HI all,
With the SSM2142 and 2143 going away, what would be recommended for a new design as a differential audio line driver and receiver?
Need to be able to drive/receive about 5 Vrms
Glenn
SSM2142
Obsolete
The SSM2142 is an integrated differential-output buffer amplifier that converts a single-ended input signal to a balanced output signal pair with high...
Datasheet
SSM2142 on Analog.com
SSM2143
Obsolete
The SSM2143 is an integrated differential amplifier intended to receive balanced line inputs in audio applications requiring a high level of immunity from...
Datasheet
SSM2143 on Analog.com
HI all,
Glenn
Hello Glenn,
I wish I had better news but any suggestions I have would be several IC solutions and not one part. The SSM6322 is a newer part but it is designed for driving headphones so it is not a replacement for the SSM2142/3 parts at all.
My only suggestion is to ask this question in the linear amplifiers section of the forum to see if they have any other solutions.
Dave T
