J-link error, failed to connect error
Hi
I have a J-link and i am trying to read data from chip but keep getting an error
I am trying to program a new file to the internal flash of the chip below
TMPM361F10FG
failed to connect, could not establish a connection to target
Attached is screenshot of error from J-flash
I have tried shorting my cables
I have tried applying power direct to the board externally from 3.3v output from j-link
Is it because it is too less amps
Do I need to keep the board inside the chassis and then connect using J-link
Has anyone seen such error before, if so how did you fix it, please
Thanks so much in advance
