AD594x Low power switches
I am developing a amperometric electrochemical sensor system using a AD5940 analog front-end. My application requires sensing two sensors per measuring cycle .
I would like to use a switch pin as the AFE1/2/3 or the DE0 pin, but from the documentation those switches are used on the high speed loop, and my application focus on the low power mode.
My question is there a way to use some of those pins to access the low power TIA , or is there a way to use the low power loop sensing one sensor and the high power loop with fixed bias sensing the second sensor?
Thanks
