Could you clarify how to connect an external reference to the ADuC7024 part?
Could you also clarify the correct MMR settings for an external reference?
    on Jul 7, 2010 5:59 PM
    The attached diagram shows the reference structure for both the internal DAC and ADC.
    If you are connecting an external reference to the Vref pin, then  set REFCON.0=0. In this case, very little drive is required as the internal reference (~10uA only) is disconnected from the external reference pin. You should note however, if REFCON.0=0, the internal reference can no longer be selected by the DAC as it is disconnected from the 470nF external cap.  On the larger pin parts (ADuC7024/25/26/26/27/28/29), this is no problem as an external reference can be connected to the DACref pins.
    However, if the ADuC7019/20/21/22 want to use an external reference for both the DAC and ADC, the Vref based external reference must be capable overdriving the internal reference.
