EVAL-ADUCM355QSPZ - EIS measurement
I want to do EIS measurement by following M355_ECSns_EIS. But the example uses 3 pins.
How do I use it with a 4 electrode sensor to perform EIS measurement?
2 pins for ac excitation (current measurement)
2 pins to read voltage. (voltage measurement)
Thank you
  • I am trying to run M355_ECSns_EIS (3 wire) with the following modifications below to change parameters in specific frequency regions. I found this code and added it because I get incorrect measurements at low frequencies during freq sweep.
    I also added uint32_t SeqWaitAddr[3]; in impedance.h file.
    However when I start the measurement with dummy resistor setup all I get in the output is the text below and nothing else. There's 0 warnings/errors when compiling.
    "This ADuCM355!
    Note: Current Silicon is S2
    AD5940LIB Version:v0.2.0"
    Any help here?
    Copyright (c) 2017-2019 Analog Devices, Inc. All Rights Reserved.
    This software is proprietary to Analog Devices, Inc. and its licensors.
    By using this software you agree to the terms of the associated
    Analog Devices Software License Agreement.
    #include "AD5940.H"
    #include <stdio.h>
    #include "string.h"
    #include "math.h"
    #include "Impedance.h"
    /* Default LPDAC resolution(2.5V internal reference). */
    #define DAC12BITVOLT_1LSB   (2200.0f/4095)  //mV
    #define DAC6BITVOLT_1LSB    (DAC12BITVOLT_1LSB*64)  //mV
    Application configuration structure. Specified by user from template.
    The variables are usable in this whole application.
    It includes basic configuration for sequencer generator and application related parameters
    AppIMPCfg_Type AppIMPCfg =
      .bParaChanged = bFALSE,
      .SeqStartAddr = 0,
      .MaxSeqLen = 0,
      .SeqStartAddrCal = 0,
      .MaxSeqLenCal = 0,
      .ImpODR = 20.0,           /* 20.0 Hz*/
      .NumOfData = -1,
      .SysClkFreq = 16000000.0,
      .WuptClkFreq = 32000.0,
      .AdcClkFreq = 16000000.0,
      .RcalVal = 10000.0,
      .DswitchSel = SWD_CE0,
      .PswitchSel = SWP_CE0,
      .NswitchSel = SWN_SE0LOAD,
      .TswitchSel = SWT_SE0LOAD,
      .PwrMod = AFEPWR_LP,
      .SensorCh0.LptiaRtiaSel = LPTIARTIA_4K, /* COnfigure RTIA */
      .SensorCh0.LpTiaRf = LPTIARF_1M,        /* Configure LPF resistor */
      .SensorCh0.LpTiaRl = LPTIARLOAD_100R,
      .HstiaRtiaSel = HSTIARTIA_1K,
      .ExcitBufGain = EXCITBUFGAIN_0P25,
      .HsDacGain = HSDACGAIN_0P2,
      .HsDacUpdateRate = 0x1B,
      .DacVoltPP = 300.0,
      .BiasVolt = -0.0f,
      .SinFreq = 100000.0, /* 1000Hz */
      .DftNum = DFTNUM_16384,
      .DftSrc = DFTSRC_SINC3,
      .HanWinEn = bTRUE,
      .AdcPgaGain = ADCPGA_1,
      .ADCSinc3Osr = ADCSINC3OSR_2,
      .ADCSinc2Osr = ADCSINC2OSR_22,
      .ADCAvgNum = ADCAVGNUM_16,
      .SweepCfg.SweepEn = bTRUE,
      .SweepCfg.SweepStart = 1000,
      .SweepCfg.SweepStop = 100000.0,
      .SweepCfg.SweepPoints = 101,
      .SweepCfg.SweepLog = bFALSE,
      .SweepCfg.SweepIndex = 0,
      .FifoThresh = 4,
      .IMPInited = bFALSE,
      .StopRequired = bFALSE,
    /* Depending on frequency of Sin wave set optimum filter settings */
    AD5940Err AppIMPCheckFreq(float freq)
      ADCFilterCfg_Type filter_cfg;
      DFTCfg_Type dft_cfg;
      HSDACCfg_Type hsdac_cfg;
      uint32_t WaitClks;
      ClksCalInfo_Type clks_cal;
      FreqParams_Type freq_params;
      uint32_t SeqCmdBuff[32];
      uint32_t SRAMAddr = 0;;
      /* Step 1: Check Frequency */
      freq_params = AD5940_GetFreqParameters(freq);
           if(freq < 0.51)
                /* Update HSDAC update rate */
        hsdac_cfg.ExcitBufGain =EXCITBUFGAIN_2;// AppIMPCfg.ExcitBufGain;
        hsdac_cfg.HsDacGain = HSDACGAIN_1;//AppIMPCfg.HsDacGain;
         hsdac_cfg.HsDacUpdateRate = 0x1B;
