ADuC7026 SPI Slave MISO
Everything works great except MISO.  I'm doing a 4 byte frame and load SPITX after each SPIRx byte is received but only the SPITX byte loaded before the master starts is returned.  It is returned 4 times even though I put a new value in SPITX after each byte is received.  Here's my code.  Any suggestions?
Also where can I find SPI example code?  I've been searching.
/* Buffers */
UINT_8 spiRxBuff[SPI_MSG_NUM_RX_BYTES];
UINT_8 spiTxBuff[SPI_MSG_NUM_TX_BYTES];
/* Counters/Pointers */
UINT_8 spiRxCount;
enum SPIState spiState;
/* SPI busy semifore */
bool Spi_Busy = FALSE;
/* Local Prototypes */
__arm void spiRxTimeout(void);
void SPIInit(void)
  /* Configure Port */
  SPICON = 0;   // Clear SPI Con to start
  SPICON = (SPICON_XFER_AND_INT_MODE        |
            SPICON_SPI_ENABLE               |   // Enable
            SPICON_SPIRX_OVERFLOW_OVERWRITE |   // Overwrite Rx data
            SPICON_SLAVE_OUTPUT_ENABLE);         // Enable MISO
  SPICON &= ~SPICON_XFER_AND_INT_MODE;                  // Rx ISR
  SPIDIV = 0x00;        // Max speed of 3.482MHz (TODO: Valid for slave?)
  /* Init Queue */
  spiRxCount = 0;
  spiState = SPI_STATE_IDLE;
  FIQEN = SPI_SLAVE_BIT;
UINT_8 SPI_temp[4];
void SPIINT(void)
  UINT_32 intFlags;
  UINT_8 rxByte;
  intFlags = SPISTA;    //  Local copy of spiStatus reg
  /* Check to see if the Rx buffer is full (1 byte depth) */
  if (intFlags & SPISTA_SPIRX_IRQ)
      rxByte = SPIRX; // Read Rx Byte
      if(spiState != SPI_STATE_PROCESSING)      // Ignore new command if still processing the last command
        spiRxBuff[spiRxCount++] = rxByte; // Save byte then bump index
        if (spiRxCount < SPI_MSG_NUM_RX_BYTES)
          SPITX = spiTxBuff[spiRxCount];   // Get next byte ready to send
          SPI_temp[spiRxCount] = spiTxBuff[spiRxCount];   // Get next byte ready to send
          spiState = SPI_STATE_COLLECTING;
        else
          FIQCLR = SPI_SLAVE_BIT;        // Disenable SPI until data processed
          /* Change msg state */
          spiState = SPI_STATE_PROCESSING;
          /* Process Message */
          taskEnqueue(&CommandResponseExecuteCommand);
