About Input offset voltage
Category: Datasheet/Specs
Product Number: LT6105
Hello team,
I understand that when using the LT6105I and the -IN voltage is within
the range of 0V < V(-IN) < 1.6V, the input offset voltage falls within
the red-framed range in the table below.
Could you please confirm if my understanding is correct?
Tsuyoshi Tokumoto
  • Hi Toku,
    Good day. The -IN voltage should be within the input voltage range, Vs+,Vs- which is within -0.3 to 44 V. It is not affected by the input offset voltage. Can you clarify where did you get the -IN voltage range? Thank you.
    Gilbeys
  • Hi Gilbeys-san,
    Thank you very much for your prompt reply.
     Based on the following information in the datasheet,
      I understood that the input offset voltage may vary depending on
     the -IN voltage range:
     ①The graph on page 6 of the datasheet.
     ②The description in the “THEORY OF OPERATION” section on page 12.
     ③The explanation in “The Two Input Stages Crossover Region” on page 14.
     Is my understanding incorrect?
    Tsuyoshi Tokumoto
