AD5940 Self Test RE/CE
I use the RE/CE option for feedback to make 3 terminal measurements in standard operating mode.  I'd like to be able to do a self-test where I do 2 terminal measurement of the RE/CE terminals.
Is this possible?  It looks like the N and T switches can't do either CE or RE, but can I push it through the crossbar in a different way?
No real accuracy requirements in this self-test mode, so it's fine if it has to route through extra internal resistances / etc.
    The AD5940_impedance example does 2 electrode impedance measurement.
    Switch settings:
    .DswitchSel = SWD_CE0,
    .PswitchSel = SWP_CE0,
    .NswitchSel = SWN_AIN1,
    .TswitchSel = SWT_AIN1
    If you are using AD5940ELCZ eval board, you may set the jumpers as below:
    JP9=JP10=JP11 = Position B (pin 3-4)
    You will obtain the impedance output magnitude as
    6.8KOhm if JP6 = Position A,
    or 750Ohm if JP6 = Position B.
  • Sorry, this does not answer my question.
    For the majority of the measurements I'm using 3 terminal mode.  This uses CE, RE, and AIN1.
    I want to be able to know if CE or RE have failed in some way.  Therefore I want a second type of measurement that does a two terminal measurement between CE and RE
    I was surprised that I could not directly measure CE to RE on the analog mux and would like to know if there is still a way to take this measurement by some other means.  I had assumed that this type of self test would be used for most 3 terminal setups, and was surprised that it wasn't directly supported.
