I'm trying to simulate on LTSPICE an AGC loop made by components whose supply is 3.3V max. After discovered here that my original choice for VGA, AD8330, has convergence problems on LTSPICE, I found interesting for me the AD8337 component, whose supply range is at least 5 V from the datasheet.
On LTspice however, I was able to test it and use it also with 3.3 V, without seeing any difference from 5V. Was those SPICE simulations reliable? Can I use AD8337 with 3.3V supply?
Thank you in advance
Dario
