
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0497_FIXPT 0x84F99E1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0497_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2064015845)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0497_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0497_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0498_ADDR 2992
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0498_FIXPT 0xDB2162F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0498_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-618568973)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0498_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0498_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0499_ADDR 2993
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0499_FIXPT 0xC5DC8DF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0499_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-975401487)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0499_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0499_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0500_ADDR 2994
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0500_FIXPT 0x3D0C2000
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0500_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1024204800)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0500_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0500_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0501_ADDR 2995
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0501_FIXPT 0x96080928
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0501_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1777858264)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0501_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0501_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0502_ADDR 2996
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0502_FIXPT 0x7B40E11D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0502_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2067849501)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0502_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0502_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0503_ADDR 2997
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0503_FIXPT 0xB1E151CE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0503_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1310633522)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0503_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0503_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0504_ADDR 2998
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0504_FIXPT 0x02E5EEE7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0504_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(48623335)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0504_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0504_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0505_ADDR 2999
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0505_FIXPT 0x6EDDB0F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0505_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1860022514)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0505_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0505_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0506_ADDR 3000
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0506_FIXPT 0xCC190B2E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0506_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-870773970)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0506_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0506_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0507_ADDR 3001
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0507_FIXPT 0x5304BEE3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0507_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1392819939)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0507_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0507_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0508_ADDR 3002
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0508_FIXPT 0xB1EFF80E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0508_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1309673458)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0508_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0508_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0509_ADDR 3003
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0509_FIXPT 0x3506A007
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0509_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(889626631)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0509_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0509_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0510_ADDR 3004
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0510_FIXPT 0x7A1E813E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0510_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2048819518)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0510_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0510_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0511_ADDR 3005
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0511_FIXPT 0xE81EA7DF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0511_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-400644129)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0511_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0511_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0512_ADDR 3006
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0512_FIXPT 0x18C2C5D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0512_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(415417816)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0512_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0512_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0513_ADDR 3007
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0513_FIXPT 0xE5E705DF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0513_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-437844513)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0513_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0513_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0514_ADDR 3008
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0514_FIXPT 0x14F28426
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0514_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(351437862)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0514_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0514_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0515_ADDR 3009
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0515_FIXPT 0x593CD40E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0515_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1497158670)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0515_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0515_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0516_ADDR 3010
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0516_FIXPT 0x22E734EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0516_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(585577710)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0516_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0516_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0517_ADDR 3011
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0517_FIXPT 0x3C116A05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0517_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1007774213)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0517_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0517_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0518_ADDR 3012
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0518_FIXPT 0x1E000317
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0518_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(503317271)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0518_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0518_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0519_ADDR 3013
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0519_FIXPT 0x193B0C17
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0519_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(423300119)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0519_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0519_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0520_ADDR 3014
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0520_FIXPT 0xE3D5EDB6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0520_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-472519242)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0520_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0520_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0521_ADDR 3015
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0521_FIXPT 0x98D77AE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0521_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1730708762)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0521_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0521_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0522_ADDR 3016
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0522_FIXPT 0x1AE64C00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0522_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(451300352)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0522_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0522_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0523_ADDR 3017
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0523_FIXPT 0xEE38AC47
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0523_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-298275769)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0523_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0523_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0524_ADDR 3018
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0524_FIXPT 0x761403E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0524_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1981023208)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0524_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0524_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0525_ADDR 3019
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0525_FIXPT 0xC4ED9409
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0525_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-991063031)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0525_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0525_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0526_ADDR 3020
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0526_FIXPT 0x45FFA7FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0526_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1174382586)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0526_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0526_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0527_ADDR 3021
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0527_FIXPT 0xBD160B36
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0527_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1122628810)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0527_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0527_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0528_ADDR 3022
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0528_FIXPT 0x4C04B5C5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0528_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1275377093)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0528_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0528_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0529_ADDR 3023
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0529_FIXPT 0x04B320DB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0529_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(78848219)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0529_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0529_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0530_ADDR 3024
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0530_FIXPT 0xE6EF36F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0530_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-420530442)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0530_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0530_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0531_ADDR 3025
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0531_FIXPT 0x4C104E4C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0531_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1276137036)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0531_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0531_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0532_ADDR 3026
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0532_FIXPT 0xD64A740F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0532_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-699763697)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0532_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0532_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0533_ADDR 3027
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0533_FIXPT 0x4EDE98E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0533_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1323210984)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0533_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0533_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0534_ADDR 3028
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0534_FIXPT 0xAB0241F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0534_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1425915400)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0534_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0534_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0535_ADDR 3029
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0535_FIXPT 0x3EF6E71B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0535_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1056368411)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0535_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0535_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0536_ADDR 3030
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0536_FIXPT 0xFD2956EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0536_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-47622417)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0536_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0536_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0537_ADDR 3031
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0537_FIXPT 0x8CBBA1B9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0537_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1933860423)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0537_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0537_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0538_ADDR 3032
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0538_FIXPT 0x46EC6BFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0538_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1189899263)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0538_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0538_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0539_ADDR 3033
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0539_FIXPT 0xB306B22A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0539_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1291406806)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0539_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0539_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0540_ADDR 3034
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0540_FIXPT 0x675C4539
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0540_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1734100281)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0540_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0540_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0541_ADDR 3035
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0541_FIXPT 0xAFF528CF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0541_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1342887729)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0541_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0541_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0542_ADDR 3036
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0542_FIXPT 0x1AEA81FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0542_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(451576316)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0542_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0542_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0543_ADDR 3037
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0543_FIXPT 0x95F0C0F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0543_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1779384076)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0543_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0543_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0544_ADDR 3038
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0544_FIXPT 0x431F1F18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0544_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1126113048)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0544_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0544_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0545_ADDR 3039
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0545_FIXPT 0x7BE19ABB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0545_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2078382779)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0545_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0545_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0546_ADDR 3040
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0546_FIXPT 0xF8D0A304
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0546_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-120544508)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0546_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0546_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0547_ADDR 3041
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0547_FIXPT 0x910FA71A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0547_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1861245158)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0547_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0547_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0548_ADDR 3042
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0548_FIXPT 0xCE45F951
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0548_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-834274991)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0548_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0548_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0549_ADDR 3043
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0549_FIXPT 0x5C16E7D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0549_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1545005016)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0549_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0549_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0550_ADDR 3044
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0550_FIXPT 0xDFC8A9ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0550_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-540497427)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0550_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0550_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0551_ADDR 3045
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0551_FIXPT 0x3DF4ECE8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0551_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1039461608)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0551_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0551_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0552_ADDR 3046
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0552_FIXPT 0x2AFC9721
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0552_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(721196833)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0552_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0552_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0553_ADDR 3047
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0553_FIXPT 0xD50B0DD9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0553_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-720695847)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0553_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0553_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0554_ADDR 3048
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0554_FIXPT 0x32C501F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0554_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(851771894)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0554_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0554_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0555_ADDR 3049
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0555_FIXPT 0x871CC81C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0555_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2028156900)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0555_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0555_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0556_ADDR 3050
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0556_FIXPT 0xB024CA49
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0556_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1339766199)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0556_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0556_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0557_ADDR 3051
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0557_FIXPT 0x3E36A4F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0557_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1043768562)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0557_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0557_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0558_ADDR 3052
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0558_FIXPT 0x19BF7DCD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0558_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(431979981)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0558_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0558_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0559_ADDR 3053
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0559_FIXPT 0x53F222E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0559_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1408377576)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0559_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0559_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0560_ADDR 3054
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0560_FIXPT 0x5FE7CA18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0560_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1609026072)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0560_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0560_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0561_ADDR 3055
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0561_FIXPT 0x872A9DF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0561_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2027250183)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0561_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0561_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0562_ADDR 3056
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0562_FIXPT 0xD7D010E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0562_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-674230045)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0562_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0562_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0563_ADDR 3057
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0563_FIXPT 0x8F1D5A1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0563_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1893901794)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0563_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0563_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0564_ADDR 3058
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0564_FIXPT 0xD0159C2F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0564_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-803890129)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0564_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0564_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0565_ADDR 3059
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0565_FIXPT 0xAE401D0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0565_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1371529974)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0565_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0565_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0566_ADDR 3060
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0566_FIXPT 0x3CC99FB5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0566_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1019846581)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0566_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0566_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0567_ADDR 3061
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0567_FIXPT 0x0AE285EA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0567_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(182617578)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0567_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0567_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0568_ADDR 3062
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0568_FIXPT 0x47E9380D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0568_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1206466573)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0568_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0568_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0569_ADDR 3063
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0569_FIXPT 0x9036261B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0569_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1875499493)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0569_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0569_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0570_ADDR 3064
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0570_FIXPT 0x5AEA79DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0570_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1525316058)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0570_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0570_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0571_ADDR 3065
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0571_FIXPT 0x320A1E1F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0571_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(839523871)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0571_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0571_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0572_ADDR 3066
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0572_FIXPT 0x9811D318
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0572_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1743662312)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0572_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0572_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0573_ADDR 3067
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0573_FIXPT 0xA0362219
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0573_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1607065063)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0573_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0573_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0574_ADDR 3068
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0574_FIXPT 0x5CD37EAA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0574_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1557364394)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0574_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0574_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0575_ADDR 3069
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0575_FIXPT 0x6FCEE2F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0575_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1875829489)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0575_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0575_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0576_ADDR 3070
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0576_FIXPT 0x30F37706
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0576_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(821262086)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0576_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0576_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0577_ADDR 3071
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0577_FIXPT 0x2C35B036
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0577_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(741716022)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0577_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0577_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0578_ADDR 3072
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0578_FIXPT 0x2D0369DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0578_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(755198426)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0578_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0578_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0579_ADDR 3073
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0579_FIXPT 0xC6F54C1A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0579_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-957002726)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0579_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0579_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0580_ADDR 3074
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0580_FIXPT 0x0D0F380B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0580_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(219101195)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0580_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0580_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0581_ADDR 3075
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0581_FIXPT 0x5C26161E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0581_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1545999902)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0581_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0581_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0582_ADDR 3076
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0582_FIXPT 0x32DB72A8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0582_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(853242536)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0582_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0582_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0583_ADDR 3077
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0583_FIXPT 0xDBC33DF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0583_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-607961610)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0583_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0583_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0584_ADDR 3078
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0584_FIXPT 0x5F00470A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0584_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1593853706)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0584_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0584_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0585_ADDR 3079
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0585_FIXPT 0x88315F45
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0585_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2010030267)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0585_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0585_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0586_ADDR 3080
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0586_FIXPT 0x0B0FCFDC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0586_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(185585628)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0586_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0586_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0587_ADDR 3081
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0587_FIXPT 0x6AE7DB11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0587_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1793579793)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0587_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0587_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0588_ADDR 3082
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0588_FIXPT 0x2E0C2402
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0588_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(772547586)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0588_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0588_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0589_ADDR 3083
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0589_FIXPT 0x5915CC1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0589_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1494600731)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0589_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0589_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0590_ADDR 3084
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0590_FIXPT 0xB6E31AB3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0590_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1226630477)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0590_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0590_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0591_ADDR 3085
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0591_FIXPT 0xBAC060FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0591_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1161797380)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0591_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0591_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0592_ADDR 3086
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0592_FIXPT 0xFE0D3513
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0592_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-32688877)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0592_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0592_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0593_ADDR 3087
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0593_FIXPT 0x3630D843
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0593_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(909170755)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0593_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0593_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0594_ADDR 3088
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0594_FIXPT 0x5813B1D9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0594_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1477685721)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0594_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0594_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0595_ADDR 3089
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0595_FIXPT 0x0BDF7508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0595_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(199193864)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0595_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0595_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0596_ADDR 3090
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0596_FIXPT 0x7C0842FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0596_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2080916218)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0596_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0596_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0597_ADDR 3091
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0597_FIXPT 0x2A06CE18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0597_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(705089048)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0597_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0597_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0598_ADDR 3092
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0598_FIXPT 0xE6EE28BB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0598_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-420599621)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0598_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0598_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0599_ADDR 3093
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0599_FIXPT 0xD1CAFD06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0599_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-775226106)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0599_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0599_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0600_ADDR 3094
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0600_FIXPT 0x6D1B7617
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0600_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1830516247)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0600_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0600_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0601_ADDR 3095
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0601_FIXPT 0xEF2AFA3F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0601_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-282396097)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0601_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0601_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0602_ADDR 3096
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0602_FIXPT 0x420F23D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0602_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1108288468)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0602_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0602_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0603_ADDR 3097
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0603_FIXPT 0x00DA85FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0603_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(14321151)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0603_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0603_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0604_ADDR 3098
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0604_FIXPT 0x4F0313F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0604_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1325601778)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0604_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0604_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0605_ADDR 3099
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0605_FIXPT 0x6402BB19
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0605_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1677900569)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0605_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0605_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0606_ADDR 3100
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0606_FIXPT 0x6FF150C4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0606_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1878085828)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0606_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0606_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0607_ADDR 3101
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0607_FIXPT 0x43DFEC12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0607_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1138748434)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0607_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0607_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0608_ADDR 3102
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0608_FIXPT 0x991FFF13
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0608_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1725956333)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0608_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0608_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0609_ADDR 3103
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0609_FIXPT 0x2C29B136
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0609_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(740929846)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0609_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0609_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0610_ADDR 3104
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0610_FIXPT 0x0B05F3CD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0610_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(184939469)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0610_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0610_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0611_ADDR 3105
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0611_FIXPT 0x0ED905F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0611_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(249103864)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0611_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0611_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0612_ADDR 3106
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0612_FIXPT 0xD3FE42F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0612_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-738311438)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0612_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0612_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0613_ADDR 3107
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0613_FIXPT 0x9908A617
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0613_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1727486441)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0613_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0613_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0614_ADDR 3108
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0614_FIXPT 0xD1F105D3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0614_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-772733485)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0614_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0614_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0615_ADDR 3109
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0615_FIXPT 0x14F32E15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0615_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(351481365)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0615_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0615_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0616_ADDR 3110
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0616_FIXPT 0x421F8E11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0616_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1109364241)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0616_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0616_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0617_ADDR 3111
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0617_FIXPT 0x51262C27
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0617_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1361456167)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0617_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0617_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0618_ADDR 3112
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0618_FIXPT 0xCBF579C8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0618_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-873104952)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0618_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0618_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0619_ADDR 3113
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0619_FIXPT 0x0CDC76F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0619_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(215774969)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0619_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0619_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0620_ADDR 3114
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0620_FIXPT 0x1B0241F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0620_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(453132789)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0620_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0620_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0621_ADDR 3115
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0621_FIXPT 0x69111317
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0621_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1762726679)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0621_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0621_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0622_ADDR 3116
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0622_FIXPT 0xD0F4D2DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0622_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-789261603)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0622_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0622_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0623_ADDR 3117
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0623_FIXPT 0x93FDF517
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0623_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1812073193)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0623_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0623_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0624_ADDR 3118
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0624_FIXPT 0x781BA10D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0624_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2015076621)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0624_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0624_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0625_ADDR 3119
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0625_FIXPT 0x681F1914
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0625_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1746868500)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0625_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0625_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0626_ADDR 3120
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0626_FIXPT 0x65DFD0CA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0626_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1709166794)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0626_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0626_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0627_ADDR 3121
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0627_FIXPT 0x98EBFE02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0627_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1729364478)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0627_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0627_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0628_ADDR 3122
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0628_FIXPT 0xF7FE28FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0628_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-134338307)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0628_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0628_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0629_ADDR 3123
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0629_FIXPT 0x4E1B5416
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0629_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1310413846)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0629_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0629_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0630_ADDR 3124
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0630_FIXPT 0xCCEA3CEA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0630_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-857064214)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0630_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0630_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0631_ADDR 3125
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0631_FIXPT 0xE5065A1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0631_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-452568549)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0631_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0631_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0632_ADDR 3126
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0632_FIXPT 0xE60DEE07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0632_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-435294713)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0632_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0632_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0633_ADDR 3127
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0633_FIXPT 0xE21453FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0633_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-501984260)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0633_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0633_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0634_ADDR 3128
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0634_FIXPT 0x77D3A4E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0634_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2010359008)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0634_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0634_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0635_ADDR 3129
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0635_FIXPT 0x8EF99D09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0635_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1896243959)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0635_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0635_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0636_ADDR 3130
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0636_FIXPT 0x59FB2F0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0636_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1509633804)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0636_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0636_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0637_ADDR 3131
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0637_FIXPT 0xF31BC907
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0637_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-216282873)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0637_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0637_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0638_ADDR 3132
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0638_FIXPT 0xA7E7A0FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0638_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1477992198)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0638_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0638_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0639_ADDR 3133
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0639_FIXPT 0xB10E2B14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0639_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1324471532)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0639_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0639_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0640_ADDR 3134
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0640_FIXPT 0xC5FBB605
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0640_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-973359611)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0640_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0640_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0641_ADDR 3135
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0641_FIXPT 0x7807E7EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0641_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2013784046)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0641_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0641_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0642_ADDR 3136
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0642_FIXPT 0x01DE90F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0642_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(31363316)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0642_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0642_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0643_ADDR 3137
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0643_FIXPT 0x4C049107
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0643_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1275367687)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0643_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0643_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0644_ADDR 3138
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0644_FIXPT 0x15FFB912
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0644_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(369080594)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0644_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0644_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0645_ADDR 3139
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0645_FIXPT 0xEF1119F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0645_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-284091912)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0645_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0645_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0646_ADDR 3140
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0646_FIXPT 0xCDF3A107
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0646_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-839671545)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0646_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0646_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0647_ADDR 3141
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0647_FIXPT 0x160BF8FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0647_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(369883387)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0647_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0647_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0648_ADDR 3142
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0648_FIXPT 0xC5F89408
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0648_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-973564920)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0648_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0648_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0649_ADDR 3143
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0649_FIXPT 0x8F007FE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0649_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1895792663)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0649_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0649_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0650_ADDR 3144
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0650_FIXPT 0xD7F34902
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0650_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-671921918)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0650_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0650_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0651_ADDR 3145
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0651_FIXPT 0xCD06A9FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0651_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-855201284)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0651_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0651_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0652_ADDR 3146
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0652_FIXPT 0xD5074810
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0652_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-720943088)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0652_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0652_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0653_ADDR 3147
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0653_FIXPT 0x470461F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0653_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1191469557)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0653_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0653_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0654_ADDR 3148
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0654_FIXPT 0xF103F001
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0654_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-251400191)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0654_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0654_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0655_ADDR 3149
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0655_FIXPT 0xEAFB7BF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0655_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-352617483)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0655_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0655_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0656_ADDR 3150
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0656_FIXPT 0x4906D705
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0656_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1225185029)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0656_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0656_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0657_ADDR 3151
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0657_FIXPT 0xC3F96CF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0657_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1007063818)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0657_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0657_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0658_ADDR 3152
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0658_FIXPT 0xAF0379FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0658_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1358726657)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0658_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0658_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0659_ADDR 3153
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0659_FIXPT 0xCBFD15FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0659_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-872606209)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0659_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0659_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0660_ADDR 3154
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0660_FIXPT 0x400CB505
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0660_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1074574597)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0660_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0660_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0661_ADDR 3155
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0661_FIXPT 0x69FC97FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0661_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1778161663)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0661_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0661_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0662_ADDR 3156
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0662_FIXPT 0x46FF65FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0662_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1191142907)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0662_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0662_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0663_ADDR 3157
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0663_FIXPT 0x46F84003
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0663_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1190674435)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0663_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0663_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0664_ADDR 3158
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0664_FIXPT 0x80074C01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0664_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2147005439)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0664_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0664_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0665_ADDR 3159
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0665_FIXPT 0x2FFC9D01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0665_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(805084417)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0665_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0665_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0666_ADDR 3160
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0666_FIXPT 0x48FF4BF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0666_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1224690681)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0666_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0666_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0667_ADDR 3161
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0667_FIXPT 0x1EFACE08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0667_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(519753224)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0667_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0667_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0668_ADDR 3162
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0668_FIXPT 0xC002D5FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0668_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1073555969)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0668_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0668_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0669_ADDR 3163
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0669_FIXPT 0xC2FC3807
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0669_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1023657977)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0669_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0669_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0670_ADDR 3164
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0670_FIXPT 0x4BFD4DF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0670_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1274891769)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0670_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0670_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0671_ADDR 3165
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0671_FIXPT 0xC801570A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0671_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-939436278)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0671_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0671_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0672_ADDR 3166
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0672_FIXPT 0xAE0029FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0672_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1375720964)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0672_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0672_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0673_ADDR 3167
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0673_FIXPT 0xBF011003
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0673_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1090449405)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0673_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0673_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0674_ADDR 3168
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0674_FIXPT 0x08F4B6F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0674_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(150255350)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0674_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0674_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0675_ADDR 3169
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0675_FIXPT 0xC30472FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0675_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1023118593)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0675_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0675_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0676_ADDR 3170
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0676_FIXPT 0x89FBD002
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0676_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1979985918)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0676_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0676_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0677_ADDR 3171
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0677_FIXPT 0x4D116F02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0677_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1292988162)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0677_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0677_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0678_ADDR 3172
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0678_FIXPT 0x57F86D02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0678_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1475898626)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0678_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0678_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0679_ADDR 3173
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0679_FIXPT 0xA90A69F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0679_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1458935306)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0679_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0679_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0680_ADDR 3174
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0680_FIXPT 0x18FAD505
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0680_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(419091717)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0680_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0680_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0681_ADDR 3175
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0681_FIXPT 0x9008A7EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0681_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1878480913)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0681_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0681_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0682_ADDR 3176
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0682_FIXPT 0x17F2F000
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0682_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(401797120)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0682_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0682_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0683_ADDR 3177
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0683_FIXPT 0x90FC0AFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0683_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1862530310)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0683_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0683_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0684_ADDR 3178
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0684_FIXPT 0xF50B541A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0684_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-183806950)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0684_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0684_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0685_ADDR 3179
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0685_FIXPT 0x060AADF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0685_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(101363190)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0685_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0685_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0686_ADDR 3180
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0686_FIXPT 0x7800A602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0686_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2013308418)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0686_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0686_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0687_ADDR 3181
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0687_FIXPT 0x58ECCEF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0687_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1491914488)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0687_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0687_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0688_ADDR 3182
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0688_FIXPT 0x110BB60E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0688_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(285980174)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0688_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0688_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0689_ADDR 3183
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0689_FIXPT 0xAFEC14EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0689_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1343482644)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0689_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0689_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0690_ADDR 3184
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0690_FIXPT 0xEEFEC7FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0690_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-285292546)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0690_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0690_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0691_ADDR 3185
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0691_FIXPT 0x33FBB913
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0691_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(872134931)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0691_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0691_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0692_ADDR 3186
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0692_FIXPT 0xB3244F10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0692_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1289466096)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0692_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0692_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0693_ADDR 3187
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0693_FIXPT 0x36F123F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0693_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(921773046)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0693_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0693_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0694_ADDR 3188
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0694_FIXPT 0x89FAA4E4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0694_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1980062492)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0694_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0694_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0695_ADDR 3189
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0695_FIXPT 0x92F92410
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0695_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1829166064)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0695_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0695_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0696_ADDR 3190
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0696_FIXPT 0xF61310EA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0696_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-166522646)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0696_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0696_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0697_ADDR 3191
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0697_FIXPT 0xB6E7A403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0697_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1226333181)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0697_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0697_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0698_ADDR 3192
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0698_FIXPT 0xF8004EFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0698_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-134197506)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0698_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0698_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0699_ADDR 3193
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0699_FIXPT 0x551C4B2F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0699_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1427917615)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0699_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0699_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0700_ADDR 3194
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0700_FIXPT 0xA00CABE3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0700_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1609782301)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0700_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0700_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0701_ADDR 3195
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0701_FIXPT 0xF9ECC9F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0701_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-101922318)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0701_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0701_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0702_ADDR 3196
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0702_FIXPT 0x50E297FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0702_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1357027322)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0702_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0702_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0703_ADDR 3197
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0703_FIXPT 0x65165D16
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0703_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1695964438)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0703_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0703_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0704_ADDR 3198
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0704_FIXPT 0x42E986ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0704_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1122600685)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0704_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0704_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0705_ADDR 3199
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0705_FIXPT 0x5E07C201
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0705_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1577566721)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0705_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0705_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0706_ADDR 3200
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0706_FIXPT 0x28044026
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0706_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(671367206)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0706_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0706_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0707_ADDR 3201