        AD5940_HSDacCfgS(&hsdac_cfg);
        AD5940_HSRTIACfgS(HSTIARTIA_40K);
        /*Update ADC rate */
        filter_cfg.ADCRate = ADCRATE_800KHZ;
        AppIMPCfg.AdcClkFreq = 16e6;
        /* Change clock to 16MHz oscillator */
        AD5940_HPModeEn(bFALSE);
            else if(freq < 5 )
    	}else if(freq < 450)
        hsdac_cfg.ExcitBufGain =AppIMPCfg.ExcitBufGain;
        hsdac_cfg.HsDacGain = AppIMPCfg.HsDacGain;
        AD5940_HSRTIACfgS(HSTIARTIA_5K);
           else if(freq<80000)
            /* High power mode */
    	if(freq >= 80000)
        hsdac_cfg.HsDacUpdateRate = 0x07;
        filter_cfg.ADCRate = ADCRATE_1P6MHZ;
        AppIMPCfg.AdcClkFreq = 32e6;
        /* Change clock to 32MHz oscillator */
        AD5940_HPModeEn(bTRUE);
      /* Step 2: Adjust ADCFILTERCON and DFTCON to set optimumn SINC3, SINC2 and DFTNUM settings  */
      filter_cfg.ADCAvgNum = ADCAVGNUM_16;  /* Don't care because it's disabled */
      filter_cfg.ADCSinc2Osr = freq_params.ADCSinc2Osr;
      filter_cfg.ADCSinc3Osr = freq_params.ADCSinc3Osr;
      filter_cfg.BpSinc3 = bFALSE;
      filter_cfg.BpNotch = bTRUE;
      filter_cfg.Sinc2NotchEnable = bTRUE;
      dft_cfg.DftNum = freq_params.DftNum;
      dft_cfg.DftSrc = freq_params.DftSrc;
      dft_cfg.HanWinEn = AppIMPCfg.HanWinEn;
      AD5940_ADCFilterCfgS(&filter_cfg);
      AD5940_DFTCfgS(&dft_cfg);
      /* Step 3: Calculate clocks needed to get result to FIFO and update sequencer wait command */
      clks_cal.DataType = DATATYPE_DFT;
      clks_cal.DftSrc = freq_params.DftSrc;
      clks_cal.DataCount = 1L<<(freq_params.DftNum+2); /* 2^(DFTNUMBER+2) */
      clks_cal.ADCSinc2Osr = freq_params.ADCSinc2Osr;
      clks_cal.ADCSinc3Osr = freq_params.ADCSinc3Osr;
      clks_cal.ADCAvgNum = 0;
      clks_cal.RatioSys2AdcClk = AppIMPCfg.SysClkFreq/AppIMPCfg.AdcClkFreq;
      AD5940_ClksCalculate(&clks_cal, &WaitClks);
    	  SRAMAddr = AppIMPCfg.MeasureSeqInfo.SeqRamAddr + AppIMPCfg.SeqWaitAddr[0];
               SeqCmdBuff[0] =SEQ_WAIT(WaitClks/2);
               SeqCmdBuff[1] =SEQ_WAIT(WaitClks/2);
    		AD5940_SEQCmdWrite(SRAMAddr, SeqCmdBuff, 2);
    		SRAMAddr = AppIMPCfg.MeasureSeqInfo.SeqRamAddr + AppIMPCfg.SeqWaitAddr[1];
                    SRAMAddr = AppIMPCfg.MeasureSeqInfo.SeqRamAddr + AppIMPCfg.SeqWaitAddr[2];
      return AD5940ERR_OK;
    This function is provided for upper controllers that want to change
    application parameters specially for user defined parameters.
    int32_t AppIMPGetCfg(void *pCfg)
      if(pCfg)
        *(AppIMPCfg_Type**)pCfg = &AppIMPCfg;
      return AD5940ERR_PARA;
    int32_t AppIMPCtrl(uint32_t Command, void *pPara)
      switch (Command)
      case IMPCTRL_START:
          WUPTCfg_Type wupt_cfg;
          if(AD5940_WakeUp(10) > 10)  /* Wakup AFE by read register, read 10 times at most */
            return AD5940ERR_WAKEUP;  /* Wakeup Failed */
          if(AppIMPCfg.IMPInited == bFALSE)
            return AD5940ERR_APPERROR;
          /* Start it */
          wupt_cfg.WuptEn = bTRUE;
          wupt_cfg.WuptEndSeq = WUPTENDSEQ_A;
          wupt_cfg.WuptOrder[0] = SEQID_0;
          wupt_cfg.SeqxSleepTime[SEQID_0] = 4;
          wupt_cfg.SeqxWakeupTime[SEQID_0] = (uint32_t)(AppIMPCfg.WuptClkFreq/AppIMPCfg.ImpODR)-4;
          AD5940_WUPTCfg(&wupt_cfg);
          AppIMPCfg.FifoDataCount = 0;  /* restart */
          break;
      case IMPCTRL_STOPNOW:
          /* Start Wupt right now */
          AD5940_WUPTCtrl(bFALSE);
          AD5940_WUPTCtrl(bFALSE);  /* @todo is it sure this will stop Wupt? */
          break;
      case IMPCTRL_STOPSYNC:
          AppIMPCfg.StopRequired = bTRUE;
          break;
      case IMPCTRL_GETFREQ:
          if(pPara == 0)
          if(AppIMPCfg.SweepCfg.SweepEn == bTRUE)
