Is it feasible to use multiple ADAU7118 (etc) PDM-to-TDM/ converters with the same MCU? How would you manage the PDM clocks?
Each device has 2 clocks, and 8 PDM channels. Could I simply enable only a single clock on one of the devices, and pass it to all mics? Or does each IC need to be using its own clock?
Can you pass a mic clock from your MCU instead, and not use the ADAU7118's PDM clock? Thank you.
(I think I understand the output; will just send a TDM/I2S signal from each IC to a unique SAI block on my MCU, and send the clocks from the MCU to each IC. The confusion is due to the AD ICs supplying the PDM clock instead of the MCU)
Clarified something
[edited by: The Alchemist at 3:21 PM (GMT -5) on 24 Dec 2021]