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0707_FIXPT 0x443016FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0707_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1144002302)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0707_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0707_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0708_ADDR 3202
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0708_FIXPT 0x12D72AE5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0708_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(316091109)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0708_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0708_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0709_ADDR 3203
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0709_FIXPT 0xD7EF43E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0709_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-672185375)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0709_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0709_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0710_ADDR 3204
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0710_FIXPT 0x8BFD671E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0710_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1946327266)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0710_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0710_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0711_ADDR 3205
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0711_FIXPT 0xAD1A33EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0711_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1390791698)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0711_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0711_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0712_ADDR 3206
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0712_FIXPT 0xBFEF6A0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0712_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1074828787)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0712_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0712_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0713_ADDR 3207
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0713_FIXPT 0x1202C20A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0713_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(302170634)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0713_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0713_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0714_ADDR 3208
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0714_FIXPT 0x9226392A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0714_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1842988758)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0714_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0714_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0715_ADDR 3209
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0715_FIXPT 0x48ECE4CA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0715_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1223484618)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0715_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0715_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0716_ADDR 3210
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0716_FIXPT 0xBFE4ADEC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0716_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1075532308)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0716_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0716_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0717_ADDR 3211
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0717_FIXPT 0xB6E26A05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0717_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1226675707)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0717_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0717_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0718_ADDR 3212
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0718_FIXPT 0x7231911D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0718_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1915851037)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0718_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0718_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0719_ADDR 3213
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0719_FIXPT 0xB6EADFF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0719_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1226121226)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0719_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0719_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0720_ADDR 3214
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0720_FIXPT 0x20127AFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0720_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(538082045)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0720_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0720_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0721_ADDR 3215
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0721_FIXPT 0xEE07B528
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0721_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-301484760)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0721_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0721_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0722_ADDR 3216
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0722_FIXPT 0x2B1D72D7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0722_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(723350231)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0722_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0722_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0723_ADDR 3217
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0723_FIXPT 0x2FC656E9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0723_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(801527529)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0723_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0723_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0724_ADDR 3218
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0724_FIXPT 0x70E7E6EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0724_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1894246123)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0724_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0724_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0725_ADDR 3219
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0725_FIXPT 0x661F8D43
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0725_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1713343811)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0725_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0725_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0726_ADDR 3220
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0726_FIXPT 0x781035E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0726_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2014328296)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0726_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0726_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0727_ADDR 3221
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0727_FIXPT 0x5901FE08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0727_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1493302792)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0727_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0727_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0728_ADDR 3222
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0728_FIXPT 0x50F4C008
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0728_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1358217224)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0728_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0728_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0729_ADDR 3223
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0729_FIXPT 0x662A6F05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0729_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1714056965)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0729_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0729_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0730_ADDR 3224
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0730_FIXPT 0x06C889C9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0730_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(113805769)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0730_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0730_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0731_ADDR 3225
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0731_FIXPT 0xA2EDC7EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0731_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1561475092)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0731_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0731_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0732_ADDR 3226
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0732_FIXPT 0x78054A3E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0732_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2013612606)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0732_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0732_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0733_ADDR 3227
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0733_FIXPT 0xD840D5FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0733_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-666839553)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0733_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0733_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0734_ADDR 3228
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0734_FIXPT 0x94E5F000
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0734_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1796870144)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0734_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0734_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0735_ADDR 3229
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0735_FIXPT 0x03F9CAEF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0735_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(66702063)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0735_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0735_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0736_ADDR 3230
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0736_FIXPT 0x8A0ED324
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0736_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1978739932)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0736_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0736_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0737_ADDR 3231
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0737_FIXPT 0x9DEBA6BD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0737_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1645500739)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0737_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0737_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0738_ADDR 3232
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0738_FIXPT 0x5AD811FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0738_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1524109820)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0738_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0738_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0739_ADDR 3233
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0739_FIXPT 0x09FE8822
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0739_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(167675938)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0739_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0739_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0740_ADDR 3234
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0740_FIXPT 0x3F53A52B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0740_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1062446379)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0740_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0740_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0741_ADDR 3235
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0741_FIXPT 0xB6E693E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0741_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1226402848)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0741_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0741_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0742_ADDR 3236
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0742_FIXPT 0x9FFCBEEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0742_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1610826005)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0742_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0742_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0743_ADDR 3237
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0743_FIXPT 0x76EFAE1A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0743_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1995419162)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0743_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0743_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0744_ADDR 3238
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0744_FIXPT 0x221404D3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0744_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(571737299)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0744_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0744_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0745_ADDR 3239
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0745_FIXPT 0x59C543FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0745_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1506100218)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0745_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0745_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0746_ADDR 3240
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0746_FIXPT 0x0809AE11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0746_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(134852113)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0746_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0746_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0747_ADDR 3241
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0747_FIXPT 0xF640DF4C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0747_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-163520692)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0747_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0747_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0748_ADDR 3242
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0748_FIXPT 0x7F019ECF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0748_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2130812623)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0748_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0748_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0749_ADDR 3243
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0749_FIXPT 0x24E6F9F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0749_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(619117040)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0749_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0749_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0750_ADDR 3244
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0750_FIXPT 0xF9E1A7FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0750_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-102651910)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0750_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0750_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0751_ADDR 3245
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0751_FIXPT 0x452706FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0751_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1160185594)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0751_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0751_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0752_ADDR 3246
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0752_FIXPT 0x91CC09E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0752_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1848899099)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0752_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0752_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0753_ADDR 3247
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0753_FIXPT 0xFC13AC12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0753_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-65819630)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0753_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0753_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0754_ADDR 3248
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0754_FIXPT 0x5724354F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0754_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1461990735)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0754_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0754_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0755_ADDR 3249
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0755_FIXPT 0x9A2206D9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0755_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1709046055)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0755_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0755_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0756_ADDR 3250
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0756_FIXPT 0x06C835EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0756_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(113784299)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0756_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0756_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0757_ADDR 3251
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0757_FIXPT 0x65E287E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0757_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1709344739)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0757_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0757_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0758_ADDR 3252
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0758_FIXPT 0x191EE921
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0758_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(421456161)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0758_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0758_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0759_ADDR 3253
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0759_FIXPT 0xA9E757D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0759_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1444456488)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0759_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0759_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0760_ADDR 3254
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0760_FIXPT 0x1E0FC81A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0760_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(504350746)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0760_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0760_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0761_ADDR 3255
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0761_FIXPT 0x0F112E38
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0761_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(252784184)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0761_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0761_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0762_ADDR 3256
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0762_FIXPT 0x5F3BEBEE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0762_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1597762542)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0762_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0762_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0763_ADDR 3257
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0763_FIXPT 0x75BA60D3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0763_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1975148755)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0763_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0763_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0764_ADDR 3258
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0764_FIXPT 0x18E524DE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0764_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(417670366)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0764_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0764_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0765_ADDR 3259
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0765_FIXPT 0xE70D5F3A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0765_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-418554054)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0765_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0765_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0766_ADDR 3260
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0766_FIXPT 0x2F098BDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0766_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(789154782)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0766_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0766_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0767_ADDR 3261
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0767_FIXPT 0xECFD3D1C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0767_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-318948068)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0767_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0767_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0768_ADDR 3262
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0768_FIXPT 0x6F0B581C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0768_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1863014428)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0768_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0768_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0769_ADDR 3263
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0769_FIXPT 0x743E0806
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0769_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1950222342)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0769_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0769_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0770_ADDR 3264
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0770_FIXPT 0x43BEE1B8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0770_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1136583096)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0770_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0770_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0771_ADDR 3265
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0771_FIXPT 0x23E25FE8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0771_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(602038248)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0771_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0771_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0772_ADDR 3266
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0772_FIXPT 0xDC025640
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0772_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-603826624)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0772_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0772_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0773_ADDR 3267
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0773_FIXPT 0x442AD4F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0773_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1143657713)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0773_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0773_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0774_ADDR 3268
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0774_FIXPT 0xD5E9C712
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0774_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-706099438)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0774_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0774_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0775_ADDR 3269
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0775_FIXPT 0x850B4D08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0775_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2062856952)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0775_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0775_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0776_ADDR 3270
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0776_FIXPT 0x3E30ED17
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0776_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1043393815)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0776_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0776_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0777_ADDR 3271
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0777_FIXPT 0x31C91AA7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0777_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(835263143)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0777_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0777_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0778_ADDR 3272
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0778_FIXPT 0xA5DD72F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0778_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1512213769)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0778_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0778_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0779_ADDR 3273
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0779_FIXPT 0x4102213D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0779_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1090658621)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0779_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0779_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0780_ADDR 3274
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0780_FIXPT 0x5245E703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0780_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1380312835)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0780_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0780_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0781_ADDR 3275
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0781_FIXPT 0x97D96501
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0781_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1747360511)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0781_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0781_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0782_ADDR 3276
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0782_FIXPT 0xDC0BBAFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0782_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-603211011)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0782_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0782_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0783_ADDR 3277
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0783_FIXPT 0x641CE31F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0783_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1679614751)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0783_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0783_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0784_ADDR 3278
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0784_FIXPT 0xA3D381A4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0784_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1546419804)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0784_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0784_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0785_ADDR 3279
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0785_FIXPT 0x7ADA2905
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0785_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2061117701)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0785_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0785_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0786_ADDR 3280
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0786_FIXPT 0xAA092339
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0786_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1442241735)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0786_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0786_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0787_ADDR 3281
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0787_FIXPT 0x7553A00C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0787_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1968414732)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0787_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0787_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0788_ADDR 3282
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0788_FIXPT 0x14D239EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0788_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(349321710)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0788_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0788_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0789_ADDR 3283
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0789_FIXPT 0xD9093EF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0789_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-653705480)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0789_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0789_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0790_ADDR 3284
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0790_FIXPT 0xF509D51D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0790_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-183904995)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0790_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0790_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0791_ADDR 3285
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0791_FIXPT 0xE6DF2BB0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0791_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-421581904)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0791_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0791_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0792_ADDR 3286
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0792_FIXPT 0xB2D9B111
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0792_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1294356207)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0792_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0792_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0793_ADDR 3287
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0793_FIXPT 0x56157235
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0793_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1444246069)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0793_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0793_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0794_ADDR 3288
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0794_FIXPT 0xC151A311
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0794_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1051614447)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0794_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0794_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0795_ADDR 3289
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0795_FIXPT 0x33CF96DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0795_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(869242589)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0795_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0795_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0796_ADDR 3290
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0796_FIXPT 0x69040CF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0796_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1761873140)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0796_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0796_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0797_ADDR 3291
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0797_FIXPT 0x70FAE119
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0797_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1895489817)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0797_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0797_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0798_ADDR 3292
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0798_FIXPT 0x42F027BE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0798_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1123035070)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0798_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0798_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0799_ADDR 3293
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0799_FIXPT 0xC5DDFD1C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0799_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-975307492)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0799_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0799_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0800_ADDR 3294
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0800_FIXPT 0xE01E722C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0800_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-534875604)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0800_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0800_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0801_ADDR 3295
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0801_FIXPT 0xDE489E12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0801_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-565666286)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0801_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0801_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0802_ADDR 3296
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0802_FIXPT 0xAACB9DD1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0802_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1429496367)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0802_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0802_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0803_ADDR 3297
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0803_FIXPT 0x03FD9AEF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0803_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(66951919)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0803_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0803_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0804_ADDR 3298
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0804_FIXPT 0x82F30F1C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0804_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2098000100)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0804_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0804_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0805_ADDR 3299
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0805_FIXPT 0x38FFF2CB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0805_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(956297931)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0805_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0805_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0806_ADDR 3300
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0806_FIXPT 0x34E70624
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0806_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(887555620)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0806_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0806_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0807_ADDR 3301
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0807_FIXPT 0x54202523
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0807_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1411392803)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0807_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0807_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0808_ADDR 3302
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0808_FIXPT 0x3E3D6B0E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0808_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1044212494)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0808_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0808_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0809_ADDR 3303
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0809_FIXPT 0x19C64DC9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0809_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(432426441)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0809_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0809_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0810_ADDR 3304
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0810_FIXPT 0xAEF595F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0810_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1359637008)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0810_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0810_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0811_ADDR 3305
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0811_FIXPT 0x27F6DB21
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0811_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(670489377)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0811_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0811_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0812_ADDR 3306
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0812_FIXPT 0xB90B5DD8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0812_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1190437416)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0812_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0812_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0813_ADDR 3307
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0813_FIXPT 0xD8F0B423
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0813_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-655313885)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0813_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0813_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0814_ADDR 3308
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0814_FIXPT 0xF51E1E18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0814_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-182575592)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0814_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0814_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0815_ADDR 3309
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0815_FIXPT 0x7E323405
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0815_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2117219333)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0815_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0815_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0816_ADDR 3310
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0816_FIXPT 0x82BE52C6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0816_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2101456186)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0816_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0816_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0817_ADDR 3311
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0817_FIXPT 0x69F6F1F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0817_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1777791478)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0817_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0817_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0818_ADDR 3312
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0818_FIXPT 0xD8FC112D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0818_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-654569171)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0818_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0818_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0819_ADDR 3313
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0819_FIXPT 0x831383DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0819_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2095873059)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0819_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0819_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0820_ADDR 3314
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0820_FIXPT 0xD9F66D23
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0820_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-638161629)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0820_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0820_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0821_ADDR 3315
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0821_FIXPT 0x7D16330F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0821_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2098606863)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0821_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0821_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0822_ADDR 3316
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0822_FIXPT 0x33273FF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0822_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(858210295)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0822_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0822_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0823_ADDR 3317
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0823_FIXPT 0xF9B525D0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0823_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-105568816)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0823_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0823_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0824_ADDR 3318
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0824_FIXPT 0x02FD5EFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0824_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(50159356)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0824_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0824_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0825_ADDR 3319
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0825_FIXPT 0x460B7636
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0825_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1175156278)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0825_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0825_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0826_ADDR 3320
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0826_FIXPT 0x270FC5DC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0826_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(655345116)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0826_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0826_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0827_ADDR 3321
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0827_FIXPT 0x4200471C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0827_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1107314460)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0827_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0827_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0828_ADDR 3322
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0828_FIXPT 0xC50BDD07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0828_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-989078265)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0828_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0828_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0829_ADDR 3323
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0829_FIXPT 0x3E1A1FE7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0829_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1041899495)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0829_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0829_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0830_ADDR 3324
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0830_FIXPT 0x3BBA40E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0830_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1002062048)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0830_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0830_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0831_ADDR 3325
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0831_FIXPT 0x53046B07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0831_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1392798471)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0831_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0831_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0832_ADDR 3326
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0832_FIXPT 0x961B9433
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0832_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1776577485)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0832_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0832_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0833_ADDR 3327
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0833_FIXPT 0x16038DE0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0833_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(369331680)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0833_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0833_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0834_ADDR 3328
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0834_FIXPT 0xDD030C14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0834_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-587002860)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0834_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0834_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0835_ADDR 3329
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0835_FIXPT 0x65FE2503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0835_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1711154435)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0835_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0835_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0836_ADDR 3330
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0836_FIXPT 0x550F9CDF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0836_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1427086559)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0836_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0836_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0837_ADDR 3331
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0837_FIXPT 0xC4C4B8F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0837_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-993740559)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0837_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0837_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0838_ADDR 3332
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0838_FIXPT 0x8613D00D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0838_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2045521907)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0838_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0838_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0839_ADDR 3333
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0839_FIXPT 0x9821C02A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0839_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1742618582)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0839_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0839_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0840_ADDR 3334
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0840_FIXPT 0x5EF5F0E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0840_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1593176291)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0840_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0840_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0841_ADDR 3335
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0841_FIXPT 0x9A02050A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0841_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1711143670)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0841_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0841_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0842_ADDR 3336
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0842_FIXPT 0x43F1B707
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0842_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1139914503)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0842_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0842_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0843_ADDR 3337
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0843_FIXPT 0x3A0AF6D6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0843_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(973797078)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0843_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0843_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0844_ADDR 3338
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0844_FIXPT 0xC8D73108
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0844_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-925421304)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0844_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0844_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0845_ADDR 3339
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0845_FIXPT 0x0619100B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0845_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(102305803)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0845_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0845_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0846_ADDR 3340
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0846_FIXPT 0xF5270A1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0846_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-181990883)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0846_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0846_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0847_ADDR 3341
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0847_FIXPT 0xFDE4C9E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0847_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-35337752)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0847_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0847_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0848_ADDR 3342
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0848_FIXPT 0x9AFF96FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0848_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1694525700)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0848_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0848_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0849_ADDR 3343
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0849_FIXPT 0xB2F47310
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0849_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1292602608)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0849_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0849_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0850_ADDR 3344
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0850_FIXPT 0xC1FF41D6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0850_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1040236074)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0850_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0850_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0851_ADDR 3345
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0851_FIXPT 0xD3F49712
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0851_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-738945262)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0851_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0851_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0852_ADDR 3346
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0852_FIXPT 0x8A10DC10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0852_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1978606576)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0852_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0852_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0853_ADDR 3347
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0853_FIXPT 0x71279503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0853_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1898419459)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0853_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0853_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0854_ADDR 3348
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0854_FIXPT 0x3ADB80ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0854_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(987463917)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0854_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0854_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0855_ADDR 3349
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0855_FIXPT 0xC1FF32F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0855_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1040239880)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0855_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0855_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0856_ADDR 3350
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0856_FIXPT 0xD4005811
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0856_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-738174959)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0856_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0856_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0857_ADDR 3351
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0857_FIXPT 0x45F31CE7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0857_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1173560551)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0857_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0857_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0858_ADDR 3352
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0858_FIXPT 0x1F047615
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0858_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(520386069)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0858_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0858_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0859_ADDR 3353
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0859_FIXPT 0x84085B19
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0859_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2079827175)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0859_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0859_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0860_ADDR 3354
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0860_FIXPT 0x6815D9E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0860_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1746262502)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0860_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0860_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0861_ADDR 3355
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0861_FIXPT 0x39E0FEF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0861_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(971046648)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0861_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0861_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0862_ADDR 3356
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0862_FIXPT 0xA7039FF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0862_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1492934664)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0862_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0862_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0863_ADDR 3357
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0863_FIXPT 0xE40DD10A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0863_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-468856566)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0863_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0863_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0864_ADDR 3358
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0864_FIXPT 0x5BEB2DF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0864_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1542139384)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0864_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0864_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0865_ADDR 3359
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0865_FIXPT 0x9A0C770E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0865_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1710459122)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0865_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0865_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0866_ADDR 3360
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0866_FIXPT 0x0D0A2313
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0866_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(218768147)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0866_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0866_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0867_ADDR 3361
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0867_FIXPT 0xD7F94CDF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0867_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-671527713)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0867_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0867_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0868_ADDR 3362
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0868_FIXPT 0x72F5E102
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0868_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1928716546)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0868_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0868_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0869_ADDR 3363
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0869_FIXPT 0xC5FE3104
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0869_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-973197052)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0869_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0869_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0870_ADDR 3364
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0870_FIXPT 0xA80D49FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0870_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1475524101)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0870_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0870_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0871_ADDR 3365
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0871_FIXPT 0xC9F1A206
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0871_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-906911226)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0871_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0871_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0872_ADDR 3366
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0872_FIXPT 0x240EFE03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0872_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(604962307)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0872_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0872_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0873_ADDR 3367
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0873_FIXPT 0x3F074400
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0873_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1057440768)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0873_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0873_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0874_ADDR 3368
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0874_FIXPT 0xAAED5CF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0874_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1427284749)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0874_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0874_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0875_ADDR 3369
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0875_FIXPT 0x5702EA04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0875_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1459808772)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0875_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0875_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0876_ADDR 3370
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0876_FIXPT 0xB7FD7D07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0876_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1208124153)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0876_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0876_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0877_ADDR 3371
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0877_FIXPT 0x76032FF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0877_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1979920373)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0877_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0877_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0878_ADDR 3372
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0878_FIXPT 0x0A034B0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0878_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(167987978)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0878_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0878_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0879_ADDR 3373
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0879_FIXPT 0x530355FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0879_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1392727547)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0879_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0879_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0880_ADDR 3374
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0880_FIXPT 0xAD022EFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0880_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1392365830)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0880_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0880_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0881_ADDR 3375
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0881_FIXPT 0xCBF53B06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0881_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-873121018)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0881_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0881_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0882_ADDR 3376
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0882_FIXPT 0x3005DBF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0882_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(805690361)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0882_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0882_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0883_ADDR 3377
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0883_FIXPT 0x7200BD03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0883_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1912651011)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0883_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0883_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0884_ADDR 3378
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0884_FIXPT 0x38FBC200
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0884_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(956023296)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0884_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0884_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0885_ADDR 3379
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0885_FIXPT 0x000BB0FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0885_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(766205)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0885_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0885_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0886_ADDR 3380
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0886_FIXPT 0xBBF58804
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0886_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1141536764)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0886_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0886_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0887_ADDR 3381
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0887_FIXPT 0xCDFECEFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0887_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-838938883)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0887_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0887_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0888_ADDR 3382
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0888_FIXPT 0x1B0BAA05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0888_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(453749253)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0888_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0888_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0889_ADDR 3383
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0889_FIXPT 0xA7F3F3F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0889_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1477184519)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0889_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0889_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0890_ADDR 3384
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0890_FIXPT 0xE8012AFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0890_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-402576644)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0890_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0890_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0891_ADDR 3385
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0891_FIXPT 0xE3018D0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0891_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-486437619)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0891_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0891_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0892_ADDR 3386
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0892_FIXPT 0x56F911F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0892_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1459163638)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0892_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0892_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0893_ADDR 3387
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0893_FIXPT 0xEC04D301
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0893_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-335228159)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0893_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0893_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0894_ADDR 3388
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0894_FIXPT 0xD103640D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0894_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-788306931)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0894_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0894_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0895_ADDR 3389
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0895_FIXPT 0x01061EEE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0895_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(17178350)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0895_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0895_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0896_ADDR 3390
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0896_FIXPT 0xADF43D01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0896_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1376502527)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0896_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0896_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0897_ADDR 3391
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0897_FIXPT 0x23F9C203
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0897_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(603570691)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0897_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0897_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0898_ADDR 3392
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0898_FIXPT 0x900EE8FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0898_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1878071042)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0898_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0898_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0899_ADDR 3393
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0899_FIXPT 0x55F50504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0899_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1442120964)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0899_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0899_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0900_ADDR 3394
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0900_FIXPT 0x9B05B503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0900_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1694124797)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0900_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0900_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0901_ADDR 3395
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0901_FIXPT 0xCE0AFF08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0901_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-838140152)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0901_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0901_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0902_ADDR 3396
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0902_FIXPT 0x29EDE5EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0902_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(703456750)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0902_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0902_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0903_ADDR 3397
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0903_FIXPT 0x2DFF17F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0903_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(771692534)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0903_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0903_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0904_ADDR 3398
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0904_FIXPT 0xD901E611
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0904_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-654186991)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0904_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0904_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0905_ADDR 3399
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0905_FIXPT 0x1B0B7DF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0905_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(453737971)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0905_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0905_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0906_ADDR 3400
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0906_FIXPT 0x0403D00A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0906_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(67358730)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0906_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0906_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0907_ADDR 3401
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0907_FIXPT 0xF8FB6806
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0907_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-117741562)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0907_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0907_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0908_ADDR 3402
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0908_FIXPT 0x0D0C35F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0908_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(218904048)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0908_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0908_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0909_ADDR 3403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0909_FIXPT 0x33E73EFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0909_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(870792956)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0909_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0909_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0910_ADDR 3404
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0910_FIXPT 0xC4F5E2FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0910_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-990518530)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0910_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0910_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0911_ADDR 3405
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0911_FIXPT 0xDF18B317
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0911_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-552029417)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0911_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0911_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0912_ADDR 3406
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0912_FIXPT 0xABF40B01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0912_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1410069759)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0912_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0912_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0913_ADDR 3407
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0913_FIXPT 0x230A43F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0913_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(587875313)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0913_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0913_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0914_ADDR 3408
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0914_FIXPT 0xAD002C10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0914_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1392497648)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0914_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0914_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0915_ADDR 3409
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0915_FIXPT 0xF1F581E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0915_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-235568672)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0915_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0915_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0916_ADDR 3410