            *(float*)pPara = AppIMPCfg.FreqofData;
          else
            *(float*)pPara = AppIMPCfg.SinFreq;
        break;
      case IMPCTRL_SHUTDOWN:
          AppIMPCtrl(IMPCTRL_STOPNOW, 0);  /* Stop the measurment if it's running. */
          /* Turn off LPloop related blocks which are not controlled automatically by hibernate operation */
          AFERefCfg_Type aferef_cfg;
          LPLoopCfg_Type lploop_cfg;
          memset(&aferef_cfg, 0, sizeof(aferef_cfg));
          AD5940_REFCfgS(&aferef_cfg);
          memset(&lploop_cfg, 0, sizeof(lploop_cfg));
          AD5940_LPLoopCfgS(&lploop_cfg);
          AD5940_EnterSleepS();  /* Enter Hibernate */
        break;
      default:
        break;
    /* generated code snnipet */
    float AppIMPGetCurrFreq(void)
        return AppIMPCfg.FreqofData;
      else
        return AppIMPCfg.SinFreq;
    /* Application initialization */
    static AD5940Err AppIMPSeqCfgGen(void)
      AD5940Err error = AD5940ERR_OK;
      const uint32_t *pSeqCmd;
      uint32_t SeqLen;
      HSLoopCfg_Type HsLoopCfg;
      DSPCfg_Type dsp_cfg;
      float sin_freq;
      /* Start sequence generator here */
      AD5940_SEQGenCtrl(bTRUE);
      AD5940_AFECtrlS(AFECTRL_ALL, bFALSE);  /* Init all to disable state */
      aferef_cfg.HpBandgapEn = bTRUE;
      aferef_cfg.Hp1V1BuffEn = bTRUE;
      aferef_cfg.Hp1V8BuffEn = bTRUE;
      aferef_cfg.Disc1V1Cap = bFALSE;
      aferef_cfg.Disc1V8Cap = bFALSE;
      aferef_cfg.Hp1V8ThemBuff = bFALSE;
      aferef_cfg.Hp1V8Ilimit = bFALSE;
      aferef_cfg.Lp1V1BuffEn = bFALSE;
      aferef_cfg.Lp1V8BuffEn = bFALSE;
      aferef_cfg.LpBandgapEn = bTRUE;
      aferef_cfg.LpRefBufEn = bTRUE;
      aferef_cfg.LpRefBoostEn = bFALSE;
      lploop_cfg.LpDacCfg.LpdacSel = LPDAC0;
      lploop_cfg.LpDacCfg.LpDacSrc = LPDACSRC_MMR;
      lploop_cfg.LpDacCfg.LpDacSW = LPDACSW_VBIAS2LPPA|LPDACSW_VBIAS2PIN|LPDACSW_VZERO2LPTIA|LPDACSW_VZERO2PIN;
      lploop_cfg.LpDacCfg.LpDacVzeroMux = LPDACVZERO_6BIT;
      lploop_cfg.LpDacCfg.LpDacVbiasMux = LPDACVBIAS_12BIT;
      lploop_cfg.LpDacCfg.LpDacRef = LPDACREF_2P5;
      lploop_cfg.LpDacCfg.DataRst = bFALSE;
      lploop_cfg.LpDacCfg.PowerEn = bTRUE;
      lploop_cfg.LpDacCfg.DacData6Bit = (uint32_t)((AppIMPCfg.SensorCh0.Vzero-200)/DAC6BITVOLT_1LSB);
      lploop_cfg.LpDacCfg.DacData12Bit =(int32_t)((AppIMPCfg.SensorCh0.SensorBias)/DAC12BITVOLT_1LSB) + lploop_cfg.LpDacCfg.DacData6Bit*64;
      if(lploop_cfg.LpDacCfg.DacData12Bit>lploop_cfg.LpDacCfg.DacData6Bit*64)
        lploop_cfg.LpDacCfg.DacData12Bit--;
      lploop_cfg.LpAmpCfg.LpAmpSel = LPAMP0;
      lploop_cfg.LpAmpCfg.LpAmpPwrMod = LPAMPPWR_NORM;
      lploop_cfg.LpAmpCfg.LpPaPwrEn = bTRUE;
      lploop_cfg.LpAmpCfg.LpTiaPwrEn = bTRUE;
      lploop_cfg.LpAmpCfg.LpTiaRf = AppIMPCfg.SensorCh0.LpTiaRf;
      lploop_cfg.LpAmpCfg.LpTiaRload = AppIMPCfg.SensorCh0.LpTiaRl;
      lploop_cfg.LpAmpCfg.LpTiaRtia = AppIMPCfg.SensorCh0.LptiaRtiaSel;
      lploop_cfg.LpAmpCfg.LpTiaSW = LPTIASW(5)|LPTIASW(2)|LPTIASW(4)|LPTIASW(12)|LPTIASW(13);
      HsLoopCfg.HsDacCfg.ExcitBufGain = AppIMPCfg.ExcitBufGain;
      HsLoopCfg.HsDacCfg.HsDacGain = AppIMPCfg.HsDacGain;
      HsLoopCfg.HsDacCfg.HsDacUpdateRate = AppIMPCfg.HsDacUpdateRate;
      HsLoopCfg.HsTiaCfg.DiodeClose = bFALSE;
      HsLoopCfg.HsTiaCfg.HstiaBias = HSTIABIAS_1P1;
      HsLoopCfg.HsTiaCfg.HstiaCtia = 31; /* 31pF + 2pF */
      HsLoopCfg.HsTiaCfg.HstiaDeRload = HSTIADERLOAD_OPEN;
      HsLoopCfg.HsTiaCfg.HstiaDeRtia = HSTIADERTIA_OPEN;
      HsLoopCfg.HsTiaCfg.HstiaRtiaSel = AppIMPCfg.HstiaRtiaSel;
      HsLoopCfg.SWMatCfg.Dswitch = SWD_OPEN;
      HsLoopCfg.SWMatCfg.Pswitch = SWP_OPEN;
      HsLoopCfg.SWMatCfg.Nswitch = SWN_OPEN;
      HsLoopCfg.SWMatCfg.Tswitch = SWT_OPEN;
