Can't run my application in ADuCM331
Can't run my application in ADuCM331.
Using Attached example file in IAR, after compile the source without warning and error, downloading to target board(exactly EVAL-ADUCM331QSPZ). And the target worked well.
And then, in attached example file I checked 'exclude from build' option to bootloader_331.c, tog.c and  I added my application, compiling without error, downloading but the target does not work even though the application work well in Keil. In IAR with debug mode, I can checked the appication goes to BusFault_Handler or Hard_Fault_Exception.
Additionally, I first make a project with CMSIS-PACK option, the application work well.
I want to know check point in IAR.
BootLoaderExampleTest.zip
Top Replies
