SPI connection between ADICUP3029 and an IMU
Hi there,
I'm having problems getting the SPI connection working between the ADICUP3029, the master device and the ADIS1640 IMU, the slave.
Before I can get the useful data from the IMU, I'm just trying to get the Product ID from the slave device so that I can confirm the SPI connection is working.
However I can't get any data back when I try to read the SPI register, I believe the issue could be when the adi_spi_MasterReadWrite function is called however I could be possibly missing a step or two somewhere!
I've attached the crosscore project folder and would greatly appreciate if someone would be able to take a look at the code, thanks in advance for your help.
Kind regards,
Matt
Main code is here:
 * ADIS16460.c
#include <sys/platform.h>
#include "adi_initialize.h"
#include "ADIS16460.h"
//#include <adi_timestamp.h>
#include "common.h"
#include "platform_drivers.h"
#include "Timer.h"
#include "math.h"
#define AD7793_COMM_ADR(x)   (((x) & 0x07) << 3)
uint8_t reg_size[8] = {1, 2, 2, 3, 1, 1, 1, 1};
void ADIS16460_WriteRegister(uint8_t ui8address, uint32_t ui32data)
    /* Set value (write command + register address) to write in COMM
     * register */
    uint8_t ui8reg_adrr=0;
    /* Write register value */
    SPI_Write(ui8reg_adrr, ui32data,  2);
   @brief Read register value
   @param ui8address - register address
   @return uint32_t - register value
uint32_t ADIS16460_ReadRegister(uint8_t ui8address)
    /* Set value (read command + register address) to write in COMM register */
	//uint8_t ui8reg_adrr = ((1<<6) | AD7793_COMM_ADR(ui8address));
    /* Read and return register value */
    return SPI_Read(ui8address, 1);
int main(int argc, char *argv[])
	adi_initComponents();
	timer_start();
	/* Begin adding your custom code here */
	SPI_Init();
	//ADIS16460_WriteRegister(0xFF, 0x00);
	uint8_t PROD_ID = 0x56;
	ADIS16460_ReadRegister(PROD_ID);
	//  uint8_t ui8reg_adrr = (AD7793_COMM_READ | AD7793_COMM_ADR(ui8address));
	//return SPI_Read(ui8reg_adrr, reg_size[ui8address]);
	//SPI_Write(ui8reg_adrr, ui32data,  reg_size[ui8address]);
	return 0;
SPI Read function:
uint32_t SPI_Read(uint8_t ui8address, uint8_t ui8bytes)
    uint32_t ui32AdcCodes = 0, status;
    uint8_t size = ui8bytes + 1;
    uint8_t ui8counter, rx_buff[size];
    uint8_t tx_buff[size];
    static uint8_t ui8read_rx;
    tx_buff[0] = ui8address;
    for(ui8counter = 1; ui8counter <= ui8bytes; ui8counter++)
        tx_buff[ui8counter] = 0x01;
    /* Configure SPI telegram */
    spi_telegram.pTransmitter		= tx_buff;
    spi_telegram.TransmitterBytes	= size; /* Transmit 1 byte of address*/
    spi_telegram.nTxIncrement		= 1; /* Address not incremented */
    spi_telegram.pReceiver 			= rx_buff;
    spi_telegram.ReceiverBytes 		= size;
    spi_telegram.nRxIncrement 		= 1; /* No data alignment */
    spi_telegram.bDMA 				= false; /* No DMA */
    spi_telegram.bRD_CTL 			= false; /* Full-duplex */
    /* Transmit register address and receive the read */
    status = adi_spi_MasterReadWrite(p_spi_device_handler,
                                     &spi_telegram);
    if(status != ADI_SPI_SUCCESS)
        return SPI_FAILURE;
    /* Compile data in an 32 bit unsigned integer format */
    for(ui8counter = 1; ui8counter <= ui8bytes; ui8counter++) {
        ui8read_rx = rx_buff[ui8counter];
        ui32AdcCodes = (uint32_t)((ui32AdcCodes << 8) | ui8read_rx);
    return ui32AdcCodes;
.ADIS16460.zip