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0916_FIXPT 0xA2F843F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0916_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1560787975)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0916_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0916_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0917_ADDR 3411
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0917_FIXPT 0x11FFA11E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0917_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(301965598)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0917_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0917_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0918_ADDR 3412
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0918_FIXPT 0x46240AF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0918_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1176767224)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0918_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0918_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0919_ADDR 3413
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0919_FIXPT 0x51FA5803
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0919_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1375361027)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0919_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0919_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0920_ADDR 3414
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0920_FIXPT 0xADE85EFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0920_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1377280262)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0920_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0920_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0921_ADDR 3415
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0921_FIXPT 0x6215E0FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0921_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1645601019)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0921_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0921_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0922_ADDR 3416
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0922_FIXPT 0x3BDB6EF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0922_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1004236534)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0922_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0922_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0923_ADDR 3417
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0923_FIXPT 0xCB01BCFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0923_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-889078530)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0923_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0923_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0924_ADDR 3418
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0924_FIXPT 0x6E24792E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0924_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1847884078)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0924_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0924_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0925_ADDR 3419
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0925_FIXPT 0x6DF9B3EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0925_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1845081068)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0925_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0925_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0926_ADDR 3420
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0926_FIXPT 0xADFB00E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0926_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1376059167)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0926_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0926_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0927_ADDR 3421
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0927_FIXPT 0x0FF8AF19
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0927_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(267955993)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0927_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0927_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0928_ADDR 3422
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0928_FIXPT 0x6C009ED8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0928_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1811979992)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0928_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0928_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0929_ADDR 3423
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0929_FIXPT 0xEBFB1707
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0929_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-335866105)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0929_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0929_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0930_ADDR 3424
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0930_FIXPT 0xB500A329
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0930_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1258249431)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0930_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0930_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0931_ADDR 3425
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0931_FIXPT 0x6035AAF2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0931_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1614129906)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0931_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0931_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0932_ADDR 3426
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0932_FIXPT 0x34E06CF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0932_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(887123187)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0932_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0932_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0933_ADDR 3427
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0933_FIXPT 0x03DEACF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0933_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(64924919)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0933_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0933_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0934_ADDR 3428
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0934_FIXPT 0x091E1E04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0934_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(152968708)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0934_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0934_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0935_ADDR 3429
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0935_FIXPT 0x99DFB000
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0935_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1713393664)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0935_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0935_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0936_ADDR 3430
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0936_FIXPT 0x3D0A1804
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0936_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1024071684)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0936_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0936_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0937_ADDR 3431
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0937_FIXPT 0x752D9531
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0937_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1965921585)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0937_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0937_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0938_ADDR 3432
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0938_FIXPT 0x6EE983D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0938_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1860797396)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0938_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0938_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0939_ADDR 3433
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0939_FIXPT 0xD5ECACDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0939_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-705909538)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0939_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0939_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0940_ADDR 3434
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0940_FIXPT 0xC4F75424
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0940_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-990424028)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0940_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0940_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0941_ADDR 3435
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0941_FIXPT 0x560E5BE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0941_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1443781606)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0941_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0941_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0942_ADDR 3436
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0942_FIXPT 0x3202170E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0942_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(838997774)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0942_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0942_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0943_ADDR 3437
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0943_FIXPT 0x9B066928
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0943_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1694078680)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0943_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0943_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0944_ADDR 3438
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0944_FIXPT 0x0A2BAEDD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0944_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(170634973)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0944_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0944_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0945_ADDR 3439
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0945_FIXPT 0xD8C9A6EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0945_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-657873173)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0945_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0945_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0946_ADDR 3440
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0946_FIXPT 0x09DFD2FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0946_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(165663483)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0946_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0946_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0947_ADDR 3441
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0947_FIXPT 0x21358316
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0947_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(557155094)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0947_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0947_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0948_ADDR 3442
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0948_FIXPT 0x58E7BE06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0948_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1491582470)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0948_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0948_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0949_ADDR 3443
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0949_FIXPT 0x6D0ECBFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0949_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1829686271)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0949_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0949_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0950_ADDR 3444
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0950_FIXPT 0x68257721
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0950_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1747285793)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0950_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0950_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0951_ADDR 3445
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0951_FIXPT 0x34CFCAC6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0951_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(886033094)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0951_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0951_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0952_ADDR 3446
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0952_FIXPT 0xBBEB2FE2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0952_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1142214686)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0952_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0952_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0953_ADDR 3447
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0953_FIXPT 0x6A0E2746
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0953_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1779312454)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0953_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0953_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0954_ADDR 3448
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0954_FIXPT 0xDC1449E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0954_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-602650136)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0954_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0954_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0955_ADDR 3449
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0955_FIXPT 0xF5091703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0955_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-183953661)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0955_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0955_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0956_ADDR 3450
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0956_FIXPT 0x5FFAC424
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0956_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1610269732)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0956_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0956_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0957_ADDR 3451
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0957_FIXPT 0x8E117EC2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0957_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1911456062)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0957_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0957_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0958_ADDR 3452
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0958_FIXPT 0xF5C9B9EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0958_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-171329042)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0958_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0958_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0959_ADDR 3453
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0959_FIXPT 0x33F24025
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0959_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(871514149)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0959_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0959_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0960_ADDR 3454
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0960_FIXPT 0x884FCB0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0960_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2008036596)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0960_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0960_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0961_ADDR 3455
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0961_FIXPT 0xC1E58703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0961_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1041922301)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0961_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0961_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0962_ADDR 3456
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0962_FIXPT 0xCEF80CF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0962_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-822604553)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0962_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0962_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0963_ADDR 3457
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0963_FIXPT 0xF12359FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0963_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-249341442)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0963_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0963_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0964_ADDR 3458
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0964_FIXPT 0x5ABB5CD4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0964_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1522228436)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0964_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0964_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0965_ADDR 3459
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0965_FIXPT 0x01FDAA03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0965_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(33401347)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0965_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0965_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0966_ADDR 3460
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0966_FIXPT 0x9B3CC14C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0966_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1690517172)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0966_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0966_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0967_ADDR 3461
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0967_FIXPT 0x1BFB06DC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0967_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(469436124)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0967_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0967_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0968_ADDR 3462
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0968_FIXPT 0xFCFD12EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0968_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-50523410)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0968_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0968_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0969_ADDR 3463
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0969_FIXPT 0x2AF67721
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0969_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(720795425)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0969_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0969_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0970_ADDR 3464
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0970_FIXPT 0x50EDFCBB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0970_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1357774011)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0970_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0970_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0971_ADDR 3465
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0971_FIXPT 0x9AED970B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0971_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1695705333)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0971_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0971_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0972_ADDR 3466
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0972_FIXPT 0xD515364E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0972_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-720030130)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0972_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0972_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0973_ADDR 3467
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0973_FIXPT 0xAB3749E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0973_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1422439967)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0973_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0973_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0974_ADDR 3468
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0974_FIXPT 0x20D993F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0974_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(551130102)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0974_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0974_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0975_ADDR 3469
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0975_FIXPT 0xEFE333FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0975_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-270322692)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0975_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0975_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0976_ADDR 3470
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0976_FIXPT 0xF21E50E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0976_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-232894237)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0976_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0976_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0977_ADDR 3471
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0977_FIXPT 0xE4CA3107
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0977_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-456511225)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0977_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0977_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0978_ADDR 3472
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0978_FIXPT 0x8218BA22
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0978_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2112308702)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0978_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0978_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0979_ADDR 3473
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0979_FIXPT 0x874FC115
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0979_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2024816363)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0979_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0979_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0980_ADDR 3474
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0980_FIXPT 0x94CA08DB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0980_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1798698789)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0980_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0980_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0981_ADDR 3475
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0981_FIXPT 0xDDEC85DC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0981_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-571701796)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0981_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0981_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0982_ADDR 3476
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0982_FIXPT 0xB30FBA1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0982_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1290814946)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0982_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0982_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0983_ADDR 3477
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0983_FIXPT 0xE0DEDFE1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0983_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-522264607)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0983_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0983_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0984_ADDR 3478
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0984_FIXPT 0xD11F6C17
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0984_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-786469865)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0984_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0984_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0985_ADDR 3479
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0985_FIXPT 0x4C29E941
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0985_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1277815105)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0985_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0985_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0986_ADDR 3480
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0986_FIXPT 0xB2EFE5BA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0986_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1292900934)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0986_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0986_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0987_ADDR 3481
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0987_FIXPT 0x41E08FE0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0987_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1105235936)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0987_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0987_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0988_ADDR 3482
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0988_FIXPT 0xA3E9D12F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0988_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1544957649)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0988_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0988_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0989_ADDR 3483
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0989_FIXPT 0xEB1592DE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0989_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-350907682)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0989_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0989_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0990_ADDR 3484
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0990_FIXPT 0xE4016820
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0990_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-469669856)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0990_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0990_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0991_ADDR 3485
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0991_FIXPT 0x640C0A33
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0991_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1678510643)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0991_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0991_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0992_ADDR 3486
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0992_FIXPT 0x6E2398C9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0992_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1847826633)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0992_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0992_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0993_ADDR 3487
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0993_FIXPT 0xB3B833E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0993_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1279773725)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0993_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0993_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0994_ADDR 3488
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0994_FIXPT 0xA2E55811
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0994_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1562028015)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0994_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0994_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0995_ADDR 3489
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0995_FIXPT 0x1940E207
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0995_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(423682567)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0995_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0995_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0996_ADDR 3490
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0996_FIXPT 0xE7E60211
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0996_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-404356591)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0996_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0996_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0997_ADDR 3491
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0997_FIXPT 0xFE10E60C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0997_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-32446964)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0997_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0997_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0998_ADDR 3492
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0998_FIXPT 0x553381F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0998_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1429438966)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0998_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0998_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0999_ADDR 3493
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0999_FIXPT 0x21ABF0C7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0999_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(564916423)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0999_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT0999_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01000_ADDR 3494
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01000_FIXPT 0xC8F485FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01000_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-923499012)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01000_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01000_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01001_ADDR 3495
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01001_FIXPT 0xBD3A0C3B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01001_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1120269253)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01001_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01001_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01002_ADDR 3496
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01002_FIXPT 0xD1F3FDE8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01002_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-772538904)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01002_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01002_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01003_ADDR 3497
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01003_FIXPT 0xA514BE00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01003_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1525367296)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01003_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01003_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01004_ADDR 3498
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01004_FIXPT 0xE1166C1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01004_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-518624227)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01004_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01004_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01005_ADDR 3499
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01005_FIXPT 0x78C5BAA9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01005_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2026224297)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01005_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01005_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01006_ADDR 3500
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01006_FIXPT 0x7AF42203
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01006_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2062819843)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01006_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01006_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01007_ADDR 3501
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01007_FIXPT 0xAF205055
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01007_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1356836779)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01007_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01007_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01008_ADDR 3502
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01008_FIXPT 0x2218BCD5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01008_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(572046549)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01008_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01008_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01009_ADDR 3503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01009_FIXPT 0x2AFC8E07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01009_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(721194503)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01009_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01009_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01010_ADDR 3504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01010_FIXPT 0x64FA551D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01010_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1694127389)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01010_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01010_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01011_ADDR 3505
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01011_FIXPT 0xCDEF09AD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01011_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-839972435)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01011_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01011_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01012_ADDR 3506
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01012_FIXPT 0x8DDA7111
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01012_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1915064047)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01012_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01012_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01013_ADDR 3507
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01013_FIXPT 0x66163848
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01013_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1712732232)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01013_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01013_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01014_ADDR 3508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01014_FIXPT 0xC13B3AE3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01014_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1053082909)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01014_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01014_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01015_ADDR 3509
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01015_FIXPT 0xA2D72607
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01015_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1562958329)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01015_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01015_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01016_ADDR 3510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01016_FIXPT 0xDBF3CA01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01016_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-604780031)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01016_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01016_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01017_ADDR 3511
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01017_FIXPT 0x9310CACD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01017_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1827616051)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01017_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01017_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01018_ADDR 3512
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01018_FIXPT 0x49C3E510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01018_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1237574928)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01018_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01018_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01019_ADDR 3513
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01019_FIXPT 0x061FBD2D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01019_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(102743341)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01019_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01019_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01020_ADDR 3514
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01020_FIXPT 0xD6492D00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01020_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-699847424)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01020_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01020_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01021_ADDR 3515
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01021_FIXPT 0x14C552F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01021_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(348476145)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01021_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01021_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01022_ADDR 3516
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01022_FIXPT 0x90F8AEEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01022_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1862750485)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01022_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01022_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01023_ADDR 3517
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01023_FIXPT 0xF315EEF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01023_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-216666377)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01023_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01023_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01024_ADDR 3518
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01024_FIXPT 0xDAC503FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01024_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-624622594)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01024_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01024_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01025_ADDR 3519
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01025_FIXPT 0xCF286C1F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01025_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-819434465)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01025_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01025_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01026_ADDR 3520
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01026_FIXPT 0xFC3B431D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01026_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-63225059)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01026_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01026_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01027_ADDR 3521
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01027_FIXPT 0x34C984D2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01027_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(885621970)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01027_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01027_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01028_ADDR 3522
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01028_FIXPT 0xCEF8FCE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01028_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-822543127)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01028_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01028_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01029_ADDR 3523
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01029_FIXPT 0xC2076A1A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01029_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1039701478)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01029_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01029_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01030_ADDR 3524
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01030_FIXPT 0xC5DEC1E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01030_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-975257112)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01030_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01030_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01031_ADDR 3525
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01031_FIXPT 0x6526A31E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01031_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1697030942)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01031_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01031_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01032_ADDR 3526
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01032_FIXPT 0x5923D42C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01032_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1495520300)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01032_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01032_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01033_ADDR 3527
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01033_FIXPT 0x28DBCABA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01033_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(685492922)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01033_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01033_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01034_ADDR 3528
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01034_FIXPT 0x15EF89F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01034_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(368019955)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01034_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01034_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01035_ADDR 3529
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01035_FIXPT 0xB0FA862A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01035_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1325758934)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01035_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01035_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01036_ADDR 3530
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01036_FIXPT 0x6E003DDD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01036_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1845509597)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01036_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01036_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01037_ADDR 3531
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01037_FIXPT 0x4B18D221
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01037_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1259917857)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01037_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01037_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01038_ADDR 3532
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01038_FIXPT 0x2D10D129
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01038_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(756076841)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01038_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01038_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01039_ADDR 3533
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01039_FIXPT 0x4DF09CB1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01039_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1307614385)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01039_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01039_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01040_ADDR 3534
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01040_FIXPT 0x9BE20EFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01040_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1679683843)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01040_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01040_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01041_ADDR 3535
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01041_FIXPT 0x37F9B72B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01041_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(939112235)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01041_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01041_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01042_ADDR 3536
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01042_FIXPT 0xAA1DDCDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01042_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1440883490)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01042_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01042_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01043_ADDR 3537
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01043_FIXPT 0x80056120
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01043_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2147131104)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01043_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01043_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01044_ADDR 3538
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01044_FIXPT 0x4507C519
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01044_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1158137113)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01044_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01044_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01045_ADDR 3539
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01045_FIXPT 0x000113B8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01045_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(70584)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01045_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01045_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01046_ADDR 3540
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01046_FIXPT 0x04D74802
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01046_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(81217538)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01046_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01046_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01047_ADDR 3541
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01047_FIXPT 0x3B026626
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01047_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(990012966)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01047_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01047_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01048_ADDR 3542
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01048_FIXPT 0xCF2CF6E9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01048_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-819136791)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01048_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01048_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01049_ADDR 3543
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01049_FIXPT 0xE1F3C018
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01049_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-504119272)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01049_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01049_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01050_ADDR 3544
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01050_FIXPT 0x80049506
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01050_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2147183354)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01050_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01050_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01051_ADDR 3545
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01051_FIXPT 0x3F0A95C9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01051_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1057658313)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01051_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01051_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01052_ADDR 3546
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01052_FIXPT 0xE8CED304
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01052_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-389098748)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01052_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01052_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01053_ADDR 3547
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01053_FIXPT 0x1F0FE31C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01053_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(521134876)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01053_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01053_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01054_ADDR 3548
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01054_FIXPT 0xB03131F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01054_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1338953224)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01054_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01054_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01055_ADDR 3549
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01055_FIXPT 0xB9E6990C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01055_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1176069876)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01055_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01055_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01056_ADDR 3550
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01056_FIXPT 0x7C03AAF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01056_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2080615158)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01056_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01056_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01057_ADDR 3551
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01057_FIXPT 0xC20F8BDC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01057_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1039168548)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01057_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01057_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01058_ADDR 3552
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01058_FIXPT 0xE5CCFC07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01058_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-439550969)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01058_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01058_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01059_ADDR 3553
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01059_FIXPT 0x3118B613
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01059_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(823703059)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01059_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01059_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01060_ADDR 3554
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01060_FIXPT 0x5231EE02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01060_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1379003906)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01060_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01060_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01061_ADDR 3555
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01061_FIXPT 0x3ADEB9FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01061_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(987675135)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01061_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01061_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01062_ADDR 3556
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01062_FIXPT 0xA80040F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01062_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1476378383)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01062_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01062_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01063_ADDR 3557
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01063_FIXPT 0xFE1069ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01063_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-32478739)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01063_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01063_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01064_ADDR 3558
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01064_FIXPT 0x57D2FD09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01064_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1473445129)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01064_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01064_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01065_ADDR 3559
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01065_FIXPT 0x8C19410F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01065_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1944502001)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01065_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01065_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01066_ADDR 3560
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01066_FIXPT 0x982CFD06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01066_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1741882106)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01066_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01066_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01067_ADDR 3561
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01067_FIXPT 0xE9D8BDF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01067_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-371671564)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01067_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01067_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01068_ADDR 3562
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01068_FIXPT 0xBFFE44F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01068_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1073855245)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01068_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01068_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01069_ADDR 3563
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01069_FIXPT 0xAF0F1FFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01069_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1357963270)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01069_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01069_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01070_ADDR 3564
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01070_FIXPT 0x7FDDE806
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01070_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2145249286)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01070_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01070_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01071_ADDR 3565
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01071_FIXPT 0x6819E50C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01071_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1746527500)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01071_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01071_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01072_ADDR 3566
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01072_FIXPT 0xC7252505
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01072_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-953867003)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01072_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01072_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01073_ADDR 3567
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01073_FIXPT 0xDBD59EEE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01073_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-606757138)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01073_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01073_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01074_ADDR 3568
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01074_FIXPT 0x3A0245F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01074_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(973227510)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01074_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01074_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01075_ADDR 3569
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01075_FIXPT 0xED0ED003
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01075_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-317796349)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01075_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01075_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01076_ADDR 3570
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01076_FIXPT 0xCAE5B703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01076_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-890915069)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01076_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01076_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01077_ADDR 3571
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01077_FIXPT 0xEE17D40B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01077_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-300428277)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01077_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01077_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01078_ADDR 3572
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01078_FIXPT 0x351B59FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01078_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(890984959)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01078_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01078_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01079_ADDR 3573
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01079_FIXPT 0x7FD5EEF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01079_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2144726769)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01079_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01079_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01080_ADDR 3574
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01080_FIXPT 0xE7047BF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01080_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-419136519)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01080_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01080_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01081_ADDR 3575
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01081_FIXPT 0x070FDB08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01081_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(118479624)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01081_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01081_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01082_ADDR 3576
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01082_FIXPT 0x27EA2104
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01082_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(669655300)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01082_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01082_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01083_ADDR 3577
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01083_FIXPT 0x10166B08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01083_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(269904648)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01083_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01083_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01084_ADDR 3578
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01084_FIXPT 0x840E56F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01084_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2079435015)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01084_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01084_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01085_ADDR 3579
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01085_FIXPT 0xCADDE7F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01085_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-891426825)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01085_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01085_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01086_ADDR 3580
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01086_FIXPT 0x220610FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01086_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(570822909)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01086_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01086_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01087_ADDR 3581
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01087_FIXPT 0xCD0E8006
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01087_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-854687738)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01087_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01087_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01088_ADDR 3582
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01088_FIXPT 0x9AEF7506
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01088_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1695582970)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01088_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01088_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01089_ADDR 3583
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01089_FIXPT 0xD9112800
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01089_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-653187072)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01089_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01089_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01090_ADDR 3584
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01090_FIXPT 0x5C047DF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01090_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1543798265)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01090_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01090_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01091_ADDR 3585
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01091_FIXPT 0x24E891FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01091_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(619221502)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01091_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01091_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01092_ADDR 3586
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01092_FIXPT 0xB80614FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01092_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1207560963)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01092_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01092_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01093_ADDR 3587
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01093_FIXPT 0x590CE203
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01093_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1494016515)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01093_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01093_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01094_ADDR 3588
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01094_FIXPT 0x7EF5CE09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01094_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2130038281)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01094_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01094_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01095_ADDR 3589
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01095_FIXPT 0x9609A3F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01095_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1777753098)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01095_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01095_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01096_ADDR 3590
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01096_FIXPT 0x9103C3FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01096_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1862024197)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01096_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01096_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01097_ADDR 3591
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01097_FIXPT 0x19F23D05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01097_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(435305733)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01097_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01097_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01098_ADDR 3592
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01098_FIXPT 0x720267FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01098_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1912760314)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01098_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01098_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01099_ADDR 3593
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01099_FIXPT 0x790ACF00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01099_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2030751488)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01099_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01099_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01100_ADDR 3594
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01100_FIXPT 0x37FCFB09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01100_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(939326217)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01100_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01100_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01101_ADDR 3595
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01101_FIXPT 0xC5FB06F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01101_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-973404425)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01101_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01101_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01102_ADDR 3596
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01102_FIXPT 0xE00596FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01102_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-536504579)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01102_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01102_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01103_ADDR 3597
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01103_FIXPT 0x5DFDD206
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01103_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1576915462)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01103_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01103_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01104_ADDR 3598
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01104_FIXPT 0xD2F8FDFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01104_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-755433988)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01104_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01104_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01105_ADDR 3599
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01105_FIXPT 0x0C0778FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01105_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(201816319)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01105_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01105_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01106_ADDR 3600
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01106_FIXPT 0x65039E02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01106_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1694735874)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01106_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01106_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01107_ADDR 3601
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01107_FIXPT 0xE7F638FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01107_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-403293954)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01107_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01107_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01108_ADDR 3602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01108_FIXPT 0x9206EC00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01108_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1845040128)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01108_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01108_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01109_ADDR 3603
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01109_FIXPT 0xD70446FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01109_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-687585537)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01109_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01109_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01110_ADDR 3604
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01110_FIXPT 0x48F597FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01110_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1224054782)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01110_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01110_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01111_ADDR 3605
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01111_FIXPT 0xE3021000
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01111_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-486404096)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01111_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01111_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01112_ADDR 3606
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01112_FIXPT 0xBE041700
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01112_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1107028224)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01112_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01112_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01113_ADDR 3607
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01113_FIXPT 0x83F8B004
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01113_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2080854012)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01113_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01113_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01114_ADDR 3608
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01114_FIXPT 0xB6050F02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01114_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1241182462)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01114_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01114_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01115_ADDR 3609
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01115_FIXPT 0xB4027FFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01115_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1274904581)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01115_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01115_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01116_ADDR 3610
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01116_FIXPT 0x1DF27901
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01116_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(502429953)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01116_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01116_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01117_ADDR 3611
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01117_FIXPT 0x98FE06FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01117_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1728182529)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01117_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01117_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01118_ADDR 3612
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01118_FIXPT 0x380C0701
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01118_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(940312321)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01118_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01118_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01119_ADDR 3613
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01119_FIXPT 0xE4F9990B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01119_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-453404405)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01119_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01119_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01120_ADDR 3614
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01120_FIXPT 0x1DFFD5FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01120_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(503305723)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01120_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01120_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01121_ADDR 3615
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01121_FIXPT 0x32073EF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01121_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(839335670)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01121_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01121_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01122_ADDR 3616
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01122_FIXPT 0x0CF12403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01122_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(217129987)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01122_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01122_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01123_ADDR 3617
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01123_FIXPT 0x1BF86707
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01123_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(469264135)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01123_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01123_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01124_ADDR 3618
