ADuCM3029 DC Offset
I am using the ADuCM3029.
While in both the low and high frequency loops,
When I produce a DAC sinusoid output signal, there seems to be a DC offset in the produced signal. In the data sheet it mentions the Vbias to create an offset.
However- is there a configuration setting to remove any DC signal from the sinusoid?
I can attach the DAC data sheet with the configuration of my registers if that helps.
Thank you for the help.