      HsLoopCfg.WgCfg.WgType = WGTYPE_SIN;
      HsLoopCfg.WgCfg.GainCalEn = bTRUE;
      HsLoopCfg.WgCfg.OffsetCalEn = bTRUE;
        AppIMPCfg.FreqofData = AppIMPCfg.SweepCfg.SweepStart;
        AppIMPCfg.SweepCurrFreq = AppIMPCfg.SweepCfg.SweepStart;
        AD5940_SweepNext(&AppIMPCfg.SweepCfg, &AppIMPCfg.SweepNextFreq);
        sin_freq = AppIMPCfg.SweepCurrFreq;
      else
        sin_freq = AppIMPCfg.SinFreq;
        AppIMPCfg.FreqofData = sin_freq;
      HsLoopCfg.WgCfg.SinCfg.SinFreqWord = AD5940_WGFreqWordCal(sin_freq, AppIMPCfg.SysClkFreq);
      HsLoopCfg.WgCfg.SinCfg.SinAmplitudeWord = (uint32_t)(AppIMPCfg.DacVoltPP/800.0f*2047 + 0.5f);
      HsLoopCfg.WgCfg.SinCfg.SinOffsetWord = 0;
      HsLoopCfg.WgCfg.SinCfg.SinPhaseWord = 0;
      AD5940_HSLoopCfgS(&HsLoopCfg);
      dsp_cfg.ADCBaseCfg.ADCMuxN = ADCMUXN_HSTIA_N;
      dsp_cfg.ADCBaseCfg.ADCMuxP = ADCMUXP_HSTIA_P;
      dsp_cfg.ADCBaseCfg.ADCPga = AppIMPCfg.AdcPgaGain;
      memset(&dsp_cfg.ADCDigCompCfg, 0, sizeof(dsp_cfg.ADCDigCompCfg));
      dsp_cfg.ADCFilterCfg.ADCAvgNum = AppIMPCfg.ADCAvgNum;
      dsp_cfg.ADCFilterCfg.ADCRate = ADCRATE_800KHZ;	/* @todo what does this parameter decide */
      dsp_cfg.ADCFilterCfg.ADCSinc2Osr = AppIMPCfg.ADCSinc2Osr;
      dsp_cfg.ADCFilterCfg.ADCSinc3Osr = AppIMPCfg.ADCSinc3Osr;
      dsp_cfg.ADCFilterCfg.BpNotch = bTRUE;
      dsp_cfg.ADCFilterCfg.BpSinc3 = bFALSE;
      dsp_cfg.ADCFilterCfg.Sinc2NotchEnable = bTRUE;
      dsp_cfg.DftCfg.DftNum = AppIMPCfg.DftNum;
      dsp_cfg.DftCfg.DftSrc = AppIMPCfg.DftSrc;
      dsp_cfg.DftCfg.HanWinEn = AppIMPCfg.HanWinEn;
      memset(&dsp_cfg.StatCfg, 0, sizeof(dsp_cfg.StatCfg));
      AD5940_DSPCfgS(&dsp_cfg);
      /* Enable all of them. They are automatically turned off during hibernate mode to save power */
      if(AppIMPCfg.BiasVolt == 0.0f)
        AD5940_AFECtrlS(AFECTRL_HSTIAPWR|AFECTRL_INAMPPWR|AFECTRL_EXTBUFPWR|\
          AFECTRL_WG|AFECTRL_DACREFPWR|AFECTRL_HSDACPWR|\
            AFECTRL_SINC2NOTCH, bTRUE);
      else
            AFECTRL_SINC2NOTCH|AFECTRL_DCBUFPWR, bTRUE);
      /* Sequence end. */
      AD5940_SEQGenInsert(SEQ_STOP()); /* Add one extral command to disable sequencer for initialization sequence because we only want it to run one time. */
      /* Stop here */
      error = AD5940_SEQGenFetchSeq(&pSeqCmd, &SeqLen);
      AD5940_SEQGenCtrl(bFALSE); /* Stop seuqncer generator */
      if(error == AD5940ERR_OK)
        AppIMPCfg.InitSeqInfo.SeqId = SEQID_1;
        AppIMPCfg.InitSeqInfo.SeqRamAddr = AppIMPCfg.SeqStartAddr;
        AppIMPCfg.InitSeqInfo.pSeqCmd = pSeqCmd;
        AppIMPCfg.InitSeqInfo.SeqLen = SeqLen;
        /* Write command to SRAM */
        AD5940_SEQCmdWrite(AppIMPCfg.InitSeqInfo.SeqRamAddr, pSeqCmd, SeqLen);
      else
        return error; /* Error */
    static AD5940Err AppIMPSeqMeasureGen(void)
      uint32_t SeqLen;
      uint32_t WaitClks;
      SWMatrixCfg_Type sw_cfg;
      LPAmpCfg_Type LpAmpCfg;
      /* Calculate number of clocks to get data to FIFO */
      clks_cal.DftSrc = AppIMPCfg.DftSrc;
      clks_cal.DataCount = 1L<<(AppIMPCfg.DftNum+2); /* 2^(DFTNUMBER+2) */
      clks_cal.ADCSinc2Osr = AppIMPCfg.ADCSinc2Osr;
      clks_cal.ADCSinc3Osr = AppIMPCfg.ADCSinc3Osr;
      clks_cal.ADCAvgNum = AppIMPCfg.ADCAvgNum;
      /* Start Sequence Generator */
      AD5940_SEQGpioCtrlS(AGPIO_Pin2); /* Set GPIO1, clear others that under control */
      AD5940_SEQGenInsert(SEQ_WAIT(16*250));  /* @todo wait 250us? */
      /* Disconnect SE0 from LPTIA*/
      LpAmpCfg.LpTiaRtia = LPTIARTIA_OPEN; /* Disconnect Rtia to avoid RC filter discharge */
      LpAmpCfg.LpTiaSW = LPTIASW(7)|LPTIASW(4)|LPTIASW(12)|LPTIASW(13);
      AD5940_LPAMPCfgS(&LpAmpCfg);
      /* Sensor + Rload Measurement */
      sw_cfg.Dswitch = AppIMPCfg.DswitchSel;