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01124_FIXPT 0xB416D6FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01124_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1273571588)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01124_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01124_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01125_ADDR 3619
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01125_FIXPT 0x8FFFD607
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01125_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1879058937)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01125_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01125_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01126_ADDR 3620
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01126_FIXPT 0x5AF00500
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01126_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1525679360)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01126_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01126_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01127_ADDR 3621
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01127_FIXPT 0x810BA7EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01127_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2129942548)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01127_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01127_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01128_ADDR 3622
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01128_FIXPT 0x3EF4BB01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01128_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1056226049)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01128_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01128_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01129_ADDR 3623
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01129_FIXPT 0x7BFABF15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01129_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2080030485)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01129_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01129_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01130_ADDR 3624
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01130_FIXPT 0xA71AB0F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01130_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1491422984)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01130_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01130_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01131_ADDR 3625
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01131_FIXPT 0x3FFF3EF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01131_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1073692406)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01131_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01131_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01132_ADDR 3626
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01132_FIXPT 0x40ED440C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01132_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1089291276)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01132_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01132_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01133_ADDR 3627
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01133_FIXPT 0x2C0633E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01133_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(738604005)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01133_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01133_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01134_ADDR 3628
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01134_FIXPT 0xFBFC6400
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01134_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-67345408)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01134_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01134_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01135_ADDR 3629
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01135_FIXPT 0x9804D124
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01135_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1744514780)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01135_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01135_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01136_ADDR 3630
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01136_FIXPT 0xA91488EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01136_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1458272020)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01136_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01136_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01137_ADDR 3631
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01137_FIXPT 0xADF837E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01137_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1376241689)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01137_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01137_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01138_ADDR 3632
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01138_FIXPT 0x77F82216
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01138_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2012750358)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01138_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01138_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01139_ADDR 3633
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01139_FIXPT 0x36F7BAE8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01139_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(922204904)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01139_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01139_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01140_ADDR 3634
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01140_FIXPT 0xD609FEFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01140_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-703987972)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01140_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01140_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01141_ADDR 3635
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01141_FIXPT 0x7F161E2F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01141_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2132155951)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01141_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01141_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01142_ADDR 3636
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01142_FIXPT 0xC5F940E2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01142_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-973520670)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01142_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01142_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01143_ADDR 3637
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01143_FIXPT 0xB0F29AE4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01143_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1326277916)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01143_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01143_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01144_ADDR 3638
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01144_FIXPT 0x9F071718
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01144_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1626925288)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01144_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01144_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01145_ADDR 3639
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01145_FIXPT 0xE7ECC0F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01145_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-403914503)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01145_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01145_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01146_ADDR 3640
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01146_FIXPT 0x300CEC02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01146_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(806153218)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01146_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01146_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01147_ADDR 3641
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01147_FIXPT 0x5B28BE1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01147_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1529396766)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01147_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01147_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01148_ADDR 3642
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01148_FIXPT 0x4BDBA5E2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01148_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1272686050)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01148_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01148_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01149_ADDR 3643
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01149_FIXPT 0x22EDBEEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01149_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(586006251)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01149_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01149_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01150_ADDR 3644
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01150_FIXPT 0xD6198315
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01150_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-702971115)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01150_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01150_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01151_ADDR 3645
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01151_FIXPT 0xA8EAB709
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01151_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1461012727)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01151_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01151_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01152_ADDR 3646
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01152_FIXPT 0x6F07980D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01152_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1862768653)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01152_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01152_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01153_ADDR 3647
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01153_FIXPT 0x322AACF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01153_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(841657593)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01153_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01153_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01154_ADDR 3648
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01154_FIXPT 0x78CADFEE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01154_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2026561518)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01154_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01154_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01155_ADDR 3649
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01155_FIXPT 0xABE4D6FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01155_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1411066113)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01155_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01155_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01156_ADDR 3650
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01156_FIXPT 0xEA323B03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01156_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-365806845)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01156_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01156_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01157_ADDR 3651
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01157_FIXPT 0x23F2F814
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01157_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(603125780)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01157_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01157_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01158_ADDR 3652
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01158_FIXPT 0x00FC7015
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01158_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(16543765)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01158_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01158_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01159_ADDR 3653
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01159_FIXPT 0x811C5DD1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01159_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2128847407)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01159_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01159_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01160_ADDR 3654
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01160_FIXPT 0x5ED665F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01160_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1591109104)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01160_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01160_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01161_ADDR 3655
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01161_FIXPT 0x01EBD02A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01161_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(32231466)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01161_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01161_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01162_ADDR 3656
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01162_FIXPT 0x1D3169EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01162_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(489777647)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01162_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01162_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01163_ADDR 3657
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01163_FIXPT 0x4C057A03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01163_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1275427331)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01163_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01163_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01164_ADDR 3658
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01164_FIXPT 0x5DF7541F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01164_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1576490015)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01164_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01164_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01165_ADDR 3659
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01165_FIXPT 0x95F667C3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01165_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1779013693)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01165_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01165_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01166_ADDR 3660
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01166_FIXPT 0x83EA14F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01166_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2081811215)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01166_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01166_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01167_ADDR 3661
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01167_FIXPT 0x7D117746
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01167_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2098296646)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01167_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01167_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01168_ADDR 3662
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01168_FIXPT 0x0612FCEA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01168_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(101907690)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01168_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01168_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01169_ADDR 3663
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01169_FIXPT 0xEE0597ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01169_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-301623315)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01169_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01169_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01170_ADDR 3664
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01170_FIXPT 0x8B025118
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01170_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1962782440)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01170_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01170_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01171_ADDR 3665
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01171_FIXPT 0xBBD145D1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01171_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1143913007)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01171_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01171_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01172_ADDR 3666
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01172_FIXPT 0xD2005E04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01172_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-771727868)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01172_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01172_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01173_ADDR 3667
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01173_FIXPT 0x0C39983C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01173_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(205101116)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01173_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01173_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01174_ADDR 3668
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01174_FIXPT 0x27EAFEEE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01174_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(669712110)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01174_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01174_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01175_ADDR 3669
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01175_FIXPT 0x62F5FBE5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01175_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1660287973)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01175_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01175_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01176_ADDR 3670
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01176_FIXPT 0x6F1723FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01176_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1863787514)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01176_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01176_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01177_ADDR 3671
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01177_FIXPT 0x83C40BFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01177_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2084303874)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01177_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01177_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01178_ADDR 3672
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01178_FIXPT 0x950B871F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01178_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1794406625)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01178_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01178_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01179_ADDR 3673
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01179_FIXPT 0x0F50D403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01179_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(256955395)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01179_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01179_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01180_ADDR 3674
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01180_FIXPT 0x82D4AAF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01180_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2099991820)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01180_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01180_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01181_ADDR 3675
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01181_FIXPT 0x5BDE2AFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01181_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1541286651)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01181_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01181_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01182_ADDR 3676
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01182_FIXPT 0x711CF9D9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01182_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1897724377)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01182_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01182_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01183_ADDR 3677
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01183_FIXPT 0xBEE77618
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01183_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1092127208)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01183_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01183_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01184_ADDR 3678
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01184_FIXPT 0x5C118A41
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01184_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1544653377)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01184_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01184_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01185_ADDR 3679
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01185_FIXPT 0xBC2619CF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01185_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1138353713)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01185_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01185_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01186_ADDR 3680
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01186_FIXPT 0xEBDE63E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01186_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-337746973)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01186_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01186_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01187_ADDR 3681
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01187_FIXPT 0x82E2BF23
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01187_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2099069149)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01187_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01187_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01188_ADDR 3682
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01188_FIXPT 0x9F041DDC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01188_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1627120164)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01188_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01188_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01189_ADDR 3683
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01189_FIXPT 0x0615BE14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01189_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(102088212)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01189_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01189_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01190_ADDR 3684
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01190_FIXPT 0xD320D93C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01190_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-752821956)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01190_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01190_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01191_ADDR 3685
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01191_FIXPT 0x51E2F3C2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01191_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1373828034)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01191_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01191_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01192_ADDR 3686
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01192_FIXPT 0xCDE414DB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01192_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-840690469)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01192_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01192_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01193_ADDR 3687
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01193_FIXPT 0xB915572C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01193_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1189783764)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01193_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01193_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01194_ADDR 3688
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01194_FIXPT 0x47EA2A01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01194_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1206528513)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01194_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01194_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01195_ADDR 3689
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01195_FIXPT 0x421B5709
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01195_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1109088009)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01195_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01195_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01196_ADDR 3690
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01196_FIXPT 0xEC379D02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01196_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-331899646)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01196_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01196_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01197_ADDR 3691
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01197_FIXPT 0xF6B388D6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01197_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-156006186)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01197_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01197_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01198_ADDR 3692
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01198_FIXPT 0x4FE3D704
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01198_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1340331780)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01198_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01198_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01199_ADDR 3693
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01199_FIXPT 0x1A447509
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01199_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(440694025)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01199_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01199_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01200_ADDR 3694
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01200_FIXPT 0x6AEE9D15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01200_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1794022677)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01200_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01200_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01201_ADDR 3695
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01201_FIXPT 0xB8027A1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01201_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1207797219)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01201_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01201_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01202_ADDR 3696
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01202_FIXPT 0xB51DDDBB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01202_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1256333893)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01202_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01202_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01203_ADDR 3697
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01203_FIXPT 0x38BE26F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01203_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(951985905)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01203_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01203_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01204_ADDR 3698
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01204_FIXPT 0x02FD4647
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01204_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(50153031)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01204_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01204_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01205_ADDR 3699
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01205_FIXPT 0x2B2D25E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01205_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(724379109)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01205_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01205_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01206_ADDR 3700
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01206_FIXPT 0xB303B904
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01206_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1291601660)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01206_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01206_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01207_ADDR 3701
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01207_FIXPT 0xA1036C26
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01207_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1593611226)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01207_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01207_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01208_ADDR 3702
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01208_FIXPT 0xC2D02DAD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01208_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1026544211)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01208_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01208_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01209_ADDR 3703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01209_FIXPT 0x78F76102
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01209_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2029478146)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01209_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01209_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01210_ADDR 3704
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01210_FIXPT 0xD83B6A4A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01210_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-667194806)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01210_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01210_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01211_ADDR 3705
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01211_FIXPT 0x47E80CEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01211_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1206389995)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01211_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01211_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01212_ADDR 3706
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01212_FIXPT 0xC60560F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01212_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-972726030)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01212_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01212_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01213_ADDR 3707
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01213_FIXPT 0x0B1DD5E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01213_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(186504679)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01213_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01213_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01214_ADDR 3708
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01214_FIXPT 0xF9AF31F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01214_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-105958926)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01214_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01214_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01215_ADDR 3709
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01215_FIXPT 0x8510FC2E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01215_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2062484434)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01215_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01215_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01216_ADDR 3710
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01216_FIXPT 0xBF5541F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01216_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1084931593)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01216_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01216_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01217_ADDR 3711
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01217_FIXPT 0xB4D39700
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01217_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1261201664)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01217_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01217_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01218_ADDR 3712
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01218_FIXPT 0x2AEBFC09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01218_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(720108553)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01218_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01218_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01219_ADDR 3713
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01219_FIXPT 0x90FF04C0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01219_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1862335296)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01219_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01219_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01220_ADDR 3714
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01220_FIXPT 0x26E9691F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01220_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(652831007)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01220_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01220_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01221_ADDR 3715
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01221_FIXPT 0x8526724E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01221_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2061077938)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01221_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01221_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01222_ADDR 3716
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01222_FIXPT 0xDF0A2AC5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01222_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-552981819)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01222_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01222_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01223_ADDR 3717
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01223_FIXPT 0xC7F231EA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01223_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-940428822)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01223_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01223_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01224_ADDR 3718
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01224_FIXPT 0x32F60417
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01224_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(854983703)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01224_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01224_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01225_ADDR 3719
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01225_FIXPT 0xA9D5F1E2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01225_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1445596702)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01225_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01225_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01226_ADDR 3720
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01226_FIXPT 0x3F2A8B1F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01226_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1059752735)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01226_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01226_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01227_ADDR 3721
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01227_FIXPT 0xCB3ED019
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01227_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-885075943)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01227_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01227_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01228_ADDR 3722
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01228_FIXPT 0xBFC040DF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01228_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1077919521)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01228_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01228_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01229_ADDR 3723
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01229_FIXPT 0xF5EAC4EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01229_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-169163540)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01229_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01229_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01230_ADDR 3724
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01230_FIXPT 0x1E2778EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01230_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(505903343)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01230_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01230_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01231_ADDR 3725
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01231_FIXPT 0x1AE25B2B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01231_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(451042091)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01231_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01231_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01232_ADDR 3726
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01232_FIXPT 0x3419322D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01232_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(874066477)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01232_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01232_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01233_ADDR 3727
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01233_FIXPT 0xBC2002C1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01233_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1138752831)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01233_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01233_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01234_ADDR 3728
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01234_FIXPT 0xD7CA16ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01234_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-674621715)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01234_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01234_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01235_ADDR 3729
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01235_FIXPT 0x42EE142E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01235_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1122898990)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01235_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01235_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01236_ADDR 3730
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01236_FIXPT 0xB80A78E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01236_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1207273245)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01236_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01236_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01237_ADDR 3731
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01237_FIXPT 0x25214516
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01237_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(622937366)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01237_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01237_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01238_ADDR 3732
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01238_FIXPT 0x911C1E22
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01238_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1860428254)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01238_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01238_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01239_ADDR 3733
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01239_FIXPT 0x84C2C6BB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01239_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2067609925)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01239_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01239_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01240_ADDR 3734
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01240_FIXPT 0xA8F3B0F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01240_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1460424458)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01240_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01240_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01241_ADDR 3735
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01241_FIXPT 0x5C316522
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01241_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1546741026)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01241_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01241_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01242_ADDR 3736
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01242_FIXPT 0x77E20C12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01242_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2011302930)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01242_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01242_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01243_ADDR 3737
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01243_FIXPT 0xC813AA0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01243_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-938235380)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01243_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01243_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01244_ADDR 3738
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01244_FIXPT 0xCA1D32C4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01244_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-904056124)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01244_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01244_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01245_ADDR 3739
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01245_FIXPT 0x05B7CAFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01245_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(95931132)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01245_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01245_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01246_ADDR 3740
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01246_FIXPT 0x0A038A35
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01246_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(168004149)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01246_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01246_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01247_ADDR 3741
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01247_FIXPT 0x442F1CE2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01247_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1143938274)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01247_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01247_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01248_ADDR 3742
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01248_FIXPT 0xA5028F10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01248_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1526558960)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01248_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01248_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01249_ADDR 3743
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01249_FIXPT 0xB8FFC616
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01249_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1191197162)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01249_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01249_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01250_ADDR 3744
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01250_FIXPT 0xD4CBB2B8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01250_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-724847944)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01250_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01250_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01251_ADDR 3745
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01251_FIXPT 0x2E074310
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01251_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(772227856)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01251_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01251_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01252_ADDR 3746
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01252_FIXPT 0xC0360D32
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01252_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1070199502)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01252_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01252_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01253_ADDR 3747
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01253_FIXPT 0xDCDEC2F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01253_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-589380874)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01253_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01253_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01254_ADDR 3748
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01254_FIXPT 0x430BE8F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01254_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1124854004)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01254_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01254_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01255_ADDR 3749
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01255_FIXPT 0x7B109FD8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01255_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2064687064)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01255_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01255_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01256_ADDR 3750
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01256_FIXPT 0x68BF6712
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01256_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1757374226)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01256_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01256_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01257_ADDR 3751
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01257_FIXPT 0x051BF331
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01257_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(85717809)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01257_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01257_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01258_ADDR 3752
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01258_FIXPT 0xF53019D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01258_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-181397032)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01258_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01258_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01259_ADDR 3753
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01259_FIXPT 0x2CEE0E04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01259_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(753798660)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01259_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01259_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01260_ADDR 3754
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01260_FIXPT 0x64ECA611
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01260_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1693230609)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01260_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01260_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01261_ADDR 3755
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01261_FIXPT 0x0FE2E3CB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01261_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(266527691)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01261_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01261_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01262_ADDR 3756
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01262_FIXPT 0xD51B591D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01262_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-719628003)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01262_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01262_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01263_ADDR 3757
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01263_FIXPT 0x242D8129
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01263_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(606961961)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01263_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01263_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01264_ADDR 3758
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01264_FIXPT 0x81D19CE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01264_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2116969242)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01264_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01264_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01265_ADDR 3759
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01265_FIXPT 0x6AFC71ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01265_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1794929133)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01265_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01265_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01266_ADDR 3760
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01266_FIXPT 0xB813C1EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01266_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1206664725)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01266_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01266_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01267_ADDR 3761
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01267_FIXPT 0xA4DBAC1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01267_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1529107426)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01267_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01267_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01268_ADDR 3762
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01268_FIXPT 0x651D2026
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01268_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1696407590)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01268_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01268_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01269_ADDR 3763
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01269_FIXPT 0xFC1E22CB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01269_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-65133877)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01269_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01269_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01270_ADDR 3764
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01270_FIXPT 0x9CDF2DFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01270_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1663095300)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01270_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01270_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01271_ADDR 3765
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01271_FIXPT 0xF1F16617
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01271_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-235837929)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01271_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01271_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01272_ADDR 3766
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01272_FIXPT 0x02F70BE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01272_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(49744870)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01272_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01272_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01273_ADDR 3767
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01273_FIXPT 0xFC1E8F1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01273_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-65106149)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01273_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01273_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01274_ADDR 3768
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01274_FIXPT 0x141C3513
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01274_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(337392915)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01274_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01274_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01275_ADDR 3769
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01275_FIXPT 0x5CC434E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01275_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1556362464)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01275_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01275_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01276_ADDR 3770
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01276_FIXPT 0x0701C3F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01276_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(117556213)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01276_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01276_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01277_ADDR 3771
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01277_FIXPT 0x9421E7FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01277_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1809717254)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01277_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01277_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01278_ADDR 3772
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01278_FIXPT 0xE1EB8521
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01278_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-504658655)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01278_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01278_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01279_ADDR 3773
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01279_FIXPT 0x4B12BF12
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01279_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1259519762)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01279_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01279_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01280_ADDR 3774
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01280_FIXPT 0x86040AC1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01280_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2046555455)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01280_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01280_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01281_ADDR 3775
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01281_FIXPT 0x9FEA8303
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01281_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1612020989)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01281_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01281_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01282_ADDR 3776
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01282_FIXPT 0x96FF3D29
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01282_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1761657559)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01282_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01282_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01283_ADDR 3777
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01283_FIXPT 0x66F6CDF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01283_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1727450612)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01283_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01283_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01284_ADDR 3778
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01284_FIXPT 0x6E1F0A05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01284_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1847527941)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01284_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01284_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01285_ADDR 3779
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01285_FIXPT 0x290B82F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01285_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(688620278)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01285_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01285_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01286_ADDR 3780
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01286_FIXPT 0xDFC922F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01286_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-540466443)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01286_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01286_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01287_ADDR 3781
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01287_FIXPT 0x40075E0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01287_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1074224652)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01287_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01287_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01288_ADDR 3782
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01288_FIXPT 0x08255AF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01288_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(136665843)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01288_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01288_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01289_ADDR 3783
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01289_FIXPT 0x1CFCB015
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01289_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(486322197)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01289_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01289_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01290_ADDR 3784
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01290_FIXPT 0xB1F87A05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01290_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1309115899)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01290_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01290_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01291_ADDR 3785
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01291_FIXPT 0xE9F1D1D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01291_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-370028076)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01291_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01291_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01292_ADDR 3786
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01292_FIXPT 0xBA008F0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01292_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1174368499)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01292_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01292_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01293_ADDR 3787
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01293_FIXPT 0x8310E01F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01293_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2096046049)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01293_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01293_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01294_ADDR 3788
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01294_FIXPT 0x4EF1A3FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01294_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1324459005)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01294_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01294_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01295_ADDR 3789
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01295_FIXPT 0x0F09D2F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01295_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(252302064)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01295_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01295_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01296_ADDR 3790
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01296_FIXPT 0x060981ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01296_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(101286381)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01296_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01296_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01297_ADDR 3791
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01297_FIXPT 0x0DE29E0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01297_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(232955404)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01297_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01297_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01298_ADDR 3792
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01298_FIXPT 0xF009C614
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01298_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-267794924)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01298_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01298_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01299_ADDR 3793
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01299_FIXPT 0x2B186CED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01299_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(723021037)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01299_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01299_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01300_ADDR 3794
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01300_FIXPT 0x8AFAB2FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01300_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1963281667)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01300_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01300_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01301_ADDR 3795
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01301_FIXPT 0x06F6DD0B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01301_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(116841739)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01301_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01301_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01302_ADDR 3796
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01302_FIXPT 0x3CECD8F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01302_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1022154993)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01302_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01302_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01303_ADDR 3797
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01303_FIXPT 0xE20F4006
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01303_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-502317050)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01303_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01303_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01304_ADDR 3798
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01304_FIXPT 0x8918710B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01304_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1994886901)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01304_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01304_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01305_ADDR 3799
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01305_FIXPT 0x8AE77DF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01305_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1964540424)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01305_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01305_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01306_ADDR 3800
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01306_FIXPT 0xEEFB6AFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01306_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-285512962)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01306_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01306_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01307_ADDR 3801
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01307_FIXPT 0x110BBBEC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01307_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(285981676)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01307_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01307_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01308_ADDR 3802
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01308_FIXPT 0x8BFC2B0E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01308_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1946408178)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01308_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01308_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01309_ADDR 3803
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01309_FIXPT 0xA806F017
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01309_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1475940329)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01309_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01309_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01310_ADDR 3804
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01310_FIXPT 0x30F892E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01310_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(821596904)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01310_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01310_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01311_ADDR 3805
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01311_FIXPT 0x1C005BFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01311_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(469785595)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01311_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01311_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01312_ADDR 3806
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01312_FIXPT 0xBB072805
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01312_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157158907)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01312_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01312_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01313_ADDR 3807
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01313_FIXPT 0xD3EE3F05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01313_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-739361019)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01313_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01313_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01314_ADDR 3808
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01314_FIXPT 0xB8098209
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01314_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1207336439)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01314_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01314_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01315_ADDR 3809
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01315_FIXPT 0x9B0B84EA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01315_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1693743894)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01315_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01315_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01316_ADDR 3810
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01316_FIXPT 0x92F7E702
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01316_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1829247230)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01316_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01316_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01317_ADDR 3811
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01317_FIXPT 0x7DFE980A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01317_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2113837066)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01317_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01317_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01318_ADDR 3812
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01318_FIXPT 0x77F988F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01318_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2012842233)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01318_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01318_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01319_ADDR 3813
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01319_FIXPT 0xE0088D04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01319_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-536310524)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01319_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01319_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01320_ADDR 3814
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01320_FIXPT 0x040730FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01320_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(67580155)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01320_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01320_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01321_ADDR 3815
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01321_FIXPT 0x0BF22703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01321_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(200419075)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01321_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01321_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01322_ADDR 3816
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01322_FIXPT 0x7002A901
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01322_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1879222529)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01322_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01322_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01323_ADDR 3817
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01323_FIXPT 0x0201FDF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01323_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(33684983)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01323_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01323_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01324_ADDR 3818
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01324_FIXPT 0x3804A106
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01324_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(939827462)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01324_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01324_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01325_ADDR 3819
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01325_FIXPT 0x3DFEB6FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01325_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1040103167)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01325_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01325_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01326_ADDR 3820
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01326_FIXPT 0xD7FA84FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01326_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-671447809)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01326_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01326_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01327_ADDR 3821
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01327_FIXPT 0x60080BFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01327_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1611140093)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01327_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01327_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01328_ADDR 3822
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01328_FIXPT 0x3AFD5FFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01328_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(989683709)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01328_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01328_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01329_ADDR 3823
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01329_FIXPT 0x7DFD6D0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01329_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2113760522)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01329_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01329_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01330_ADDR 3824
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01330_FIXPT 0xBFFC71FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01330_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1073974790)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01330_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01330_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01331_ADDR 3825
