SSM2603 serve as a functional replacement for the max9860
Can the SSM2603 serve as a functional replacement for the max9860 if used with the max98307 amplifier?
We are concerned about the output load impedance between these two chips.
Max98307 has 8 ohm input load, ssm2603 has 16 ohm output load. Is that a problem in this case?
