AD1939 PLL unlocked?
hi,
I used the DEMO of  "21489 AD1939 I2S C Sampled-Based Talkthru", but PLL lock indicator in PLL and Clock Control 1 Register is always UNLOCKED ?  get stuck in an infinite loop, marked in red .
at the same time, SPI is ok, it can write or read from AD1939's Registers.
#define USE_48_KHZ_SAMPLE_RATE
//#define USE_96_KHZ_SAMPLE_RATE
//#define USE_192_KHZ_SAMPLE_RATE
/* Setup the SPI parameters here in a buffer first */
unsigned char ConfigParam1939 [] = {
            (AD1939_ADDR), DACMUTE, 0x00,
            (AD1939_ADDR), CLKCTRL0, DIS_ADC_DAC | INPUT256 | PLL_IN_MCLK | MCLK_OUT_OFF | PLL_PWR_DWN,
            (AD1939_ADDR), CLKCTRL1, DAC_CLK_PLL | ADC_CLK_PLL | DIS_VREF,
#ifdef USE_48_KHZ_SAMPLE_RATE
            (AD1939_ADDR), DACCTRL0, DAC_FMT_I2S | DAC_BCLK_DLY_1 | DAC_SR_48K,
#endif
#ifdef USE_96_KHZ_SAMPLE_RATE
            (AD1939_ADDR), DACCTRL0, DAC_FMT_I2S | DAC_BCLK_DLY_1 | DAC_SR_96K,
#endif
#ifdef USE_192_KHZ_SAMPLE_RATE
            (AD1939_ADDR), DACCTRL0, DAC_FMT_I2S | DAC_BCLK_DLY_1 | DAC_SR_192K,
#endif
          (AD1939_ADDR), DACCTRL1,  DAC_BCLK_SLAVE| DAC_LRCLK_SLAVE  | DAC_CHANNELS_2 | DAC_LATCH_MID, //Ddebug
            (AD1939_ADDR), DACCTRL2, DAC_WIDTH_24,
            (AD1939_ADDR), ADCCTRL0, ADC_SR_48K,
#endif
            (AD1939_ADDR), ADCCTRL0, ADC_SR_96K,
#endif
            (AD1939_ADDR), ADCCTRL0, ADC_SR_192K,
#endif
            (AD1939_ADDR), ADCCTRL1, ADC_LATCH_MID | ADC_FMT_I2S | ADC_BCLK_DLY_1 | ADC_WIDTH_24,
          (AD1939_ADDR), ADCCTRL2, ADC_BCLK_SRC_INTERNAL | ADC_BCLK_MASTER | ADC_CHANNELS_2 | ADC_LRCLK_MASTER  | ADC_LRCLK_FMT_50_50|ADC_LRCLK_POL_NORM|ADC_BCLK_POL_NORM, // NDdebug
          (AD1939_ADDR), DACVOL_L1, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R1, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_L2, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R2, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_L3, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R3, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_L4, DACVOL_MAX,
            (AD1939_ADDR), DACVOL_R4, DACVOL_MAX,
            (AD1939_ADDR), CLKCTRL0, DIS_ADC_DAC | PLL_IN_MCLK | MCLK_OUT_OFF | INPUT256 | PLL_PWR_UP,
            (AD1939_ADDR), CLKCTRL0, ENA_ADC_DAC | PLL_IN_MCLK | MCLK_OUT_OFF | INPUT256 | PLL_PWR_UP,
void Init1939viaSPI()
    int configSize = sizeof(ConfigParam1939);
    int i,j=0 ;
    unsigned char tmpA[sizeof(ConfigParam1939) / 3];
    //Set up AD1939
    SetupSPI1939(AD1939_CS);
    //Write register settings
    for(i = 0; i < configSize-6; i+=3)
        Configure1939Register(ConfigParam1939[i], ConfigParam1939[i+1], ConfigParam1939[i+2], AD1939_CS);
        Delay(272);
        //Read back register settings for debugging
        AD1938_Regs_Read[j++] = Get1939Register(ConfigParam1939[i+1], AD1939_CS);
        Delay(272);
    // Make sure the PLL is locked before enabling the CODEC.
    LockTest = Get1939Register(0x1, AD1939_CS);
    while (!(LockTest & AD1938_PLL_LOCK))
    LockTest = Get1939Register(CLKCTRL1, AD1939_CS);
    LockCount++;
    for(i = configSize-6; i < configSize; i+=3)
        Delay(272);
        Delay(272);
    DisableSPI1939();
Others, I changed the Crystal Oscillator from 12.288MHz to 24MHz, the PLL is ok and locked.