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01331_FIXPT 0x650149FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01331_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1694583295)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01331_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01331_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01332_ADDR 3826
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01332_FIXPT 0x330E4800
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01332_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(856573952)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01332_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01332_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01333_ADDR 3827
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01333_FIXPT 0x56F2F4FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01333_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1458763007)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01333_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01333_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01334_ADDR 3828
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01334_FIXPT 0x64FA1508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01334_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1694110984)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01334_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01334_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01335_ADDR 3829
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01335_FIXPT 0x500450F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01335_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1342460147)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01335_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01335_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01336_ADDR 3830
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01336_FIXPT 0x59056A00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01336_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1493527040)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01336_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01336_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01337_ADDR 3831
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01337_FIXPT 0x7D0C500B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01337_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2097958923)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01337_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01337_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01338_ADDR 3832
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01338_FIXPT 0xC3EBAEF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01338_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1007964423)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01338_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01338_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01339_ADDR 3833
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01339_FIXPT 0xF5F92F00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01339_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-168218880)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01339_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01339_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01340_ADDR 3834
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01340_FIXPT 0x730F4AF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01340_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1930382071)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01340_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01340_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01341_ADDR 3835
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01341_FIXPT 0x15FD8D07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01341_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(368938247)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01341_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01341_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01342_ADDR 3836
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01342_FIXPT 0x7D053310
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01342_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2097492752)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01342_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01342_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01343_ADDR 3837
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01343_FIXPT 0x65F403EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01343_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1710490604)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01343_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01343_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01344_ADDR 3838
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01344_FIXPT 0x80FE21F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01344_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2130828809)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01344_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01344_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01345_ADDR 3839
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01345_FIXPT 0x8D0C940B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01345_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1928555509)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01345_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01345_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01346_ADDR 3840
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01346_FIXPT 0xF7F4D809
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01346_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-134948855)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01346_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01346_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01347_ADDR 3841
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01347_FIXPT 0xC903AE06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01347_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-922505722)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01347_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01347_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01348_ADDR 3842
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01348_FIXPT 0x790756E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01348_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2030524135)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01348_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01348_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01349_ADDR 3843
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01349_FIXPT 0xD3F451F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01349_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-738962951)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01349_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01349_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01350_ADDR 3844
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01350_FIXPT 0x2700211B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01350_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(654319899)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01350_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01350_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01351_ADDR 3845
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01351_FIXPT 0x2EFFCFFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01351_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(788516861)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01351_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01351_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01352_ADDR 3846
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01352_FIXPT 0xD70CF5F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01352_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-687016458)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01352_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01352_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01353_ADDR 3847
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01353_FIXPT 0xC50894FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01353_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-989293318)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01353_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01353_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01354_ADDR 3848
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01354_FIXPT 0x3EE3B0FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01354_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1055109373)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01354_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01354_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01355_ADDR 3849
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01355_FIXPT 0x4DF63017
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01355_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1307979799)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01355_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01355_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01356_ADDR 3850
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01356_FIXPT 0x671BD3F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01356_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1729876981)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01356_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01356_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01357_ADDR 3851
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01357_FIXPT 0x6709D8F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01357_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1728698610)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01357_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01357_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01358_ADDR 3852
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01358_FIXPT 0x12FA680F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01358_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(318400527)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01358_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01358_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01359_ADDR 3853
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01359_FIXPT 0x9CE45BEF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01359_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1662755857)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01359_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01359_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01360_ADDR 3854
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01360_FIXPT 0x20FFFC05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01360_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(553647109)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01360_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01360_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01361_ADDR 3855
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01361_FIXPT 0xF62A2109
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01361_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-165011191)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01361_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01361_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01362_ADDR 3856
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01362_FIXPT 0xF2F4C9FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01362_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-218838533)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01362_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01362_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01363_ADDR 3857
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01363_FIXPT 0x3FE6240F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01363_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1072047119)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01363_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01363_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01364_ADDR 3858
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01364_FIXPT 0x64FD85DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01364_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1694336477)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01364_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01364_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01365_ADDR 3859
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01365_FIXPT 0x09080EFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01365_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(151523070)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01365_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01365_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01366_ADDR 3860
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01366_FIXPT 0x3722352A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01366_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(924988714)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01366_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01366_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01367_ADDR 3861
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01367_FIXPT 0xA3E953F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01367_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1544989707)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01367_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01367_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01368_ADDR 3862
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01368_FIXPT 0x2BE452FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01368_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(736383738)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01368_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01368_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01369_ADDR 3863
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01369_FIXPT 0xF91688E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01369_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-115963679)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01369_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01369_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01370_ADDR 3864
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01370_FIXPT 0x52FD5508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01370_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1392334088)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01370_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01370_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01371_ADDR 3865
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01371_FIXPT 0xE80F4238
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01371_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-401653192)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01371_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01371_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01372_ADDR 3866
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01372_FIXPT 0xFEF8CFDD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01372_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-17248291)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01372_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01372_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01373_ADDR 3867
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01373_FIXPT 0x66ED30E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01373_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1726820581)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01373_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01373_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01374_ADDR 3868
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01374_FIXPT 0xC3166802
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01374_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1021941758)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01374_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01374_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01375_ADDR 3869
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01375_FIXPT 0x92EBFE11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01375_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1830027759)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01375_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01375_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01376_ADDR 3870
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01376_FIXPT 0xBE05432C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01376_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1106951380)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01376_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01376_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01377_ADDR 3871
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01377_FIXPT 0xCF165DCF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01377_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-820617777)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01377_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01377_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01378_ADDR 3872
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01378_FIXPT 0x2DE92EE2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01378_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(770256610)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01378_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01378_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01379_ADDR 3873
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01379_FIXPT 0xFB017025
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01379_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-83791835)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01379_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01379_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01380_ADDR 3874
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01380_FIXPT 0x13F0FD05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01380_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(334560517)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01380_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01380_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01381_ADDR 3875
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01381_FIXPT 0x300E2110
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01381_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(806232336)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01381_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01381_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01382_ADDR 3876
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01382_FIXPT 0xDD2AB2DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01382_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-584404262)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01382_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01382_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01383_ADDR 3877
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01383_FIXPT 0x36D30BEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01383_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(919800811)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01383_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01383_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01384_ADDR 3878
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01384_FIXPT 0xE6EDA033
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01384_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-420634573)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01384_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01384_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01385_ADDR 3879
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01385_FIXPT 0xE00CA9F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01385_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-536040974)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01385_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01385_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01386_ADDR 3880
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01386_FIXPT 0x0717ACFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01386_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(118992124)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01386_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01386_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01387_ADDR 3881
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01387_FIXPT 0xE8224CFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01387_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-400405253)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01387_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01387_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01388_ADDR 3882
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01388_FIXPT 0xFEBE2BED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01388_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-21091347)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01388_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01388_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01389_ADDR 3883
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01389_FIXPT 0xA9E8AE2A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01389_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1444368854)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01389_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01389_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01390_ADDR 3884
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01390_FIXPT 0xB83069ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01390_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1204786707)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01390_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01390_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01391_ADDR 3885
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01391_FIXPT 0xF40D5CF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01391_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-200450823)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01391_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01391_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01392_ADDR 3886
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01392_FIXPT 0x6B095915
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01392_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1795774741)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01392_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01392_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01393_ADDR 3887
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01393_FIXPT 0x27C308DC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01393_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(667093212)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01393_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01393_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01394_ADDR 3888
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01394_FIXPT 0x01F5C915
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01394_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(32885013)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01394_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01394_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01395_ADDR 3889
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01395_FIXPT 0x664A08FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01395_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1716127998)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01395_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01395_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01396_ADDR 3890
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01396_FIXPT 0xA0F496FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01396_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1594583298)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01396_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01396_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01397_ADDR 3891
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01397_FIXPT 0x2EF1001B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01397_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(787546139)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01397_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01397_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01398_ADDR 3892
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01398_FIXPT 0x21DA99C8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01398_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(567974344)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01398_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01398_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01399_ADDR 3893
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01399_FIXPT 0x4F03890B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01399_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1325631755)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01399_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01399_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01400_ADDR 3894
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01400_FIXPT 0x3A4AB01E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01400_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(977973278)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01400_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01400_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01401_ADDR 3895
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01401_FIXPT 0x33DD21FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01401_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(870130173)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01401_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01401_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01402_ADDR 3896
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01402_FIXPT 0x7EE44E0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01402_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2128891405)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01402_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01402_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01403_ADDR 3897
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01403_FIXPT 0xFFF910C3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01403_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-454461)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01403_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01403_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01404_ADDR 3898
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01404_FIXPT 0x75062210
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01404_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1963336208)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01404_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01404_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01405_ADDR 3899
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01405_FIXPT 0xA53A4438
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01405_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1522908104)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01405_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01405_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01406_ADDR 3900
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01406_FIXPT 0x88D7ACEC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01406_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1999131412)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01406_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01406_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01407_ADDR 3901
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01407_FIXPT 0x49E525F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01407_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1239754227)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01407_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01407_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01408_ADDR 3902
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01408_FIXPT 0xD516D4D1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01408_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-719924015)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01408_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01408_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01409_ADDR 3903
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01409_FIXPT 0x07FC771B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01409_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(133986075)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01409_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01409_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01410_ADDR 3904
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01410_FIXPT 0x95250243
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01410_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1792736701)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01410_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01410_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01411_ADDR 3905
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01411_FIXPT 0x72E1D1D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01411_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1927401940)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01411_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01411_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01412_ADDR 3906
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01412_FIXPT 0x72E786E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01412_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1927775968)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01412_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01412_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01413_ADDR 3907
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01413_FIXPT 0x9C2479F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01413_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1675331087)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01413_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01413_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01414_ADDR 3908
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01414_FIXPT 0x44EDA723
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01414_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1156425507)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01414_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01414_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01415_ADDR 3909
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01415_FIXPT 0x2E14933E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01415_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(773100350)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01415_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01415_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01416_ADDR 3910
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01416_FIXPT 0xCCF5E4BE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01416_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-856300354)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01416_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01416_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01417_ADDR 3911
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01417_FIXPT 0xDCE46DDB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01417_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-589009445)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01417_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01417_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01418_ADDR 3912
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01418_FIXPT 0x73269413
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01418_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1931908115)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01418_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01418_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01419_ADDR 3913
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01419_FIXPT 0xE0E8E01F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01419_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-521609185)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01419_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01419_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01420_ADDR 3914
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01420_FIXPT 0x7C0C5D2C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01420_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2081185068)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01420_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01420_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01421_ADDR 3915
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01421_FIXPT 0xAF0DA8B2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01421_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1358059342)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01421_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01421_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01422_ADDR 3916
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01422_FIXPT 0xF1D93BE4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01422_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-237421596)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01422_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01422_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01423_ADDR 3917
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01423_FIXPT 0xC51FA232
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01423_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-987782606)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01423_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01423_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01424_ADDR 3918
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01424_FIXPT 0x04EE4310
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01424_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(82723600)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01424_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01424_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01425_ADDR 3919
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01425_FIXPT 0x4A0B5A16
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01425_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1242257942)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01425_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01425_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01426_ADDR 3920
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01426_FIXPT 0x7F1C8CB4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01426_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2132577460)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01426_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01426_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01427_ADDR 3921
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01427_FIXPT 0xFCC83CF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01427_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-53986060)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01427_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01427_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01428_ADDR 3922
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01428_FIXPT 0x0D16414B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01428_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(219562315)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01428_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01428_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01429_ADDR 3923
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01429_FIXPT 0x34F987F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01429_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(888768505)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01429_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01429_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01430_ADDR 3924
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01430_FIXPT 0xF70B4A02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01430_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-150255102)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01430_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01430_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01431_ADDR 3925
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01431_FIXPT 0x881F29BC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01431_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2011223620)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01431_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01431_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01432_ADDR 3926
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01432_FIXPT 0xE8BFE302
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01432_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-390077694)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01432_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01432_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01433_ADDR 3927
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01433_FIXPT 0x03130458
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01433_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(51577944)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01433_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01433_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01434_ADDR 3928
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01434_FIXPT 0xEA06ACE2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01434_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-368661278)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01434_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01434_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01435_ADDR 3929
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01435_FIXPT 0x9C090EF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01435_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1677127948)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01435_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01435_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01436_ADDR 3930
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01436_FIXPT 0xB5190DCB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01436_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1256649269)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01436_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01436_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01437_ADDR 3931
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01437_FIXPT 0x1DBFBF0E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01437_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(499105550)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01437_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01437_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01438_ADDR 3932
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01438_FIXPT 0x59185957
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01438_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1494767959)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01438_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01438_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01439_ADDR 3933
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01439_FIXPT 0xCF10BFD2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01439_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-820985902)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01439_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01439_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01440_ADDR 3934
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01440_FIXPT 0xA701A7EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01440_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1493063701)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01440_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01440_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01441_ADDR 3935
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01441_FIXPT 0xAC0C2AE5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01441_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1408488731)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01441_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01441_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01442_ADDR 3936
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01442_FIXPT 0x81C26B15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01442_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2117965035)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01442_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01442_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01443_ADDR 3937
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01443_FIXPT 0x0622E149
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01443_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(102949193)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01443_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01443_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01444_ADDR 3938
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01444_FIXPT 0xB21715C7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01444_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1307109945)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01444_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01444_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01445_ADDR 3939
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01445_FIXPT 0x0CF717E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01445_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(217520102)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01445_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01445_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01446_ADDR 3940
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01446_FIXPT 0x66012001
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01446_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1711349761)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01446_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01446_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01447_ADDR 3941
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01447_FIXPT 0xDBC93018
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01447_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-607571944)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01447_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01447_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01448_ADDR 3942
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01448_FIXPT 0xF0262537
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01448_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-265935561)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01448_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01448_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01449_ADDR 3943
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01449_FIXPT 0xF11DABBF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01449_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-249713729)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01449_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01449_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01450_ADDR 3944
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01450_FIXPT 0x81E950E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01450_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2115415837)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01450_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01450_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01451_ADDR 3945
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01451_FIXPT 0xBD00C716
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01451_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1124022506)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01451_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01451_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01452_ADDR 3946
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01452_FIXPT 0x89D64F18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01452_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1982443752)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01452_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01452_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01453_ADDR 3947
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01453_FIXPT 0x93251326
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01453_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1826286810)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01453_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01453_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01454_ADDR 3948
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01454_FIXPT 0xAC2197BC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01454_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1407084612)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01454_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01454_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01455_ADDR 3949
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01455_FIXPT 0x88D9E7E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01455_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1998985241)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01455_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01455_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01456_ADDR 3950
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01456_FIXPT 0x8C05C027
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01456_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1945780185)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01456_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01456_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01457_ADDR 3951
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01457_FIXPT 0xFAE4C313
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01457_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-85671149)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01457_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01457_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01458_ADDR 3952
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01458_FIXPT 0xFD1F1A18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01458_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-48293352)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01458_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01458_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01459_ADDR 3953
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01459_FIXPT 0x462078B9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01459_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1176533177)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01459_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01459_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01460_ADDR 3954
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01460_FIXPT 0x1DCD3BF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01460_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(499989491)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01460_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01460_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01461_ADDR 3955
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01461_FIXPT 0x2D0A5B38
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01461_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(755653432)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01461_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01461_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01462_ADDR 3956
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01462_FIXPT 0xDBEEFA08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01462_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-605095416)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01462_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01462_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01463_ADDR 3957
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01463_FIXPT 0x1F1A160C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01463_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(521803276)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01463_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01463_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01464_ADDR 3958
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01464_FIXPT 0x7718FCB5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01464_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1998126261)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01464_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01464_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01465_ADDR 3959
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01465_FIXPT 0x5CCC8C00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01465_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1556909056)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01465_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01465_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01466_ADDR 3960
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01466_FIXPT 0x7A12A342
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01466_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2048041794)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01466_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01466_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01467_ADDR 3961
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01467_FIXPT 0x43F40EFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01467_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1140068091)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01467_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01467_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01468_ADDR 3962
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01468_FIXPT 0x7714BF00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01468_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1997848320)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01468_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01468_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01469_ADDR 3963
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01469_FIXPT 0xCA0F49B8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01469_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-904967752)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01469_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01469_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01470_ADDR 3964
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01470_FIXPT 0x67D3A90F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01470_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1741924623)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01470_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01470_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01471_ADDR 3965
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01471_FIXPT 0xA81C5944
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01471_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1474537148)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01471_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01471_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01472_ADDR 3966
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01472_FIXPT 0x78F266EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01472_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2029151983)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01472_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01472_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01473_ADDR 3967
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01473_FIXPT 0x290E51F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01473_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(688804341)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01473_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01473_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01474_ADDR 3968
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01474_FIXPT 0x3B0BC8C1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01474_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(990628033)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01474_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01474_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01475_ADDR 3969
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01475_FIXPT 0x9CDCAB1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01475_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1663259874)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01475_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01475_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01476_ADDR 3970
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01476_FIXPT 0xB2200841
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01476_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1306523583)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01476_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01476_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01477_ADDR 3971
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01477_FIXPT 0x71E960E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01477_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1911120104)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01477_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01477_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01478_ADDR 3972
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01478_FIXPT 0xA40589EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01478_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1543140884)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01478_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01478_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01479_ADDR 3973
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01479_FIXPT 0x5A0D09CB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01479_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1510803915)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01479_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01479_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01480_ADDR 3974
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01480_FIXPT 0x5BEA2028
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01480_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1542070312)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01480_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01480_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01481_ADDR 3975
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01481_FIXPT 0xBF1E4D3A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01481_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1088533190)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01481_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01481_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01482_ADDR 3976
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01482_FIXPT 0xB9DF8AE2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01482_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1176532254)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01482_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01482_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01483_ADDR 3977
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01483_FIXPT 0x8BFC54ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01483_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1946397459)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01483_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01483_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01484_ADDR 3978
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01484_FIXPT 0xB91084D5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01484_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1190099755)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01484_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01484_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01485_ADDR 3979
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01485_FIXPT 0x9AFB7128
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01485_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1694797528)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01485_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01485_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01486_ADDR 3980
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01486_FIXPT 0x141DF22E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01486_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(337506862)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01486_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01486_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01487_ADDR 3981
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01487_FIXPT 0x9BD7D8DB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01487_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1680353061)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01487_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01487_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01488_ADDR 3982
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01488_FIXPT 0xBFF90BF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01488_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1074197517)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01488_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01488_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01489_ADDR 3983
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01489_FIXPT 0xA61570E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01489_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1508544285)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01489_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01489_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01490_ADDR 3984
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01490_FIXPT 0x6F048527
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01490_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1862567207)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01490_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01490_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01491_ADDR 3985
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01491_FIXPT 0x7217A420
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01491_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1914151968)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01491_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01491_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01492_ADDR 3986
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01492_FIXPT 0xE3CC58DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01492_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-473147174)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01492_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01492_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01493_ADDR 3987
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01493_FIXPT 0x8BFE1AF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01493_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1946281224)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01493_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01493_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01494_ADDR 3988
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01494_FIXPT 0x64208AE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01494_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1679854313)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01494_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01494_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01495_ADDR 3989
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01495_FIXPT 0xB8082824
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01495_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1207424988)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01495_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01495_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01496_ADDR 3990
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01496_FIXPT 0xAC0D8411
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01496_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1408400367)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01496_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01496_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01497_ADDR 3991
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01497_FIXPT 0x42C287E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01497_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1120045030)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01497_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01497_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01498_ADDR 3992
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01498_FIXPT 0x98003E04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01498_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1744814588)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01498_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01498_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01499_ADDR 3993
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01499_FIXPT 0x062710E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01499_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(103223528)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01499_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01499_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01500_ADDR 3994
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01500_FIXPT 0x350F0919
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01500_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(890177817)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01500_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01500_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01501_ADDR 3995
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01501_FIXPT 0x8804B302
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01501_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2012957950)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01501_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01501_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01502_ADDR 3996
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01502_FIXPT 0xFDC42FF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01502_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-37474317)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01502_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01502_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01503_ADDR 3997
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01503_FIXPT 0xFF037815
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01503_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-16549867)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01503_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01503_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01504_ADDR 3998
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01504_FIXPT 0xC11E2BEA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01504_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1054987286)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01504_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01504_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01505_ADDR 3999
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01505_FIXPT 0x9D119C09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01505_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1659790327)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01505_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01505_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01506_ADDR 4000
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01506_FIXPT 0x26FD97FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01506_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(654153723)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01506_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01506_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01507_ADDR 4001
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01507_FIXPT 0xC9CD0AFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01507_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-909309187)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01507_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01507_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01508_ADDR 4002
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01508_FIXPT 0xB10C531A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01508_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1324592358)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01508_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01508_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01509_ADDR 4003
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01509_FIXPT 0x4916F2EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01509_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1226240748)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01509_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01509_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01510_ADDR 4004
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01510_FIXPT 0xED0C5FF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01510_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-317956103)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01510_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01510_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01511_ADDR 4005
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01511_FIXPT 0xEBFD98F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01511_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-335701768)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01511_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01511_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01512_ADDR 4006
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01512_FIXPT 0xEAD6090B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01512_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-355071733)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01512_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01512_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01513_ADDR 4007
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01513_FIXPT 0x830D4B1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01513_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2096280805)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01513_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01513_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01514_ADDR 4008
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01514_FIXPT 0x100FC1EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01514_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(269468139)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01514_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01514_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01515_ADDR 4009
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01515_FIXPT 0x0E040AF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01515_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(235145969)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01515_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01515_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01516_ADDR 4010
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01516_FIXPT 0x090704F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01516_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(151454961)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01516_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01516_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01517_ADDR 4011
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01517_FIXPT 0xC1E76E14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01517_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1041797612)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01517_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01517_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01518_ADDR 4012
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01518_FIXPT 0x4809141F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01518_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1208554527)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01518_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01518_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01519_ADDR 4013
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01519_FIXPT 0xA0005AE8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01519_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1610589464)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01519_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01519_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01520_ADDR 4014
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01520_FIXPT 0x72FE46F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01520_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1929266933)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01520_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01520_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01521_ADDR 4015
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01521_FIXPT 0xC50A2DEF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01521_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-989188625)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01521_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01521_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01522_ADDR 4016
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01522_FIXPT 0x66F78D13
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01522_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1727499539)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01522_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01522_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01523_ADDR 4017
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01523_FIXPT 0x480A731C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01523_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1208644380)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01523_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01523_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01524_ADDR 4018
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01524_FIXPT 0x52ECC7EA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01524_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1391249386)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01524_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01524_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01525_ADDR 4019
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01525_FIXPT 0xF800B2FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01525_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-134171910)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01525_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01525_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01526_ADDR 4020
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01526_FIXPT 0xB60CF3EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01526_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1240665106)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01526_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01526_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01527_ADDR 4021
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01527_FIXPT 0x31014C10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01527_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(822168592)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01527_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01527_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01528_ADDR 4022
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01528_FIXPT 0x480D370D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01528_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1208825613)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01528_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01528_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01529_ADDR 4023
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01529_FIXPT 0x19E142F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01529_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(434193144)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01529_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01529_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01530_ADDR 4024
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01530_FIXPT 0x9F003103
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01530_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1627377405)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01530_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01530_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01531_ADDR 4025
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01531_FIXPT 0xE30714F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01531_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-486075151)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01531_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01531_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01532_ADDR 4026
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01532_FIXPT 0x6409A90B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01532_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1678354699)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01532_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01532_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01533_ADDR 4027
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01533_FIXPT 0x330A30FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01533_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(856305914)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01533_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01533_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01534_ADDR 4028
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01534_FIXPT 0xC8E95502
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01534_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-924232446)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01534_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01534_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01535_ADDR 4029
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01535_FIXPT 0x38008606
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01535_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(939558406)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01535_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01535_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01536_ADDR 4030
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01536_FIXPT 0x21FF32FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01536_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(570372858)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01536_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01536_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01537_ADDR 4031
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01537_FIXPT 0xDC0C8D03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01537_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-603157245)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01537_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01537_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01538_ADDR 4032
