If I am only using one of the current sense inputs how should I terminate the unused +IN and -IN inputs?
Mark
LTC6103
Recommended for New Designs
The LTC6103 is a versatile, high voltage, high side, dual current sense amplifier. The two internal amplifiers are independent except that they share the...
Datasheet
LTC6103 on Analog.com
Mark
Hi three21mark ,
Good day. You can tie the unused input to both inputs and connect it to ground (0 V) to ensure that there is no differential voltage across the pins. Thank you.
Gilbeys