      sw_cfg.Pswitch = AppIMPCfg.PswitchSel;
      sw_cfg.Nswitch = AppIMPCfg.NswitchSel;
      sw_cfg.Tswitch = SWT_TRTIA|AppIMPCfg.TswitchSel;
      AD5940_SWMatrixCfgS(&sw_cfg);
      AD5940_AFECtrlS(AFECTRL_ADCPWR|AFECTRL_SINC2NOTCH, bTRUE);  /* Enable Waveform generator */
      //delay for signal settling DFT_WAIT
      AD5940_SEQGenInsert(SEQ_WAIT(16*10));
      AD5940_AFECtrlS(AFECTRL_ADCCNV|AFECTRL_DFT, bTRUE);  /* Start ADC convert and DFT */
      AD5940_SEQGenFetchSeq(NULL, &AppIMPCfg.SeqWaitAddr[0]); /* Record the start address of the next command. */
      AD5940_SEQGenInsert(SEQ_WAIT(WaitClks/2));
      //wait for first data ready
          AFECTRL_SINC2NOTCH|AFECTRL_DFT|AFECTRL_ADCCNV, bFALSE);
      /* RLOAD Measurement */
      sw_cfg.Dswitch = SWD_SE0;
      sw_cfg.Pswitch = SWP_SE0;
      sw_cfg.Nswitch = SWN_SE0LOAD;
      sw_cfg.Tswitch = SWT_SE0LOAD|SWT_TRTIA;
        AFECTRL_WG|AFECTRL_DACREFPWR|AFECTRL_HSDACPWR|AFECTRL_SINC2NOTCH, bTRUE);
      AD5940_SEQGenInsert(SEQ_WAIT(16*10));  //delay for signal settling DFT_WAIT
      AD5940_SEQGenFetchSeq(NULL, &AppIMPCfg.SeqWaitAddr[1]); /* Record the start address of the next command. */
          AFECTRL_SINC2NOTCH|AFECTRL_ADCCNV, bFALSE);
      /* RCAL Measurement */
      sw_cfg.Dswitch = SWD_RCAL0;
      sw_cfg.Pswitch = SWP_RCAL0;
      sw_cfg.Nswitch = SWN_RCAL1;
      sw_cfg.Tswitch = SWT_RCAL1|SWT_TRTIA;
      /* Reconnect LP loop */
      LpAmpCfg.LpTiaRtia = AppIMPCfg.SensorCh0.LptiaRtiaSel; /* Reconnect Rtia */
      LpAmpCfg.LpTiaSW = LPTIASW(5)|LPTIASW(2)|LPTIASW(8)|LPTIASW(12)|LPTIASW(13);
      AD5940_AFECtrlS(AFECTRL_ADCCNV|AFECTRL_DFT/*|AFECTRL_SINC2NOTCH*/, bTRUE);  /* Start ADC convert and DFT */
     AD5940_SEQGenFetchSeq(NULL, &AppIMPCfg.SeqWaitAddr[2]); /* Record the start address of the next command. */
      AD5940_AFECtrlS(AFECTRL_ADCCNV|AFECTRL_DFT|AFECTRL_WG|AFECTRL_ADCPWR, bFALSE);  /* Stop ADC convert and DFT */
          AFECTRL_SINC2NOTCH, bFALSE);
      AD5940_SEQGpioCtrlS(0); /* Clr GPIO1 */
      sw_cfg.Dswitch = SWD_OPEN;
      sw_cfg.Pswitch = SWP_OPEN;
      sw_cfg.Nswitch = SWN_OPEN;
      sw_cfg.Tswitch = SWT_OPEN;
      //AD5940_EnterSleepS();/* Goto hibernate */
      /* Sequence end. */
        AppIMPCfg.MeasureSeqInfo.SeqId = SEQID_0;
        AppIMPCfg.MeasureSeqInfo.SeqRamAddr = AppIMPCfg.InitSeqInfo.SeqRamAddr + AppIMPCfg.InitSeqInfo.SeqLen ;
        AppIMPCfg.MeasureSeqInfo.pSeqCmd = pSeqCmd;
        AppIMPCfg.MeasureSeqInfo.SeqLen = SeqLen;
        AD5940_SEQCmdWrite(AppIMPCfg.MeasureSeqInfo.SeqRamAddr, pSeqCmd, SeqLen);
      else
    /* This function provide application initialize. It can also enable Wupt that will automatically trigger sequence. Or it can configure  */
    int32_t AppIMPInit(uint32_t *pBuffer, uint32_t BufferSize)
      SEQCfg_Type seq_cfg;
      FIFOCfg_Type fifo_cfg;
      /* Configure sequencer and stop it */
      seq_cfg.SeqMemSize = SEQMEMSIZE_2KB;  /* 2kB SRAM is used for sequencer, others for data FIFO */
      seq_cfg.SeqBreakEn = bFALSE;
      seq_cfg.SeqIgnoreEn = bTRUE;
      seq_cfg.SeqCntCRCClr = bTRUE;
      seq_cfg.SeqEnable = bFALSE;
      seq_cfg.SeqWrTimer = 0;
      AD5940_SEQCfg(&seq_cfg);
      /* Reconfigure FIFO */
      AD5940_FIFOCtrlS(FIFOSRC_DFT, bFALSE);									/* Disable FIFO firstly */
      fifo_cfg.FIFOEn = bTRUE;
      fifo_cfg.FIFOMode = FIFOMODE_FIFO;
      fifo_cfg.FIFOSize = FIFOSIZE_4KB;                       /* 4kB for FIFO, The reset 2kB for sequencer */
      fifo_cfg.FIFOSrc = FIFOSRC_DFT;
      fifo_cfg.FIFOThresh = AppIMPCfg.FifoThresh;              /* DFT result. One pair for RCAL, another for Rz. One DFT result have real part and imaginary part */
      AD5940_FIFOCfg(&fifo_cfg);
      AD5940_INTCClrFlag(AFEINTSRC_ALLINT);