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01538_FIXPT 0x6F00A3F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01538_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1862312949)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01538_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01538_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01539_ADDR 4033
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01539_FIXPT 0x17F8E006
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01539_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(402186246)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01539_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01539_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01540_ADDR 4034
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01540_FIXPT 0x9EFD6804
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01540_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1627559932)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01540_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01540_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01541_ADDR 4035
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01541_FIXPT 0x5DFCEA03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01541_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1576856067)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01541_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01541_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01542_ADDR 4036
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01542_FIXPT 0x7808D3F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01542_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2013844471)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01542_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01542_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01543_ADDR 4037
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01543_FIXPT 0x210122F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01543_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(553722616)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01543_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01543_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01544_ADDR 4038
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01544_FIXPT 0x95059801
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01544_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1794795519)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01544_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01544_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01545_ADDR 4039
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01545_FIXPT 0x25FACC03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01545_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(637193219)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01545_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01545_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01546_ADDR 4040
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01546_FIXPT 0x17FD0D0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01546_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(402459914)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01546_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01546_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01547_ADDR 4041
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01547_FIXPT 0x1EF962FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01547_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(519660285)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01547_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01547_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01548_ADDR 4042
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01548_FIXPT 0xEA019901
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01548_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-368994047)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01548_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01548_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01549_ADDR 4043
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01549_FIXPT 0xB00728F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01549_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1341708045)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01549_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01549_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01550_ADDR 4044
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01550_FIXPT 0x76015BFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01550_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1979800575)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01550_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01550_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01551_ADDR 4045
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01551_FIXPT 0xFE044101
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01551_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-33275647)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01551_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01551_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01552_ADDR 4046
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01552_FIXPT 0x72F6FA05
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01552_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1928788485)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01552_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01552_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01553_ADDR 4047
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01553_FIXPT 0x6C02DF09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01553_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1812127497)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01553_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01553_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01554_ADDR 4048
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01554_FIXPT 0x4CF8BDF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01554_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1291369972)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01554_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01554_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01555_ADDR 4049
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01555_FIXPT 0xA901CCFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01555_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1459499777)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01555_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01555_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01556_ADDR 4050
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01556_FIXPT 0xA10856FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01556_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1593288966)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01556_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01556_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01557_ADDR 4051
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01557_FIXPT 0x76FF3E08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01557_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1996439048)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01557_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01557_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01558_ADDR 4052
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01558_FIXPT 0xA4035503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01558_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1543285501)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01558_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01558_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01559_ADDR 4053
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01559_FIXPT 0xADF056FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01559_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1376758021)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01559_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01559_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01560_ADDR 4054
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01560_FIXPT 0xBCFDBC02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01560_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1124221950)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01560_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01560_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01561_ADDR 4055
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01561_FIXPT 0x2D0CF6F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01561_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(755824376)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01561_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01561_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01562_ADDR 4056
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01562_FIXPT 0x4F0ADC00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01562_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1326111744)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01562_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01562_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01563_ADDR 4057
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01563_FIXPT 0xC1FFD6FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01563_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1040197891)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01563_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01563_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01564_ADDR 4058
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01564_FIXPT 0x3EEDCF01
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01564_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1055772417)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01564_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01564_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01565_ADDR 4059
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01565_FIXPT 0x00FAE70F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01565_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(16443151)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01565_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01565_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01566_ADDR 4060
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01566_FIXPT 0xAE08BFFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01566_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1375158275)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01566_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01566_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01567_ADDR 4061
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01567_FIXPT 0xA9083DF2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01567_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1459077646)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01567_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01567_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01568_ADDR 4062
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01568_FIXPT 0xDF0778F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01568_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-553158414)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01568_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01568_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01569_ADDR 4063
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01569_FIXPT 0x17F4B4FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01569_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(401913086)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01569_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01569_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01570_ADDR 4064
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01570_FIXPT 0xA604FE1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01570_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1509622243)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01570_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01570_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01571_ADDR 4065
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01571_FIXPT 0x79FD0203
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01571_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2046624259)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01571_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01571_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01572_ADDR 4066
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01572_FIXPT 0xB2F11EF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01572_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1292820743)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01572_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01572_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01573_ADDR 4067
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01573_FIXPT 0x330B29E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01573_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(856369639)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01573_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01573_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01574_ADDR 4068
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01574_FIXPT 0x9C00D9FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01574_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1677665795)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01574_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01574_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01575_ADDR 4069
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01575_FIXPT 0xD819FB18
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01575_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-669385960)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01575_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01575_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01576_ADDR 4070
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01576_FIXPT 0x69F129F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01576_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1777412601)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01576_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01576_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01577_ADDR 4071
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01577_FIXPT 0x5DE8C00D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01577_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1575534605)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01577_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01577_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01578_ADDR 4072
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01578_FIXPT 0x03FAB1ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01578_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(66761197)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01578_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01578_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01579_ADDR 4073
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01579_FIXPT 0xEB092906
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01579_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-351721210)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01579_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01579_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01580_ADDR 4074
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01580_FIXPT 0x0D2CBDFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01580_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(221036026)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01580_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01580_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01581_ADDR 4075
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01581_FIXPT 0x8CEAACEB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01581_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1930777365)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01581_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01581_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01582_ADDR 4076
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01582_FIXPT 0xC1F76514
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01582_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1040751340)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01582_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01582_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01583_ADDR 4077
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01583_FIXPT 0x62EA0507
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01583_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1659503879)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01583_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01583_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01584_ADDR 4078
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01584_FIXPT 0x3F04F51D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01584_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1057289501)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01584_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01584_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01585_ADDR 4079
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01585_FIXPT 0xB21D79DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01585_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1306691110)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01585_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01585_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01586_ADDR 4080
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01586_FIXPT 0x64EE69E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01586_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1693346279)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01586_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01586_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01587_ADDR 4081
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01587_FIXPT 0x5E0F020B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01587_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1578041867)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01587_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01587_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01588_ADDR 4082
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01588_FIXPT 0x88F2F510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01588_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1997343472)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01588_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01588_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01589_ADDR 4083
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01589_FIXPT 0xD109EF27
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01589_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-787878105)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01589_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01589_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01590_ADDR 4084
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01590_FIXPT 0x7CECB9D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01590_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2095888856)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01590_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01590_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01591_ADDR 4085
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01591_FIXPT 0x23EFF7F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01591_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(602929139)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01591_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01591_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01592_ADDR 4086
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01592_FIXPT 0xA02804F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01592_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1607990024)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01592_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01592_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01593_ADDR 4087
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01593_FIXPT 0xDC06250B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01593_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-603577077)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01593_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01593_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01594_ADDR 4088
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01594_FIXPT 0x5B10D211
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01594_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1527829009)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01594_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01594_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01595_ADDR 4089
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01595_FIXPT 0xB1C9EAEE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01595_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1312167186)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01595_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01595_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01596_ADDR 4090
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01596_FIXPT 0x51E8B121
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01596_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1374204193)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01596_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01596_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01597_ADDR 4091
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01597_FIXPT 0xE81EE9F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01597_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-400627215)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01597_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01597_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01598_ADDR 4092
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01598_FIXPT 0xB11436F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01598_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1324075272)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01598_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01598_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01599_ADDR 4093
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01599_FIXPT 0xDA19E8E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01599_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-635836189)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01599_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01599_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01600_ADDR 4094
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01600_FIXPT 0xA8D442F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01600_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1462484238)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01600_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01600_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01601_ADDR 4095
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01601_FIXPT 0xBE07213D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01601_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1106828995)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01601_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01601_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01602_ADDR 4096
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01602_FIXPT 0x61FAD505
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01602_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1643828485)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01602_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01602_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01603_ADDR 4097
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01603_FIXPT 0x7CF8EEFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01603_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2096688895)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01603_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01603_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01604_ADDR 4098
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01604_FIXPT 0xFB0973C7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01604_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-83266617)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01604_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01604_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01605_ADDR 4099
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01605_FIXPT 0x55F134FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01605_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1441871103)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01605_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01605_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01606_ADDR 4100
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01606_FIXPT 0xCF33FB25
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01606_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-818676955)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01606_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01606_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01607_ADDR 4101
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01607_FIXPT 0x9BEA6900
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01607_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1679136512)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01607_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01607_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01608_ADDR 4102
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01608_FIXPT 0x06E73613
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01608_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(115815955)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01608_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01608_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01609_ADDR 4103
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01609_FIXPT 0xEFDE41DC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01609_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-270646820)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01609_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01609_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01610_ADDR 4104
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01610_FIXPT 0xBD0C1419
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01610_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1123281895)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01610_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01610_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01611_ADDR 4105
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01611_FIXPT 0x5F4620EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01611_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1598431470)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01611_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01611_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01612_ADDR 4106
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01612_FIXPT 0x20F0D2E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01612_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(552653542)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01612_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01612_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01613_ADDR 4107
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01613_FIXPT 0xD1F88209
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01613_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-772242935)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01613_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01613_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01614_ADDR 4108
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01614_FIXPT 0x88CEFF10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01614_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1999700208)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01614_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01614_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01615_ADDR 4109
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01615_FIXPT 0x620F6941
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01615_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1645177153)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01615_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01615_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01616_ADDR 4110
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01616_FIXPT 0x350ED3D3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01616_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(890164179)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01616_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01616_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01617_ADDR 4111
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01617_FIXPT 0xD2EDADDE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01617_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-756175394)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01617_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01617_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01618_ADDR 4112
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01618_FIXPT 0x681BB3E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01618_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1746645991)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01618_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01618_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01619_ADDR 4113
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01619_FIXPT 0xC4FA101A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01619_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-990244838)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01619_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01619_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01620_ADDR 4114
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01620_FIXPT 0xAB224032
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01620_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1423818702)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01620_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01620_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01621_ADDR 4115
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01621_FIXPT 0xD4CD54E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01621_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-724740895)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01621_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01621_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01622_ADDR 4116
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01622_FIXPT 0xFEDA380C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01622_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-19253236)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01622_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01622_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01623_ADDR 4117
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01623_FIXPT 0x7E1486E9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01623_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2115274473)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01623_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01623_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01624_ADDR 4118
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01624_FIXPT 0xA01F590E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01624_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1608558322)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01624_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01624_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01625_ADDR 4119
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01625_FIXPT 0xBC3426EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01625_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1137432852)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01625_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01625_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01626_ADDR 4120
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01626_FIXPT 0xF1C229E4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01626_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-238933532)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01626_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01626_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01627_ADDR 4121
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01627_FIXPT 0x89F2EB36
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01627_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1980568778)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01627_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01627_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01628_ADDR 4122
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01628_FIXPT 0x6DF4F20F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01628_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1844769295)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01628_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01628_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01629_ADDR 4123
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01629_FIXPT 0x390E621C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01629_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(957243932)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01629_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01629_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01630_ADDR 4124
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01630_FIXPT 0xA00F1DB2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01630_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1609622094)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01630_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01630_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01631_ADDR 4125
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01631_FIXPT 0x3CE039EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01631_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1021327851)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01631_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01631_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01632_ADDR 4126
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01632_FIXPT 0x3338DC1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01632_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(859364381)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01632_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01632_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01633_ADDR 4127
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01633_FIXPT 0xC0F4F112
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01633_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1057689326)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01633_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01633_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01634_ADDR 4128
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01634_FIXPT 0xDEFF4721
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01634_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-553695455)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01634_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01634_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01635_ADDR 4129
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01635_FIXPT 0x7ABDA8CD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01635_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2059249869)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01635_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01635_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01636_ADDR 4130
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01636_FIXPT 0x71F8AA25
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01636_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1912121893)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01636_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01636_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01637_ADDR 4131
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01637_FIXPT 0x834446E9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01637_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2092677399)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01637_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01637_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01638_ADDR 4132
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01638_FIXPT 0xF90737F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01638_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-116967433)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01638_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01638_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01639_ADDR 4133
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01639_FIXPT 0x4A16F5E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01639_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1243018721)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01639_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01639_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01640_ADDR 4134
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01640_FIXPT 0x7BB6F703
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01640_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2075588355)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01640_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01640_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01641_ADDR 4135
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01641_FIXPT 0x79166057
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01641_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2031509591)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01641_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01641_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01642_ADDR 4136
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01642_FIXPT 0xDCF673EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01642_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-587828242)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01642_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01642_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01643_ADDR 4137
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01643_FIXPT 0x71FACEFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01643_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1912262394)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01643_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01643_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01644_ADDR 4138
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01644_FIXPT 0x0001EAB6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01644_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(125622)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01644_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01644_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01645_ADDR 4139
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01645_FIXPT 0x35FF6718
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01645_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(905930520)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01645_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01645_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01646_ADDR 4140
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01646_FIXPT 0x744DA717
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01646_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1951246103)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01646_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01646_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01647_ADDR 4141
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01647_FIXPT 0xC7D2F3FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01647_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-942476294)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01647_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01647_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01648_ADDR 4142
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01648_FIXPT 0x66E5610E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01648_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1726308622)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01648_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01648_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01649_ADDR 4143
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01649_FIXPT 0x78D019F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01649_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2026904048)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01649_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01649_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01650_ADDR 4144
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01650_FIXPT 0x1426EC34
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01650_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(338095156)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01650_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01650_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01651_ADDR 4145
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01651_FIXPT 0xF4320ACB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01651_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-198047029)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01651_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01651_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01652_ADDR 4146
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01652_FIXPT 0xAEEBD6DE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01652_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1360275746)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01652_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01652_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01653_ADDR 4147
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01653_FIXPT 0xF107B2F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01653_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-251153671)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01653_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01653_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01654_ADDR 4148
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01654_FIXPT 0x26E09A2F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01654_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(652253743)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01654_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01654_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01655_ADDR 4149
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01655_FIXPT 0xA51F1A3B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01655_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1524688325)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01655_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01655_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01656_ADDR 4150
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01656_FIXPT 0x47D56BD2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01656_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1205169106)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01656_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01656_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01657_ADDR 4151
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01657_FIXPT 0x0AE222FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01657_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(182592251)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01657_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01657_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01658_ADDR 4152
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01658_FIXPT 0xC61F8CE0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01658_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-971010848)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01658_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01658_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01659_ADDR 4153
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01659_FIXPT 0x6927C616
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01659_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1764214294)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01659_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01659_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01660_ADDR 4154
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01660_FIXPT 0xDF30DBED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01660_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-550446099)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01660_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01660_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01661_ADDR 4155
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01661_FIXPT 0x7FB736E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01661_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2142713574)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01661_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01661_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01662_ADDR 4156
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01662_FIXPT 0xC0F5E135
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01662_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1057627851)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01662_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01662_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01663_ADDR 4157
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01663_FIXPT 0x64F3BB11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01663_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1693694737)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01663_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01663_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01664_ADDR 4158
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01664_FIXPT 0x3C174A1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01664_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1008159259)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01664_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01664_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01665_ADDR 4159
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01665_FIXPT 0xA10793A8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01665_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1593338968)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01665_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01665_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01666_ADDR 4160
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01666_FIXPT 0x26E4C4F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01666_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(652526840)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01666_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01666_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01667_ADDR 4161
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01667_FIXPT 0xFA3B7010
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01667_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-96767984)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01667_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01667_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01668_ADDR 4162
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01668_FIXPT 0x49F74018
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01668_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1240940568)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01668_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01668_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01669_ADDR 4163
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01669_FIXPT 0xBF078112
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01669_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1090027246)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01669_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01669_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01670_ADDR 4164
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01670_FIXPT 0x06AA8BDC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01670_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(111840220)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01670_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01670_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01671_ADDR 4165
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01671_FIXPT 0xF6044F36
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01671_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-167489738)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01671_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01671_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01672_ADDR 4166
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01672_FIXPT 0x582E13E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01672_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1479414753)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01672_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01672_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01673_ADDR 4167
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01673_FIXPT 0x4A130AFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01673_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1242761978)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01673_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01673_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01674_ADDR 4168
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01674_FIXPT 0x511255BA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01674_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1360156090)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01674_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01674_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01675_ADDR 4169
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01675_FIXPT 0x00D59514
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01675_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(13997332)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01675_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01675_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01676_ADDR 4170
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01676_FIXPT 0x1E317D3D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01676_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(506559805)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01676_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01676_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01677_ADDR 4171
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01677_FIXPT 0x4BD88C04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01677_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1272482820)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01677_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01677_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01678_ADDR 4172
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01678_FIXPT 0xF5F47207
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01678_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-168529401)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01678_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01678_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01679_ADDR 4173
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01679_FIXPT 0x86D779CB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01679_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2032698933)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01679_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01679_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01680_ADDR 4174
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01680_FIXPT 0x1121142A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01680_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(287380522)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01680_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01680_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01681_ADDR 4175
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01681_FIXPT 0x09424FDA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01681_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(155340762)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01681_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01681_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01682_ADDR 4176
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01682_FIXPT 0x20F1F7F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01682_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(552728562)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01682_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01682_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01683_ADDR 4177
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01683_FIXPT 0xC4F9E7F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01683_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-990255118)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01683_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01683_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01684_ADDR 4178
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01684_FIXPT 0x38CBEB26
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01684_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(952888102)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01684_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01684_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01685_ADDR 4179
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01685_FIXPT 0xF424243E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01685_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-198958018)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01685_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01685_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01686_ADDR 4180
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01686_FIXPT 0xFAE5C8D9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01686_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-85604135)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01686_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01686_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01687_ADDR 4181
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01687_FIXPT 0x8CF397F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01687_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1930192911)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01687_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01687_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01688_ADDR 4182
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01688_FIXPT 0x000A99D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01688_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(694740)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01688_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01688_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01689_ADDR 4183
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01689_FIXPT 0xFA243122
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01689_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-98291422)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01689_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01689_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01690_ADDR 4184
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01690_FIXPT 0xBE310DF1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01690_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1104081423)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01690_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01690_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01691_ADDR 4185
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01691_FIXPT 0xD8C505F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01691_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-658176524)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01691_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01691_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01692_ADDR 4186
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01692_FIXPT 0xA0EE871D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01692_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1594980579)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01692_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01692_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01693_ADDR 4187
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01693_FIXPT 0x69E4CC19
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01693_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1776602137)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01693_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01693_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01694_ADDR 4188
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01694_FIXPT 0x7B22BF21
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01694_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2065874721)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01694_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01694_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01695_ADDR 4189
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01695_FIXPT 0xA0F7D9B7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01695_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1594369609)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01695_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01695_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01696_ADDR 4190
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01696_FIXPT 0x2EF625F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01696_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(787883506)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01696_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01696_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01697_ADDR 4191
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01697_FIXPT 0x852AE8F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01697_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2060785421)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01697_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01697_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01698_ADDR 4192
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01698_FIXPT 0x360BE020
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01698_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(906747936)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01698_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01698_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01699_ADDR 4193
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01699_FIXPT 0xDC101CFF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01699_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-602923777)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01699_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01699_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01700_ADDR 4194
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01700_FIXPT 0x62B166F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01700_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1655793399)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01700_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01700_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01701_ADDR 4195
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01701_FIXPT 0xD9FB0233
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01701_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-637861325)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01701_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01701_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01702_ADDR 4196
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01702_FIXPT 0x39FE4101
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01702_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(972964097)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01702_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01702_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01703_ADDR 4197
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01703_FIXPT 0x9A1B9B03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01703_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1709466877)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01703_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01703_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01704_ADDR 4198
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01704_FIXPT 0x140103B6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01704_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(335610806)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01704_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01704_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01705_ADDR 4199
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01705_FIXPT 0x8AF53309
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01705_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1963642103)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01705_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01705_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01706_ADDR 4200
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01706_FIXPT 0xAE319F09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01706_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1372479735)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01706_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01706_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01707_ADDR 4201
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01707_FIXPT 0xBFF37F14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01707_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1074561260)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01707_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01707_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01708_ADDR 4202
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01708_FIXPT 0x35F7BE00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01708_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(905428480)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01708_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01708_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01709_ADDR 4203
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01709_FIXPT 0x02BEB0F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01709_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(46051576)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01709_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01709_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01710_ADDR 4204
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01710_FIXPT 0x9C16602C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01710_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1676255188)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01710_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01710_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01711_ADDR 4205
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01711_FIXPT 0x9C13DAE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01711_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1676420378)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01711_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01711_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01712_ADDR 4206
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01712_FIXPT 0xB00D89EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01712_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1341290002)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01712_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01712_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01713_ADDR 4207
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01713_FIXPT 0x3906E9C8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01713_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(956754376)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01713_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01713_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01714_ADDR 4208
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01714_FIXPT 0x8AFFBC1D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01714_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1962951651)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01714_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01714_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01715_ADDR 4209
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01715_FIXPT 0x6B274714
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01715_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1797736212)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01715_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01715_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01716_ADDR 4210
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01716_FIXPT 0xE4DC6704
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01716_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-455317756)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01716_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01716_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01717_ADDR 4211
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01717_FIXPT 0x62EB310A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01717_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1659580682)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01717_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01717_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01718_ADDR 4212
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01718_FIXPT 0x7ED50F03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01718_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2127892227)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01718_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01718_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01719_ADDR 4213
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01719_FIXPT 0x4F1F1622
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01719_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1327437346)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01719_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01719_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01720_ADDR 4214
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01720_FIXPT 0x3B1269D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01720_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(991062484)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01720_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01720_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01721_ADDR 4215
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01721_FIXPT 0x87FCF8EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01721_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2013464337)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01721_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01721_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01722_ADDR 4216
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01722_FIXPT 0x780C40E4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01722_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2014068964)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01722_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01722_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01723_ADDR 4217
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01723_FIXPT 0x9305661F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01723_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1828362721)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01723_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01723_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01724_ADDR 4218
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01724_FIXPT 0x421CD10C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01724_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1109184780)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01724_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01724_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01725_ADDR 4219
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01725_FIXPT 0xC2CDEBFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01725_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1026692102)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01725_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01725_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01726_ADDR 4220
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01726_FIXPT 0x8CF4FD0E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01726_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1930101490)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01726_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01726_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01727_ADDR 4221
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01727_FIXPT 0xB6F1D603
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01727_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1225665021)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01727_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01727_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01728_ADDR 4222
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01728_FIXPT 0x441F7513
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01728_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1142912275)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01728_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01728_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01729_ADDR 4223
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01729_FIXPT 0x4C02EECB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01729_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1275260619)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01729_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01729_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01730_ADDR 4224
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01730_FIXPT 0x97FE8CF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01730_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1744925449)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01730_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01730_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01731_ADDR 4225
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01731_FIXPT 0x291561F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01731_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(689267191)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01731_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01731_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01732_ADDR 4226
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01732_FIXPT 0xD201501D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01732_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-771665891)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01732_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01732_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01733_ADDR 4227
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01733_FIXPT 0x4F075AFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01733_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1325882106)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01733_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01733_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01734_ADDR 4228
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01734_FIXPT 0xB4D20602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01734_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1261304318)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01734_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01734_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01735_ADDR 4229
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01735_FIXPT 0x97FCB819
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01735_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1745045479)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01735_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01735_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01736_ADDR 4230
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01736_FIXPT 0xE7F7D504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01736_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-403188476)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01736_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01736_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01737_ADDR 4231
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01737_FIXPT 0x901593FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01737_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1877634052)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01737_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01737_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01738_ADDR 4232
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01738_FIXPT 0x42F910DB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01738_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1123619035)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01738_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01738_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01739_ADDR 4233
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01739_FIXPT 0x5104F702
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01739_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1359279874)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01739_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01739_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01740_ADDR 4234
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01740_FIXPT 0x0C1804FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01740_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(202900730)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01740_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01740_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01741_ADDR 4235
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01741_FIXPT 0x8606C508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01741_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2046376696)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01741_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01741_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01742_ADDR 4236
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01742_FIXPT 0xA4F6C5FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01742_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1527331333)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01742_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01742_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01743_ADDR 4237
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01743_FIXPT 0x44E3A308
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01743_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1155769096)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01743_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01743_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01744_ADDR 4238
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01744_FIXPT 0xAB044316
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01744_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1425784042)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01744_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01744_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01745_ADDR 4239
