Below is the LTC6560DICE Specification,I want to konw which pin is the pin1?
Thanks!
LTC6560
Recommended for New Designs
The LTC6560 is a low-noise, transimpedance amplifier (TIA) with 220MHz bandwidth. The LTC6560’s low noise, high transimpedance and low power dissipation...
Datasheet
LTC6560 on Analog.com
Thanks!
Hello jerrytang,
Apologies for missing this. I'm not quite sure what you mean (are you referring to pad number 1?), but to be able to locate the pad names, you can check this table:
You can also look for the die ID as a reference in looking for other pads:
Paul
