Regarding the thermal design of SSM2211
The user inquired about discrepancies in the thermal resistance values (θJC and θJA) for the SSM2211 LFCSP and SOIC_N packages, and the upper limit of the junction temperature range listed as +165°C. The support engineer confirmed that θJC values are valid for LFCSP, measured from the die hottest junction to the top of the package, and acknowledged the lack of recent product thermal data. The +165°C junction temperature limit was not addressed.
Category: Datasheet/Specs
Product Number: SSM2211
Hi.
I have a question related to the package thermal resistance described in the SSM2211 datasheet.
(Data Sheet SSM2211 Rev. G | Page 6 of 24)
1)
Table 5.Thermal Resistance is listed as follows.
If you look closely, you will see that θJC is larger than θJA for the LFCSP package. This does not seem to be correct.
Also, I think the difference between θJA and θJC is too large for SOIC_N package.
I think there is some kind of typo.
I am sorry, but could you please confirm this?
2)
In Table 4, the upper limit of the Junction Temperature Range is listed as +165°C.
This does not seem to be consistent with the descriptions in other parts of the data sheet.
Could you please confirm this point as well?
Thank you in advance.
