Warning CPU could not be halted (EVAL-,ADuCM355QSPZ, IAR, Midas-Link
Hi All,
I have just received a EVAL-,ADuCM355QSPZ evaluation board, installed the latest IAR ARM EW 8.40.1 and Segger JLink for Windows (V656a) and am having terrible difficulty with repeated 'Warning CPU could not be halted' messages, as well as other messages like verification failures, could not start CPU core (errorcode -1) and CPU is not halted (when attempting to pause execution).
Powering via USB cable. Also tried using a Segger J-Trace with same results - and I know that this is a good J-Trace as I have used (and continue to use) this with other ARM processors.. Running standard samples that can be downloaded for this evaluation board.Tried slowing down connect (as can be seen in logs below).
Would have thought that this would be an easy 'out-of-the-box' evaluation. Any help appreciated!
Debug log information:
Fri Dec 06, 2019 09:59:03: IAR Embedded Workbench 8.40.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench ARM 8.40.1\arm\bin\armproc.dll)
Fri Dec 06, 2019 09:59:03: JLINK command: ProjectFile = C:\Crowcon\ProjWork\ADuCM355\Software\settings\M355_ECSns_DCTest_Debug.jlink, return = 0
Fri Dec 06, 2019 09:59:03: Device "ADUCM355" selected.
Fri Dec 06, 2019 09:59:03: DLL version: V6.56a, compiled Nov 25 2019 17:05:33
Fri Dec 06, 2019 09:59:03: Firmware: J-Link V10 compiled Nov  8 2019 16:40:12
Fri Dec 06, 2019 09:59:03: Selecting SWD as current target interface.
Fri Dec 06, 2019 09:59:03: JTAG speed is fixed to: 100 kHz
Fri Dec 06, 2019 09:59:04: Hardware reset with strategy 3 was performed
Fri Dec 06, 2019 09:59:04: Initial reset was performed
Fri Dec 06, 2019 09:59:05: Found SW-DP with ID 0x2BA01477
Fri Dec 06, 2019 09:59:05: Scanning AP map to find all available APs
Fri Dec 06, 2019 09:59:05: AP[1]: Stopped AP scan as end of AP map has been reached
Fri Dec 06, 2019 09:59:05: AP[0]: AHB-AP (IDR: 0x24770011)
Fri Dec 06, 2019 09:59:05: Iterating through AP map to find AHB-AP to use
Fri Dec 06, 2019 09:59:05: AP[0]: Core found
Fri Dec 06, 2019 09:59:05: AP[0]: AHB-AP ROM base: 0xE00FF000
Fri Dec 06, 2019 09:59:05: CPUID register: 0x412FC231. Implementer code: 0x41 (ARM)
Fri Dec 06, 2019 09:59:05: Found Cortex-M3 r2p1, Little endian.
Fri Dec 06, 2019 09:59:05: FPUnit: 2 code (BP) slots and 0 literal slots
Fri Dec 06, 2019 09:59:05: CoreSight components:
Fri Dec 06, 2019 09:59:05: ROMTbl[0] @ E00FF000
Fri Dec 06, 2019 09:59:05: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB000 SCS
Fri Dec 06, 2019 09:59:05: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
Fri Dec 06, 2019 09:59:05: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
Fri Dec 06, 2019 09:59:06: 928 bytes downloaded and verified (1.16 Kbytes/sec)
Fri Dec 06, 2019 09:59:06: Warning: Verify error, failed to read memory at address 0x10000000 - 0x1000005F
Fri Dec 06, 2019 09:59:06: Verify error at address 0x10000000, target byte: 0xAA, byte in file: 0x70
<< Similar messages deleted>>
Fri Dec 06, 2019 09:59:06: Verify error at address 0x1000005E, target byte: 0xAA, byte in file: 0x00
Fri Dec 06, 2019 09:59:06: Verify error at address 0x1000005F, target byte: 0xAA, byte in file: 0x10
Fri Dec 06, 2019 09:59:06: Warning: Verify error, failed to read memory at address 0x10000100 - 0x1000043F
Fri Dec 06, 2019 09:59:06: Verify error at address 0x10000168, target byte: 0xAA, byte in file: 0x16
Fri Dec 06, 2019 09:59:06: Warning: Too many verify errors, only the first 200 are displayed
Fri Dec 06, 2019 09:59:09: Fatal error: There were warnings during download of FLASH loader, see Log Window   Session aborted!
Fri Dec 06, 2019 09:59:09: Failed to load flash loader: C:\Program Files (x86)\IAR Systems\Embedded Workbench ARM 8.40.1\arm\config\flashloader\AnalogDevices\FlashADUCM355.out
Fri Dec 06, 2019 09:59:16: IAR Embedded Workbench 8.40.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench ARM 8.40.1\arm\bin\armproc.dll)
Next log for 'CPU is not halted':
Fri Dec 06, 2019 10:00:58: IAR Embedded Workbench 8.40.1 (C:\Program Files (x86)\IAR Systems\Embedded Workbench ARM 8.40.1\arm\bin\armproc.dll)
Fri Dec 06, 2019 10:00:58: JLINK command: ProjectFile = C:\Crowcon\ProjWork\ADuCM355\Software\settings\M355_ECSns_DCTest_Debug.jlink, return = 0
Fri Dec 06, 2019 10:00:58: Device "ADUCM355" selected.
Fri Dec 06, 2019 10:00:58: DLL version: V6.56a, compiled Nov 25 2019 17:05:33
Fri Dec 06, 2019 10:00:58: Firmware: J-Link V10 compiled Nov  8 2019 16:40:12
Fri Dec 06, 2019 10:00:58: Selecting SWD as current target interface.
Fri Dec 06, 2019 10:00:58: JTAG speed is fixed to: 100 kHz
Fri Dec 06, 2019 10:00:58: Found SW-DP with ID 0x2BA01477
Fri Dec 06, 2019 10:00:58: Scanning AP map to find all available APs
Fri Dec 06, 2019 10:00:58: AP[1]: Stopped AP scan as end of AP map has been reached
Fri Dec 06, 2019 10:00:58: AP[0]: AHB-AP (IDR: 0x24770011)
Fri Dec 06, 2019 10:00:58: Iterating through AP map to find AHB-AP to use
Fri Dec 06, 2019 10:00:58: AP[0]: Core found
Fri Dec 06, 2019 10:00:58: AP[0]: AHB-AP ROM base: 0xE00FF000
Fri Dec 06, 2019 10:00:58: CPUID register: 0x412FC231. Implementer code: 0x41 (ARM)
Fri Dec 06, 2019 10:00:58: Found Cortex-M3 r2p1, Little endian.
Fri Dec 06, 2019 10:00:58: FPUnit: 2 code (BP) slots and 0 literal slots
Fri Dec 06, 2019 10:00:58: CoreSight components:
Fri Dec 06, 2019 10:00:58: ROMTbl[0] @ E00FF000
Fri Dec 06, 2019 10:00:58: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB000 SCS
Fri Dec 06, 2019 10:00:58: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
Fri Dec 06, 2019 10:00:58: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
Fri Dec 06, 2019 10:00:59: Hardware reset with strategy 3 was performed
Fri Dec 06, 2019 10:00:59: Initial reset was performed
Fri Dec 06, 2019 10:00:59: 13103 bytes with download suppressed
Fri Dec 06, 2019 10:00:59: Loaded debugee: C:\Crowcon\ProjWork\ADuCM355\Software\Debug\Exe\M355_ECSns_DCTest.out
Fri Dec 06, 2019 10:00:59: Software reset was performed
Fri Dec 06, 2019 10:00:59: Target reset