      /* Start sequence generator */
      /* Initialize sequencer generator */
      if((AppIMPCfg.IMPInited == bFALSE)||\
        (AppIMPCfg.bParaChanged == bTRUE))
        if(pBuffer == 0)  return AD5940ERR_PARA;
        if(BufferSize == 0) return AD5940ERR_PARA;
        AD5940_SEQGenInit(pBuffer, BufferSize);
        /* Generate initialize sequence */
        error = AppIMPSeqCfgGen(); /* Application initialization sequence using either MCU or sequencer */
        if(error != AD5940ERR_OK) return error;
        /* Generate measurement sequence */
        error = AppIMPSeqMeasureGen();
        AppIMPCfg.bParaChanged = bFALSE; /* Clear this flag as we already implemented the new configuration */
      /* Initialization sequencer  */
      AppIMPCfg.InitSeqInfo.WriteSRAM = bFALSE;
      AD5940_SEQInfoCfg(&AppIMPCfg.InitSeqInfo);
      seq_cfg.SeqEnable = bTRUE;
      AD5940_SEQCfg(&seq_cfg);  /* Enable sequencer */
      AD5940_SEQMmrTrig(AppIMPCfg.InitSeqInfo.SeqId);
      while(AD5940_INTCTestFlag(AFEINTC_1, AFEINTSRC_ENDSEQ) == bFALSE);
      /* Measurment sequence  */
      AppIMPCfg.MeasureSeqInfo.WriteSRAM = bFALSE;
      AD5940_SEQInfoCfg(&AppIMPCfg.MeasureSeqInfo);
      AppIMPCheckFreq(AppIMPCfg.FreqofData);
      AD5940_SEQCfg(&seq_cfg);  /* Enable sequencer, and wait for trigger */
      AD5940_ClrMCUIntFlag();   /* Clear interrupt flag generated before */
      AD5940_AFEPwrBW(AppIMPCfg.PwrMod, AFEBW_250KHZ);
      AppIMPCfg.IMPInited = bTRUE;  /* IMP application has been initialized. */
    /* Modify registers when AFE wakeup */
    int32_t AppIMPRegModify(int32_t * const pData, uint32_t *pDataCount)
      if(AppIMPCfg.NumOfData > 0)
        AppIMPCfg.FifoDataCount += *pDataCount/4;
        if(AppIMPCfg.FifoDataCount >= AppIMPCfg.NumOfData)
      if(AppIMPCfg.StopRequired == bTRUE)
      if(AppIMPCfg.SweepCfg.SweepEn) /* Need to set new frequency and set power mode */
        AD5940_WGFreqCtrlS(AppIMPCfg.SweepNextFreq, AppIMPCfg.SysClkFreq);
        AppIMPCheckFreq(AppIMPCfg.SweepNextFreq);
    /* Depending on the data type, do appropriate data pre-process before return back to controller */
    int32_t AppIMPDataProcess(int32_t * const pData, uint32_t *pDataCount)
      uint32_t DataCount = *pDataCount;
      uint32_t ImpResCount = DataCount/6;
      fImpPol_Type * const pOut = (fImpPol_Type*)pData;
      iImpCar_Type * pSrcData = (iImpCar_Type*)pData;
      *pDataCount = 0;
      DataCount = (DataCount/6)*6;/* We expect Rz+Rload, Rload and RCAL data, . One DFT result has two data in FIFO, real part and imaginary part.  */
      /* Convert DFT result to int32_t type */
      for(uint32_t i=0; i<DataCount; i++)
        pData[i] &= 0x3ffff; /* @todo option to check ECC */
        if(pData[i]&(1L<<17)) /* Bit17 is sign bit */
          pData[i] |= 0xfffc0000; /* Data is 18bit in two's complement, bit17 is the sign bit */
      for(uint32_t i=0; i<ImpResCount; i++)
    //    if(1)
    //      fImpCar_Type DftRcal, DftRzRload, DftRload, temp1, temp2, res;
    //      fImpCar_Type DftConst1 = {1.0f, 0};
    //      The sign of DFT Image result is added '-1' by hardware. Fix it below.
    //      DftRzRload.Real = pSrcData->Real;
    //      DftRzRload.Image = -pSrcData->Image;
    //      pSrcData++;
    //      DftRload.Real = pSrcData->Real;
    //      DftRload.Image = -pSrcData->Image;
    //      pSrcData++;
    //      DftRcal.Real = pSrcData->Real;
    //      DftRcal.Image = -pSrcData->Image;
    //      pSrcData++;
    //      Rz = RloadRz - Rload
    //      RloadRz = DftRcal/DftRzRload*RCAL;
    //      Rload = DftRcal/DftRload*RCAL;
    //      Rz = RloadRz - Rload =
    //      (1/DftRzRload - 1/DftRload)*DftRcal*RCAL;
    //      where RCAL is the RCAL resistor value in Ohm.
