Debugger: mIDAS-Link
IDE: IAR Embedded Workbench
I'm trying out the function of EVAL-ADuCM355QSPZ via firmware provided in aducm355-examples and ad5940lib .
At first everything was normal and the measurement results were correct (including M355_ECSns_EIS and M355_GPIO), but when I change to another example, the downloading process fails.
Output log:
Sat Aug 06, 2022 16:39:50: IAR Embedded Workbench 9.30.1 (D:\software\arm\bin\
armPROC.dll)
Sat Aug 06, 2022 16:39:50: JLINK command: ProjectFile = D:\SenseUs\ADuCM355\
aducm355-examples-master\examples\ApplicationExamples\M355_ECSns_EIS\iar\
settings\M355_ECSns_EIS_Debug.jlink, return = 0
Sat Aug 06, 2022 16:39:50: Device "ADUCM355" selected.
Sat Aug 06, 2022 16:39:50: DLL version: V7.70 , compiled Aug 3 2022 17:20:31
Sat Aug 06, 2022 16:39:50: Firmware: J-Link V11 compiled Jul 22 2022 10:21:23
Sat Aug 06, 2022 16:39:50: Selecting SWD as current target interface.
Sat Aug 06, 2022 16:39:50: JTAG speed is initially set to: 1000 kHz
Sat Aug 06, 2022 16:39:50: ConfigTargetSettings() start
Sat Aug 06, 2022 16:39:50: Disabling flash programming optimizations: Compare,
SkipBlankDataOnProg and flash breakpoints
Sat Aug 06, 2022 16:39:50: ConfigTargetSettings() end
Sat Aug 06, 2022 16:39:50: Found SW-DP with ID 0x2BA01477
Sat Aug 06, 2022 16:39:50: DPIDR: 0x2BA01477
Sat Aug 06, 2022 16:39:50: CoreSight SoC-400 or earlier
Sat Aug 06, 2022 16:39:50: Scanning AP map to find all available APs
Sat Aug 06, 2022 16:39:50: AP[1]: Stopped AP scan as end of AP map has been
reached
Sat Aug 06, 2022 16:39:50: AP[0]: AHB-AP (IDR: 0x24770011)
Sat Aug 06, 2022 16:39:50: Iterating through AP map to find AHB-AP to use
Sat Aug 06, 2022 16:39:50: AP[0]: Core found
Sat Aug 06, 2022 16:39:50: AP[0]: AHB-AP ROM base: 0xE00FF000
Sat Aug 06, 2022 16:39:50: CPUID register: 0x412FC231. Implementer code: 0x41
(ARM)
Sat Aug 06, 2022 16:39:50: Found Cortex-M3 r2p1, Little endian.
Sat Aug 06, 2022 16:39:50: FPUnit: 2 code (BP) slots and 0 literal slots
Sat Aug 06, 2022 16:39:50: CoreSight components:
Sat Aug 06, 2022 16:39:50: ROMTbl[0] @ E00FF000
Sat Aug 06, 2022 16:39:50: [0][0]: E000E000 CID B105E00D PID 000BB000 SCS
Sat Aug 06, 2022 16:39:50: [0][1]: E0001000 CID B105E00D PID 003BB002 DWT
Sat Aug 06, 2022 16:39:50: [0][2]: E0002000 CID B105E00D PID 002BB003 FPB
Sat Aug 06, 2022 16:39:50: ResetTarget() start
Sat Aug 06, 2022 16:39:50: Core did not halt after reset, manually halting CPU...
Sat Aug 06, 2022 16:39:50: CPU could not be halted
Sat Aug 06, 2022 16:39:50: CPU did not halt after reset.
Sat Aug 06, 2022 16:39:50: ResetTarget() end
Sat Aug 06, 2022 16:39:50: Warning: Failed to halt CPU.
Sat Aug 06, 2022 16:39:50: Hardware reset with strategy 8 was performed
Sat Aug 06, 2022 16:39:50: Initial reset was performed
Sat Aug 06, 2022 16:39:57: IAR Embedded Workbench 9.30.1 (D:\software\arm\bin\
armPROC.dll)
Sat Aug 06, 2022 16:39:57: Loading the J-Link Driver driver
I tried out resetting the MCU in J-Link commander, but the same error appears (CPU did not halt after reset.).
Is this a hardware failure? How can I solve the problem?
Thanks
