Dear AD Team,
I searched for an existing answer to my question but without success.
I'm new to Sigmastudio and just started programming on an ADAU1466 DSP board.
I'm planning to design a multi-effect with several effects like flanger, chorus, overdrive...etc...in total should be 8 or 9 effects.
Each effect will be inside a dedicated hierarchy block.
Is there any way to allow a configurable execution order of the effects/blocks?
e.g. 1.Overdrive, 2.Flanger, 3.chorus.............-----or---->1.Flanger, 2.Chorus 3.Overdrive................
is it possible to do this using a multiplexer or routing matrix? sorry but it looks not easy to me...
or are there easier ways?
Also is there any way to bypass a block and avoid that the inner content is computed at every cycle, to save processing power?
Many Thanks in advance!
Phil
