GNU on ADuCM360 IDE
Hi all,
I'm using ADuCM360 IDE in oder to build some examples.
In an example, included  cstddef(#include <cstddef>) library from GNU.
I also installed GNU(Version:5.3 2016q1) on my PC.
Below picture is errors when i try to build CN0359 source code.
but, when i right-click on cstddef and choose Open Declaration
please let me know what wrong
Thank all !
    on Jun 23, 2016 9:56 AM
    Hi
    I made below changes in your project:
    - As I said the template actually contain the system clock configuration => removed ClockInit() call.
    - The low drivers for ADuCM360 are written in C language so when you will want to use them inside of the C++ project you should make sure that you use:
    #ifdef __cplusplus
    extern "C" {
    #ifdef __cplusplus
    #endif
    I added this in Interrupts.cpp, your interrupt routines never were reached. Please check the project I attached.
    Veronica
    Mekong_fix.zip
