Keil uVision 3 vs uVision 4
Hi All,
Is there anyone can help me out with this problem?
I have a project file that is built on Keil uVision 3 that comes along with the hex file. The hex file works perfectly but it comes back the header and C file using uVision 4. When the file is opened, it shows the following message:
"The selected device has no corresponding toolchain installed.
Either use "Project-Select Device" to change the device for the project, or install the missing toolchain."
Then, I select the device which is the aduc7024 as I am using the ADXL developement board.
After that, when i try to compile, it comes out an error stating some fiq is not declared.
Is the uVision 3 IDE not compatible with uVision4 or all this while, I am having some issue that related to startup.s?
The self generated startup.s based on the device chosen cause a lot of problem during my initial testing as it cannot trigger an interrupt.
Please help on this matter as I dont really know much about the startup.s
For now, my main problem is that I am not able to compile my program as it shows error whereas I got the file which already compiled the hex file and working using uVision 4.
Please advise on this matter.
Thanks for the help in advance..
Nicky
Parents Reply Children
No Data