    //      //temp1 = 1/DftRzRload;
    //      //temp2 = 1/DftRload;
    //      temp1 = AD5940_ComplexDivFloat(&DftConst1, &DftRzRload);
    //      temp2 = AD5940_ComplexDivFloat(&DftConst1, &DftRload);
    //      res = AD5940_ComplexSubFloat(&temp1, &temp2);
    //      res = AD5940_ComplexMulFloat(&res, &DftRcal);
    //      pOut[i].Magnitude = AD5940_ComplexMag(&res)*AppIMPCfg.RcalVal;
    //      pOut[i].Phase = AD5940_ComplexPhase(&res);
    //    else
          iImpCar_Type *pDftRcal, *pDftRzRload, *pDftRload;
          pDftRzRload = pSrcData++;
          pDftRload = pSrcData++;
          pDftRcal = pSrcData++;
          float RzRloadMag, RzRloadPhase;
          float RloadMag, RloadPhase;
          float RzMag,RzPhase;
          float RcalMag, RcalPhase;
          float RzReal, RzImage;
          RzReal = pDftRload->Real - pDftRzRload->Real;
          RzImage = pDftRload->Image - pDftRzRload->Image;
          RzRloadMag = sqrt((float)pDftRzRload->Real*pDftRzRload->Real+(float)pDftRzRload->Image*pDftRzRload->Image);
          RzRloadPhase = atan2(-pDftRzRload->Image,pDftRzRload->Real);
          RcalMag = sqrt((float)pDftRcal->Real*pDftRcal->Real+(float)pDftRcal->Image*pDftRcal->Image);
          RcalPhase = atan2(-pDftRcal->Image,pDftRcal->Real);
          RzMag = sqrt((float)RzReal*RzReal+(float)RzImage*RzImage);
          RzPhase = atan2(-RzImage,RzReal);
          RloadMag = sqrt((float)pDftRload->Real*pDftRload->Real+(float)pDftRload->Image*pDftRload->Image);
          RloadPhase = atan2(-pDftRload->Image,pDftRload->Real);
          RzMag = (AppIMPCfg.RcalVal*RcalMag*RzMag)/(RzRloadMag*RloadMag);
          RzPhase = -(RcalPhase + RzPhase - RloadPhase - RzRloadPhase);
          // RzPhase = (RcalPhase + RzPhase - RloadPhase - RzRloadPhase);
          pOut[i].Magnitude = RzMag;
          pOut[i].Phase = RzPhase;
      *pDataCount = ImpResCount;
      AppIMPCfg.FreqofData = AppIMPCfg.SweepCurrFreq;
      /* Calculate next frequency point */
        AppIMPCfg.SweepCurrFreq = AppIMPCfg.SweepNextFreq;
      return 0;
    int32_t AppIMPISR(void *pBuff, uint32_t *pCount)
      uint32_t BuffCount;
      uint32_t FifoCnt;
      BuffCount = *pCount;
      *pCount = 0;
      AD5940_SleepKeyCtrlS(SLPKEY_LOCK);  /* Prohibit AFE to enter sleep mode. */
      if(AD5940_INTCTestFlag(AFEINTC_0, AFEINTSRC_DATAFIFOTHRESH) == bTRUE)
        /* Now there should be 4 data in FIFO */
        FifoCnt = (AD5940_FIFOGetCnt()/6)*6;
        if(FifoCnt > BuffCount)
          ///@todo buffer is limited.
        AD5940_FIFORd((uint32_t *)pBuff, FifoCnt);
        AD5940_INTCClrFlag(AFEINTSRC_DATAFIFOTHRESH);
        AppIMPRegModify(pBuff, &FifoCnt);   /* If there is need to do AFE re-configure, do it here when AFE is in active state */
        //AD5940_EnterSleepS(); /* Manually put AFE back to hibernate mode. This operation only takes effect when register value is ACTIVE previously */
        AD5940_SleepKeyCtrlS(SLPKEY_UNLOCK);  /* Allow AFE to enter sleep mode. */
        /* Process data */
        AppIMPDataProcess((int32_t*)pBuff,&FifoCnt);
        *pCount = FifoCnt;
        return 0;
      return 0;
    If you sweeping form very low frequencies,
    start with low impODR (eg., impODR = 0.00001).
    For frequencies<5Hz, you will have to wait for atleast 2 mins for each output.
  • Hi Akila
    I added that in Impedance.c but I'm still not getting output after waiting some minutes. Any idea what's wrong? We're very curious of the results of this uC. Appreciated the help.
