I am studying the sigma studio help, the webpage of Loudness (Low and High) External Control [Analog Devices Wiki]
Controls:
LP Knob The LP gain knob controls the relative amount of low frequency boost that is applied 0% - 100%.
LP Frequency The LP frequency spin control lets you change the cutoff frequency of the lowpass filter. The default value approximates the Fletcher-Munson curve. Higher-frequency values provide greater bass-bandwidth gain.
HF Knob The LP gain knob controls the relative amount of high frequency boost that is applied 0% - 100%.
HP Frequency The HF frequency spin control lets you change the cutoff frequency of the highpass filter. The default value of 7kHz approximates the Fletcher-Munson curve.
SW Slew Rate Adjusts the external volume parameter's slew rate (controls how quickly the algorithm responds to changes in the control signal).
I think the content should be the following:
HF Knob The HF gain knob controls the relative amount of high frequency boost that is applied 0% - 100%.
HP Frequency The HP frequency spin control lets you change the cutoff frequency of the highpass filter. The default value of 7kHz approximates the Fletcher-Munson curve.
