About the output of SSM3302
I have a question about SSM3302.
The "INPUT CAPACITOR SELECTION" on page 17 of the data sheet states that an input capacitor is required for single-ended use, and it is recognized that single-ended input can also be used.
Does the SSM3302 output differentially even if a single end is input?
Is it necessary to convert the differential signal to single-ended with a transformer etc. to obtain single-ended output?
I would appreciate it if you could check it.
Best Regards,
Knj
