Hello there,
I am using the AD1939 to drive a differential buffer and would like to know what is the output impedance of the AD1939 in order to adjust my resistors properly. I tried the datasheet but this information is missing.
Thank you,
Fernando.
AD1939
Production
The AD1939 is a high performance, single-chip codec that provides four analog-to-digital converters (ADCs) with differential input, and eight digital-to...
Datasheet
AD1939 on Analog.com
Hello there,
Thank you,
Fernando.
Hello Fernando,
This post has the closest answer for you.
https://ez.analog.com/thread/41549
I have not actually measured the output impedance directly. So the best I can do is to mention that the specifications are measured with a 3k1 ohm load on each pin.
Dave T
Thank you Dave. It was helpful.