    if(freq < 0.51)
    AppIMPCfg.PwrMod = AFEPWR_LP;
    AppIMPCfg.ImpODR = 0.007; //lower value
    Heres my AD5940Main.c
    User could configure following parameters
    #define APPBUFF_SIZE 512
    uint32_t AppBuff[APPBUFF_SIZE];
    int32_t ImpedanceShowResult(uint32_t *pData, uint32_t DataCount)
      float freq;
      fImpPol_Type *pImp = (fImpPol_Type*)pData;
      AppIMPCtrl(IMPCTRL_GETFREQ, &freq);
      printf("Freq:%.2f ", freq);
      /*Process data*/
      for(int i=0;i<DataCount;i++)
        printf("RzMag: %f Ohm , RzPhase: %f \n",pImp[i].Magnitude,pImp[i].Phase*180/MATH_PI);
      return 0;
    static int32_t AD5940PlatformCfg(void)
      CLKCfg_Type clk_cfg;
      AD5940_Initialize();
      /* Platform configuration */
      /* Step1. Configure clock */
      clk_cfg.ADCClkDiv = ADCCLKDIV_1;
      clk_cfg.ADCCLkSrc = ADCCLKSRC_HFOSC;
      clk_cfg.SysClkDiv = SYSCLKDIV_1;
      clk_cfg.SysClkSrc = SYSCLKSRC_HFOSC;
      clk_cfg.HfOSC32MHzMode = bFALSE;
      clk_cfg.HFOSCEn = bTRUE;
      clk_cfg.HFXTALEn = bFALSE;
      clk_cfg.LFOSCEn = bTRUE;
      AD5940_CLKCfg(&clk_cfg);
      /* Step3. Interrupt controller */
      AD5940_INTCCfg(AFEINTC_1, AFEINTSRC_ALLINT, bTRUE);           /* Enable all interrupt in Interrupt Controller 1, so we can check INTC flags */
      AD5940_INTCCfg(AFEINTC_0, AFEINTSRC_DATAFIFOTHRESH, bTRUE);   /* Interrupt Controller 0 will control GP0 to generate interrupt to MCU */
      return 0;
    void AD5940ImpedanceStructInit(void)
      AppIMPCfg_Type *pImpedanceCfg;
      AppIMPGetCfg(&pImpedanceCfg);
      /* Step1: configure initialization sequence Info */
      pImpedanceCfg->SeqStartAddr = 0;
      pImpedanceCfg->MaxSeqLen = 512;
      pImpedanceCfg->RcalVal = 200.0;
      pImpedanceCfg->SinFreq = 60000.0;
      pImpedanceCfg->FifoThresh = 6;
      pImpedanceCfg->ImpODR = 10;                /* 10 Hz output data rate rate */
      /* Configure EC Sensor Parameters */
      /*Sensor is connected to CH0 on EVAL-ADuCM355QSPZ */
      pImpedanceCfg->SensorCh0.LpTiaRf = LPTIARF_1M;         /* 1Mohm Rfilter, 4.7uF cap connected external on AIN4 */
      pImpedanceCfg->SensorCh0.LpTiaRl = LPTIARLOAD_10R;     /* 10ohm Rload */
      pImpedanceCfg->SensorCh0.LptiaRtiaSel = LPTIARTIA_200R;  /* Configure TIA gain resistor*/
      pImpedanceCfg->SensorCh0.Vzero = 1100;                  /* Set Vzero = 1100mV. Voltage on SE0 pin*/
      pImpedanceCfg->SensorCh0.SensorBias = 00;              /* 0V bias voltage */
      /* Set switch matrix to connect to sensor in Ch0 for impedance measurement. */
      pImpedanceCfg->DswitchSel = SWD_CE0;
      pImpedanceCfg->PswitchSel = SWP_RE0;
      pImpedanceCfg->NswitchSel = SWN_SE0LOAD;
      pImpedanceCfg->TswitchSel = SWT_SE0LOAD;
    /* The dummy sensor is as low as 5kOhm. We need to make sure RTIA is
        small enough that HSTIA won't be saturated. */
      pImpedanceCfg->HstiaRtiaSel = HSTIARTIA_200;
      /* Configure the sweep function. */
      pImpedanceCfg->SweepCfg.SweepEn = bTRUE;
      pImpedanceCfg->SweepCfg.SweepStart = 0.1f;	/* Set start frequency*/
      pImpedanceCfg->SweepCfg.SweepStop = 10e3f;	/* Set final frequency */
      pImpedanceCfg->SweepCfg.SweepPoints = 10;		/* Set number of points for sweep*/
      pImpedanceCfg->SweepCfg.SweepLog = bTRUE;
      /* Configure Power Mode. Use HP mode if frequency is higher than 80kHz. */
      pImpedanceCfg->PwrMod = AFEPWR_LP;
      /* Configure filters if necessary */
      pImpedanceCfg->ADCSinc3Osr = ADCSINC3OSR_4;
      pImpedanceCfg->DftNum = DFTNUM_16384;
      pImpedanceCfg->DftSrc = DFTSRC_SINC3;
    void AD5940_Main(void)
      uint32_t temp;
      AD5940PlatformCfg();
      AD5940ImpedanceStructInit();
      /* Initialize the application and configure EC sensor */
      AppIMPInit(AppBuff, APPBUFF_SIZE);
      /* Control IMP measurment to start. Second parameter has no meaning with this command. */
      AppIMPCtrl(IMPCTRL_START, 0);
      while(1)
        if(AD5940_GetMCUIntFlag())
          temp = APPBUFF_SIZE;
          AppIMPISR(AppBuff, &temp);
          ImpedanceShowResult(AppBuff, temp);
    Add it in AD5940Main.c,
  • Akila,
    I put it instead in AD5940Main.c but still no measurements after waiting 30 mins to an hour. Is there anything else I am missing? Let me know if you need to see any more files.
  • Any idea how to fix this? Sorry for the bump.
    Since you are sweeping from 0.1Hz, you may set ODR to lower value and check:
    Example:
    pImpedanceCfg->ImpODR = 0.0001;
  • Hello, I tried this previously with no success (AD5940Main.c). Still no output after waiting even up to an hour. Would appreciate any further ideas.
  • Can anyone provide further support please? Thank you.
