AD1865 N-K chip
I know this chip has been obsolete for some time, but I have a DAC that I had just finished upgrading around the DAC PCB and then the AD1865 chip went bad, either to over-voltage, static discharge, or just for being a fake.
The only sources are in China for this chip at the moment and so there is quite a bit of fakery probably going on.
Is there another current chip in the same package that might work in its place?  I'd hate to waste the PCB for it if I can't find a straight fit replacement.
Thanks much.
whaleman
  • Hello whaleman,
    Unfortunately there is no drop-in replacement for the part. You would have to modify the design to work with a newer DAC.
    Dave T
  • Thank you Dave!
          From: DaveThib <analog@analog-vm.hosted.jivesoftware.com>
    To: ALEX RIVERA <arivera911@yahoo.com>
    Sent: Monday, January 22, 2018 7:43 AM
    Subject: Re:  - Re: AD1865 N-K chip
    #yiv9720310906 * #yiv9720310906 a #yiv9720310906 body {font-family:Helvetica, Arial, sans-serif;}#yiv9720310906 #yiv9720310906 h1, #yiv9720310906 h2, #yiv9720310906 h3, #yiv9720310906 h4, #yiv9720310906 h5, #yiv9720310906 h6, #yiv9720310906 p, #yiv9720310906 hr {}#yiv9720310906 .yiv9720310906button td {}
    Re: AD1865 N-K chip
    reply from DaveThib in Audio - View the full discussionHello whaleman, Unfortunately there is no drop-in replacement for the part. You would have to modify the design to work with a newer DAC. Dave T
    Reply to this message by replying to this email, or go to the message on EngineerZone
    Start a new discussion in Audio by email or at EngineerZone
    Following Re: AD1865 N-K chip in these streams: Inbox
      This email was sent by EngineerZone because you are a registered user.
    You may unsubscribe instantly from EngineerZone, or adjust email frequency in your email preferences   |