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01745_FIXPT 0x06FD3C02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01745_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(117259266)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01745_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01745_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01746_ADDR 4240
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01746_FIXPT 0x99FD91F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01746_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1711435271)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01746_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01746_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01747_ADDR 4241
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01747_FIXPT 0x11FE77EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01747_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(301889516)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01747_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01747_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01748_ADDR 4242
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01748_FIXPT 0x910A9504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01748_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1861577468)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01748_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01748_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01749_ADDR 4243
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01749_FIXPT 0xAB1558FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01749_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1424664324)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01749_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01749_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01750_ADDR 4244
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01750_FIXPT 0xFBFAB5F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01750_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-67455496)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01750_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01750_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01751_ADDR 4245
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01751_FIXPT 0x7AFF1B00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01751_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2063538944)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01751_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01751_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01752_ADDR 4246
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01752_FIXPT 0x04F3E608
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01752_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(83093000)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01752_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01752_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01753_ADDR 4247
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01753_FIXPT 0x0B057D13
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01753_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(184909075)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01753_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01753_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01754_ADDR 4248
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01754_FIXPT 0xF5F501F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01754_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-168492554)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01754_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01754_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01755_ADDR 4249
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01755_FIXPT 0x37FB5F03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01755_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(939220739)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01755_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01755_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01756_ADDR 4250
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01756_FIXPT 0x18003CF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01756_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(402668789)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01756_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01756_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01757_ADDR 4251
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01757_FIXPT 0x5B08F104
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01757_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1527312644)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01757_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01757_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01758_ADDR 4252
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01758_FIXPT 0x400FC9EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01758_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1074776558)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01758_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01758_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01759_ADDR 4253
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01759_FIXPT 0xC7FAC0FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01759_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-939867907)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01759_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01759_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01760_ADDR 4254
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01760_FIXPT 0x900704FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01760_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1878588165)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01760_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01760_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01761_ADDR 4255
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01761_FIXPT 0xBAFBB706
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01761_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157908730)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01761_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01761_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01762_ADDR 4256
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01762_FIXPT 0x2807CF03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01762_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(671600387)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01762_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01762_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01763_ADDR 4257
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01763_FIXPT 0xDCF0ED02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01763_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-588190462)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01763_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01763_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01764_ADDR 4258
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01764_FIXPT 0x87FFC307
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01764_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2013281529)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01764_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01764_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01765_ADDR 4259
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01765_FIXPT 0x93F64602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01765_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1812576766)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01765_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01765_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01766_ADDR 4260
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01766_FIXPT 0xE303F804
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01766_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-486279164)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01766_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01766_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01767_ADDR 4261
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01767_FIXPT 0x7EFACCFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01767_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2130365691)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01767_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01767_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01768_ADDR 4262
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01768_FIXPT 0xE2050001
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01768_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-502988799)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01768_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01768_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01769_ADDR 4263
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01769_FIXPT 0xDDFD56F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01769_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-570599687)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01769_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01769_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01770_ADDR 4264
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01770_FIXPT 0x6906AC00
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01770_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1762044928)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01770_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01770_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01771_ADDR 4265
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01771_FIXPT 0x9CFE99FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01771_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1661036036)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01771_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01771_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01772_ADDR 4266
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01772_FIXPT 0x2B06F806
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01772_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(721876998)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01772_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01772_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01773_ADDR 4267
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01773_FIXPT 0x96F913FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01773_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1762061318)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01773_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01773_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01774_ADDR 4268
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01774_FIXPT 0x89FD8308
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01774_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1979874552)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01774_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01774_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01775_ADDR 4269
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01775_FIXPT 0x11F82800
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01775_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(301475840)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01775_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01775_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01776_ADDR 4270
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01776_FIXPT 0x11007F0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01776_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(285245199)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01776_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01776_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01777_ADDR 4271
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01777_FIXPT 0xDBFE01F3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01777_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-604110349)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01777_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01777_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01778_ADDR 4272
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01778_FIXPT 0x75FA7C02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01778_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1979350018)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01778_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01778_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01779_ADDR 4273
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01779_FIXPT 0x3C0764F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01779_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1007117557)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01779_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01779_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01780_ADDR 4274
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01780_FIXPT 0x62060706
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01780_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1644562182)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01780_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01780_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01781_ADDR 4275
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01781_FIXPT 0x4A139EEC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01781_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1242799852)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01781_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01781_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01782_ADDR 4276
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01782_FIXPT 0xE8F79FF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01782_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-386424840)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01782_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01782_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01783_ADDR 4277
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01783_FIXPT 0x84099100
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01783_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2079747840)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01783_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01783_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01784_ADDR 4278
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01784_FIXPT 0x13FA0F08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01784_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(335154952)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01784_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01784_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01785_ADDR 4279
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01785_FIXPT 0xFA0A5A08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01785_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-99984888)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01785_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01785_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01786_ADDR 4280
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01786_FIXPT 0x2DE671FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01786_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(770077180)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01786_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01786_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01787_ADDR 4281
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01787_FIXPT 0xB9F83611
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01787_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1174915567)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01787_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01787_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01788_ADDR 4282
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01788_FIXPT 0x2DFD5E03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01788_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(771579395)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01788_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01788_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01789_ADDR 4283
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01789_FIXPT 0x7C087F07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01789_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2080931591)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01789_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01789_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01790_ADDR 4284
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01790_FIXPT 0x1AFCA1E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01790_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(452764134)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01790_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01790_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01791_ADDR 4285
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01791_FIXPT 0x66FCEBFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01791_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1727851515)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01791_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01791_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01792_ADDR 4286
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01792_FIXPT 0xEF197EFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01792_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-283541766)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01792_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01792_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01793_ADDR 4287
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01793_FIXPT 0xF30BFDFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01793_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-217317891)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01793_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01793_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01794_ADDR 4288
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01794_FIXPT 0x530335F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01794_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1392719348)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01794_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01794_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01795_ADDR 4289
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01795_FIXPT 0xCAEA58FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01795_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-890611461)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01795_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01795_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01796_ADDR 4290
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01796_FIXPT 0xDF08471E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01796_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-553105634)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01796_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01796_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01797_ADDR 4291
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01797_FIXPT 0x95F95B0B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01797_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1778820341)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01797_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01797_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01798_ADDR 4292
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01798_FIXPT 0x78EF6008
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01798_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2028953608)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01798_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01798_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01799_ADDR 4293
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01799_FIXPT 0x55EBE2F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01799_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1441522416)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01799_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01799_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01800_ADDR 4294
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01800_FIXPT 0x4DFF6018
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01800_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1308581912)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01800_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01800_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01801_ADDR 4295
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01801_FIXPT 0x551ADCF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01801_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1427823863)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01801_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01801_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01802_ADDR 4296
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01802_FIXPT 0xC9FBF1EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01802_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-906235413)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01802_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01802_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01803_ADDR 4297
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01803_FIXPT 0x710F4CE1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01803_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1896828129)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01803_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01803_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01804_ADDR 4298
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01804_FIXPT 0x89FF0103
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01804_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1979776765)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01804_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01804_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01805_ADDR 4299
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01805_FIXPT 0xE526800E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01805_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-450461682)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01805_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01805_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01806_ADDR 4300
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01806_FIXPT 0x20EE93EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01806_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(552506347)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01806_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01806_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01807_ADDR 4301
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01807_FIXPT 0x88F8E80A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01807_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1996953590)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01807_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01807_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01808_ADDR 4302
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01808_FIXPT 0x66E2FA0E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01808_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1726151182)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01808_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01808_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01809_ADDR 4303
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01809_FIXPT 0x1F091733
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01809_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(520689459)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01809_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01809_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01810_ADDR 4304
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01810_FIXPT 0x84F04BE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01810_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2064626711)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01810_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01810_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01811_ADDR 4305
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01811_FIXPT 0x25E4AE07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01811_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(635743751)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01811_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01811_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01812_ADDR 4306
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01812_FIXPT 0x050277F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01812_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(84047860)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01812_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01812_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01813_ADDR 4307
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01813_FIXPT 0x6010A817
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01813_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1611704343)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01813_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01813_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01814_ADDR 4308
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01814_FIXPT 0xE9241ED5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01814_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-383508779)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01814_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01814_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01815_ADDR 4309
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01815_FIXPT 0x1EEB6AE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01815_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(518744806)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01815_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01815_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01816_ADDR 4310
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01816_FIXPT 0xB5185BFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01816_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1256694786)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01816_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01816_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01817_ADDR 4311
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01817_FIXPT 0x68039D0F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01817_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1745067279)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01817_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01817_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01818_ADDR 4312
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01818_FIXPT 0x141D3608
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01818_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(337458696)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01818_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01818_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01819_ADDR 4313
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01819_FIXPT 0x64CADEED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01819_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1691016941)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01819_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01819_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01820_ADDR 4314
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01820_FIXPT 0xDEF1FD2C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01820_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-554566356)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01820_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01820_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01821_ADDR 4315
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01821_FIXPT 0xA8F49214
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01821_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1460366828)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01821_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01821_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01822_ADDR 4316
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01822_FIXPT 0xCB04531E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01822_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-888909026)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01822_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01822_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01823_ADDR 4317
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01823_FIXPT 0x82E215D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01823_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2099112492)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01823_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01823_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01824_ADDR 4318
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01824_FIXPT 0x02ECF511
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01824_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(49083665)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01824_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01824_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01825_ADDR 4319
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01825_FIXPT 0x052D06F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01825_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(86836980)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01825_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01825_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01826_ADDR 4320
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01826_FIXPT 0x1F138DFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01826_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(521375226)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01826_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01826_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01827_ADDR 4321
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01827_FIXPT 0xF01425C6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01827_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-267115066)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01827_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01827_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01828_ADDR 4322
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01828_FIXPT 0xBCE790F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01828_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1125674761)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01828_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01828_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01829_ADDR 4323
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01829_FIXPT 0x8939B714
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01829_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1992706284)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01829_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01829_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01830_ADDR 4324
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01830_FIXPT 0x88FABDFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01830_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1996833282)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01830_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01830_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01831_ADDR 4325
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01831_FIXPT 0x2FFC5400
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01831_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(805065728)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01831_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01831_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01832_ADDR 4326
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01832_FIXPT 0xE8C2B2FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01832_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-389893379)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01832_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01832_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01833_ADDR 4327
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01833_FIXPT 0x35124846
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01833_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(890390598)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01833_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01833_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01834_ADDR 4328
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01834_FIXPT 0xE8F487FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01834_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-386627590)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01834_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01834_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01835_ADDR 4329
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01835_FIXPT 0x72E9FD07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01835_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1927937287)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01835_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01835_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01836_ADDR 4330
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01836_FIXPT 0xDEE4E4DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01836_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-555424550)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01836_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01836_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01837_ADDR 4331
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01837_FIXPT 0x0D135229
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01837_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(219370025)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01837_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01837_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01838_ADDR 4332
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01838_FIXPT 0xDD35F9DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01838_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-583665190)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01838_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01838_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01839_ADDR 4333
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01839_FIXPT 0xACF5BBE0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01839_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1393181728)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01839_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01839_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01840_ADDR 4334
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01840_FIXPT 0xC2110BD3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01840_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1039070253)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01840_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01840_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01841_ADDR 4335
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01841_FIXPT 0xB5086717
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01841_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1257740521)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01841_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01841_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01842_ADDR 4336
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01842_FIXPT 0xB940BC02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01842_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1186939902)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01842_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01842_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01843_ADDR 4337
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01843_FIXPT 0xC1D675E5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01843_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1042909723)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01843_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01843_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01844_ADDR 4338
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01844_FIXPT 0xBCF1DC0E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01844_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1125000178)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01844_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01844_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01845_ADDR 4339
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01845_FIXPT 0xC5E12422
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01845_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-975100894)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01845_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01845_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01846_ADDR 4340
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01846_FIXPT 0x491A1F36
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01846_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1226448694)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01846_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01846_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01847_ADDR 4341
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01847_FIXPT 0x49D147DE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01847_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1238452190)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01847_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01847_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01848_ADDR 4342
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01848_FIXPT 0xBFDA3019
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01848_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1076219879)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01848_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01848_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01849_ADDR 4343
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01849_FIXPT 0xDD011201
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01849_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-587132415)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01849_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01849_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01850_ADDR 4344
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01850_FIXPT 0x341F751F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01850_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(874476831)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01850_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01850_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01851_ADDR 4345
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01851_FIXPT 0x4F12FCB8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01851_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1326644408)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01851_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01851_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01852_ADDR 4346
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01852_FIXPT 0xC1E1C9EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01852_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1042167313)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01852_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01852_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01853_ADDR 4347
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01853_FIXPT 0xE53596F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01853_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-449472779)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01853_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01853_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01854_ADDR 4348
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01854_FIXPT 0x1D1ACE07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01854_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(488295943)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01854_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01854_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01855_ADDR 4349
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01855_FIXPT 0x9D2668D6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01855_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1658427178)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01855_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01855_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01856_ADDR 4350
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01856_FIXPT 0x22C26EEC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01856_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(583167724)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01856_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01856_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01857_ADDR 4351
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01857_FIXPT 0x56212830
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01857_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1445013552)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01857_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01857_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01858_ADDR 4352
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01858_FIXPT 0x08F38313
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01858_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(150176531)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01858_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01858_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01859_ADDR 4353
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01859_FIXPT 0x82036E11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01859_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2113704431)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01859_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01859_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01860_ADDR 4354
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01860_FIXPT 0x47ABF2E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01860_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1202451176)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01860_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01860_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01861_ADDR 4355
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01861_FIXPT 0xF404AD4E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01861_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-201020082)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01861_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01861_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01862_ADDR 4356
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01862_FIXPT 0x3B055CFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01862_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(990207226)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01862_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01862_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01863_ADDR 4357
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01863_FIXPT 0x7AFE2B0C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01863_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2063477516)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01863_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01863_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01864_ADDR 4358
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01864_FIXPT 0x9DDFEFBC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01864_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1646268484)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01864_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01864_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01865_ADDR 4359
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01865_FIXPT 0x240C562D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01865_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(604788269)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01865_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01865_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01866_ADDR 4360
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01866_FIXPT 0xC5422BDC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01866_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-985519140)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01866_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01866_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01867_ADDR 4361
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01867_FIXPT 0x8D0213ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01867_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1929243667)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01867_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01867_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01868_ADDR 4362
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01868_FIXPT 0x8A08E8BC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01868_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1979127620)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01868_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01868_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01869_ADDR 4363
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01869_FIXPT 0x83F95E1E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01869_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2080809442)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01869_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01869_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01870_ADDR 4364
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01870_FIXPT 0x454D5604
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01870_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1162696196)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01870_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01870_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01871_ADDR 4365
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01871_FIXPT 0xFEDC6BF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01871_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-19108877)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01871_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01871_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01872_ADDR 4366
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01872_FIXPT 0x42F2C8F5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01872_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1123207413)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01872_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01872_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01873_ADDR 4367
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01873_FIXPT 0xDCD2BA27
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01873_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-590169561)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01873_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01873_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01874_ADDR 4368
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01874_FIXPT 0x452D6C36
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01874_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1160604726)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01874_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01874_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01875_ADDR 4369
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01875_FIXPT 0xE6CC64ED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01875_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-422812435)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01875_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01875_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01876_ADDR 4370
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01876_FIXPT 0x17DC1510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01876_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(400299280)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01876_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01876_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01877_ADDR 4371
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01877_FIXPT 0x71E45008
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01877_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1910788104)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01877_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01877_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01878_ADDR 4372
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01878_FIXPT 0x1F2C1D32
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01878_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(522984754)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01878_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01878_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01879_ADDR 4373
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01879_FIXPT 0xFCFBB4C3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01879_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-50613053)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01879_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01879_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01880_ADDR 4374
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01880_FIXPT 0xBBE516F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01880_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1142614281)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01880_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01880_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01881_ADDR 4375
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01881_FIXPT 0x091B49E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01881_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(152783336)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01881_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01881_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01882_ADDR 4376
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01882_FIXPT 0xD32F0816
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01882_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-751892458)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01882_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01882_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01883_ADDR 4377
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01883_FIXPT 0x2E29AABD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01883_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(774482621)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01883_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01883_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01884_ADDR 4378
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01884_FIXPT 0x8FD634E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01884_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1881787160)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01884_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01884_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01885_ADDR 4379
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01885_FIXPT 0x522C5A03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01885_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1378638339)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01885_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01885_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01886_ADDR 4380
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01886_FIXPT 0x1D0DE318
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01886_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(487449368)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01886_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01886_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01887_ADDR 4381
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01887_FIXPT 0xD61C85EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01887_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-702773780)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01887_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01887_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01888_ADDR 4382
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01888_FIXPT 0xA2AEB4F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01888_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1565608718)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01888_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01888_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01889_ADDR 4383
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01889_FIXPT 0xC3112D39
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01889_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1022284487)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01889_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01889_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01890_ADDR 4384
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01890_FIXPT 0x7DEFA219
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01890_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2112856601)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01890_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01890_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01891_ADDR 4385
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01891_FIXPT 0xC403F212
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01891_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1006374382)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01891_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01891_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01892_ADDR 4386
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01892_FIXPT 0x87ADAEE2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01892_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2018660638)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01892_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01892_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01893_ADDR 4387
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01893_FIXPT 0x430A0F45
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01893_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1124732741)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01893_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01893_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01894_ADDR 4388
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01894_FIXPT 0x1F09EDF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01894_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(520744439)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01894_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01894_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01895_ADDR 4389
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01895_FIXPT 0x4508B205
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01895_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1158197765)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01895_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01895_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01896_ADDR 4390
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01896_FIXPT 0xC0DDFDBA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01896_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1059193414)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01896_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01896_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01897_ADDR 4391
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01897_FIXPT 0xC514912B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01897_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-988507861)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01897_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01897_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01898_ADDR 4392
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01898_FIXPT 0xFA3AABDA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01898_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-96818214)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01898_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01898_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01899_ADDR 4393
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01899_FIXPT 0x4909ADEF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01899_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1225371119)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01899_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01899_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01900_ADDR 4394
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01900_FIXPT 0x98FF12BA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01900_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1728113990)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01900_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01900_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01901_ADDR 4395
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01901_FIXPT 0x4108F124
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01901_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1091105060)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01901_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01901_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01902_ADDR 4396
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01902_FIXPT 0x8C4537F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01902_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1941620751)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01902_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01902_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01903_ADDR 4397
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01903_FIXPT 0x82E7E7F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01903_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2098731020)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01903_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01903_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01904_ADDR 4398
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01904_FIXPT 0x79F7EAE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01904_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2046290662)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01904_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01904_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01905_ADDR 4399
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01905_FIXPT 0xEFE17030
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01905_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-270438352)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01905_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01905_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01906_ADDR 4400
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01906_FIXPT 0x512FCC1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01906_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1362086939)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01906_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01906_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01907_ADDR 4401
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01907_FIXPT 0x18C887F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01907_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(415795191)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01907_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01907_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01908_ADDR 4402
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01908_FIXPT 0x33E6400D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01908_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(870727693)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01908_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01908_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01909_ADDR 4403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01909_FIXPT 0x9FD87525
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01909_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1613204187)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01909_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01909_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01910_ADDR 4404
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01910_FIXPT 0x1424292E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01910_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(337914158)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01910_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01910_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01911_ADDR 4405
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01911_FIXPT 0x0DD468DC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01911_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(232024284)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01911_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01911_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01912_ADDR 4406
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01912_FIXPT 0x59EB7F0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01912_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1508605709)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01912_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01912_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01913_ADDR 4407
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01913_FIXPT 0x70FB4104
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01913_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1895514372)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01913_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01913_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01914_ADDR 4408
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01914_FIXPT 0x6B2B671C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01914_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1798006556)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01914_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01914_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01915_ADDR 4409
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01915_FIXPT 0x0CFB57BA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01915_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(217798586)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01915_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01915_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01916_ADDR 4410
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01916_FIXPT 0xCDF50AFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01916_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-839578885)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01916_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01916_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01917_ADDR 4411
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01917_FIXPT 0xAD25B2EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01917_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1390038292)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01917_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01917_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01918_ADDR 4412
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01918_FIXPT 0xD8282B0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01918_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-668456179)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01918_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01918_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01919_ADDR 4413
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01919_FIXPT 0x051221B7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01919_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(85074359)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01919_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01919_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01920_ADDR 4414
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01920_FIXPT 0x25EBAFFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01920_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(636203004)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01920_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01920_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01921_ADDR 4415
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01921_FIXPT 0x9A30B7FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01921_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1708083205)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01921_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01921_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01922_ADDR 4416
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01922_FIXPT 0x600DAC11
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01922_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1611508753)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01922_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01922_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01923_ADDR 4417
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01923_FIXPT 0x9709B9D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01923_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1760970280)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01923_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01923_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01924_ADDR 4418
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01924_FIXPT 0x97CC120A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01924_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1748233718)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01924_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01924_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01925_ADDR 4419
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01925_FIXPT 0xA7210A1F
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01925_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1491006945)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01925_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01925_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01926_ADDR 4420
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01926_FIXPT 0xD6EF5B15
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01926_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-688956651)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01926_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01926_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01927_ADDR 4421
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01927_FIXPT 0x94F7C9F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01927_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1795700233)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01927_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01927_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01928_ADDR 4422
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01928_FIXPT 0xBBBE9A0B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01928_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1145136629)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01928_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01928_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01929_ADDR 4423
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01929_FIXPT 0x59199333
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01929_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1494848307)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01929_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01929_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01930_ADDR 4424
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01930_FIXPT 0xA8EB2005
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01930_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1460985851)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01930_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01930_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01931_ADDR 4425
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01931_FIXPT 0x7BF46200
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01931_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2079613440)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01931_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01931_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01932_ADDR 4426
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01932_FIXPT 0xD5CF19FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01932_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-707847685)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01932_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01932_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01933_ADDR 4427
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01933_FIXPT 0x2D1F0C2C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01933_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(757009452)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01933_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01933_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01934_ADDR 4428
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01934_FIXPT 0x06017EE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01934_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(100761321)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01934_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01934_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01935_ADDR 4429
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01935_FIXPT 0x2CFB61F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01935_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(754672118)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01935_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01935_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01936_ADDR 4430
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01936_FIXPT 0xE8F042E4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01936_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-386907420)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01936_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01936_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01937_ADDR 4431
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01937_FIXPT 0x5E26ED1C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01937_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1579609372)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01937_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01937_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01938_ADDR 4432
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01938_FIXPT 0x991B5FD4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01938_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1726259244)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01938_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01938_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01939_ADDR 4433
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01939_FIXPT 0x0CFB35F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01939_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(217789936)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01939_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01939_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01940_ADDR 4434
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01940_FIXPT 0xBD0660E3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01940_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1123655453)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01940_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01940_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01941_ADDR 4435
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01941_FIXPT 0x791E5118
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01941_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2032029976)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01941_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01941_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01942_ADDR 4436
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01942_FIXPT 0x1F220CD7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01942_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(522325207)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01942_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01942_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01943_ADDR 4437
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01943_FIXPT 0x10ECAEF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01943_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(283946742)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01943_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01943_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01944_ADDR 4438
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01944_FIXPT 0x5709EFF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01944_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1460269044)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01944_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01944_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01945_ADDR 4439
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01945_FIXPT 0x0B09F41D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01945_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(185201693)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01945_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01945_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01946_ADDR 4440
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01946_FIXPT 0xB016C2E7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01946_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1340685593)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01946_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01946_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01947_ADDR 4441
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01947_FIXPT 0x72DAD600
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01947_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1926944256)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01947_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01947_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01948_ADDR 4442
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01948_FIXPT 0xE603570C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01948_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-435988724)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01948_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01948_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01949_ADDR 4443
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01949_FIXPT 0xB6F5F522
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01949_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1225394910)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01949_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01949_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01950_ADDR 4444
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01950_FIXPT 0x5C088AFA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01950_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1544063738)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01950_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01950_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01951_ADDR 4445
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01951_FIXPT 0xD1D1C003
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01951_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-774782973)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01951_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01951_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01952_ADDR 4446
