ADIChip.ini for ADuCM362/3 is needed
Category: Choose a category
Product Number: ADucm362/3 serial loader
Software Version: cm3wsd version 2
In previous thread, https://ez.analog.com/analog-microcontrollers/precision-microcontrollers/f/discussions/18624/aducm362-adichip-ini-file, it listed a directory to download the cm3wsd, but the link is no longer available.
Can you update me?
I am working with ADuCM362/3 to replace ADuCM360/1
I downloaded cm3wsd from https://ez.analog.com/analog-microcontrollers/precision-microcontrollers/m/file-uploads/348, but when i try to flash it, it ran into an error:
add more info
[edited by: dinrail at 3:15 PM (GMT -4) on 31 Aug 2022]
Parents
    If you go to the folder where CM3WSD is installed you will see an ADIChip.ini file.
    Can you try to copy and paste the [ADuCM360] and [ADuCM361] sections and rename these new sections as [ADuCM362] and [ADuCM363] so it looks like the screenshot below?
    If that works, then you can modify the ROMEnd and RAMEnd to match the particular memory sizes of the silicon you are using..
    Raquel
  • Further testing seems to indicate another problem:
    I am using CM3WSD ver 2.0, 2012
    I added the entry for ADIChip.ini as you instructed
    When I flash it, cm3wsd indicating page of 512 bytes, but the data sheet for ADuCM362 says the page size is 2K, it doesn't seem right to me
Reply Children
No Data
