Datasheet of SSM2166 says maximum input voltage is supply voltage. I'm using 5V supply to the IC. What maximum negative voltage can be applied to AUDIO-IN pin of IC?
It is mentioned in datasheet that there is 1.5V DC shift at AUDIO-IN pin. Do all these together imply that maximum negative input is -1.5V?
Is there any protection circuit internal to the IC?