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01952_FIXPT 0xE8FF931A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01952_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-385903846)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01952_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01952_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01953_ADDR 4447
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01953_FIXPT 0xFBF09D1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01953_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-68117221)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01953_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01953_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01954_ADDR 4448
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01954_FIXPT 0x5501A2FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01954_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1426170623)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01954_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01954_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01955_ADDR 4449
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01955_FIXPT 0xBDD76FFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01955_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1109954564)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01955_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01955_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01956_ADDR 4450
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01956_FIXPT 0x0705B219
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01956_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(117813785)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01956_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01956_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01957_ADDR 4451
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01957_FIXPT 0x73FA210C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01957_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1945772300)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01957_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01957_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01958_ADDR 4452
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01958_FIXPT 0x8101F1FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01958_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2130578949)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01958_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01958_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01959_ADDR 4453
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01959_FIXPT 0x4CE8D3F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01959_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1290327025)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01959_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01959_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01960_ADDR 4454
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01960_FIXPT 0x870C2912
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01960_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2029246190)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01960_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01960_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01961_ADDR 4455
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01961_FIXPT 0x10089FFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01961_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(269000701)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01961_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01961_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01962_ADDR 4456
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01962_FIXPT 0xFB019EF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01962_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-83779851)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01962_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01962_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01963_ADDR 4457
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01963_FIXPT 0x33FA21EB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01963_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(872030699)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01963_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01963_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01964_ADDR 4458
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01964_FIXPT 0x4D0FDD0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01964_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1292885258)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01964_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01964_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01965_ADDR 4459
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01965_FIXPT 0x841342F4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01965_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2079112460)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01965_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01965_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01966_ADDR 4460
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01966_FIXPT 0xA7FDDCF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01966_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1476535051)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01966_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01966_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01967_ADDR 4461
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01967_FIXPT 0xE303ABEC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01967_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-486298644)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01967_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01967_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01968_ADDR 4462
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01968_FIXPT 0x6B0B5C08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01968_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1795906568)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01968_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01968_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01969_ADDR 4463
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01969_FIXPT 0x7C1620F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01969_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2081825010)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01969_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01969_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01970_ADDR 4464
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01970_FIXPT 0x70F7F1F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01970_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1895297528)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01970_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01970_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01971_ADDR 4465
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01971_FIXPT 0x3A07A4F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01971_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(973579506)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01971_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01971_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01972_ADDR 4466
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01972_FIXPT 0x65047009
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01972_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1694789641)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01972_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01972_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01973_ADDR 4467
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01973_FIXPT 0x8F12E2F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01973_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1894587662)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01973_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01973_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01974_ADDR 4468
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01974_FIXPT 0x0EF427FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01974_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(250882046)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01974_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01974_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01975_ADDR 4469
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01975_FIXPT 0xD706F0F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01975_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-687410952)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01975_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01975_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01976_ADDR 4470
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01976_FIXPT 0x75FEEE0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01976_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1979641354)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01976_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01976_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01977_ADDR 4471
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01977_FIXPT 0x190C2DF6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01977_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(420228598)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01977_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01977_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01978_ADDR 4472
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01978_FIXPT 0xDBF34D02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01978_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-604812030)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01978_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01978_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01979_ADDR 4473
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01979_FIXPT 0x7C05B5FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01979_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2080749052)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01979_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01979_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01980_ADDR 4474
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01980_FIXPT 0x5CFDA00A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01980_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1560125450)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01980_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01980_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01981_ADDR 4475
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01981_FIXPT 0xB705EEF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01981_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1224347913)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01981_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01981_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01982_ADDR 4476
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01982_FIXPT 0x4BF7AD04
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01982_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1274522884)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01982_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01982_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01983_ADDR 4477
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01983_FIXPT 0x3402CDFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01983_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(872599038)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01983_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01983_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01984_ADDR 4478
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01984_FIXPT 0x51FD8009
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01984_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1375567881)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01984_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01984_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01985_ADDR 4479
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01985_FIXPT 0x0DFF3EFB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01985_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(234831611)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01985_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01985_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01986_ADDR 4480
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01986_FIXPT 0x0AFCEB06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01986_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(184347398)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01986_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01986_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01987_ADDR 4481
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01987_FIXPT 0x5EFC79FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01987_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1593604606)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01987_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01987_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01988_ADDR 4482
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01988_FIXPT 0xBAFEC708
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01988_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1157708024)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01988_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01988_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01989_ADDR 4483
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01989_FIXPT 0x4DF9FCFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01989_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1308228862)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01989_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01989_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01990_ADDR 4484
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01990_FIXPT 0xE8FF9009
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01990_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-385904631)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01990_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01990_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01991_ADDR 4485
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01991_FIXPT 0xB2F5C7FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01991_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1292515330)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01991_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01991_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01992_ADDR 4486
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01992_FIXPT 0x8FFF6208
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01992_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1879088632)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01992_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01992_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01993_ADDR 4487
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01993_FIXPT 0x23F65F03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01993_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(603348739)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01993_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01993_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01994_ADDR 4488
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01994_FIXPT 0x6104250A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01994_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1627661578)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01994_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01994_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01995_ADDR 4489
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01995_FIXPT 0xC5EF23FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01995_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-974183425)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01995_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01995_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01996_ADDR 4490
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01996_FIXPT 0xBDFED608
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01996_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1107372536)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01996_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01996_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01997_ADDR 4491
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01997_FIXPT 0x1CF64906
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01997_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(485902598)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01997_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01997_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01998_ADDR 4492
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01998_FIXPT 0x1A078807
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01998_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(436701191)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01998_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01998_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01999_ADDR 4493
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01999_FIXPT 0x43EE4FFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01999_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1139691518)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01999_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT01999_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02000_ADDR 4494
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02000_FIXPT 0x5AFE460A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02000_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1526613514)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02000_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02000_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02001_ADDR 4495
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02001_FIXPT 0x2EF95C08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02001_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(788093960)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02001_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02001_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02002_ADDR 4496
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02002_FIXPT 0x9805CB03
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02002_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1744450813)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02002_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02002_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02003_ADDR 4497
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02003_FIXPT 0xD7EE1FFC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02003_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-672260100)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02003_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02003_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02004_ADDR 4498
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02004_FIXPT 0xB2FCB10C
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02004_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1292062452)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02004_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02004_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02005_ADDR 4499
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02005_FIXPT 0x31FE1E09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02005_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(838737417)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02005_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02005_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02006_ADDR 4500
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02006_FIXPT 0x2A014400
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02006_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(704726016)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02006_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02006_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02007_ADDR 4501
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02007_FIXPT 0xA1F10BF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02007_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1578038279)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02007_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02007_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02008_ADDR 4502
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02008_FIXPT 0x67FC4910
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02008_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1744587024)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02008_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02008_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02009_ADDR 4503
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02009_FIXPT 0xAE058F06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02009_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1375367418)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02009_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02009_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02010_ADDR 4504
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02010_FIXPT 0x5FF99BFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02010_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1610193917)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02010_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02010_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02011_ADDR 4505
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02011_FIXPT 0x4BF65AF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02011_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1274436340)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02011_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02011_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02012_ADDR 4506
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02012_FIXPT 0x9FFEAE13
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02012_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1610699245)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02012_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02012_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02013_ADDR 4507
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02013_FIXPT 0x3D0DC5FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02013_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1024312831)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02013_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02013_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02014_ADDR 4508
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02014_FIXPT 0x72F2A4FC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02014_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1928504572)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02014_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02014_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02015_ADDR 4509
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02015_FIXPT 0x00FDE8EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02015_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(16640239)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02015_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02015_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02016_ADDR 4510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02016_FIXPT 0xE0032613
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02016_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-536664557)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02016_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02016_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02017_ADDR 4511
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02017_FIXPT 0x4717F6F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02017_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1192752882)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02017_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02017_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02018_ADDR 4512
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02018_FIXPT 0xA6EE84FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02018_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1494317830)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02018_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02018_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02019_ADDR 4513
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02019_FIXPT 0x7D0246EF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02019_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2097301231)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02019_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02019_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02020_ADDR 4514
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02020_FIXPT 0x8609F214
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02020_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2046168556)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02020_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02020_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02021_ADDR 4515
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02021_FIXPT 0xC41C2FE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02021_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1004785690)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02021_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02021_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02022_ADDR 4516
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02022_FIXPT 0xBBEDB0F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02022_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1142050569)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02022_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02022_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02023_ADDR 4517
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02023_FIXPT 0xBC0AF8F0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02023_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1140131600)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02023_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02023_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02024_ADDR 4518
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02024_FIXPT 0x070E4214
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02024_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(118374932)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02024_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02024_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02025_ADDR 4519
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02025_FIXPT 0x081C3CDA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02025_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(136068314)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02025_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02025_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02026_ADDR 4520
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02026_FIXPT 0xB0EE4FF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02026_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1326559243)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02026_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02026_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02027_ADDR 4521
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02027_FIXPT 0x05149DF3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02027_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(85237235)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02027_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02027_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02028_ADDR 4522
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02028_FIXPT 0x6D11AF10
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02028_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1829875472)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02028_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02028_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02029_ADDR 4523
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02029_FIXPT 0xAA18FBD2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02029_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1441203246)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02029_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02029_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02030_ADDR 4524
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02030_FIXPT 0x2BEFA6F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02030_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(737126130)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02030_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02030_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02031_ADDR 4525
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02031_FIXPT 0xA12176F6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02031_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1591642378)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02031_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02031_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02032_ADDR 4526
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02032_FIXPT 0x52147608
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02032_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1377072648)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02032_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02032_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02033_ADDR 4527
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02033_FIXPT 0x6F1283CE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02033_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1863484366)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02033_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02033_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02034_ADDR 4528
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02034_FIXPT 0xF5EF7AF4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02034_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-168854796)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02034_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02034_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02035_ADDR 4529
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02035_FIXPT 0x652ED0F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02035_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1697566968)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02035_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02035_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02036_ADDR 4530
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02036_FIXPT 0xBD132BFD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02036_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1122817027)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02036_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02036_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02037_ADDR 4531
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02037_FIXPT 0xC60E9CCF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02037_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-972120881)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02037_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02037_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02038_ADDR 4532
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02038_FIXPT 0x2BEF4FFE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02038_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(737103870)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02038_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02038_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02039_ADDR 4533
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02039_FIXPT 0x263697FB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02039_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(641112059)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02039_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02039_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02040_ADDR 4534
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02040_FIXPT 0x5E0C41F2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02040_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1577861618)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02040_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02040_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02041_ADDR 4535
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02041_FIXPT 0xE60B19D1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02041_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-435480111)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02041_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02041_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02042_ADDR 4536
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02042_FIXPT 0x0FF17F07
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02042_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(267484935)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02042_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02042_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02043_ADDR 4537
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02043_FIXPT 0x293A96FD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02043_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(691705597)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02043_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02043_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02044_ADDR 4538
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02044_FIXPT 0x07FF0EE9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02044_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(134156009)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02044_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02044_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02045_ADDR 4539
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02045_FIXPT 0xCC093AD3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02045_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-871810349)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02045_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02045_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02046_ADDR 4540
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02046_FIXPT 0x99FA9510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02046_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1711631088)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02046_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02046_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02047_ADDR 4541
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02047_FIXPT 0xB23DF6F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02047_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1304561929)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02047_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02047_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02048_ADDR 4542
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02048_FIXPT 0xDDF231E2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02048_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-571330078)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02048_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02048_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02049_ADDR 4543
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02049_FIXPT 0x210B4DDB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02049_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(554388955)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02049_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02049_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02050_ADDR 4544
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02050_FIXPT 0x4D04EB14
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02050_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1292167956)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02050_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02050_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02051_ADDR 4545
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02051_FIXPT 0x853DB3EE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02051_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2059553810)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02051_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02051_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02052_ADDR 4546
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02052_FIXPT 0x8DE717DE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02052_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1914234914)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02052_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02052_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02053_ADDR 4547
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02053_FIXPT 0x9A0EDDE6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02053_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1710301722)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02053_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02053_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02054_ADDR 4548
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02054_FIXPT 0x710E1E17
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02054_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1896750615)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02054_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02054_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02055_ADDR 4549
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02055_FIXPT 0x8037A1E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02055_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2143837722)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02055_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02055_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02056_ADDR 4550
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02056_FIXPT 0xC9DC09DE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02056_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-908326434)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02056_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02056_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02057_ADDR 4551
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02057_FIXPT 0xE414AFF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02057_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-468406281)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02057_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02057_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02058_ADDR 4552
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02058_FIXPT 0xC8112116
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02058_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-938401514)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02058_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02058_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02059_ADDR 4553
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02059_FIXPT 0xBB2C93DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02059_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1154706470)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02059_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02059_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02060_ADDR 4554
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02060_FIXPT 0xCED535E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02060_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-824887839)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02060_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02060_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02061_ADDR 4555
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02061_FIXPT 0xEB237403
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02061_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-349998077)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02061_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02061_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02062_ADDR 4556
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02062_FIXPT 0x1612FB0D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02062_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(370342669)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02062_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02062_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02063_ADDR 4557
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02063_FIXPT 0xAD2271D2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02063_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1390251566)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02063_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02063_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02064_ADDR 4558
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02064_FIXPT 0xF2D1EEEA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02064_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-221122838)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02064_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02064_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02065_ADDR 4559
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02065_FIXPT 0x16351B08
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02065_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(372579080)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02065_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02065_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02066_ADDR 4560
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02066_FIXPT 0x3B0FAD02
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02066_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(990883074)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02066_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02066_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02067_ADDR 4561
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02067_FIXPT 0x4F1AB4C6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02067_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1327150278)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02067_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02067_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02068_ADDR 4562
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02068_FIXPT 0x93D515FA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02068_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1814751750)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02068_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02068_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02069_ADDR 4563
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02069_FIXPT 0xB242CA09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02069_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1304245751)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02069_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02069_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02070_ADDR 4564
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02070_FIXPT 0xBC037FF9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02070_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1140621319)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02070_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02070_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02071_ADDR 4565
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02071_FIXPT 0xE40F3FC1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02071_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-468762687)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02071_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02071_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02072_ADDR 4566
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02072_FIXPT 0x3DE3070D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02072_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1038288653)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02072_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02072_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02073_ADDR 4567
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02073_FIXPT 0x464D38FE
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02073_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1179465982)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02073_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02073_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02074_ADDR 4568
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02074_FIXPT 0xB1FABCEF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02074_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1308967697)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02074_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02074_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02075_ADDR 4569
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02075_FIXPT 0xFA07D4C3
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02075_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-100150077)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02075_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02075_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02076_ADDR 4570
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02076_FIXPT 0xB9F3C81B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02076_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1175205861)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02076_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02076_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02077_ADDR 4571
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02077_FIXPT 0x994D2CF0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02077_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1722995472)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02077_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02077_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02078_ADDR 4572
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02078_FIXPT 0xC3F167E6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02078_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1007589402)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02078_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02078_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02079_ADDR 4573
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02079_FIXPT 0x7204D9CD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02079_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1912920525)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02079_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02079_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02080_ADDR 4574
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02080_FIXPT 0xBA09A626
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02080_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1173772762)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02080_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02080_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02081_ADDR 4575
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02081_FIXPT 0xE744E9E0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02081_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-414914080)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02081_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02081_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02082_ADDR 4576
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02082_FIXPT 0x58E95FDD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02082_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1491689437)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02082_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02082_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02083_ADDR 4577
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02083_FIXPT 0xDE0A48DD
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02083_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-569751331)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02083_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02083_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02084_ADDR 4578
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02084_FIXPT 0x2B1A4726
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02084_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(723142438)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02084_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02084_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02085_ADDR 4579
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02085_FIXPT 0xA93550D0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02085_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1456123696)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02085_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02085_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02086_ADDR 4580
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02086_FIXPT 0x49E117DB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02086_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1239488475)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02086_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02086_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02087_ADDR 4581
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02087_FIXPT 0x541CC3E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02087_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1411171304)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02087_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02087_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02088_ADDR 4582
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02088_FIXPT 0x5127991A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02088_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1361549594)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02088_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02088_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02089_ADDR 4583
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02089_FIXPT 0x7C2AA9C2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02089_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2083170754)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02089_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02089_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02090_ADDR 4584
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02090_FIXPT 0xAEDA93E8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02090_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1361407000)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02090_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02090_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02091_ADDR 4585
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02091_FIXPT 0x772CDDF5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02091_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1999429109)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02091_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02091_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02092_ADDR 4586
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02092_FIXPT 0x49258410
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02092_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1227195408)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02092_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02092_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02093_ADDR 4587
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02093_FIXPT 0xFD1956B2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02093_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-48671054)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02093_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02093_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02094_ADDR 4588
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02094_FIXPT 0x7DDD46FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02094_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2111653631)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02094_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02094_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02095_ADDR 4589
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02095_FIXPT 0x7339E5F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02095_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1933174265)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02095_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02095_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02096_ADDR 4590
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02096_FIXPT 0xEB19E507
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02096_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-350624505)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02096_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02096_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02097_ADDR 4591
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02097_FIXPT 0x9F09C0A6
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02097_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1626750810)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02097_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02097_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02098_ADDR 4592
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02098_FIXPT 0x27F26916
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02098_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(670198038)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02098_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02098_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02099_ADDR 4593
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02099_FIXPT 0x5742DAED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02099_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1463999213)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02099_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02099_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02100_ADDR 4594
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02100_FIXPT 0xDB11C4FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02100_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-619592449)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02100_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02100_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02101_ADDR 4595
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02101_FIXPT 0xCAF6A8AB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02101_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-889804629)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02101_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02101_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02102_ADDR 4596
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02102_FIXPT 0x4809D02A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02102_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1208602666)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02102_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02102_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02103_ADDR 4597
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02103_FIXPT 0x983BB2E1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02103_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1740918047)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02103_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02103_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02104_ADDR 4598
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02104_FIXPT 0x2407BEF8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02104_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(604487416)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02104_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02104_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02105_ADDR 4599
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02105_FIXPT 0xF1E277C5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02105_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-236816443)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02105_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02105_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02106_ADDR 4600
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02106_FIXPT 0xA81D333E
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02106_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1474481346)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02106_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02106_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02107_ADDR 4601
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02107_FIXPT 0x2620E4DA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02107_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(639689946)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02107_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02107_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02108_ADDR 4602
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02108_FIXPT 0xF5FB89F1
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02108_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-168064527)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02108_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02108_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02109_ADDR 4603
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02109_FIXPT 0xFCE3ACDF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02109_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-52187937)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02109_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02109_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02110_ADDR 4604
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02110_FIXPT 0x7F2E533D
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02110_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2133742397)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02110_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02110_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02111_ADDR 4605
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02111_FIXPT 0x2B0421D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02111_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(721691096)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02111_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02111_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02112_ADDR 4606
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02112_FIXPT 0xF1EC39F7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02112_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-236176905)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02112_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02112_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02113_ADDR 4607
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02113_FIXPT 0x98E919FF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02113_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1729553921)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02113_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02113_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02114_ADDR 4608
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02114_FIXPT 0xB3323233
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02114_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1288555981)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02114_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02114_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02115_ADDR 4609
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02115_FIXPT 0x2EEBEED5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02115_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(787214037)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02115_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02115_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02116_ADDR 4610
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02116_FIXPT 0x9CE3B40A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02116_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1662798838)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02116_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02116_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02117_ADDR 4611
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02117_FIXPT 0x09F19018
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02117_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(166826008)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02117_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02117_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02118_ADDR 4612
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02118_FIXPT 0x8F255D27
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02118_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1893376729)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02118_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02118_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02119_ADDR 4613
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02119_FIXPT 0xBBCD69D8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02119_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1144165928)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02119_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02119_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02120_ADDR 4614
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02120_FIXPT 0xBDE81623
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02120_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1108863453)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02120_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02120_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02121_ADDR 4615
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02121_FIXPT 0xD0F60723
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02121_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-789182685)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02121_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02121_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02122_ADDR 4616
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02122_FIXPT 0xD7155E19
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02122_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-686465511)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02122_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02122_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02123_ADDR 4617
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02123_FIXPT 0x37B99FE0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02123_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(934911968)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02123_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02123_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02124_ADDR 4618
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02124_FIXPT 0x35FC8332
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02124_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(905741106)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02124_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02124_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02125_ADDR 4619
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02125_FIXPT 0xB5F5AA21
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02125_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1242191327)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02125_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02125_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02126_ADDR 4620
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02126_FIXPT 0xF6070805
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02126_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-167311355)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02126_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02126_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02127_ADDR 4621
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02127_FIXPT 0x00AD7DF7
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02127_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(11369975)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02127_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02127_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02128_ADDR 4622
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02128_FIXPT 0xCB134936
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02128_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-887928522)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02128_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02128_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02129_ADDR 4623
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02129_FIXPT 0x0DF0DC16
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02129_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(233888790)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02129_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02129_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02130_ADDR 4624
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02130_FIXPT 0x7EFE87EC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02130_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(2130610156)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02130_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02130_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02131_ADDR 4625
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02131_FIXPT 0xEEB83311
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02131_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-289918191)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02131_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02131_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02132_ADDR 4626
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02132_FIXPT 0x5F2B0625
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02132_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1596655141)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02132_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02132_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02133_ADDR 4627
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02133_FIXPT 0xD9EADA09
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02133_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-638920183)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02133_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02133_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02134_ADDR 4628
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02134_FIXPT 0xD5F6D2DC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02134_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-705244452)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02134_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02134_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02135_ADDR 4629
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02135_FIXPT 0x5ED54E23
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02135_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1591037475)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02135_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02135_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02136_ADDR 4630
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02136_FIXPT 0x8F352D0A
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02136_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1892340470)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02136_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02136_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02137_ADDR 4631
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02137_FIXPT 0x25EA10F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02137_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(636096761)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02137_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02137_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02138_ADDR 4632
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02138_FIXPT 0xECF7E2D4
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02138_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-319298860)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02138_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02138_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02139_ADDR 4633
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02139_FIXPT 0x3FFF5528
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02139_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1073698088)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02139_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02139_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02140_ADDR 4634
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02140_FIXPT 0xF4354EE8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02140_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-197832984)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02140_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02140_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02141_ADDR 4635
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02141_FIXPT 0xFFED8DEA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02141_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1208854)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02141_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02141_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02142_ADDR 4636
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02142_FIXPT 0xEF0149DB
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02142_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-285128229)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02142_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02142_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02143_ADDR 4637
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02143_FIXPT 0x6E1DD823
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02143_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1847449635)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02143_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02143_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02144_ADDR 4638
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02144_FIXPT 0xD32663CF
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02144_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-752458801)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02144_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02144_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02145_ADDR 4639
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02145_FIXPT 0xD2EF1DED
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02145_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-756081171)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02145_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02145_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02146_ADDR 4640
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02146_FIXPT 0x220BB3EA
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02146_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(571192298)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02146_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02146_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02147_ADDR 4641
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02147_FIXPT 0x932ABB1B
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02147_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1825916133)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02147_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02147_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02148_ADDR 4642
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02148_FIXPT 0x660ECCC2
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02148_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1712245954)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02148_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02148_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02149_ADDR 4643
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02149_FIXPT 0xC1F640F9
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02149_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1040826119)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02149_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02149_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02150_ADDR 4644
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02150_FIXPT 0x641319F8
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02150_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(1678973432)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02150_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02150_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02151_ADDR 4645
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02151_FIXPT 0x96298510
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02151_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1775663856)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02151_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02151_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02152_ADDR 4646
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02152_FIXPT 0xD2EBE2CC
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02152_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-756292916)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02152_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02152_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02153_ADDR 4647
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02153_FIXPT 0x91FD7112
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02153_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-1845661422)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02153_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02153_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02154_ADDR 4648
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02154_FIXPT 0x860B1607
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02154_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2046093817)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02154_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02154_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02155_ADDR 4649
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02155_FIXPT 0x8419BE06
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02155_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2078687738)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02155_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02155_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02156_ADDR 4650
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02156_FIXPT 0x0BD25CE5
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02156_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(198335717)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02156_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02156_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02157_ADDR 4651
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02157_FIXPT 0x0D05F226
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02157_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(218493478)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02157_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02157_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02158_ADDR 4652
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02158_FIXPT 0x85FAD413
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02158_VALUE SIGMASTUDIOTYPE_INTEGER_CONVERT(-2047159277)
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02158_TYPE SIGMASTUDIOTYPE_INTEGER
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02158_MEMORYPAGE 0
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02159_ADDR 4653
    #define MOD_AUDIOOUT_WAVPLAYER1_ALG0_WAV_DATA_BUFF_OUT02159_FIXPT 0xF0FFE6FC
